Hello
My UART converter is fine, but he don’t work well on usb 3.0.
In an Live system connected to Usb 2.0 i have a good connection.
The Port Scan On LAN0 gives Information about 3 Services
A DNS Server (Port 53) and a webpage (Port 80).
And on 8022/tcp filtered oa-system
Running: Linux 3.X|4.X
OS CPE: cpe:/o:linux:linux_kernel:3 cpe:/o:linux:linux_kernel:4
OS details: Linux 3.10 - 4.11, Linux 3.2 - 4.9
Uptime guess: 19.815 days (since Tue May 26 05:36:06 2020)
The basic http authentication gives the information
http://192.168.50.1 is requesting your username and password. The site says: “KROS”
The complete serial boot log
U-Boot SPL 2019.07 (Jan 14 2020 - 09:28:59 +0000)
High speed PHY - Version: 2.0
MiniPCIe/mSATA card detection... MiniPCIe
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 5 | PCIe0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 0: remains Gen1
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: detected no link
mv_ddr: mv_ddr-armada-18.09.2
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
mv_ddr: completed successfully
Trying to boot from SPI
U-Boot 2019.07 (Jan 14 2020 - 09:28:59 +0000)
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 2 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Disabling MCU watchdog... disabled
WDT: Started with servicing (60s timeout)
MMC: mv_sdh: 0
Model: Turris Omnia
Turris Omnia:
RAM size: 2048 MiB
Serial Number: 0000000*********
Regdomain set to **
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000
BOOTING KROS...
15331768 bytes read in 1210 ms (12.1 MiB/s)
18117 bytes read in 31 ms (570.3 KiB/s)
## Flattened Device Tree blob at 00800000
Booting using the fdt blob at 0x800000
Loading Device Tree to 0fff8000, end 0ffff6c4 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.132 (gcauchois@FRUSRGCAUCHOIS04) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 unknown)) #0 SMP Tue Jan 14 16:31:29 2020
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Turris Omnia
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] random: get_random_bytes called from start_kernel+0x74/0x478 with crng_init=0
[ 0.000000] percpu: Embedded 12 pages/cpu s18956 r8192 d22004 u49152
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 kros_bootmode=0 kroboot=1
[ 0.000000] Bootloader command line not present
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 2023008K/2097152K available (6144K kernel code, 193K rwdata, 1388K rodata, 48128K init, 226K bss, 74144K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc3800000 (48128 kB)
[ 0.000000] .data : 0xc3800000 - 0xc3830600 ( 194 kB)
[ 0.000000] .bss : 0xc3830600 - 0xc38691d8 ( 227 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[ 0.000006] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[ 0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[ 0.000031] Switching to timer-based delay loop, resolution 1ns
[ 0.000160] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000167] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000289] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[ 0.000297] pid_max: default: 32768 minimum: 301
[ 0.000352] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000358] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000580] CPU: Testing write buffer coherency: ok
[ 0.000591] CPU0: Spectre v2: using BPIALL workaround
[ 0.000699] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.000806] Setting up static identity map for 0x100000 - 0x100060
[ 0.000880] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.000957] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.001000] Hierarchical SRCU implementation.
[ 0.001181] smp: Bringing up secondary CPUs ...
[ 0.001295] Booting CPU 1
[ 0.001475] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.001477] CPU1: Spectre v2: using BPIALL workaround
[ 0.001527] smp: Brought up 1 node, 2 CPUs
[ 0.001532] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[ 0.001535] CPU: All CPU(s) started in SVC mode.
