Atypical behavior www.centrum.cz and www.sreality.cz
For a long time I have a problem with loading pages www.centrum.cz(more than 1 year), now the same problems have appeared on the site www.sreality.cz. This is reflected in the fact that the page does not load at all and the error does not show any error message. I tried other browsers (Chrome, Avast secure browser) without result. If I turn on its VPN in Opera, it loads www.centrum.cz,
… www.sreality.cz it doesn’t load again. I tried to create a resolver debug - during the time I tried to reload the affected addresses.
If I enter a direct address on the subpage … is available … such as
Sreality.cz • reality a nemovitosti z celé ČR
cen
Edit: debug removed
While I’m looking into community documentation for debugging such DNS problems as you described, I see there is described on the last step that this should be sent to support.
Follow instructions on page Error reporting and send your logs to support
Forum is not an official support channel. Also, it contains sensitive data and the output is not complete. You are not using [code][/code]. And also, you are using VPN. This might be a culprit as well. Did you try it on different device on your network without VPN?
VPN is “Opera VPN”. Debug log removed :slight_smile: Problems i indicate mainly on the desktop win10… now I tested both sites from a tablet … both do not load. I’ll send documents to support .
The bit of log in forum history (only available to moderators?) contains nothing about sreality.cz or centrum.cz. I suspect you might have hit a cache in OS or browser.
If you are yousing AdBlock, try to suspend it or add these sites into whitelist.
Adblock
cen
sre
But :slight_smile: www.centrum.cz is not on the blacklist but !! after turning off AdBlock page the Centrum loads … Sreality unchanged.
So, you can add it to whitelist and it should work (even after AdBlock restart or router reboot).
I’ve written www.centrum.cz on the whitelist in the past. Now I have added www.sreality.cz … both without effect.
And have you tried to reboot router? Sometimes it helps.
Now I will not restart the router - I have another reason.
I emphasize that the problem with the server www.centrum.cz takes more than 1 year. I also dealt with this with support “Centrum” when I thought it was their problem with securing dnsssec https://dnsviz.net/d/www.centrum.cz/dnssec/ where there are errors … said this is not the case (disabling dnssec will not bring improvement).
Does it make any change if you force your clients to use different DNS? Such as:
Do you mean other DNS server ? In your example, you are changing DHCP settings … Suppose - instead DNS serve of connection provider change to forward DNS to Clouflare ? => no change.
I have fixed IP in LAN … I will not change this setting - the problem occurs on all stations in the LAN.
If I add a www.centrum.cz and www.sreality.cz to AdBlock blacklist … The Centrum does not load again without an error message, Sreality will report … The IP address of the server not found. Try running Windows Network Diagnostics. DNS_PROBE_FINISHED_NXDOMAIN
Possible, the cause of both problems is different.
Do you run Adblock on Omnia or on your PC?
Im not sure how Adblock work on a router, is it done via dns intrusion? If yes, then forcing clients to use public dns such as 1.1.1.1 should resolve the issue
Yes, adblock package loads rules into the resolver. (multiple implementations are supported)
Let me post it here, as there’s nothing “private” in what I write and this was the first thread on the topic anyway.
I’m sorry; a week ago I could find nothing really useful in the logs you sent (e.g. a failure), and now I looked again without success.
There’s no query for **.sreality.cz and one for www.centrum.cz A. The query finds that cache for it has expired (CNAME by 13s and target by 54s), and it obtains the records from authoritative servers. Both the (signed) CNAME to d3ngxn1oh0qgdy.cloudfront.net and the (unsigned) four-tuple of A addresses seem good to me. Everything suggests you got a “good answer”.
Oh, now I see the other file that contains logs from more queries. I thought the kresd logs you sent were extracted from there, but apparently they come from a slightly different time range.
Todday full resolver debug send via email is too big
x
x
x
2020-05-27 19:51:57 info kresd[30062]:
2020-05-27 19:51:57 info kresd[30062]: [51979.11][iter]     <= rcode: NOERROR
2020-05-27 19:51:57 info kresd[30062]: [51979.11][iter]     <= continuing with qname minimization
2020-05-27 19:51:57 info kresd[30062]: [51979.11][resl]     <= server: '193.29.206.1' rtt: 11 ms
2020-05-27 19:51:57 info kresd[30062]: [51979.11][iter]     'sld2.ns.nic.cz.' type 'A' new uid was assigned .12, parent uid .09
2020-05-27 19:51:57 info kresd[30062]: [51979.12][resl]     => id: '39589' querying:
Souhrn
‘193.29.206.1#00053’ score: 11 zone cut: ‘nic.cz.’ qname: ‘NS.nIC.Cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [51979.12][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 39589
2020-05-27 19:51:57 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 4; ADDITIONAL: 1
2020-05-27 19:51:57 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:51:57 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:51:57 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:51:57 info kresd[30062]: ns.nic.cz. NS
2020-05-27 19:51:57 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:51:57 info kresd[30062]: nic.cz. 1800 SOA a.ns.nic.cz. hostmaster.nic.cz. 1590579145 10800 3600 1209600 7200
2020-05-27 19:51:57 info kresd[30062]: 82qoe5f9r7eopu3r1kcoak39g0i13vc4.nic.cz. 7200 NSEC3 1 0 10 1BE8BE1DC9EB10B6 83riach60vetm45k1im9cqtb3l7ea8uv
2020-05-27 19:51:57 info kresd[30062]: nic.cz. 1800 RRSIG SOA 13 2 1800 20200610093416 20200527103225 49888 nic.cz. LpY1IAZdfN8t9scQME07S3KAWq6Y2QtiHeltvivnicY2wGCzuVU5plUvJJtamvbIMea2F9m6QtN70b7Y6c/BrA==
2020-05-27 19:51:57 info kresd[30062]: 82qoe5f9r7eopu3r1kcoak39g0i13vc4.nic.cz. 7200 RRSIG NSEC3 13 3 7200 20200609221305 20200527103225 49888 nic.cz. EQAVRmFkGgPAKlnbLIIJEeaOPoco2EbzDi9V/fxQ2BIitW7Mt02OkazxZaGV301z8IhKAswds0E+sWzoGXKrIw==
2020-05-27 19:51:57 info kresd[30062]: [51979.12][iter] <= rcode: NOERROR
2020-05-27 19:51:57 info kresd[30062]: [51979.12][iter] <= retrying with non-minimized name
2020-05-27 19:51:57 info kresd[30062]: [51979.12][cach] => not overwriting NS ns.nic.cz.
2020-05-27 19:51:57 info kresd[30062]: [51979.12][resl] <= server: ‘193.29.206.1’ rtt: 8 ms
2020-05-27 19:51:57 info kresd[30062]: [51979.12][iter] ‘sld2.ns.nic.cz.’ type ‘A’ new uid was assigned .13, parent uid .09
2020-05-27 19:51:57 info kresd[30062]: [51979.13][resl] => id: ‘22098’ querying: ‘194.0.12.1#00053’ score: 11 zone cut: ‘nic.cz.’ qname: ‘SLD2.nS.Nic.cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [51979.13][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 22098
2020-05-27 19:51:57 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:51:57 info kresd[30062]: sld2.ns.nic.cz. A
2020-05-27 19:51:57 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:51:57 info kresd[30062]: sld2.ns.nic.cz. 1800 A 217.31.204.71
2020-05-27 19:51:57 info kresd[30062]: sld2.ns.nic.cz. 1800 RRSIG A 13 4 1800 20200609113757 20200527103225 49888 nic.cz. oSP7N7ScfY9rSwQN+WTyywHdoa2mf9Qn5s/JIhRRLhIz1m6fVjGhVTgoTi6Pj8/hC0rrZdJ41e5BsnCnG0QSIg==
2020-05-27 19:51:57 info kresd[30062]: [51979.13][iter] <= rcode: NOERROR
2020-05-27 19:51:57 info kresd[30062]: [51979.13][cach] => stashed sld2.ns.nic.cz. A, rank 020, 112 B total, incl. 1 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [51979.13][resl] <= server: ‘194.0.12.1’ rtt: 7 ms
2020-05-27 19:51:57 info kresd[30062]: [51979.09][iter] ‘www.rhybar.cz.’ type ‘A’ new uid was assigned .14, parent uid .00
2020-05-27 19:51:57 info kresd[30062]: [51979.14][resl] => id: ‘25368’ querying: ‘217.31.204.71#00053’ score: 10 zone cut: ‘rhybar.cz.’ qname: ‘wWw.rhybar.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [51979.14][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 25368
2020-05-27 19:51:57 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 2; AUTHORITY: 3; ADDITIONAL: 1
2020-05-27 19:51:57 info kresd[30062]: www.rhybar.cz. A
2020-05-27 19:51:57 info kresd[30062]: www.rhybar.cz. 600 A 217.31.205.55
2020-05-27 19:51:57 info kresd[30062]: www.rhybar.cz. 600 RRSIG A 5 3 600 20081030080058 20080930080058 5172 rhybar.cz. XVkut4l9mw2MhodZFIOD2L57AU2u+I6wGVlK1fr6w5locFC5NIe8ukw79jYdOCH3WwFgSMscumIz1sGqRPrN/CrhXiU0ymFGFju9x/k10lv6SGS6lslgnZluet04CyibGQ2HBnwTx7qK3j+bNzxKLvjpn7DY9f+YKB8F2FtwNOc=
2020-05-27 19:51:57 info kresd[30062]: rhybar.cz. 600 NS sld1.ns.nic.cz.
2020-05-27 19:51:57 info kresd[30062]: rhybar.cz. 600 NS sld2.ns.nic.cz.
2020-05-27 19:51:57 info kresd[30062]: rhybar.cz. 600 RRSIG NS 5 2 600 20081030080058 20080930080058 5172 rhybar.cz. XNIBK/CmsKZsw6lT2iAa5g+TLOVxPx39N7vOxqW5lafaC56EuCZxUEmZT6ECvU/WzvQIqE1vqN4X6N/Z+5QTXKM3zcT+UhayyiLNRNwdlkmG0xo/+bYACj85lhyB3UGJ+vpRWg2VVJOy9RLMyIka/S7nVYpgKUZFAZuxue6K17o=
2020-05-27 19:51:57 info kresd[30062]: [51979.14][iter] <= rcode: NOERROR
2020-05-27 19:51:57 info kresd[30062]: [51979.14][cach] => stashed www.rhybar.cz. A, rank 020, 180 B total, incl. 1 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [51979.14][cach] => not overwriting NS rhybar.cz.
2020-05-27 19:51:57 info kresd[30062]: [51979.14][resl] <= server: ‘217.31.204.71’ rtt: 15 ms
2020-05-27 19:51:57 info kresd[30062]: [51979.14][resl] AD: request NOT classified as SECURE
2020-05-27 19:51:57 notice resolver-debug[]:
2020-05-27 19:51:57 info kresd[30062]: [51979.14][resl] finished: 0, queries: 3, mempool: 32784 B
2020-05-27 19:51:57 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec www.rhybar.cz
2020-05-27 19:51:57 notice resolver-debug[]: ; (1 server found)
2020-05-27 19:51:57 notice resolver-debug[]: ;; global options: +cmd
2020-05-27 19:51:57 notice resolver-debug[]: ;; Got answer:
2020-05-27 19:51:57 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 51979
2020-05-27 19:51:57 notice resolver-debug[]: ;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
2020-05-27 19:51:57 notice resolver-debug[]: ;; OPT PSEUDOSECTION:
2020-05-27 19:51:57 notice resolver-debug[]: ; EDNS: version: 0, flags: do; udp: 4096
2020-05-27 19:51:57 notice resolver-debug[]: ;; QUESTION SECTION:
2020-05-27 19:51:57 notice resolver-debug[]: ;www.rhybar.cz. IN A
2020-05-27 19:51:57 notice resolver-debug[]: ;; ANSWER SECTION:
2020-05-27 19:51:57 notice resolver-debug[]: www.rhybar.cz. 600 IN A 217.31.205.55
2020-05-27 19:51:57 notice resolver-debug[]: www.rhybar.cz. 600 IN RRSIG A 5 3 600 20081030080058 20080930080058 5172 rhybar.cz. XVkut4l9mw2MhodZFIOD2L57AU2u+I6wGVlK1fr6w5locFC5NIe8ukw7 9jYdOCH3WwFgSMscumIz1sGqRPrN/CrhXiU0ymFGFju9x/k10lv6SGS6 lslgnZluet04CyibGQ2HBnwTx7qK3j+bNzxKLvjpn7DY9f+YKB8F2Ftw NOc=
2020-05-27 19:51:57 notice resolver-debug[]: ;; Query time: 2479 msec
2020-05-27 19:51:57 notice resolver-debug[]: ;; SERVER: 127.0.0.1#53(127.0.0.1)
2020-05-27 19:51:57 notice resolver-debug[]: ;; WHEN: Wed May 27 19:51:57 CEST 2020
2020-05-27 19:51:57 notice resolver-debug[]: ;; MSG SIZE rcvd: 227
2020-05-27 19:51:57 info kresd[30062]: [00000.00][plan] plan ‘.wilda.rhybar.0skar.cz.’ type ‘A’ uid [17633.00]
2020-05-27 19:51:57 info kresd[30062]: [17633.00][iter] '
.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:51:57 info kresd[30062]: [17633.01][cach] => no NSEC* cached for zone: cz.
