Since the last update drivers for wifi cards a few months ago, does not respond properly flashing the wifi LED to the wifi activities on both frequencies. The LED is permanently lit, rather.
Does anyone have a similar experience?
Is there a solution?
I tried it, it partly helped. For some actions, it works for some not. I have tried such as Speetest.net and in both zones wifi without flashing. Outweighs the status LED is not responding to that wifi traffic. The signal can’t be relied upon.
I tried to save the above settings for the second time, and the result is the same. Immediately after saving acts for a while (approx. 1-3 minute) correctly and then stops responding on wifi traffic or just the random sporadic response.
Could it be related to Active script for control of LED brightness and response control connection ? connCheck.sh
leds_control