[ 0.003113] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.003162] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.003169] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.003221] pinctrl core: initialized pinctrl subsystem
[ 0.003469] NET: Registered protocol family 16
[ 0.004056] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.004683] cpuidle: using governor ladder
[ 0.004840] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[ 0.004847] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[ 0.010791] SCSI subsystem initialized
[ 0.010996] usbcore: registered new interface driver usbfs
[ 0.011022] usbcore: registered new interface driver hub
[ 0.011051] usbcore: registered new device driver usb
[ 0.011600] clocksource: Switched to clocksource arm_global_timer
[ 0.011976] NET: Registered protocol family 2
[ 0.012229] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.012268] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.012329] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.012379] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.012407] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.012488] NET: Registered protocol family 1
[ 0.175326] Crashlog allocated RAM at address 0x3f00000
[ 0.175526] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 0.176985] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.176992] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.179002] bounce: pool size: 64 pages
[ 0.179013] io scheduler noop registered
[ 0.179017] io scheduler deadline registered (default)
[ 0.179454] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[ 0.180418] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[ 0.180426] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
[ 0.180431] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[ 0.180436] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.180679] PCI: bus0: Fast back to back transfers disabled
[ 0.180685] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.180691] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.180697] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.180914] PCI: bus1: Fast back to back transfers disabled
[ 0.181129] PCI: bus2: Fast back to back transfers disabled
[ 0.181171] PCI: bus3: Fast back to back transfers enabled
[ 0.181196] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[ 0.181201] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[ 0.181208] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[ 0.181218] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.181225] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe00fffff]
[ 0.181232] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[ 0.181242] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[ 0.181247] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.181252] pci 0000:00:02.0: bridge window [mem 0xe0200000-0xe04fffff]
[ 0.181257] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.181467] mv_xor f1060800.xor: Marvell shared XOR driver
[ 0.252038] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.252150] mv_xor f1060900.xor: Marvell shared XOR driver
[ 0.312025] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.312168] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.312450] console [ttyS0] disabled
[ 0.332517] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[ 1.065012] console [ttyS0] enabled
[ 1.088713] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[ 1.099146] loop: module loaded
[ 1.102617] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 1.111697] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 1.120838] scsi host0: ahci-mvebu
[ 1.124487] scsi host1: ahci-mvebu
[ 1.127963] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
[ 1.135916] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
[ 1.144654] m25p80 spi0.0: s25fl164k (8192 Kbytes)
[ 1.155602] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.161991] Creating 2 MTD partitions on "spi0.0":
[ 1.166795] 0x000000000000-0x000000100000 : "U-Boot"
[ 1.172047] 0x000000100000-0x000000800000 : "Rescue system"
[ 1.178025] libphy: Fixed MDIO Bus: probed
[ 1.182454] libphy: orion_mdio_bus: probed
[ 1.192402] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[ 1.380427] libphy: mv88e6xxx SMI: probed
[ 1.385722] mvneta f1070000.ethernet eth0: Using hardware mac address d8:*:*:*:*:*
[ 1.394495] mvneta f1030000.ethernet eth1: Using hardware mac address d8:*:*:*:*:*
[ 1.403191] mvneta f1034000.ethernet eth2: Using hardware mac address d8:*:*:*:*:*
[ 1.411358] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.417911] ehci-platform: EHCI generic platform driver
[ 1.423215] ehci-orion: EHCI orion driver
[ 1.427320] orion-ehci f1058000.usb: EHCI Host Controller
[ 1.432749] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[ 1.440380] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
[ 1.471601] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[ 1.477757] hub 1-0:1.0: USB hub found
[ 1.481527] hub 1-0:1.0: 1 port detected
[ 1.485781] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 1.487899] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.491113] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[ 1.496547] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.504089] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 1.518697] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[ 1.524652] hub 2-0:1.0: USB hub found