2020-05-27 19:51:57 info kresd[30062]: [17633.01][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:57 info kresd[2679]: Last message ‘[17633.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:57 info kresd[30062]: [17633.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:57 info kresd[30062]: [17633.01][zcut] found cut: cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:57 info kresd[30062]: [17633.01][resl] => id: ‘16597’ querying: ‘194.0.13.1#00053’ score: 11 zone cut: ‘cz.’ qname: ‘0SkaR.cZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.01][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16597
2020-05-27 19:51:57 info kresd[30062]: ;; Flags: qr QUERY: 1; ANSWER: 0; AUTHORITY: 5; ADDITIONAL: 3
2020-05-27 19:51:57 info kresd[30062]: 0skar.cz. NS
2020-05-27 19:51:57 info kresd[30062]: 0skar.cz. 3600 NS ns1.petrkrcmar.cz.
2020-05-27 19:51:57 info kresd[30062]: 0skar.cz. 3600 NS auron.oskarcz.eu.
2020-05-27 19:51:57 info kresd[30062]: 0skar.cz. 3600 NS flexi.oskarcz.net.
2020-05-27 19:51:57 info kresd[30062]: 0skar.cz. 3600 DS 45297 13 2 8C3ADA65895C265F21B1E24E55BFCC7EB7A488EC71592F0C839010E3A6F4925C
2020-05-27 19:51:57 info kresd[30062]: 0skar.cz. 3600 RRSIG DS 13 2 3600 20200608064244 20200525100542 44987 cz. ty+Rk8DxokIdGQFw4Hp0LvDf8wiWBKxBNcpm+hEbtggSYbG+gbRLO7k1WQvUh8Ukcu8EieXWOBtYGo4MkfV1og==
2020-05-27 19:51:57 info kresd[30062]: ;; ADDITIONAL SECTION
2020-05-27 19:51:57 info kresd[30062]: ns1.petrkrcmar.cz. 3600 A 37.205.10.41
2020-05-27 19:51:57 info kresd[30062]: ns1.petrkrcmar.cz. 3600 AAAA 2a01:430:17:1::ffff:205
2020-05-27 19:51:57 info kresd[30062]: [17633.01][iter] <= loaded 2 glue addresses
2020-05-27 19:51:57 info kresd[30062]: [17633.01][iter] <= referral response, follow
2020-05-27 19:51:57 info kresd[30062]: [17633.01][cach] => stashed 0skar.cz. DS, rank 020, 140 B total, incl. 1 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.01][cach] => stashed 0skar.cz. NS, rank 002, 78 B total, incl. 0 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.01][cach] => stashed also 2 nonauth RRsets
2020-05-27 19:51:57 info kresd[30062]: [17633.01][resl] <= server: ‘194.0.13.1’ rtt: 12 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.01][iter] ‘.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:51:57 info kresd[30062]: [17633.02][resl] => id: ‘32516’ querying: ‘2a01:430:17:1::ffff:205#00053’ score: 10 zone cut: ‘0skar.cz.’ qname: ‘rHYBAr.0SKAr.cZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.02][resl] => id: ‘32516’ querying: ‘37.205.10.41#00053’ score: 10 zone cut: ‘0skar.cz.’ qname: ‘rHYBAr.0SKAr.cZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.02][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 32516
2020-05-27 19:51:57 info kresd[30062]: ;; Flags: qr QUERY: 1; ANSWER: 0; AUTHORITY: 3; ADDITIONAL: 1
2020-05-27 19:51:57 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:51:57 info kresd[30062]: rhybar.0skar.cz. NS
2020-05-27 19:51:57 info kresd[30062]: rhybar.0skar.cz. 3600 NS flexi.oskarcz.net.
2020-05-27 19:51:57 info kresd[30062]: rhybar.0skar.cz. 3600 DS 28887 10 2 2A5CBF17973787B57A3FB41FF5169A46CAA1E3C01EED5BD0E8799D7B36A21837
2020-05-27 19:51:57 info kresd[30062]: rhybar.0skar.cz. 3600 RRSIG DS 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. Y80ouKraySIsX0TG9QwzhRY22yZcVF3qnKWtgdngOXPSnZkltbvZF8xf+yVBYJ8YpFUNtJPyto13BGXIhl6uPA==
2020-05-27 19:51:57 info kresd[30062]: [17633.02][iter] <= referral response, follow
2020-05-27 19:51:57 info kresd[30062]: [17633.02][cach] => stashed rhybar.0skar.cz. DS, rank 020, 146 B total, incl. 1 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.02][cach] => stashed rhybar.0skar.cz. NS, rank 002, 36 B total, incl. 0 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.02][resl] <= server: ‘2a01:430:17:1::ffff:205’ rtt: >= 115 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.02][resl] <= server: ‘37.205.10.41’ rtt: 15 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.02][iter] '
.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:51:57 info kresd[30062]: [17633.03][plan] plan ‘flexi.oskarcz.net.’ type ‘AAAA’ uid [17633.04]
2020-05-27 19:51:57 info kresd[30062]: [17633.04][iter] ‘flexi.oskarcz.net.’ type ‘AAAA’ new uid was assigned .05, parent uid .03
2020-05-27 19:51:57 info kresd[30062]: [17633.05][cach] => no NSEC* cached for zone: net.
2020-05-27 19:51:57 info kresd[30062]: [17633.05][cach] => skipping zone: net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:57 info kresd[2679]: Last message '[17633.05][cach] ’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:57 info kresd[30062]: [17633.05][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:57 info kresd[30062]: [17633.05][zcut] found cut: net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:57 info kresd[30062]: [17633.05][resl] => id: ‘58721’ querying: ‘2001:502:1ca1::30#00053’ score: 10 zone cut: ‘net.’ qname: ‘oskArCz.nET.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.05][resl] => id: ‘58721’ querying: ‘192.12.94.30#00053’ score: 10 zone cut: ‘net.’ qname: ‘oskArCz.nET.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.05][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 58721
2020-05-27 19:51:57 info kresd[30062]: ;; Flags: qr cd QUERY: 1; ANSWER: 0; AUTHORITY: 5; ADDITIONAL: 3
2020-05-27 19:51:57 info kresd[30062]: oskarcz.net. NS
2020-05-27 19:51:57 info kresd[30062]: oskarcz.net. 172800 NS flexi.oskarcz.net.
2020-05-27 19:51:57 info kresd[30062]: oskarcz.net. 172800 NS auron.oskarcz.eu.
2020-05-27 19:51:57 info kresd[30062]: oskarcz.net. 172800 NS ns1.petrkrcmar.cz.
2020-05-27 19:51:57 info kresd[30062]: oskarcz.net. 86400 DS 22290 13 2 E0D34337EB502C6AFABD689C18B4D40B19F23DB9628B966240BB0F2792237ECA
2020-05-27 19:51:57 info kresd[30062]: oskarcz.net. 86400 RRSIG DS 8 2 86400 20200531065243 20200524054243 36059 net. MmzCVF6TaB+IdXOrG4ncSTj2uhvWZ4HsdNy3xjSaJRTHfpRKVUXS4XeahGPTQKYIW4eOJo0mDPJeZpqgM42utIjNWZLW1LTNsXYR8LWcmLtpuGr6bkBtbnptQNzy8Ydzj13ZPgLYB2Cx11O5Cr4otabdT7++eVEJkv+aOBM153GzhT6Q8tw2IDDlNVMddi82zLapTjNDvt5gwxY3Y6eHRw==
2020-05-27 19:51:57 info kresd[30062]: flexi.oskarcz.net. 172800 AAAA 2001:1528:132:70::1
2020-05-27 19:51:57 info kresd[30062]: flexi.oskarcz.net. 172800 A 85.239.227.179
2020-05-27 19:51:57 info kresd[30062]: [17633.05][iter] <= loaded 2 glue addresses
2020-05-27 19:51:57 info kresd[30062]: [17633.05][iter] <= referral response, follow
2020-05-27 19:51:57 info kresd[30062]: [17633.05][cach] => stashed oskarcz.net. DS, rank 020, 238 B total, incl. 1 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.05][cach] => stashed oskarcz.net. NS, rank 002, 78 B total, incl. 0 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.05][cach] => stashed also 2 nonauth RRsets
2020-05-27 19:51:57 info kresd[30062]: [17633.05][resl] <= server: ‘2001:502:1ca1::30’ rtt: >= 123 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.05][resl] <= server: ‘192.12.94.30’ rtt: 23 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.05][iter] ‘flexi.oskarcz.net.’ type ‘AAAA’ new uid was assigned .06, parent uid .03
2020-05-27 19:51:57 info kresd[30062]: [17633.06][resl] => id: ‘02185’ querying: ‘2001:1528:132:70::1#00053’ score: 10 zone cut: ‘oskarcz.net.’ qname: ‘FLEXi.oSKarCz.NeT.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.06][resl] => id: ‘02185’ querying: ‘85.239.227.179#00053’ score: 10 zone cut: ‘oskarcz.net.’ qname: ‘FLEXi.oSKarCz.NeT.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:51:57 info kresd[30062]: [17633.06][iter] <= answer received:
2020-05-27 19:51:57 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 2185
2020-05-27 19:51:57 info kresd[30062]: flexi.oskarcz.net. AAAA
2020-05-27 19:51:57 info kresd[30062]: flexi.oskarcz.net. 3600 AAAA 2001:1528:132:70::1
2020-05-27 19:51:57 info kresd[30062]: flexi.oskarcz.net. 3600 RRSIG AAAA 13 3 3600 20200607105629 20200524092629 22290 oskarcz.net. 3sF00UlSDUr/aukI/faL8I1gI5NlHgw8mpxeiGTiPk7eJLUPgsOJptclaOWrlNhekkv/mrAyoBHKAeBZhfoxPw==
2020-05-27 19:51:57 info kresd[30062]: [17633.06][iter] <= rcode: NOERROR
2020-05-27 19:51:57 info kresd[30062]: [17633.06][cach] => stashed flexi.oskarcz.net. AAAA, rank 020, 130 B total, incl. 1 RRSIGs
2020-05-27 19:51:57 info kresd[30062]: [17633.06][resl] <= server: ‘2001:1528:132:70::1’ rtt: >= 115 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.06][resl] <= server: ‘85.239.227.179’ rtt: 15 ms
2020-05-27 19:51:57 info kresd[30062]: [17633.03][iter] ‘.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .07, parent uid .00
2020-05-27 19:51:57 info kresd[30062]: [17633.07][resl] => id: ‘40151’ querying: ‘2001:1528:132:70::1#00053’ score: 115 zone cut: ‘rhybar.0skar.cz.’ qname: ‘wIldA.rhYBAR.0SKAR.CZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[2679]: Last message ‘[17633.07][resl] =’ repeated 3 times, suppressed by syslog-ng on turris
2020-05-27 19:51:59 info kresd[30062]: [17633.07][wrkr] => server: ‘2001:1528:132:70::1#00053’ flagged as ‘bad’
2020-05-27 19:51:59 info kresd[30062]: [17633.07][iter] '
.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .08, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [17633.08][resl] => id: ‘25740’ querying: ‘2001:1528:132:70::1#00053’ score: 1324 zone cut: ‘rhybar.0skar.cz.’ qname: ‘WILda.RhyBar.0skAr.CZ.’ qtype: ‘NS’ proto: ‘tcp’
2020-05-27 19:51:59 info kresd[30062]: [17633.08][wrkr] => connecting to: ‘2001:1528:132:70::1#00053’
2020-05-27 19:51:59 info kresd[30062]: [wrkr]=> connect to ‘2001:1528:132:70::1#00053’ failed (permission denied), flagged as ‘bad’
