As described here and also here in this thread, I have problems with my Turris Omnia. The router reboots continuously and the LED are blinking blue. In this condition I’m losing connection to the router and not even being able to ping - nor when I’m setting a static IP an plug in the LAN directly to the router.
As I’m not sure it’s related to the OS release, I’ll open a separated thread.
Can someone help me debugging this issue? What does these blue LED mean?
-deleted-
Here are some logs at the time when the error occurs (around 18:13).
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.714057] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.724792] ath10k_pci 0000:02:00.0: Falling back to user helper
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.743658] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.754046] ath10k_pci 0000:02:00.0: Falling back to user helper
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.843812] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.850931] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
2017-09-17T18:13:53+02:00 warning kernel[]: [ 14.861398] ath10k_pci 0000:02:00.0: Falling back to user helper
2017-09-17T18:14:01+02:00 warning dnsmasq[1953]: overflow: 5 log entries lost
2017-09-17T16:14:07+02:00 warning pppd[2271]: Connected to *** via interface eth1.11
2017-09-17T18:14:08+02:00 warning dnsmasq[2427]: script process exited with status 1
2017-09-17T18:14:09+02:00 warning dnsmasq[2427]: script process exited with status 1
2017-09-17T16:14:09+02:00 warning odhcpd[1742]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
2017-09-17T16:14:44+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T16:14:48+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:14:48+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 1 times, suppressed by syslog-ng on turris
2017-09-17T16:15:02+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:15:02+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 1 times, suppressed by syslog-ng on turris
2017-09-17T16:15:21+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:15:21+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:15:32+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:15:32+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:15:44+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:15:44+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:15:50+02:00 warning odhcpd[1742]: DHCPV6 SOLICIT IA_NA from 0001000120bdc5066476badaa720 on br-lan: ok *** ***
2017-09-17T16:15:51+02:00 warning odhcpd[1742]: DHCPV6 REQUEST IA_NA from 0001000120bdc5066476badaa720 on br-lan: ok *** ***
2017-09-17T16:15:56+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:15:56+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:16:00+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:16:00+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:17:04+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:17:04+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:17:55+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:17:55+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:18:02+02:00 warning odhcpd[1742]: DHCPV6 REBIND IA_NA from 0001000120ef8de7b827ebb8b478 on br-lan: ok
2017-09-17T16:18:11+02:00 warning odhcpd[1742]: DHCPV6 REBIND IA_NA from 0001000120ef8de7b827ebb8b478 on br-lan: ok
2017-09-17T16:18:30+02:00 warning odhcpd[1742]: DHCPV6 REBIND IA_NA from 0001000120ef8de7b827ebb8b478 on br-lan: ok
2017-09-17T16:19:07+02:00 warning odhcpd[1742]: DHCPV6 REBIND IA_NA from 0001000120ef8de7b827ebb8b478 on br-lan: ok
2017-09-17T16:19:10+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:19:10+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:19:28+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:19:28+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T18:19:28+02:00 warning dnsmasq[2427]: script process exited with status 1
2017-09-17T16:19:44+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:19:44+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:19:45+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:19:45+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T18:19:45+02:00 warning dnsmasq[2427]: script process exited with status 1
2017-09-17T16:19:48+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:19:48+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:19:49+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:19:49+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T18:19:49+02:00 warning dnsmasq[2427]: script process exited with status 1
2017-09-17T16:20:03+02:00 warning watchdog[]: Restarted nethist
2017-09-17T16:20:18+02:00 warning odhcpd[1742]: DHCPV6 REBIND IA_NA from 0001000120ef8de7b827ebb8b478 on br-lan: ok
2017-09-17T16:20:21+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:20:21+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T16:20:22+02:00 warning dhcp_host_domain_ng.py[]: Add_lease, hostname check failed
2017-09-17T18:20:22+02:00 warning dhcp_host_domain_ng.py[1898]: Last message 'Add_lease, hostname ' repeated 2 times, suppressed by syslog-ng on turris
2017-09-17T18:20:22+02:00 warning dnsmasq[2427]: script process exited with status 1
Thanks in advance.