[ 1.528423] hub 2-0:1.0: 1 port detected
[ 1.532458] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 1.537786] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[ 1.545303] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[ 1.551790] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.560056] hub 3-0:1.0: USB hub found
[ 1.563832] hub 3-0:1.0: 1 port detected
[ 1.567913] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 1.573251] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[ 1.580799] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 1.590062] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[ 1.596031] hub 4-0:1.0: USB hub found
[ 1.599801] hub 4-0:1.0: 1 port detected
[ 1.603828] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 1.609156] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[ 1.616669] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[ 1.623158] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.631421] hub 5-0:1.0: USB hub found
[ 1.635199] hub 5-0:1.0: 1 port detected
[ 1.639319] usbcore: registered new interface driver usb-storage
[ 1.645744] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
[ 1.653373] i2c /dev entries driver
[ 1.667324] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 1.679732] orion_wdt: Initial timeout 171 sec
[ 1.684430] sdhci: Secure Digital Host Controller Interface driver
[ 1.690623] sdhci: Copyright(c) Pierre Ossman
[ 1.751607] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[ 1.759117] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.765502] marvell-cesa f1090000.crypto: CESA device successfully registered
[ 1.773066] NET: Registered protocol family 10
[ 1.779059] Segment Routing with IPv6
[ 1.782776] NET: Registered protocol family 17
[ 1.787346] 8021q: 802.1Q VLAN Support v1.8
[ 1.791579] Registering SWP/SWPB emulation handler
[ 1.797822] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[ 1.836883] mmc0: new high speed MMC card at address 0001
[ 1.842467] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 1.851642] usb 1-1: new high-speed USB device number 2 using orion-ehci
[ 1.858398] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[ 1.869719] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[ 1.875869] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB
[ 1.882896] mmcblk0: p1 p2
[ 1.987930] libphy: mv88e6xxx SMI: probed
[ 1.991992] DSA: switch 0 0 parsed
[ 1.995403] DSA: tree 0 parsed
[ 2.705688] Marvell 88E1540 mv88e6xxx-1:00: attached PHY driver [Marvell 88E1540] (mii_bus:phy_addr=mv88e6xxx-1:00, irq=POLL)
[ 2.837921] Marvell 88E1540 mv88e6xxx-1:01: attached PHY driver [Marvell 88E1540] (mii_bus:phy_addr=mv88e6xxx-1:01, irq=POLL)
[ 2.967921] Marvell 88E1540 mv88e6xxx-1:02: attached PHY driver [Marvell 88E1540] (mii_bus:phy_addr=mv88e6xxx-1:02, irq=POLL)
[ 3.097921] Marvell 88E1540 mv88e6xxx-1:03: attached PHY driver [Marvell 88E1540] (mii_bus:phy_addr=mv88e6xxx-1:03, irq=POLL)
[ 3.227920] Marvell 88E1540 mv88e6xxx-1:04: attached PHY driver [Marvell 88E1540] (mii_bus:phy_addr=mv88e6xxx-1:04, irq=POLL)
[ 3.247474] armada38x-rtc f10a3800.rtc: setting system clock to 1970-01-04 03:58:33 UTC (273513)
[ 3.280089] Freeing unused kernel memory: 48128K
[ 3.355825] init: Console is alive
[ 3.359306] init: - watchdog -
[ 3.367788] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 3.541630] raid6: int32x1 gen() 171 MB/s
[ 3.711649] raid6: int32x1 xor() 243 MB/s
[ 3.881721] raid6: int32x2 gen() 255 MB/s
[ 4.051696] raid6: int32x2 xor() 290 MB/s
[ 4.221767] raid6: int32x4 gen() 304 MB/s
[ 4.391686] raid6: int32x4 xor() 263 MB/s
[ 4.561661] raid6: int32x8 gen() 328 MB/s
[ 4.731599] raid6: int32x8 xor() 229 MB/s
[ 4.901640] raid6: neonx1 gen() 1112 MB/s
[ 5.071600] raid6: neonx1 xor() 1058 MB/s
[ 5.241625] raid6: neonx2 gen() 1303 MB/s
[ 5.411597] raid6: neonx2 xor() 1349 MB/s
[ 5.581649] raid6: neonx4 gen() 1071 MB/s
[ 5.751602] raid6: neonx4 xor() 1308 MB/s
[ 5.921632] raid6: neonx8 gen() 1014 MB/s
[ 6.091620] raid6: neonx8 xor() 947 MB/s
[ 6.095898] raid6: using algorithm neonx2 gen() 1303 MB/s
[ 6.101307] raid6: .... xor() 1349 MB/s, rmw enabled
[ 6.106285] raid6: using neon recovery algorithm
[ 6.113168] xor: measuring software checksum speed
[ 6.211593] arm4regs : 2404.400 MB/sec
[ 6.311593] 8regs : 1942.800 MB/sec
[ 6.411591] 32regs : 2058.800 MB/sec
[ 6.511592] neon : 1836.800 MB/sec
[ 6.515783] xor: using function: arm4regs (2404.400 MB/sec)
[ 6.529911] Btrfs loaded, crc32c=crc32c-generic
[ 6.535435] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.544679] init: - preinit -
[ 6.581847] random: jshn: uninitialized urandom read (4 bytes read)
[ 6.597522] random: jshn: uninitialized urandom read (4 bytes read)
[ 6.612112] random: jshn: uninitialized urandom read (4 bytes read)
RTNETLINK answers: Network is down
sendto(): Network unreachable
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 9.679611] procd: - early -
[ 9.682542] procd: - watchdog -
[ 10.322133] procd: - watchdog -
[ 10.325366] procd: - ubus -
[ 10.329804] urandom_read: 2 callbacks suppressed
[ 10.329807] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.377802] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.384251] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.390804] procd: - init -
Please press Enter to activate this console.
