Borgbackup not found
Hey everyone.
I just received hardware to build a raid for backup storage connected to the MOX via USB.
After troubleshooting some performance issues (that are hopefully solved now by adding an additional power supply) i finally got the raid assembled and mounted and tried to write a backup of a device on my LAN to it via borgbackup. However i realized that borg is not installed on the router and also not available on the repos.
That surprises me because
  1. i thought i had already installed borg on the Mox for testing purposes (although i may have done a fresh install of the device since then)
  2. borgbackup is available upstream in openwrt
Steps to reproduce:
opkg update
opkg install borgbackup
returns
 * opkg_install_cmd: Cannot install package borgbackup.
Is borg not available on turrisOS? Or is it just temporarily absent due to some build failure? (First would mean i’d misrember about having it installed already)
I checked the package list with my Omnia and BorgBackup is not present.
