Curious if there is any known issue using the following WiFi 6 module in Turris MOX running the latest Turris OS:
AW7915-NP1
I have one and when trying to use it in MOX the card is recognized and initially configurable both in Luci and Foris interfaces, but once the card is enabled MOX shuts down and fails to reboot successfully.
Changing the wireless module back to original one supplied with MOX after re-loading OS has MOX booting without issue.
I haven’t taken the time to pull any logs related to this, but was curious if there is a known issue with this or if I need to install some other driver available in repos to get the module to function with MOX.
I did see that this module should function without issue:
AsiaRF AW7915-NPD
As is supported in change logs and such, but I am trying to use AW7915-NP1 instead of AW7915-NPD.