[ 10.425115] kmodloader: loading kernel modules from /etc/modules.d/*
[ 10.438338] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 10.450860] Initializing XFRM netlink socket
[ 10.455717] NET: Registered protocol family 15
[ 10.460736] tun: Universal TUN/TAP device driver, 1.6
[ 10.472697] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 10.480919] Netfilter messages via NETLINK v0.30.
[ 10.486998] ip_set: protocol 6
[ 10.508406] i2c i2c-0: Added multiplexed i2c bus 1
[ 10.513324] i2c i2c-0: Added multiplexed i2c bus 2
[ 10.518427] i2c i2c-0: Added multiplexed i2c bus 3
[ 10.523342] i2c i2c-0: Added multiplexed i2c bus 4
[ 10.528251] i2c i2c-0: Added multiplexed i2c bus 5
[ 10.533203] i2c i2c-0: Added multiplexed i2c bus 6
[ 10.538121] i2c i2c-0: Added multiplexed i2c bus 7
[ 10.543237] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
[ 10.559058] i2c i2c-0: Added multiplexed i2c bus 8
[ 10.563880] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[ 10.575122] u32 classifier
[ 10.577844] input device check on
[ 10.581521] Actions configured
[ 10.585838] Mirror/redirect action on
[ 10.593218] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 10.601453] usbcore: registered new interface driver cdc_wdm
[ 10.607799] Loading modules backported from Linux version wt-2017-11-01-0-gfe248fc2c180
[ 10.615857] Backport generated by backports.git v4.14-rc2-1-31-g86cf0e5d
[ 10.624098] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.646716] usbcore: registered new interface driver usbserial
[ 10.652647] usbcore: registered new interface driver usbserial_generic
[ 10.659252] usbserial: USB Serial support registered for generic
[ 10.676149] xt_time: kernel timezone is -0000
[ 10.682934] cdc_ether 1-1:2.0 wwan0: register 'cdc_ether' at usb-f1058000.usb-1, Mobile Broadband Network Device, 02:1e:10:1f:00:00
[ 10.694926] usbcore: registered new interface driver cdc_ether
[ 10.702502] usbcore: registered new interface driver cdc_ncm
[ 10.715377] usbcore: registered new interface driver huawei_cdc_ncm
[ 10.734331] PPP generic driver version 2.4.2
[ 10.739246] NET: Registered protocol family 24
[ 10.744560] usbcore: registered new interface driver qmi_wwan
[ 10.751092] usbcore: registered new interface driver sierra_net
[ 10.764862] pci 0000:00:02.0: enabling device (0140 -> 0142)
[ 10.770568] ath10k_pci 0000:02:00.0: enabling device (0140 -> 0142)
[ 10.777156] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 11.024251] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[ 11.035011] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 11.070439] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[ 11.079609] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[ 11.089999] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 11.099992] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[ 11.108884] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
[ 11.119623] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 11.129539] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
[ 11.139224] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 11.148504] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[ 11.158016] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00037 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 a4a52adb
[ 11.202816] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[ 11.213283] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 11.223464] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[ 11.232334] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 12.368606] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 12.381202] random: fast init done
[ 12.499701] usbcore: registered new interface driver option
[ 12.505367] usbserial: USB Serial support registered for GSM modem (1-port)
[ 12.512645] option 1-1:2.2: GSM modem (1-port) converter detected
[ 12.518895] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 12.525860] option 1-1:2.3: GSM modem (1-port) converter detected