2020-05-27 19:51:59 info kresd[30062]: [17633.08][iter] ‘.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .09, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [17633.09][plan] plan ‘flexi.oskarcz.net.’ type ‘A’ uid [17633.10]
2020-05-27 19:51:59 info kresd[30062]: [17633.10][iter] ‘flexi.oskarcz.net.’ type ‘A’ new uid was assigned .11, parent uid .09
2020-05-27 19:51:59 info kresd[30062]: [17633.11][cach] => satisfied by exact RRset: rank 001, new TTL 172798
2020-05-27 19:51:59 info kresd[30062]: [17633.11][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 12769
2020-05-27 19:51:59 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
2020-05-27 19:51:59 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:51:59 info kresd[30062]: flexi.oskarcz.net. A
2020-05-27 19:51:59 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:51:59 info kresd[30062]: flexi.oskarcz.net. 172798 A 85.239.227.179
2020-05-27 19:51:59 info kresd[30062]: [17633.11][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [17633.09][iter] '
.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .12, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [17633.12][resl] => id: ‘40894’ querying: ‘85.239.227.179#00053’ score: 15 zone cut: ‘rhybar.0skar.cz.’ qname: ‘WILDa.RhyBar.0skAr.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [17633.12][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 40894
2020-05-27 19:51:59 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 6; ADDITIONAL: 1
2020-05-27 19:51:59 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:51:59 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:51:59 info kresd[30062]: wilda.rhybar.0skar.cz. NS
2020-05-27 19:51:59 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:51:59 info kresd[30062]: rhybar.0skar.cz. 300 SOA flexi.oskarcz.net. hostmaster.oskarcz.net. 1437236326 3600 900 1814400 3600
2020-05-27 19:51:59 info kresd[30062]: .wild.rhybar.0skar.cz. 3600 NSEC .wilda.rhybar.0skar.cz. CNAME RRSIG NSEC
2020-05-27 19:51:59 info kresd[30062]: .wilda.rhybar.0skar.cz. 3600 NSEC .wildt.rhybar.0skar.cz. A AAAA RRSIG NSEC
2020-05-27 19:51:59 info kresd[30062]: rhybar.0skar.cz. 300 RRSIG SOA 10 3 300 19031125173144 20150718151845 28887 rhybar.0skar.cz. DdOSxwRBWoi7x9qEBU1vIf4/ERTJgiGmtYP26K3v0d4nTtUrTMM4jpa02DDzikNY6w5fzB1mVNjAQ9mWGVR8xq2LC1bMvPYYcT/+F024xTQ8cwoXKTX/vd2L5BGiool8WpuP1laccsQfg3m/LtrPRbGFDVPCkw8jyaxMjNVbmisjEAAd886G5YGxmeXIlAN1E069VgRUtWRNAxldhu/SJTNhvipjDH4nXY7jrLunfKw2cdufrH6b2pUywk71hYEH98kkm+FZJUSIY6YE7TdYAR7j409HHrjadNk4Nq8Tr/QAw6Go8D3dIoe8E0x0A3KQo5u+7OGEjnb4oCDzy6weog==
2020-05-27 19:51:59 info kresd[30062]: .wild.rhybar.0skar.cz. 3600 RRSIG NSEC 10 4 3600 19031125173144 20150718151845 28887 rhybar.0skar.cz. PEhnyTEF7jipezYH6l/6u+w14sLhrANzbbrXjiCEL/MJ0xCMfdvNwBTEifqCovA9FeEIhRXz3RuS1xNZ90ifQikK/YS6B4lrs21/LeAzwY+sVtH2nySR7WXAS3ZrgTeREKuA3pC9TMiIgph45uOEqgO115cT3HVGIIdeITJpD3pMP2QgXja9QzJJpkddjSNEIlXQufXGAl/owr3p6pJK+83hjzjM6N/YfgROPvhyFTJNHVuyp6MvBJkd68nFAxNuUpDC80NoULT38Vs+hEBpJuM4heBjmcc0Blbyqn53ICwEWLBdJSsvZAFtbPxAknb/5LyUla32xXZ2e7vBroGhCQ==
2020-05-27 19:51:59 info kresd[30062]: .wilda.rhybar.0skar.cz. 3600 RRSIG NSEC 10 4 3600 19031125173144 20150718151845 28887 rhybar.0skar.cz. CgS9BthZJmNXx/03y46WfK4dUqhOePxpnczGQbAfFl3473CBK73c+yoIgSqhkIAvG4O3ectEANge68bDJ05493o+3169iPUcTZkhtm/JnPiIA44ePa7CXw9qXMeF7veyHWy4I2fStTZ8CHR9Ii44GkRfdwrMM156IdHZSv8z42e3dr4rLfk8BsdYsozEJnY4MLmvfdDxUC9ze8g5q9jjJ76VY0g9s3MGFCENFauqfJCGttW/csUt2ElP99+lxgpfDtQznARCsNN/sjtEVnr2qqHeogvqOvQjtsg967mOoSPqfdWtOhqB2u7gYnJFugv9gW/9+cqtsLkWX0acGwuXGg==
2020-05-27 19:51:59 info kresd[30062]: [17633.12][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [17633.12][iter] <= retrying with non-minimized name
2020-05-27 19:51:59 info kresd[30062]: [17633.12][cach] => stashed packet: rank 020, TTL 300, NS wilda.rhybar.0skar.cz. (1134 B)
2020-05-27 19:51:59 info kresd[30062]: [17633.12][resl] <= server: ‘85.239.227.179’ rtt: 8 ms
2020-05-27 19:51:59 info kresd[30062]: [17633.12][iter] '
.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .13, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [17633.13][resl] => id: ‘10248’ querying: ‘85.239.227.179#00053’ score: 13 zone cut: ‘rhybar.0skar.cz.’ qname: '
.wILdA.rhybAr.0SkAR.cZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [17633.13][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 10248
2020-05-27 19:51:59 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:51:59 info kresd[30062]: .wilda.rhybar.0skar.cz. A
2020-05-27 19:51:59 notice resolver-debug[]:
2020-05-27 19:51:59 info kresd[30062]: .wilda.rhybar.0skar.cz. 300 A 85.239.227.179
2020-05-27 19:51:59 info kresd[30062]: .wilda.rhybar.0skar.cz. 300 RRSIG A 10 4 300 19031125173144 20150718151845 28887 rhybar.0skar.cz. wawMnHrqTKm7gd3SCU59pUX1ah7BCANULX6oK+wnkmnPz/eKbOSenGIY6BVsYfZD+j8ICyazMRehvw+VIOErVJwjIgcJF+RqsgxL6Z+xIIkLRZzIHxnDRu9PSRG+E1jIYQp+Pa4Ez2WqLnC0LrGmFbgXd7FugG8Lij4eExDnhFpRC6rgDhUa3V3a12EIqw1TnoccoC2X0+W+TsIxYsVsTMC3z8n0+zyx1cINJur4dach7Cntir21cM7cdAksbPZFiz3mKyUFQIR3fQlquohEuFpPTn6IySD29otynUD/iBGwQ2tBN7A07pnZmYKpnP3O9hr29Khs4W5BcBe8jDTnuw==
2020-05-27 19:51:59 info kresd[30062]: [17633.13][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [17633.13][cach] => stashed .wilda.rhybar.0skar.cz. A, rank 020, 314 B total, incl. 1 RRSIGs
2020-05-27 19:51:59 info kresd[30062]: [17633.13][resl] <= server: ‘85.239.227.179’ rtt: 8 ms
2020-05-27 19:51:59 info kresd[30062]: [17633.13][resl] AD: request NOT classified as SECURE
2020-05-27 19:51:59 info kresd[30062]: [17633.13][resl] finished: 0, queries: 3, mempool: 32784 B
2020-05-27 19:51:59 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec .wilda.rhybar.0skar.cz
2020-05-27 19:51:59 notice resolver-debug[]: ; (1 server found)
2020-05-27 19:51:59 notice resolver-debug[]: ;; global options: +cmd
2020-05-27 19:51:59 notice resolver-debug[]: ;; Got answer:
2020-05-27 19:51:59 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 17633
2020-05-27 19:51:59 notice resolver-debug[]: ;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
2020-05-27 19:51:59 notice resolver-debug[]: ;; OPT PSEUDOSECTION:
2020-05-27 19:51:59 notice resolver-debug[]: ; EDNS: version: 0, flags: do; udp: 4096
2020-05-27 19:51:59 notice resolver-debug[]: ;; QUESTION SECTION:
.wilda.rhybar.0skar.cz. IN A
2020-05-27 19:51:59 notice resolver-debug[]: ;; ANSWER SECTION:
2020-05-27 19:51:59 notice resolver-debug[]: .wilda.rhybar.0skar.cz. 300 IN A 85.239.227.179
2020-05-27 19:51:59 notice resolver-debug[]: .wilda.rhybar.0skar.cz. 300 IN RRSIG A 10 4 300 20400101000000 20150718151845 28887 rhybar.0skar.cz. wawMnHrqTKm7gd3SCU59pUX1ah7BCANULX6oK+wnkmnPz/eKbOSenGIY 6BVsYfZD+j8ICyazMRehvw+VIOErVJwjIgcJF+RqsgxL6Z+xIIkLRZzI HxnDRu9PSRG+E1jIYQp+Pa4Ez2WqLnC0LrGmFbgXd7FugG8Lij4eExDn hFpRC6rgDhUa3V3a12EIqw1TnoccoC2X0+W+TsIxYsVsTMC3z8n0+zyx 1cINJur4dach7Cntir21cM7cdAksbPZFiz3mKyUFQIR3fQlquohEuFpP Tn6IySD29otynUD/iBGwQ2tBN7A07pnZmYKpnP3O9hr29Khs4W5BcBe8 jDTnuw==
2020-05-27 19:51:59 notice resolver-debug[]: ;; Query time: 2383 msec
2020-05-27 19:51:59 notice resolver-debug[]: ;; SERVER: 127.0.0.1#53(127.0.0.1)
2020-05-27 19:51:59 notice resolver-debug[]: ;; WHEN: Wed May 27 19:51:59 CEST 2020
2020-05-27 19:51:59 notice resolver-debug[]: ;; MSG SIZE rcvd: 371
2020-05-27 19:51:59 info kresd[30062]: [00000.00][plan] plan '
.wilda.nsec.0skar.cz.’ type ‘A’ uid [41810.00]
2020-05-27 19:51:59 info kresd[30062]: [41810.00][iter] '
.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [41810.01][cach] => no NSEC
cached for zone: 0skar.cz.
2020-05-27 19:51:59 info kresd[30062]: [41810.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:59 info kresd[2679]: Last message ‘[41810.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:59 info kresd[30062]: [41810.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:59 info kresd[30062]: [41810.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:59 info kresd[30062]: [41810.01][resl] => id: ‘49776’ querying: ‘85.239.227.179#00053’ score: 12 zone cut: ‘0skar.cz.’ qname: ‘NseC.0skAr.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [41810.01][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 49776
2020-05-27 19:51:59 info kresd[30062]: nsec.0skar.cz. NS
2020-05-27 19:51:59 info kresd[30062]: nsec.0skar.cz. 300 NS flexi.oskarcz.net.
2020-05-27 19:51:59 info kresd[30062]: nsec.0skar.cz. 300 RRSIG NS 10 3 300 19431125173144 20140130121330 28887 nsec.0skar.cz. mEWLGN9GBXm4EjsmekE3NvthE5uzit95aVK9GPRRpvFvNk9ikOK3kCaDaQDL2Jnk4auYwplXETigva3xuwPnp4TNsBToUeqQFk6B21dc7SvLxzP8zvGHeNjs5RPAecZc5DnKwF+0Wj/0pl5UvYDI1XXo+beq8CQmqKXICZnIrG8j/xjmPzwd5yu+fNluQmQKNyP30XBgvRrPKOqbBGDpSD5Roq3mz8urNV/I018Wk5IW6/eUMjZDqyJ823nmXC2ZB2r15eNkMvQk1CR0ldqFtt+n3r/8t7PIVsuqcuHjqyd547FwcD6mNyO92dIy9P3Iyu8cY4w8KBS1Vk388oa6Kw==
2020-05-27 19:51:59 info kresd[30062]: [41810.01][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [41810.01][iter] <= continuing with qname minimization
2020-05-27 19:51:59 info kresd[30062]: [41810.01][resl] <= server: ‘85.239.227.179’ rtt: 15 ms
2020-05-27 19:51:59 info kresd[30062]: [41810.01][iter] '
.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [41810.02][resl] => id: ‘46787’ querying: ‘37.205.10.41#00053’ score: 15 zone cut: ‘nsec.0skar.cz.’ qname: ‘wilda.nSeC.0SKar.Cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [41810.02][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 46787
2020-05-27 19:51:59 info kresd[30062]: ;; Flags: qr QUERY: 1; ANSWER: 0; AUTHORITY: 3; ADDITIONAL: 1
2020-05-27 19:51:59 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:51:59 info kresd[30062]: wilda.nsec.0skar.cz. NS
2020-05-27 19:51:59 info kresd[30062]: nsec.0skar.cz. 3600 NS flexi.oskarcz.net.
