DRAM: 1 GiB
Enabling Armada 3720 wComphy-0: SGMII1 3.125 Gbps
Comphy-1: PEX0 5 Gbps
Comphy-2: USB3_HOST0 5 Gbps
MMC: sdhci@d8000: 0
Loading Environment from SPI Flash… SF: Detected w25q64dw with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Model: CZ.NIC Turris Mox Board
Net: eth0: neta@30000
Turris Mox:
Board version: 22
RAM size: 1024 MiB
Serial Number: xyz
ECDSA Public Key: xyz
SD/eMMC version: SD
Module Topology:
1: Mini-PCIe Module
2: Peridot Switch Module (8-port)
3: Topaz Switch Module (4-port)
Hit any key to stop autoboot: 2 1 0
gpio: pin GPIO221 (gpio 57) value is 0
gpio: pin GPIO220 (gpio 56) value is 1
device 0 offset 0x7f0000, size 0x10000
SF: 65536 bytes @ 0x7f0000 Read: OK
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1…
Found U-Boot script /boot.scr
2070 bytes read in 73 ms (27.3 KiB/s)
Executing script at 04d00000
19554 bytes read in 68 ms (280.3 KiB/s)
10280960 bytes read in 512 ms (19.1 MiB/s)
Flattened Device Tree blob at 04f00000
Booting using the fdt blob at 0x4f00000
Loading Device Tree to 000000003bf14000, end 000000003bf1bc61 … OK
Starting kernel …
After some minutes, it just reboots.
Can’t access the device.
How can i backup my etc config from SDCARD? I’m afraid to setup everything after flashing something.
I read the [reboot-issue-workaround-v4 ] and downloaded both files. But, since the device is unaccessible, how can i execute the mentioned commands
I just flashed another SDCard, booted and executed the workaround mtd commands.
With the original SDCard (with the failed update) i now get this error:
U-Boot 2021.10-rc3-00050-g7d3fea2c7f (Sep 07 2021 - 18:16:56 +0200)
DRAM: 1 GiB
WDT: Started with servicing (60s timeout)
Comphy chip #0:
PCIE-0: Link up
MMC: sdhci@d8000: 0
Loading Environment from SPIFlash… SF: Detected w25q64dw with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Turris Mox:
Board version: 22
RAM size: 1024 MiB
Serial Number: xyz
SD/eMMC version: SD
Module Topology:
1: Mini-PCIe Module
Scanning mmc 0:1…
2070 bytes read in 90 ms (22.5 KiB/s)
19554 bytes read in 102 ms (186.5 KiB/s)
10448904 bytes read in 569 ms (17.5 MiB/s)
Moving Image from 0x5000000 to 0x5080000, end=5acb000
Loading Device Tree to 000000003faf5000, end 000000003fafcc61 … OK
I tried copy @16 to the second SDCard which let the system boot.
But i can’t use schnapps rollback 16:
root@mox:/# schnapps list -j
{ “snapshots”: [
{ “number”: 16, “type”: “pre”, “size”: “313.04MiB”, “created”: “2022-01-25 17:10:32 +0100”, “description”: “Automatic pre-update snapshot (TurrisOS 5.3.3)” }
root@mox:/# schnapps rollback 16
ERROR: Not a Btrfs subvolume: Invalid argument
Rolling back failed!
root@mox:/# [ 60.633457] BTRFS info (device mmcblk1p1): qgroup scan completed (inconsistency flag cleared)
I also tried to copy @16/etc and @/root from the original (that fails to boot after update) SDCard to the second one /@ directory. The MOX boots, i can ssh into it but some software is missing and webserver not active. So i can’t use luci gui.
My workaround was to reflash a new SDCard with a fresh installation, install
vpn-policy-routing
luci-app-vpn-policy-routing
wireguard
wireguard-tools
luci-app-wireguard
luci-i18n-wireguard-de
relayd
luci-proto-relayd
tmux,
copy /etc/config files (without foris file) from the old SDCard/@16/etc/config to the fresh installation.
Sadly, since i no longer can trust auto updates from turris, i disabled this feature.
Thanks for the reply. The documentation, in special the rescue modes was my first hope. But it is not helpful. I don’t know who uses this procedure. But i don’t do anything an a device i cannot fully control. And pressing a not exposed button with a paper clip while plugin the power jack, count seconds and hope getting the correct mode is one of the things i cannot fully control. I don’t recommend it to anyone.
The important part in this documentation, the rescue shell is missing. There is only a hint about it “This option is for true geeks”. As mentioned above, a step by step guide how to repair / recover system from rescue shell would be great. Not just flashing a new image. The challenge is fixing the existing system on SDCard.