[ 12.532093] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 12.539039] option 1-1:2.4: GSM modem (1-port) converter detected
[ 12.545296] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 12.552242] option 1-1:2.5: GSM modem (1-port) converter detected
[ 12.558463] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 12.565421] option 1-1:2.6: GSM modem (1-port) converter detected
[ 12.571660] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB4
[ 12.580195] usbcore: registered new interface driver qcserial
[ 12.586034] usbserial: USB Serial support registered for Qualcomm USB modem
[ 12.596869] pci 0000:00:01.0: enabling device (0140 -> 0142)
[ 12.602586] ath9k 0000:01:00.0: enabling device (0140 -> 0142)
[ 12.709371] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf11c0000, irq=54
[ 12.716347] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.261856] BTRFS: device label KROS_BOOT devid 1 transid 18 /dev/mmcblk0p1
[ 13.270449] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[ 13.276985] BTRFS info (device mmcblk0p1): disk space caching is enabled
[ 13.283724] BTRFS info (device mmcblk0p1): has skinny extents
[ 13.355643] BTRFS: device label kros_storage devid 1 transid 683 /dev/mmcblk0p2
[ 13.364597] BTRFS info (device mmcblk0p2): enabling ssd optimizations
[ 13.371056] BTRFS info (device mmcblk0p2): disk space caching is enabled
[ 13.377790] BTRFS info (device mmcblk0p2): has skinny extents
[ 13.392335] BTRFS warning (device mmcblk0p2): block group 22020096 has wrong amount of free space
[ 13.401232] BTRFS warning (device mmcblk0p2): failed to load free space cache for block group 22020096, rebuilding it now
[ 13.430744] BTRFS info (device mmcblk0p2): checking UUID tree
[ 14.554148] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[ 14.562101] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 14.567991] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 14.581816] br-lan: port 1(lan0) entered blocking state
[ 14.587060] br-lan: port 1(lan0) entered disabled state
[ 14.595157] device lan0 entered promiscuous mode
[ 14.599792] device eth1 entered promiscuous mode
[ 14.604684] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 14.632036] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 14.654856] br-lan: port 2(lan1) entered blocking state
[ 14.660107] br-lan: port 2(lan1) entered disabled state
[ 14.678477] device lan1 entered promiscuous mode
[ 14.697386] br-lan: port 3(lan2) entered blocking state
[ 14.702658] br-lan: port 3(lan2) entered disabled state
[ 14.728534] device lan2 entered promiscuous mode
[ 14.749382] br-lan: port 4(lan3) entered blocking state
[ 14.754644] br-lan: port 4(lan3) entered disabled state
[ 14.768359] device lan3 entered promiscuous mode
[ 14.795221] br-lan: port 5(lan4) entered blocking state
[ 14.800481] br-lan: port 5(lan4) entered disabled state
[ 14.816568] device lan4 entered promiscuous mode
[ 14.942439] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510]
[ 14.951668] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
[ 14.959352] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 15.233978] device lan4 left promiscuous mode
[ 15.238426] br-lan: port 5(lan4) entered disabled state
[ 15.255173] IPv6: ADDRCONF(NETDEV_UP): lan4: link is not ready
[ 15.266838] br-lan: port 5(lan4) entered blocking state
[ 15.272100] br-lan: port 5(lan4) entered disabled state
[ 15.285088] device lan4 entered promiscuous mode
[ 15.392144] IPv6: ADDRCONF(NETDEV_UP): br-KROS1: link is not ready
[ 15.567123] device lan0 left promiscuous mode
[ 15.571543] br-lan: port 1(lan0) entered disabled state
[ 15.592349] IPv6: ADDRCONF(NETDEV_UP): lan0: link is not ready
[ 15.598501] device lan1 left promiscuous mode
[ 15.602964] br-lan: port 2(lan1) entered disabled state
[ 15.632262] IPv6: ADDRCONF(NETDEV_UP): lan1: link is not ready
[ 15.638670] device lan2 left promiscuous mode