2020-05-27 19:51:59 info kresd[30062]: nsec.0skar.cz. 3600 DS 28887 10 2 91EC2CE9169EEFCEF4ED611791FCA8A90D7DF02B6A48E85BE6E1B016253AEDA1
2020-05-27 19:51:59 info kresd[30062]: nsec.0skar.cz. 3600 RRSIG DS 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. mcnU5wUtgkXNugSAb6hJTa37x49RettaZuYbPZ4wKK93vXT3qPLVF1eN9fT5O76qpTnq/DPHaOIi/T71/7xJ4A==
2020-05-27 19:51:59 info kresd[30062]: [41810.02][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [41810.02][iter] <= retrying with non-minimized name
2020-05-27 19:51:59 info kresd[30062]: [41810.02][resl] <= server: ‘37.205.10.41’ rtt: 9 ms
2020-05-27 19:51:59 info kresd[30062]: [41810.02][iter] '
.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [41810.03][resl] => id: ‘20316’ querying: ‘85.239.227.179#00053’ score: 13 zone cut: ‘nsec.0skar.cz.’ qname: '
.wIldA.NSEC.0SKAR.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [41810.03][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 20316
2020-05-27 19:51:59 info kresd[30062]: .wilda.nsec.0skar.cz. A
2020-05-27 19:51:59 info kresd[30062]: .wilda.nsec.0skar.cz. 300 A 85.239.227.179
2020-05-27 19:51:59 info kresd[30062]: .wilda.nsec.0skar.cz. 300 RRSIG A 10 4 300 19431125173144 20140130121330 28887 nsec.0skar.cz. fJxvVUjFwkEqsDvCOrQHoyLwOQf4XKtmhMJCEZiCEy7MvxGx73uJPI1TlxFhM3PfZCsDUQukMEcGhQgKmnZbSkudE9ocSXELt9ponJHWdh0TIoFhBciCOA8UfO3K2gcYR+v0wyXlHGLHWXysPiULCk3ujDbFHTUBxQadN+9Ef0TODRF/VtPrwJFisCDGPV9SofuOChI64Xys/Ycmn6fFKp09YTDDhroIIuedqT1CgKPi0WHFLLAqkSUBzRFPYu5769xrR/ukPHBBcj/SGJWdTkcWybHSoR9rRr9JyQ2o+FrIf+nKtcY8rVQ8EUexq7CsdMcUo3ZGwgjuaR1vIUVVNw==
2020-05-27 19:51:59 info kresd[30062]: [41810.03][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [41810.03][cach] => stashed .wilda.nsec.0skar.cz. A, rank 020, 312 B total, incl. 1 RRSIGs
2020-05-27 19:51:59 info kresd[30062]: [41810.03][resl] <= server: ‘85.239.227.179’ rtt: 9 ms
2020-05-27 19:51:59 info kresd[30062]: [41810.03][resl] AD: request NOT classified as SECURE
2020-05-27 19:51:59 info kresd[30062]: [41810.03][resl] finished: 0, queries: 1, mempool: 32784 B
2020-05-27 19:51:59 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec .wilda.nsec.0skar.cz
2020-05-27 19:51:59 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 41810
.wilda.nsec.0skar.cz. IN A
2020-05-27 19:51:59 notice resolver-debug[]: .wilda.nsec.0skar.cz. 300 IN A 85.239.227.179
2020-05-27 19:51:59 notice resolver-debug[]: .wilda.nsec.0skar.cz. 300 IN RRSIG A 10 4 300 20800101000000 20140130121330 28887 nsec.0skar.cz. fJxvVUjFwkEqsDvCOrQHoyLwOQf4XKtmhMJCEZiCEy7MvxGx73uJPI1T lxFhM3PfZCsDUQukMEcGhQgKmnZbSkudE9ocSXELt9ponJHWdh0TIoFh BciCOA8UfO3K2gcYR+v0wyXlHGLHWXysPiULCk3ujDbFHTUBxQadN+9E f0TODRF/VtPrwJFisCDGPV9SofuOChI64Xys/Ycmn6fFKp09YTDDhroI IuedqT1CgKPi0WHFLLAqkSUBzRFPYu5769xrR/ukPHBBcj/SGJWdTkcW ybHSoR9rRr9JyQ2o+FrIf+nKtcY8rVQ8EUexq7CsdMcUo3ZGwgjuaR1v IUVVNw==
2020-05-27 19:51:59 notice resolver-debug[]: ;; Query time: 33 msec
2020-05-27 19:51:59 notice resolver-debug[]: ;; MSG SIZE rcvd: 367
.wild.nsec.0skar.cz.’ type ‘A’ uid [04279.00]
2020-05-27 19:51:59 info kresd[30062]: [04279.00][iter] '
.wild.nsec.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [04279.01][cach] => no NSEC
2020-05-27 19:51:59 info kresd[30062]: [04279.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:59 info kresd[2679]: Last message ‘[04279.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:59 info kresd[30062]: [04279.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:59 info kresd[30062]: [04279.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:59 info kresd[30062]: [04279.01][resl] => id: ‘16173’ querying: ‘85.239.227.179#00053’ score: 12 zone cut: ‘0skar.cz.’ qname: ‘nsEC.0skAr.Cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [04279.01][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16173
2020-05-27 19:51:59 info kresd[30062]: [04279.01][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [04279.01][iter] <= continuing with qname minimization
2020-05-27 19:51:59 info kresd[30062]: [04279.01][resl] <= server: ‘85.239.227.179’ rtt: 20 ms
2020-05-27 19:51:59 info kresd[30062]: [04279.01][iter] '
.wild.nsec.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [04279.02][resl] => id: ‘50502’ querying: ‘37.205.10.41#00053’ score: 13 zone cut: ‘nsec.0skar.cz.’ qname: ‘Wild.nsec.0skaR.cZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [04279.02][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 50502
2020-05-27 19:51:59 info kresd[30062]: wild.nsec.0skar.cz. NS
2020-05-27 19:51:59 info kresd[30062]: [04279.02][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [04279.02][iter] <= retrying with non-minimized name
2020-05-27 19:51:59 info kresd[30062]: [04279.02][resl] <= server: ‘37.205.10.41’ rtt: 17 ms
2020-05-27 19:51:59 info kresd[30062]: [04279.02][iter] '
.wild.nsec.0skar.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [04279.03][resl] => id: ‘08440’ querying: ‘37.205.10.41#00053’ score: 15 zone cut: ‘nsec.0skar.cz.’ qname: '
.WilD.nsEc.0SkAR.cZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [04279.03][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 8440
2020-05-27 19:51:59 info kresd[30062]: .wild.nsec.0skar.cz. A
2020-05-27 19:51:59 info kresd[30062]: [04279.03][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [04279.03][iter] <= lame response: non-auth sent negative response
2020-05-27 19:51:59 info kresd[30062]: [04279.03][iter] '
.wild.nsec.0skar.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [04279.04][resl] => id: ‘50616’ querying: ‘85.239.227.179#00053’ score: 16 zone cut: ‘nsec.0skar.cz.’ qname: '
.wiLD.NSec.0SKAR.cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [04279.04][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 50616
2020-05-27 19:51:59 info kresd[30062]: .wild.nsec.0skar.cz. 300 CNAME flexi.oskarcz.net.
2020-05-27 19:51:59 info kresd[30062]: .wild.nsec.0skar.cz. 300 RRSIG CNAME 10 4 300 19431125173144 20140130121330 28887 nsec.0skar.cz. OCgbO4C5z8FvuxZ+nb5ZGR8boZaWYLSWfEPxt1BKhFgMNKc/gugNMvIr7L2kKTnw/gpqmBvCY3pBn5v5HbwZ280yOouHvUrHDWQV8rDEIil0E+QHEqlz4sUxPlmRlIkdzMf31WYN/6qOfTWwdDA3FWrw+316BzVVnteR3o8W+pJy41SI4XQApVfeDM/4wbPVxNzQT+rchOEAIo0Q+3cqeI9BnbQtiZwdCthmTcIbcV8GnzYbI48XbUIr13upMjzE8ZI3mi/ZGI9qs2BUy88D1HRzsHKgRfSPjwGcJfAxvvTWqVu1u0JIvg/agfgGEAh/GNYmcfHg7F+iMFZxV2GmWg==
2020-05-27 19:51:59 info kresd[30062]: [04279.04][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [04279.04][iter] <= cname chain, following
2020-05-27 19:51:59 info kresd[30062]: [00000.00][plan] plan ‘flexi.oskarcz.net.’ type ‘A’ uid [04279.05]
2020-05-27 19:51:59 info kresd[30062]: [04279.04][cach] => stashed .wild.nsec.0skar.cz. CNAME, rank 020, 328 B total, incl. 1 RRSIGs
2020-05-27 19:51:59 info kresd[30062]: [04279.04][resl] <= server: ‘85.239.227.179’ rtt: 6 ms
2020-05-27 19:51:59 info kresd[30062]: [04279.05][iter] ‘flexi.oskarcz.net.’ type ‘A’ new uid was assigned .06, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [04279.06][cach] => skipping exact RR: rank 001 (min. 020), new TTL 172798
2020-05-27 19:51:59 info kresd[30062]: [04279.06][cach] => no NSEC
cached for zone: oskarcz.net.
2020-05-27 19:51:59 info kresd[30062]: [04279.06][cach] => skipping zone: oskarcz.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:59 info kresd[2679]: Last message ‘[04279.06][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:59 info kresd[30062]: [04279.06][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:59 info kresd[30062]: [04279.06][zcut] found cut: oskarcz.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:59 info kresd[30062]: [04279.06][resl] => id: ‘48230’ querying: ‘85.239.227.179#00053’ score: 13 zone cut: ‘oskarcz.net.’ qname: ‘flExI.oSKarcZ.NEt.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [04279.06][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 48230
2020-05-27 19:51:59 info kresd[30062]: flexi.oskarcz.net. 3600 A 85.239.227.179
2020-05-27 19:51:59 info kresd[30062]: flexi.oskarcz.net. 3600 RRSIG A 13 3 3600 20200607105629 20200524092629 22290 oskarcz.net. veacbhMaX+Wy//d5gUu47kAZ2snsJAblm2MSCfdjwUqdV+fSim+d2g25eebW4Mh7ePzNbmEt/Fs9GIhilC3onw==
2020-05-27 19:51:59 info kresd[30062]: [04279.06][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [04279.06][cach] => stashed flexi.oskarcz.net. A, rank 020, 118 B total, incl. 1 RRSIGs
2020-05-27 19:51:59 info kresd[30062]: [04279.06][resl] <= server: ‘85.239.227.179’ rtt: 8 ms
2020-05-27 19:51:59 info kresd[30062]: [04279.06][resl] AD: request NOT classified as SECURE
2020-05-27 19:51:59 info kresd[30062]: [04279.06][resl] finished: 0, queries: 2, mempool: 32784 B
2020-05-27 19:51:59 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec .wild.nsec.0skar.cz
2020-05-27 19:51:59 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 4279
2020-05-27 19:51:59 notice resolver-debug[]: ;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
.wild.nsec.0skar.cz. IN A
2020-05-27 19:51:59 notice resolver-debug[]: .wild.nsec.0skar.cz. 300 IN CNAME flexi.oskarcz.net.
2020-05-27 19:51:59 notice resolver-debug[]: .wild.nsec.0skar.cz. 300 IN RRSIG CNAME 10 4 300 20800101000000 20140130121330 28887 nsec.0skar.cz. OCgbO4C5z8FvuxZ+nb5ZGR8boZaWYLSWfEPxt1BKhFgMNKc/gugNMvIr 7L2kKTnw/gpqmBvCY3pBn5v5HbwZ280yOouHvUrHDWQV8rDEIil0E+QH Eqlz4sUxPlmRlIkdzMf31WYN/6qOfTWwdDA3FWrw+316BzVVnteR3o8W +pJy41SI4XQApVfeDM/4wbPVxNzQT+rchOEAIo0Q+3cqeI9BnbQtiZwd CthmTcIbcV8GnzYbI48XbUIr13upMjzE8ZI3mi/ZGI9qs2BUy88D1HRz sHKgRfSPjwGcJfAxvvTWqVu1u0JIvg/agfgGEAh/GNYmcfHg7F+iMFZx V2GmWg==
2020-05-27 19:51:59 notice resolver-debug[]: flexi.oskarcz.net. 3600 IN A 85.239.227.179
2020-05-27 19:51:59 notice resolver-debug[]: flexi.oskarcz.net. 3600 IN RRSIG A 13 3 3600 20200607105629 20200524092629 22290 oskarcz.net. veacbhMaX+Wy//d5gUu47kAZ2snsJAblm2MSCfdjwUqdV+fSim+d2g25 eebW4Mh7ePzNbmEt/Fs9GIhilC3onw==
2020-05-27 19:51:59 notice resolver-debug[]: ;; Query time: 57 msec
2020-05-27 19:51:59 notice resolver-debug[]: ;; MSG SIZE rcvd: 521
.wilda.0skar.cz.’ type ‘A’ uid [36627.00]
2020-05-27 19:51:59 info kresd[30062]: [36627.00][iter] '
.wilda.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [36627.01][cach] => no NSEC
2020-05-27 19:51:59 info kresd[30062]: [36627.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:59 info kresd[2679]: Last message ‘[36627.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:59 info kresd[30062]: [36627.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:59 info kresd[30062]: [36627.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:59 info kresd[30062]: [36627.01][resl] => id: ‘62928’ querying: ‘85.239.227.179#00053’ score: 12 zone cut: ‘0skar.cz.’ qname: ‘wILda.0SkAR.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [36627.01][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 62928
2020-05-27 19:51:59 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 4; ADDITIONAL: 1
2020-05-27 19:51:59 info kresd[30062]: wilda.0skar.cz. NS
2020-05-27 19:51:59 info kresd[30062]: 0skar.cz. 3600 SOA flexi.oskarcz.net. hostmaster.oskarcz.net. 1590441859 3600 900 1814400 3600
2020-05-27 19:51:59 info kresd[30062]: jpajkvu1p2cje5uq29h88o3lbeqpqqi0.0skar.cz. 3600 NSEC3 1 0 10 9021D6D3A9A71DE7 k9hsdgd9m6ahe8qgjnmjuvjekp0vfh3q
2020-05-27 19:51:59 info kresd[30062]: 0skar.cz. 3600 RRSIG SOA 13 2 3600 20200608212419 20200525195419 22377 0skar.cz. KvxAxHYJzKZKd6Ta/e1HOIQ9pzvXzR9ryiA0K4MpFZaUTZPiieT7GqliJHZlKbAYedbdGahyyr6qlSNrAZPPnA==
2020-05-27 19:51:59 info kresd[30062]: jpajkvu1p2cje5uq29h88o3lbeqpqqi0.0skar.cz. 3600 RRSIG NSEC3 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. R5iJ8L7Agmiri94hHbJ/WUHJ8Hhr7ZS/6gS5F5UJHGUmSpk2GpbXSl5VUXeNw4LmFhQKSUNAbhmv2wJBDQksmA==
2020-05-27 19:51:59 info kresd[30062]: [36627.01][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [36627.01][iter] <= retrying with non-minimized name
2020-05-27 19:51:59 info kresd[30062]: [36627.01][cach] => stashed packet: rank 020, TTL 3600, NS wilda.0skar.cz. (406 B)
2020-05-27 19:51:59 info kresd[30062]: [36627.01][resl] <= server: ‘85.239.227.179’ rtt: 7 ms
2020-05-27 19:51:59 info kresd[30062]: [36627.01][iter] '
.wilda.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [36627.02][resl] => id: ‘04281’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: '
.WildA.0SKAr.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:51:59 info kresd[30062]: [36627.02][iter] <= answer received:
2020-05-27 19:51:59 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 4281
2020-05-27 19:51:59 info kresd[30062]: .wilda.0skar.cz. A
2020-05-27 19:51:59 info kresd[30062]: .wilda.0skar.cz. 3600 A 85.239.227.179
2020-05-27 19:51:59 info kresd[30062]: .wilda.0skar.cz. 3600 RRSIG A 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. nBH2LD2NAA4xoEPX02NDtpan+B/03EoD+DM+XDe29eDTesl18GL/Tg2r6S7H/O6b5FtaUHNtFqpT+vv1ZPW5mg==
2020-05-27 19:51:59 info kresd[30062]: [36627.02][iter] <= rcode: NOERROR
2020-05-27 19:51:59 info kresd[30062]: [36627.02][cach] => stashed .wilda.0skar.cz. A, rank 020, 114 B total, incl. 1 RRSIGs
2020-05-27 19:51:59 info kresd[30062]: [36627.02][resl] <= server: ‘85.239.227.179’ rtt: 7 ms
2020-05-27 19:51:59 info kresd[30062]: [36627.02][resl] AD: request NOT classified as SECURE
2020-05-27 19:51:59 info kresd[30062]: [36627.02][resl] finished: 0, queries: 1, mempool: 32784 B
2020-05-27 19:51:59 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec .wilda.0skar.cz
2020-05-27 19:51:59 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 36627
.wilda.0skar.cz. IN A
2020-05-27 19:51:59 notice resolver-debug[]: .wilda.0skar.cz. 3600 IN A 85.239.227.179
2020-05-27 19:51:59 notice resolver-debug[]: .wilda.0skar.cz. 3600 IN RRSIG A 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. nBH2LD2NAA4xoEPX02NDtpan+B/03EoD+DM+XDe29eDTesl18GL/Tg2r 6S7H/O6b5FtaUHNtFqpT+vv1ZPW5mg==
2020-05-27 19:51:59 notice resolver-debug[]: ;; Query time: 14 msec
2020-05-27 19:51:59 notice resolver-debug[]: ;; MSG SIZE rcvd: 165
.wild.0skar.cz.’ type ‘A’ uid [50640.00]
2020-05-27 19:51:59 info kresd[30062]: [50640.00][iter] '
.wild.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:51:59 info kresd[30062]: [50640.01][cach] => no NSEC
2020-05-27 19:51:59 info kresd[30062]: [50640.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:51:59 info kresd[2679]: Last message ‘[50640.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:51:59 info kresd[30062]: [50640.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:51:59 info kresd[30062]: [50640.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:51:59 info kresd[30062]: [50640.01][resl] => id: ‘08902’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: ‘WilD.0Skar.CZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [50640.01][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 8902
2020-05-27 19:52:00 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 4; ADDITIONAL: 1
2020-05-27 19:52:00 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:00 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:52:00 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:00 info kresd[30062]: wild.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:52:00 info kresd[30062]: 0skar.cz. 3600 SOA flexi.oskarcz.net. hostmaster.oskarcz.net. 1590441859 3600 900 1814400 3600
2020-05-27 19:52:00 info kresd[30062]: h6bg4vs4bquekdrtjhnguma2ca209h4u.0skar.cz. 3600 NSEC3 1 0 10 9021D6D3A9A71DE7 hlfpdbb4ncdton4q7jdf3psglkep8put
2020-05-27 19:52:00 info kresd[30062]: 0skar.cz. 3600 RRSIG SOA 13 2 3600 20200608212419 20200525195419 22377 0skar.cz. KvxAxHYJzKZKd6Ta/e1HOIQ9pzvXzR9ryiA0K4MpFZaUTZPiieT7GqliJHZlKbAYedbdGahyyr6qlSNrAZPPnA==
2020-05-27 19:52:00 info kresd[30062]: h6bg4vs4bquekdrtjhnguma2ca209h4u.0skar.cz. 3600 RRSIG NSEC3 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. AK1lThSfdZ28wgKx+7xTjg4OoZsNl1kavXXfBcSpMA6e8HiWdRZU9UL6SbIJsGFAglU6d5nWm/6dMVrQprQfLw==
2020-05-27 19:52:00 info kresd[30062]: [50640.01][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [50640.01][iter] <= retrying with non-minimized name
2020-05-27 19:52:00 info kresd[30062]: [50640.01][cach] => stashed packet: rank 020, TTL 3600, NS wild.0skar.cz. (405 B)
2020-05-27 19:52:00 info kresd[30062]: [50640.01][resl] <= server: ‘85.239.227.179’ rtt: 7 ms
2020-05-27 19:52:00 info kresd[30062]: [50640.01][iter] '
.wild.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [50640.02][resl] => id: ‘10570’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: '
.wILD.0SKAR.cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [50640.02][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 10570
2020-05-27 19:52:00 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:00 info kresd[30062]: .wild.0skar.cz. A
2020-05-27 19:52:00 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:00 info kresd[30062]: .wild.0skar.cz. 3600 CNAME flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: .wild.0skar.cz. 3600 RRSIG CNAME 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. fyzRHJDljQrtKuOPITxv8tVkkGN5FcQryZMqCZccLpL0yTQO9x6cq6WHePuDFDjeXH1u9sNeH9wVShCpQKQPbA==
2020-05-27 19:52:00 info kresd[30062]: [50640.02][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [50640.02][iter] <= cname chain, following
2020-05-27 19:52:00 info kresd[30062]: [00000.00][plan] plan ‘flexi.oskarcz.net.’ type ‘A’ uid [50640.03]
2020-05-27 19:52:00 info kresd[30062]: [50640.02][cach] => stashed .wild.0skar.cz. CNAME, rank 020, 130 B total, incl. 1 RRSIGs
2020-05-27 19:52:00 info kresd[30062]: [50640.02][resl] <= server: ‘85.239.227.179’ rtt: 11 ms
2020-05-27 19:52:00 info kresd[30062]: [50640.03][iter] ‘flexi.oskarcz.net.’ type ‘A’ new uid was assigned .04, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [50640.04][cach] => satisfied by exact RRset: rank 020, new TTL 3599
2020-05-27 19:52:00 info kresd[30062]: [50640.04][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 51312
2020-05-27 19:52:00 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
2020-05-27 19:52:00 info kresd[30062]: flexi.oskarcz.net. A
2020-05-27 19:52:00 info kresd[30062]: flexi.oskarcz.net. 3599 A 85.239.227.179
2020-05-27 19:52:00 info kresd[30062]: flexi.oskarcz.net. 3600 RRSIG A 13 3 3600 20200607105629 20200524092629 22290 oskarcz.net. veacbhMaX+Wy//d5gUu47kAZ2snsJAblm2MSCfdjwUqdV+fSim+d2g25eebW4Mh7ePzNbmEt/Fs9GIhilC3onw==
2020-05-27 19:52:00 info kresd[30062]: [50640.04][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [50640.04][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:00 info kresd[30062]: [50640.04][resl] finished: 0, queries: 2, mempool: 32784 B
2020-05-27 19:52:00 notice resolver-debug[]:
2020-05-27 19:52:00 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec .wild.0skar.cz
2020-05-27 19:52:00 notice resolver-debug[]: ; (1 server found)
2020-05-27 19:52:00 notice resolver-debug[]: ;; global options: +cmd
2020-05-27 19:52:00 notice resolver-debug[]: ;; Got answer:
2020-05-27 19:52:00 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 50640
2020-05-27 19:52:00 notice resolver-debug[]: ;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
2020-05-27 19:52:00 notice resolver-debug[]: ;; OPT PSEUDOSECTION:
2020-05-27 19:52:00 notice resolver-debug[]: ; EDNS: version: 0, flags: do; udp: 4096
2020-05-27 19:52:00 notice resolver-debug[]: ;; QUESTION SECTION:
.wild.0skar.cz. IN A
2020-05-27 19:52:00 notice resolver-debug[]: ;; ANSWER SECTION:
2020-05-27 19:52:00 notice resolver-debug[]: .wild.0skar.cz. 3600 IN CNAME flexi.oskarcz.net.
2020-05-27 19:52:00 notice resolver-debug[]: .wild.0skar.cz. 3600 IN RRSIG CNAME 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. fyzRHJDljQrtKuOPITxv8tVkkGN5FcQryZMqCZccLpL0yTQO9x6cq6WH ePuDFDjeXH1u9sNeH9wVShCpQKQPbA==
2020-05-27 19:52:00 notice resolver-debug[]: flexi.oskarcz.net. 3599 IN A 85.239.227.179
2020-05-27 19:52:00 notice resolver-debug[]: flexi.oskarcz.net. 3599 IN RRSIG A 13 3 3600 20200607105629 20200524092629 22290 oskarcz.net. veacbhMaX+Wy//d5gUu47kAZ2snsJAblm2MSCfdjwUqdV+fSim+d2g25 eebW4Mh7ePzNbmEt/Fs9GIhilC3onw==
2020-05-27 19:52:00 notice resolver-debug[]: ;; Query time: 20 msec
2020-05-27 19:52:00 notice resolver-debug[]: ;; SERVER: 127.0.0.1#53(127.0.0.1)
2020-05-27 19:52:00 notice resolver-debug[]: ;; WHEN: Wed May 27 19:52:00 CEST 2020
2020-05-27 19:52:00 notice resolver-debug[]: ;; MSG SIZE rcvd: 319
2020-05-27 19:52:00 info kresd[30062]: [00000.00][plan] plan ‘www.wilda.nsec.0skar.cz.’ type ‘A’ uid [08291.00]
2020-05-27 19:52:00 info kresd[30062]: [08291.00][iter] ‘www.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [08291.01][cach] => no NSEC
2020-05-27 19:52:00 info kresd[30062]: [08291.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:00 info kresd[2679]: Last message ‘[08291.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:00 info kresd[30062]: [08291.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:00 info kresd[30062]: [08291.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:00 info kresd[30062]: [08291.01][resl] => id: ‘25810’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: ‘NSEc.0SKAR.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [08291.01][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 25810
2020-05-27 19:52:00 info kresd[30062]: nsec.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: nsec.0skar.cz. 300 NS flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: nsec.0skar.cz. 300 RRSIG NS 10 3 300 19431125173144 20140130121330 28887 nsec.0skar.cz. mEWLGN9GBXm4EjsmekE3NvthE5uzit95aVK9GPRRpvFvNk9ikOK3kCaDaQDL2Jnk4auYwplXETigva3xuwPnp4TNsBToUeqQFk6B21dc7SvLxzP8zvGHeNjs5RPAecZc5DnKwF+0Wj/0pl5UvYDI1XXo+beq8CQmqKXICZnIrG8j/xjmPzwd5yu+fNluQmQKNyP30XBgvRrPKOqbBGDpSD5Roq3mz8urNV/I018Wk5IW6/eUMjZDqyJ823nmXC2ZB2r15eNkMvQk1CR0ldqFtt+n3r/8t7PIVsuqcuHjqyd547FwcD6mNyO92dIy9P3Iyu8cY4w8KBS1Vk388oa6Kw==
2020-05-27 19:52:00 info kresd[30062]: [08291.01][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [08291.01][iter] <= continuing with qname minimization
2020-05-27 19:52:00 info kresd[30062]: [08291.01][resl] <= server: ‘85.239.227.179’ rtt: 8 ms
2020-05-27 19:52:00 info kresd[30062]: [08291.01][iter] ‘www.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [08291.02][resl] => id: ‘15085’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘nsec.0skar.cz.’ qname: ‘wiLDA.nseC.0sKaR.Cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [08291.02][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 15085
2020-05-27 19:52:00 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 6; ADDITIONAL: 1
2020-05-27 19:52:00 info kresd[30062]: wilda.nsec.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: nsec.0skar.cz. 300 SOA flexi.oskarcz.net. hostmaster.oskarcz.net. 1391087610 3600 900 1814400 3600
2020-05-27 19:52:00 info kresd[30062]: .wild.nsec.0skar.cz. 3600 NSEC .wilda.nsec.0skar.cz. CNAME RRSIG NSEC
2020-05-27 19:52:00 info kresd[30062]: .wilda.nsec.0skar.cz. 3600 NSEC www.wilda.nsec.0skar.cz. A AAAA RRSIG NSEC
2020-05-27 19:52:00 info kresd[30062]: nsec.0skar.cz. 300 RRSIG SOA 10 3 300 19431125173144 20140130121330 28887 nsec.0skar.cz. GScva9Psu0QG8gDw5HMm+3jyjHVZecQQlvAQLowIuhdLHa9U1uDs64lhBjOeev44a765dje+M5ToOE+2MCR5VgfucMc1/DWi2TYEEQogH8zy2q88QxeAoveEzt9gL4RzWdRRMXA0o9RFkYk3C3wqP+WuHYR4nfdemnvGoY4RknpwGvIwW685G3U6Sd0ui7rHHXWTE5QjDkqT73W8mp2deKDIstj32j7TiEtbzqciZus23zpnp7FLyunZpPxY+V7kudY/niegOd24b5FYKxwvcLg5ORSHxDyLRMFQdveoXlR6SPHs7ZnOhuMI9Z2I7iViTYyRHYPbyC/e/3MM0hC7DA==
2020-05-27 19:52:00 info kresd[30062]: .wild.nsec.0skar.cz. 3600 RRSIG NSEC 10 4 3600 19431125173144 20140130121330 28887 nsec.0skar.cz. VJQslMRTGPU2yQcnIWi0AglZV/sY+lpw1O5aLwnLyKhFyBZZ4eYG68z74IfEf7DKhjw8BKNLezxD9jUpjBkF1VFU+0TuV0pBdO4tMeI3ta9vK8mb4qeIQre7Xci7TXpYEZDJq62zcZ2xMWHCtShoFsZpA5WC1Aa+kuaKaT3jZys/2tei21Rwijv+46fIgMia22pGiYNN+YGyiy6tPbIMidAOO9f+433FeT+xz1subT3LcVjzEBAmnuR+cx8hxo9TMUo7iD30iZnHkXErpTlDeIE4nkoQBpKPd/9Btk6GS4tbFlv8GK57hNycaDRhybqO4qajk7EUDAs4ThWJXGd9tQ==