[ 15.643130] br-lan: port 3(lan2) entered disabled state
[ 15.669043] IPv6: ADDRCONF(NETDEV_UP): lan2: link is not ready
[ 15.674990] device lan3 left promiscuous mode
[ 15.679429] br-lan: port 4(lan3) entered disabled state
[ 15.701699] IPv6: ADDRCONF(NETDEV_UP): lan3: link is not ready
[ 15.707693] device lan4 left promiscuous mode
[ 15.712089] device eth1 left promiscuous mode
[ 15.716562] br-lan: port 5(lan4) entered disabled state
[ 15.728199] mvneta f1030000.ethernet eth1: Link is Down
[ 15.741920] IPv6: ADDRCONF(NETDEV_UP): lan4: link is not ready
[ 15.793123] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[ 15.800602] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 15.806523] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 15.814478] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 15.833859] br-LAN1: port 1(lan0) entered blocking state
[ 15.839199] br-LAN1: port 1(lan0) entered disabled state
[ 15.849840] device lan0 entered promiscuous mode
[ 15.854498] device eth1 entered promiscuous mode
[ 15.865499] IPv6: ADDRCONF(NETDEV_UP): br-LAN1: link is not ready
[ 15.881285] br-LAN1: port 2(lan1) entered blocking state
[ 15.886651] br-LAN1: port 2(lan1) entered disabled state
[ 15.895497] device lan1 entered promiscuous mode
[ 15.914625] br-LAN1: port 3(lan2) entered blocking state
[ 15.919960] br-LAN1: port 3(lan2) entered disabled state
[ 15.930228] device lan2 entered promiscuous mode
[ 16.062315] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510]
[ 16.071855] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
[ 16.898015] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[ 17.000175] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[ 17.009398] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Down
[ 17.018797] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Down
[ 17.055106] mv88e6085 f1072004.mdio-mii:10 lan4: Link is Down
D8********* login:
With the [f] key i can get into a failsafe mode
ash: can't access tty; job control turned off
__ __ _______ ______ ______
| KK / KK| KKKKKKK\| KKKKKK\| KKKKKK\
| KK/ KK | KK__| KK| KK | KK| KK___\KK
| KK KK | KK KK| KK | KK \KK \
| KKKKK\ | KKKKKKK\| KK | KK _\KKKKKK\
| KK \KK\ | KK | KK| KK__/ KK| \__| KK
| KK \KK\| KK | KK \KK KK \KK KK
\KK \KK \KK \KK \KKKKKK \KKKKKK
KROS 1.0.2, rk600-1579096510
================= FAILSAFE MODE active ================
special commands:
* firstboot reset settings to factory defaults
* mount_root mount root-partition with config files
after mount_root:
* passwd change root's password
* /etc/config directory with config files
for more help see:
https://openwrt.org/docs/guide-user/troubleshooting/
- failsafe_and_factory_reset
- root_password_reset
firstboot or passwd dont chanke any notable on the device.
In the /etc/config i find dropbear with followin config:
root@(none):/etc/config# cat dropbear
config dropbear
option PasswordAuth ‘1’
option RootLogin ‘1’
option Port ‘8022’
With ssh i can’t connect to this port Name or service not known
In this failesave mode i am not able to run fw_printenv or fw_Setenv
root@(none):/etc/config# fw_printenv
Cannot parse config file '/etc/fw_env.config': No such file or directory
root@(none):/etc/config# fw_setenv bootcmd 'env default -f -a; saveenv; reset;'
Error: environment not initialized
And I am still unable to interrupt u-boot.
But i am able to boot the omnia via UART in to u-boot
./kwboot -t -b uboot-devel -B 115200 /dev/ttyUSB0
In my Network i have a DHCP Server
On the live System i installed tftpd-hpa with uboot-devel as file
I connected the omnia with its WAN Port with my Router
I run in the uboot propt
setenv autoload no
dhcp
The prompt gives back
Waiting for PHY auto negotiation to complete .......TIMEOUT !
No link.
BOOTP broadcast 0....100
BootP broadcast stops with [STRG]+[c]
Is there a easier way to get uboot-devel into the uboot prompt to write it into the NOR
Best regards