2020-05-27 19:52:00 info kresd[30062]: .wilda.nsec.0skar.cz. 3600 RRSIG NSEC 10 4 3600 19431125173144 20140130121330 28887 nsec.0skar.cz. wwDV2M2xIchq845sB5nL0pJyBBVlhsJIt5w5CRai6C1X182ZU3K0c96i4cMiNbXZX4+Oa92IRTPTxnSH+Yi6qbhnqkzE1LBESyP1XP8Wq5+DCXPY/+qWN8wgqbeZoFthGd/Hk3IbeDGBX3v9er43wa2bQChyxRnRr7bpTVJUNCH4JmOP0miThjmYFU61uUy1b/C5eYgiyoeXtFjMMeikZJWTc7saqTnNf2bdzvlbGiT8wxT6cuEk0vlLqid+WOFuDzTYriRrQ7bw4WYgMjQlCXJtbbhSHflKtl1KTMylfwEGA00sTrTM4X4rapQFRQfK+agM3tTaRjOpF5xAnXVDSA==
2020-05-27 19:52:00 info kresd[30062]: [08291.02][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [08291.02][iter] <= retrying with non-minimized name
2020-05-27 19:52:00 info kresd[30062]: [08291.02][cach] => stashed packet: rank 020, TTL 300, NS wilda.nsec.0skar.cz. (1124 B)
2020-05-27 19:52:00 info kresd[30062]: [08291.02][resl] <= server: ‘85.239.227.179’ rtt: 13 ms
2020-05-27 19:52:00 info kresd[30062]: [08291.02][iter] ‘www.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [08291.03][resl] => id: ‘07855’ querying: ‘85.239.227.179#00053’ score: 12 zone cut: ‘nsec.0skar.cz.’ qname: ‘WwW.WildA.NseC.0SKAR.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [08291.03][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 7855
2020-05-27 19:52:00 info kresd[30062]: www.wilda.nsec.0skar.cz. A
2020-05-27 19:52:00 info kresd[30062]: www.wilda.nsec.0skar.cz. 300 CNAME flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: www.wilda.nsec.0skar.cz. 300 RRSIG CNAME 10 5 300 19431125173144 20140130121330 28887 nsec.0skar.cz. VCwEXOf8qK1MZ52r6zGGKI4+JUEm8tF/xTYM7isp/W0a9S7O0Zntl7qN7Eu0uy9TJ3lhTyGGjo4kI63TgZW6DaROepBMwRRHmsMNdR69+shBWumjq65grbAHkZh4D4BHmWz44iQOjc6l5zyl42zUHd8Oo3NEVm/gt5hRf/bPprtmNwVvoHrQJfDdEEa49s+ES5dKUE0m1t2JiYIOsCkC2WOdHHnDPj61gKRi7+ktYmejl7srj98dvCCiNKI4Qb3FkTotaLxtFCs8n69/UO0e4m/bgXerIRrh8P4dJuy/p73Bsm1v4RdrnJ0CMdc+2kEKrD4fGy6QWAWl8MtA/vicnw==
2020-05-27 19:52:00 info kresd[30062]: [08291.03][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [08291.03][iter] <= cname chain, following
2020-05-27 19:52:00 info kresd[30062]: [00000.00][plan] plan ‘flexi.oskarcz.net.’ type ‘A’ uid [08291.04]
2020-05-27 19:52:00 info kresd[30062]: [08291.03][cach] => stashed www.wilda.nsec.0skar.cz. CNAME, rank 020, 328 B total, incl. 1 RRSIGs
2020-05-27 19:52:00 info kresd[30062]: [08291.03][resl] <= server: ‘85.239.227.179’ rtt: 7 ms
2020-05-27 19:52:00 info kresd[30062]: [08291.04][iter] ‘flexi.oskarcz.net.’ type ‘A’ new uid was assigned .05, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [08291.05][cach] => satisfied by exact RRset: rank 020, new TTL 3599
2020-05-27 19:52:00 info kresd[30062]: [08291.05][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 13252
2020-05-27 19:52:00 info kresd[30062]: [08291.05][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [08291.05][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:00 info kresd[30062]: [08291.05][resl] finished: 0, queries: 2, mempool: 32784 B
2020-05-27 19:52:00 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec www.wilda.nsec.0skar.cz
2020-05-27 19:52:00 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8291
2020-05-27 19:52:00 notice resolver-debug[]: ;www.wilda.nsec.0skar.cz. IN A
2020-05-27 19:52:00 notice resolver-debug[]: www.wilda.nsec.0skar.cz. 300 IN CNAME flexi.oskarcz.net.
2020-05-27 19:52:00 notice resolver-debug[]: www.wilda.nsec.0skar.cz. 300 IN RRSIG CNAME 10 5 300 20800101000000 20140130121330 28887 nsec.0skar.cz. VCwEXOf8qK1MZ52r6zGGKI4+JUEm8tF/xTYM7isp/W0a9S7O0Zntl7qN 7Eu0uy9TJ3lhTyGGjo4kI63TgZW6DaROepBMwRRHmsMNdR69+shBWumj q65grbAHkZh4D4BHmWz44iQOjc6l5zyl42zUHd8Oo3NEVm/gt5hRf/bP prtmNwVvoHrQJfDdEEa49s+ES5dKUE0m1t2JiYIOsCkC2WOdHHnDPj61 gKRi7+ktYmejl7srj98dvCCiNKI4Qb3FkTotaLxtFCs8n69/UO0e4m/b gXerIRrh8P4dJuy/p73Bsm1v4RdrnJ0CMdc+2kEKrD4fGy6QWAWl8MtA /vicnw==
2020-05-27 19:52:00 notice resolver-debug[]: ;; Query time: 28 msec
2020-05-27 19:52:00 notice resolver-debug[]: ;; MSG SIZE rcvd: 524
2020-05-27 19:52:00 info kresd[30062]: [00000.00][plan] plan ‘www.wilda.0skar.cz.’ type ‘A’ uid [40639.00]
2020-05-27 19:52:00 info kresd[30062]: [40639.00][iter] ‘www.wilda.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [40639.01][cach] => skipping unfit NS packet: rank 020, new TTL 3599
2020-05-27 19:52:00 info kresd[30062]: [40639.01][cach] => no NSEC
2020-05-27 19:52:00 info kresd[30062]: [40639.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:00 info kresd[2679]: Last message ‘[40639.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:00 info kresd[30062]: [40639.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:00 info kresd[30062]: [40639.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:00 info kresd[30062]: [40639.01][resl] => id: ‘18170’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: ‘WildA.0skAr.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [40639.01][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 18170
2020-05-27 19:52:00 info kresd[30062]: wilda.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: jpajkvu1p2cje5uq29h88o3lbeqpqqi0.0skar.cz. 3600 NSEC3 1 0 10 9021D6D3A9A71DE7 k9hsdgd9m6ahe8qgjnmjuvjekp0vfh3q
2020-05-27 19:52:00 info kresd[30062]: jpajkvu1p2cje5uq29h88o3lbeqpqqi0.0skar.cz. 3600 RRSIG NSEC3 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. R5iJ8L7Agmiri94hHbJ/WUHJ8Hhr7ZS/6gS5F5UJHGUmSpk2GpbXSl5VUXeNw4LmFhQKSUNAbhmv2wJBDQksmA==
2020-05-27 19:52:00 info kresd[30062]: [40639.01][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [40639.01][iter] <= retrying with non-minimized name
2020-05-27 19:52:00 info kresd[30062]: [40639.01][cach] => not overwriting NS wilda.0skar.cz.
2020-05-27 19:52:00 info kresd[30062]: [40639.01][resl] <= server: ‘85.239.227.179’ rtt: 7 ms
2020-05-27 19:52:00 info kresd[30062]: [40639.01][iter] ‘www.wilda.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [40639.02][resl] => id: ‘16684’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: ‘wWW.WIlda.0skar.CZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [40639.02][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16684
2020-05-27 19:52:00 info kresd[30062]: www.wilda.0skar.cz. A
2020-05-27 19:52:00 info kresd[30062]: www.wilda.0skar.cz. 3600 CNAME flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: www.wilda.0skar.cz. 3600 RRSIG CNAME 13 4 3600 20200608202419 20200525185419 22377 0skar.cz. IbWrlyclFOE5YTWKww7sAy6fE24A4s6bad99eWyhLOMxBhMqaHcULRXGJrUdYIZ/GKeZUPNFFHZwK6pxWE2BUQ==
2020-05-27 19:52:00 info kresd[30062]: [40639.02][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [40639.02][iter] <= cname chain, following
2020-05-27 19:52:00 info kresd[30062]: [00000.00][plan] plan ‘flexi.oskarcz.net.’ type ‘A’ uid [40639.03]
2020-05-27 19:52:00 info kresd[30062]: [40639.02][cach] => stashed www.wilda.0skar.cz. CNAME, rank 020, 130 B total, incl. 1 RRSIGs
2020-05-27 19:52:00 info kresd[30062]: [40639.02][resl] <= server: ‘85.239.227.179’ rtt: 6 ms
2020-05-27 19:52:00 info kresd[30062]: [40639.03][iter] ‘flexi.oskarcz.net.’ type ‘A’ new uid was assigned .04, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [40639.04][cach] => satisfied by exact RRset: rank 020, new TTL 3599
2020-05-27 19:52:00 info kresd[30062]: [40639.04][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 39494
2020-05-27 19:52:00 info kresd[30062]: [40639.04][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [40639.04][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:00 info kresd[30062]: [40639.04][resl] finished: 0, queries: 2, mempool: 32784 B
2020-05-27 19:52:00 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec www.wilda.0skar.cz
2020-05-27 19:52:00 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 40639
2020-05-27 19:52:00 notice resolver-debug[]: ;www.wilda.0skar.cz. IN A
2020-05-27 19:52:00 notice resolver-debug[]: www.wilda.0skar.cz. 3600 IN CNAME flexi.oskarcz.net.
2020-05-27 19:52:00 notice resolver-debug[]: www.wilda.0skar.cz. 3600 IN RRSIG CNAME 13 4 3600 20200608202419 20200525185419 22377 0skar.cz. IbWrlyclFOE5YTWKww7sAy6fE24A4s6bad99eWyhLOMxBhMqaHcULRXG JrUdYIZ/GKeZUPNFFHZwK6pxWE2BUQ==
2020-05-27 19:52:00 notice resolver-debug[]: ;; Query time: 14 msec
2020-05-27 19:52:00 notice resolver-debug[]: ;; MSG SIZE rcvd: 322
2020-05-27 19:52:00 info kresd[30062]: [00000.00][plan] plan '
.wilda.rhybar.ecdsa.0skar.cz.’ type ‘A’ uid [14170.00]
2020-05-27 19:52:00 info kresd[30062]: [14170.00][iter] '
.wilda.rhybar.ecdsa.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [14170.01][cach] => no NSEC
2020-05-27 19:52:00 info kresd[30062]: [14170.01][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:00 info kresd[2679]: Last message ‘[14170.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:00 info kresd[30062]: [14170.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:00 info kresd[30062]: [14170.01][zcut] found cut: 0skar.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:00 info kresd[30062]: [14170.01][resl] => id: ‘38927’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘0skar.cz.’ qname: ‘eCDsA.0sKaR.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [14170.01][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 38927
2020-05-27 19:52:00 info kresd[30062]: ecdsa.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: ecdsa.0skar.cz. 300 NS flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: ecdsa.0skar.cz. 300 RRSIG NS 14 3 300 19031125173144 20150718171608 26277 ecdsa.0skar.cz. /XYewUwLOMEvmT2bXtckrfKSA0llkmYUe4T3PyGbfYRtvjhkGiHGYSOg9s05m4I0ZPWjQf2awKuKOhb4xlvnoPAHf9B6xlQGLYBiG8IqIsJ1bAGXOhVnGEJf9nK/YnU5
2020-05-27 19:52:00 info kresd[30062]: [14170.01][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [14170.01][iter] <= continuing with qname minimization
2020-05-27 19:52:00 info kresd[30062]: [14170.01][resl] <= server: ‘85.239.227.179’ rtt: 7 ms
2020-05-27 19:52:00 info kresd[30062]: [14170.01][iter] '
.wilda.rhybar.ecdsa.0skar.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [14170.02][resl] => id: ‘43531’ querying: ‘85.239.227.179#00053’ score: 11 zone cut: ‘ecdsa.0skar.cz.’ qname: ‘RhYbAR.EcDSA.0sKar.CZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[2679]: Last message ‘[14170.02][resl] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:00 info kresd[30062]: [14170.02][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 43531
2020-05-27 19:52:00 info kresd[30062]: rhybar.ecdsa.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: rhybar.ecdsa.0skar.cz. 300 NS flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: rhybar.ecdsa.0skar.cz. 300 RRSIG NS 14 4 300 19031125173144 20150718171320 17611 rhybar.ecdsa.0skar.cz. dQZoFLDTIVONTXZ4Q+OtT5DNH5xCEKkYpGBswCZOeIdzUXhnTp+RpQxmOSRsK/g5r0RcmSoJrp251ioUsfPc/tg2/CpxtVGbFSXqBJYgGQOMEvDyDFRBwkXKDWzerf1D
2020-05-27 19:52:00 info kresd[30062]: [14170.02][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [14170.02][iter] <= continuing with qname minimization
2020-05-27 19:52:00 info kresd[30062]: [14170.02][resl] <= server: ‘85.239.227.179’ rtt: 36 ms
2020-05-27 19:52:00 info kresd[30062]: [14170.02][iter] '
.wilda.rhybar.ecdsa.0skar.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [14170.03][resl] => id: ‘47664’ querying: ‘37.205.10.41#00053’ score: 15 zone cut: ‘rhybar.ecdsa.0skar.cz.’ qname: ‘wIldA.RHybar.EcdSa.0SKar.cZ.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [14170.03][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 47664
2020-05-27 19:52:00 info kresd[30062]: ;; Flags: qr QUERY: 1; ANSWER: 0; AUTHORITY: 3; ADDITIONAL: 1
2020-05-27 19:52:00 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:52:00 info kresd[30062]: wilda.rhybar.ecdsa.0skar.cz. NS
2020-05-27 19:52:00 info kresd[30062]: ecdsa.0skar.cz. 3600 NS flexi.oskarcz.net.
2020-05-27 19:52:00 info kresd[30062]: ecdsa.0skar.cz. 3600 DS 26277 14 2 EAD0667D089E3F33836A6EB266D61428FC9F559C6C56A08102F6367E0F10B2D5
2020-05-27 19:52:00 info kresd[30062]: ecdsa.0skar.cz. 3600 RRSIG DS 13 3 3600 20200608202419 20200525185419 22377 0skar.cz. pNOghRrKA3CBBMhbj7iwBeXIy1VrQ2d2n+dx1iFy9Z/U83GT6ENAfE4Ywhu5EN87Z9CO9JGNCpHxXPfglM3VNw==
2020-05-27 19:52:00 info kresd[30062]: [14170.03][iter] <= authority: ns outside bailiwick
2020-05-27 19:52:00 info kresd[30062]: [14170.03][iter] '
.wilda.rhybar.ecdsa.0skar.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [14170.04][resl] => id: ‘29161’ querying: ‘85.239.227.179#00053’ score: 23 zone cut: ‘rhybar.ecdsa.0skar.cz.’ qname: ‘wILDa.rHybaR.EcdSA.0SKar.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [14170.04][resl] => id: ‘29161’ querying: ‘2a01:430:17:1::ffff:205#00053’ score: 23 zone cut: ‘rhybar.ecdsa.0skar.cz.’ qname: ‘wILDa.rHybaR.EcdSA.0SKar.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [14170.04][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 29161
2020-05-27 19:52:00 info kresd[30062]: rhybar.ecdsa.0skar.cz. 300 SOA flexi.oskarcz.net. hostmaster.oskarcz.net. 1437243200 3600 900 1814400 3600
2020-05-27 19:52:00 info kresd[30062]: .wild.rhybar.ecdsa.0skar.cz. 3600 NSEC .wilda.rhybar.ecdsa.0skar.cz. CNAME RRSIG NSEC
2020-05-27 19:52:00 info kresd[30062]: .wilda.rhybar.ecdsa.0skar.cz. 3600 NSEC .wildt.rhybar.ecdsa.0skar.cz. A AAAA RRSIG NSEC
2020-05-27 19:52:00 info kresd[30062]: rhybar.ecdsa.0skar.cz. 300 RRSIG SOA 14 4 300 19031125173144 20150718171320 17611 rhybar.ecdsa.0skar.cz. usTCT2SCZZ+qaQt9l+5cX9vuIJ9Q+KBsIjS5Spr9HSfhY7XCrzzjv0y81FLSkD+YbQ/PvMaXG/uh/8Q2FXs/ULuA+ap96WA3UpMBEFpzjN+MH0/Gf8GmbIzSwV7dGJbH
2020-05-27 19:52:00 info kresd[30062]: .wild.rhybar.ecdsa.0skar.cz. 3600 RRSIG NSEC 14 5 3600 19031125173144 20150718171320 17611 rhybar.ecdsa.0skar.cz. NFWnU2eCh+mGdID2C4JVeRFMHgwrAqMJ9QovlEXiwzucgnwyktKb8/0ZijlvkpGdu6uAWV6l3qcM2u/+LmDblxnyiuLHXh/5fTW7/3QqxXmTDuBMootbZTw/OlWOr6l5
2020-05-27 19:52:00 info kresd[30062]: .wilda.rhybar.ecdsa.0skar.cz. 3600 RRSIG NSEC 14 5 3600 19031125173144 20150718171320 17611 rhybar.ecdsa.0skar.cz. qztLkRIxsJ39XLkV7trop5mAv6YD91HhLaDhxvcoOiqnvtyUogl+iivRFV5zBCXMHWKhDZi3gwi8ZSsWTVYLfXTJttH7ChR7SIK2dyRL83RUKmbXU43imv0e5pxPy1xC
2020-05-27 19:52:00 info kresd[30062]: [14170.04][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [14170.04][iter] <= retrying with non-minimized name
2020-05-27 19:52:00 info kresd[30062]: [14170.04][cach] => stashed packet: rank 020, TTL 300, NS wilda.rhybar.ecdsa.0skar.cz. (690 B)
2020-05-27 19:52:00 info kresd[30062]: [14170.04][resl] <= server: ‘85.239.227.179’ rtt: 38 ms
2020-05-27 19:52:00 info kresd[30062]: [14170.04][iter] '
.wilda.rhybar.ecdsa.0skar.cz.’ type ‘A’ new uid was assigned .05, parent uid .00
2020-05-27 19:52:00 info kresd[30062]: [14170.05][resl] => id: ‘42427’ querying: ‘85.239.227.179#00053’ score: 30 zone cut: ‘rhybar.ecdsa.0skar.cz.’ qname: '
.wILDa.RhyBaR.EcDSA.0skar.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:00 info kresd[30062]: [14170.05][iter] <= answer received:
2020-05-27 19:52:00 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 42427
2020-05-27 19:52:00 info kresd[30062]: .wilda.rhybar.ecdsa.0skar.cz. A
2020-05-27 19:52:00 info kresd[30062]: .wilda.rhybar.ecdsa.0skar.cz. 300 A 85.239.227.179
2020-05-27 19:52:00 info kresd[30062]: .wilda.rhybar.ecdsa.0skar.cz. 300 RRSIG A 14 5 300 19031125173144 20150718171320 17611 rhybar.ecdsa.0skar.cz. 5DYvvmw7BBLJEsbWD1sTS2pGBoFzb/C32TILLEzJdEeJ/BnwmfEA388x1p5+sDHCgb94GRsL7Of/yY/kcSXziieEjl+CpK80ljKqzWFFE3UqSVLS4FsgBmUrxUZ0/3H8
2020-05-27 19:52:00 info kresd[30062]: [14170.05][iter] <= rcode: NOERROR
2020-05-27 19:52:00 info kresd[30062]: [14170.05][cach] => stashed .wilda.rhybar.ecdsa.0skar.cz. A, rank 020, 160 B total, incl. 1 RRSIGs
2020-05-27 19:52:00 info kresd[30062]: [14170.05][resl] <= server: ‘85.239.227.179’ rtt: 9 ms
2020-05-27 19:52:00 info kresd[30062]: [14170.05][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:00 info kresd[30062]: [14170.05][resl] finished: 0, queries: 1, mempool: 32784 B
2020-05-27 19:52:00 notice resolver-debug[]: ; <<>> DiG 9.12.4-P2 <<>> @127.0.0.1 +dnssec .wilda.rhybar.ecdsa.0skar.cz
2020-05-27 19:52:00 notice resolver-debug[]: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14170
2020-05-27 19:52:00 notice resolver-debug[]: ;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
.wilda.rhybar.ecdsa.0skar.cz. IN A
2020-05-27 19:52:00 notice resolver-debug[]: .wilda.rhybar.ecdsa.0skar.cz. 300 IN A 85.239.227.179
2020-05-27 19:52:00 notice resolver-debug[]: .wilda.rhybar.ecdsa.0skar.cz. 300 IN RRSIG A 14 5 300 20400101000000 20150718171320 17611 rhybar.ecdsa.0skar.cz. 5DYvvmw7BBLJEsbWD1sTS2pGBoFzb/C32TILLEzJdEeJ/BnwmfEA388x 1p5+sDHCgb94GRsL7Of/yY/kcSXziieEjl+CpK80ljKqzWFFE3UqSVLS 4FsgBmUrxUZ0/3H8
2020-05-27 19:52:00 notice resolver-debug[]: ;; Query time: 97 msec
2020-05-27 19:52:00 notice resolver-debug[]: ;; MSG SIZE rcvd: 223
2020-05-27 19:52:00 notice resolver-debug[]: Debug started
2020-05-27 19:52:01 info /usr/sbin/cron[30578]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2020-05-27 19:52:01 info /usr/sbin/cron[30579]: (root) CMD (nethist_stats.lua)
2020-05-27 19:52:03 info kresd[30062]: [00000.00][plan] plan ‘wpad.lan.’ type ‘A’ uid [29093.00]
2020-05-27 19:52:03 info kresd[30062]: [29093.00][iter] ‘wpad.lan.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:03 info kresd[30062]: [29093.01][cach] => satisfied by exact packet: rank 020, new TTL 64554
2020-05-27 19:52:03 info kresd[30062]: [29093.01][iter] <= answer received:
2020-05-27 19:52:03 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NXDOMAIN; id: 9599
2020-05-27 19:52:03 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 0; AUTHORITY: 6; ADDITIONAL: 1
2020-05-27 19:52:03 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:03 info kresd[30062]: ;; Version: 0; flags: ; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:52:03 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:03 info kresd[30062]: wpad.lan. A
2020-05-27 19:52:03 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:52:03 info kresd[30062]: . 64554 SOA a.root-servers.net. nstld.verisign-grs.com. 2020052700 1800 900 604800 86400
2020-05-27 19:52:03 info kresd[30062]: . 86400 RRSIG SOA 8 0 86400 20200609050000 20200527040000 48903 . QaIodaqhkIAR+yUXG8bqnfEJARfrN2xFRfKpDBU4iDiy6Q1smDygoJqmwt83LkA7u5H7p/eMi9piJc72f1Ffg5DfJtuKzlG7chserCb9DMc9w3wsoGXfPzordTmfOuZDMeHRwcc+iqOsgYsC9qfhXJ1fy6zfcP3xKhlc5Vz/lyt2gArrCeWU4BMR5LltFNrYsXse/Q1RVvzOJpnZu70FuEt9Iq9nCNcjaAQmfeLKWjRf8taXpWBUd2rEMxh8QfgiR9gX147t9Eai0j0koCQXxWwNJDx67gG/V711ndPp228/V2ANVf+UGLGKARLRCSXrAupy6+Dv4D0pGUw7ntLPRA==
2020-05-27 19:52:03 info kresd[30062]: . 64554 NSEC aaa. NS SOA RRSIG NSEC DNSKEY
2020-05-27 19:52:03 info kresd[30062]: . 86400 RRSIG NSEC 8 0 86400 20200609050000 20200527040000 48903 . Mxuj4gNssYOvFP/SSDexhexhoh0se30AbBXGi9yKgFsI0F5bw7B/BmBYw1xgOvFHf2ns0EkOWRbj86w9cyAOG3b7AbNZQWg2pVatNV2xy/w+sEken/duiP7T66UsSe4xFQPs5/qI6ikd/gXwQqNEQs8S9u/RKhL995q/vaBIBGqr8LF8EZxaf1A/R/L+VVMaGWvkyGCm0AiUftkgUga2CXydmxllK8KIvYTDUW5yUVhY6F55RQry1ENZzySubmnSJkTDpsv4n3kDdft3Fia0MxyeVXtGyUUDS1dTb9+E7nLyTQw6TFGG0yeaugG62bA2TMGFlaMlENYxLaryNG+/WQ==
2020-05-27 19:52:03 info kresd[30062]: lamer. 64554 NSEC lancaster. NS DS RRSIG NSEC
2020-05-27 19:52:03 info kresd[30062]: lamer. 86400 RRSIG NSEC 8 1 86400 20200609050000 20200527040000 48903 . S/v0tlC4/i5Hf0Aggr0Hk61vDhqqZqOqlQ/5QTHejRShMymuPUwdXgoO8IlQ3XqqSBv/f0hZNfgDMeo8sl7TVbFJomrjsF11oCoqPg/BG2GyHH3eZXtnuLdIj0cc/9VAnNbWeDF1lxx9Ha/mSnTrxL6hhYuCPDyxG7dEhwAzEGJb+fY/D30SZyNoMtbOMP+g/ikpgH7aNav+xh+dWAilkCV+GGzA4hHuG6tFFhadksqxGiD6hd/ukV4+0Ki2jTdVfOo5LxZQwGh1WH0QnjrvLMugAnuXMnzcQHchZNAPBl5yUCjzEZw+12PEH1e6YDq1LA/HtF7QNtH1tncP17pTqg==
2020-05-27 19:52:03 info kresd[30062]: [29093.01][iter] <= rcode: NXDOMAIN
2020-05-27 19:52:03 info kresd[30062]: [29093.01][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:03 info kresd[30062]: [29093.01][resl] finished: 0, queries: 1, mempool: 32784 B
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘sitecheck.opera.com.’ type ‘A’ uid [08539.00]
2020-05-27 19:52:08 info kresd[30062]: [08539.00][iter] ‘sitecheck.opera.com.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [08539.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 5
2020-05-27 19:52:08 info kresd[30062]: [08539.01][cach] => no NSEC
cached for zone: opera.com.
2020-05-27 19:52:08 info kresd[30062]: [08539.01][cach] => skipping zone: opera.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[08539.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [08539.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [08539.01][zcut] found cut: opera.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [08539.01][resl] => id: ‘31035’ querying: ‘185.26.183.160#00053’ score: 10 zone cut: ‘opera.com.’ qname: ‘SIteChECK.OpeRA.COm.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘www.sreality.cz.’ type ‘A’ uid [52197.00]
2020-05-27 19:52:08 info kresd[30062]: [52197.00][iter] ‘www.sreality.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [52197.01][cach] => skipping unfit CNAME RR: rank 020, new TTL -188
2020-05-27 19:52:08 info kresd[30062]: [52197.01][cach] => no NSEC
cached for zone: sreality.cz.
2020-05-27 19:52:08 info kresd[30062]: [52197.01][cach] => skipping zone: sreality.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[52197.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [52197.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [52197.01][zcut] found cut: sreality.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [52197.01][resl] => id: ‘40286’ querying: ‘2a02:598:3333::3#00053’ score: 10 zone cut: ‘sreality.cz.’ qname: ‘wwW.SreALitY.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [08539.01][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 31035
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 1; AUTHORITY: 6; ADDITIONAL: 7
2020-05-27 19:52:08 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:08 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:52:08 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:08 info kresd[30062]: sitecheck.opera.com. A
2020-05-27 19:52:08 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:08 info kresd[30062]: sitecheck.opera.com. 60 CNAME sitecheck.geo.opera.com.
2020-05-27 19:52:08 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:52:08 info kresd[30062]: geo.opera.com. 60 NS geo5.opera.technology.
2020-05-27 19:52:08 info kresd[30062]: geo.opera.com. 60 NS geo8.opera.technology.
2020-05-27 19:52:08 info kresd[30062]: geo.opera.com. 60 NS geo7.opera.technology.
2020-05-27 19:52:08 info kresd[30062]: geo.opera.com. 60 NS geo9.opera.technology.
2020-05-27 19:52:08 info kresd[30062]: geo.opera.com. 60 NS geo6.opera.technology.
2020-05-27 19:52:08 info kresd[30062]: geo.opera.com. 60 NS geo10.opera.technology.
2020-05-27 19:52:08 info kresd[30062]: ;; ADDITIONAL SECTION
2020-05-27 19:52:08 info kresd[30062]: geo5.opera.technology. 3600 A 107.167.110.153
2020-05-27 19:52:08 info kresd[30062]: geo6.opera.technology. 3600 A 185.26.182.77
2020-05-27 19:52:08 info kresd[30062]: geo7.opera.technology. 3600 A 185.26.182.91
2020-05-27 19:52:08 info kresd[30062]: geo8.opera.technology. 3600 A 107.167.110.154
2020-05-27 19:52:08 info kresd[30062]: geo9.opera.technology. 3600 A 185.26.182.102
2020-05-27 19:52:08 info kresd[30062]: geo10.opera.technology. 3600 A 82.145.216.11
2020-05-27 19:52:08 info kresd[30062]: [08539.01][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [08539.01][iter] <= cname chain, following
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘sitecheck.geo.opera.com.’ type ‘A’ uid [08539.02]
2020-05-27 19:52:08 info kresd[30062]: [08539.01][cach] => stashed sitecheck.opera.com. CNAME, rank 020, 42 B total, incl. 0 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [08539.01][cach] => stashed geo.opera.com. NS, rank 002, 170 B total, incl. 0 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [08539.01][resl] <= server: ‘185.26.183.160’ rtt: 20 ms
2020-05-27 19:52:08 info kresd[30062]: [08539.02][iter] ‘sitecheck.geo.opera.com.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [08539.03][cach] => skipping unfit CNAME RR: rank 020, new TTL 5
2020-05-27 19:52:08 info kresd[30062]: [08539.03][cach] => no NSEC
cached for zone: geo.opera.com.
2020-05-27 19:52:08 info kresd[30062]: [08539.03][cach] => skipping zone: geo.opera.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[08539.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [08539.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [08539.03][zcut] found cut: geo.opera.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [08539.03][resl] => id: ‘21948’ querying: ‘107.167.110.154#00053’ score: 10 zone cut: ‘geo.opera.com.’ qname: ‘siTECHECK.Geo.OPErA.COm.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [52197.01][resl] => id: ‘40286’ querying: ‘77.75.74.80#00053’ score: 10 zone cut: ‘sreality.cz.’ qname: ‘wwW.SreALitY.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [08539.03][resl] => id: ‘21948’ querying: ‘107.167.110.153#00053’ score: 10 zone cut: ‘geo.opera.com.’ qname: ‘siTECHECK.Geo.OPErA.COm.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [08539.03][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 21948
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 1; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:08 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1680 B; ext-rcode: Unused
2020-05-27 19:52:08 info kresd[30062]: sitecheck.geo.opera.com. A
2020-05-27 19:52:08 info kresd[30062]: sitecheck.geo.opera.com. 60 CNAME nl.sitecheck.opera.com.
2020-05-27 19:52:08 info kresd[30062]: [08539.03][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [08539.03][iter] <= cname chain, following
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘nl.sitecheck.opera.com.’ type ‘A’ uid [08539.04]
2020-05-27 19:52:08 info kresd[30062]: [08539.03][cach] => stashed sitecheck.geo.opera.com. CNAME, rank 020, 40 B total, incl. 0 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [08539.03][resl] <= server: ‘107.167.110.154’ rtt: 103 ms
2020-05-27 19:52:08 info kresd[30062]: [08539.03][resl] <= server: ‘107.167.110.153’ rtt: >= 3 ms
2020-05-27 19:52:08 info kresd[30062]: [08539.04][iter] ‘nl.sitecheck.opera.com.’ type ‘A’ new uid was assigned .05, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [08539.05][cach] => satisfied by exact RRset: rank 020, new TTL 5
2020-05-27 19:52:08 info kresd[30062]: [08539.05][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 37355
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
2020-05-27 19:52:08 info kresd[30062]: nl.sitecheck.opera.com. A
2020-05-27 19:52:08 info kresd[30062]: nl.sitecheck.opera.com. 5 A 185.26.182.106
2020-05-27 19:52:08 info kresd[30062]: nl.sitecheck.opera.com. 5 A 185.26.182.118
2020-05-27 19:52:08 info kresd[30062]: [08539.05][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [08539.05][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘nl.sitecheck.opera.com.’ type ‘A’ uid [65564.00]
2020-05-27 19:52:08 info kresd[30062]: [65564.00][iter] ‘nl.sitecheck.opera.com.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [65564.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [65564.01][zcut] found cut: opera.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [65564.01][resl] => id: ‘01195’ querying: ‘107.167.127.230#00053’ score: 10 zone cut: ‘opera.com.’ qname: ‘SITecheCk.oPeRa.Com.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [08539.05][resl] finished: 0, queries: 3, mempool: 32784 B
2020-05-27 19:52:08 info kresd[30062]: [52197.01][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 40286
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 5; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:08 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:52:08 info kresd[30062]: www.sreality.cz. A
2020-05-27 19:52:08 info kresd[30062]: www.sreality.cz. 300 CNAME sreality.cz.
2020-05-27 19:52:08 info kresd[30062]: sreality.cz. 300 A 77.75.77.146
2020-05-27 19:52:08 info kresd[30062]: sreality.cz. 300 A 77.75.79.146
2020-05-27 19:52:08 info kresd[30062]: www.sreality.cz. 300 RRSIG CNAME 13 3 300 20200609101354 20200526084354 54346 sreality.cz. OKo5ct8ZrwXY9sBQEKsXKR4EMx/gnD+D0sPoGaeaOvv1IWeLdml2kB/rd2Lx4zL0/Z6RxFJ4b32zgVQ+hAxIRg==
2020-05-27 19:52:08 info kresd[30062]: sreality.cz. 300 RRSIG A 13 2 300 20200609101354 20200526084354 54346 sreality.cz. DDldiMRawkPTyPPow43NFn2FeQlPwbqyjRVds5GMle4YPvEH+YRbTF0xrHLIydf4dc4lLww5BLJ4M5+BApDhAg==
2020-05-27 19:52:08 info kresd[30062]: [52197.01][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [52197.01][iter] <= cname chain, following
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘sreality.cz.’ type ‘A’ uid [52197.02]
2020-05-27 19:52:08 info kresd[30062]: [52197.01][cach] => stashed www.sreality.cz. CNAME, rank 020, 128 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [52197.01][resl] <= server: ‘2a02:598:3333::3’ rtt: >= 128 ms
2020-05-27 19:52:08 info kresd[30062]: [52197.01][resl] <= server: ‘77.75.74.80’ rtt: 28 ms
2020-05-27 19:52:08 info kresd[30062]: [52197.02][iter] ‘sreality.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [52197.03][cach] => skipping exact RR: rank 020 (min. 020), new TTL -188
2020-05-27 19:52:08 info kresd[30062]: [52197.03][cach] => no NSEC
2020-05-27 19:52:08 info kresd[30062]: [52197.03][cach] => skipping zone: sreality.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[52197.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [52197.03][zcut] found cut: sreality.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] => id: ‘56730’ querying: ‘2a02:598:4444::4#00053’ score: 10 zone cut: ‘sreality.cz.’ qname: ‘Sreality.cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [65564.01][resl] => id: ‘01195’ querying: ‘103.83.123.78#00053’ score: 10 zone cut: ‘opera.com.’ qname: ‘SITecheCk.oPeRa.Com.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] => id: ‘56730’ querying: ‘77.75.75.230#00053’ score: 10 zone cut: ‘sreality.cz.’ qname: ‘Sreality.cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [52197.03][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 56730
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:08 info kresd[30062]: sreality.cz. A
2020-05-27 19:52:08 info kresd[30062]: sreality.cz. 300 RRSIG A 13 2 300 20200609101354 20200526084354 54346 sreality.cz. n98tG1ldQKNrCNtHpxhg72LwtApgS5pfLdMXbjgzJSI+yJdkS+8rT/Vh+xcfCBtOygzqsSavg5McODwH110Piw==
2020-05-27 19:52:08 info kresd[30062]: [52197.03][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [52197.03][cach] => stashed sreality.cz. A, rank 020, 124 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] <= server: ‘2a02:598:4444::4’ rtt: >= 138 ms
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] <= server: ‘77.75.75.230’ rtt: 38 ms
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:08 info kresd[30062]: [52197.03][resl] finished: 0, queries: 2, mempool: 16392 B
2020-05-27 19:52:08 info kresd[30062]: [65564.01][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 1195
2020-05-27 19:52:08 info kresd[30062]: sitecheck.opera.com. NS
2020-05-27 19:52:08 info kresd[30062]: [65564.01][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [65564.01][iter] <= retrying with non-minimized name
2020-05-27 19:52:08 info kresd[30062]: [65564.01][resl] <= server: ‘107.167.127.230’ rtt: 187 ms
2020-05-27 19:52:08 info kresd[30062]: [65564.01][resl] <= server: ‘103.83.123.78’ rtt: >= 87 ms
2020-05-27 19:52:08 info kresd[30062]: [65564.01][iter] ‘nl.sitecheck.opera.com.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [65564.02][resl] => id: ‘54929’ querying: ‘185.26.183.160#00053’ score: 20 zone cut: ‘opera.com.’ qname: ‘nl.siTEcHEck.OpeRA.Com.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [65564.02][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 54929
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 2; AUTHORITY: 4; ADDITIONAL: 6
2020-05-27 19:52:08 info kresd[30062]: nl.sitecheck.opera.com. 60 A 185.26.182.106
2020-05-27 19:52:08 info kresd[30062]: nl.sitecheck.opera.com. 60 A 185.26.182.118
2020-05-27 19:52:08 info kresd[30062]: opera.com. 604800 NS nic4.opera.com.
2020-05-27 19:52:08 info kresd[30062]: opera.com. 604800 NS nic1.opera.com.
2020-05-27 19:52:08 info kresd[30062]: opera.com. 604800 NS nic3.opera.com.
2020-05-27 19:52:08 info kresd[30062]: opera.com. 604800 NS nic2.opera.no.
2020-05-27 19:52:08 info kresd[30062]: nic1.opera.com. 86400 A 185.26.183.160
2020-05-27 19:52:08 info kresd[30062]: nic2.opera.no. 86400 A 37.228.109.145
2020-05-27 19:52:08 info kresd[30062]: nic3.opera.com. 3600 A 103.83.123.78
2020-05-27 19:52:08 info kresd[30062]: nic4.opera.com. 300 A 107.167.127.230
2020-05-27 19:52:08 info kresd[30062]: nic1.opera.com. 86400 AAAA 2001:4c28:4000:727:185:26:183:160
2020-05-27 19:52:08 info kresd[30062]: [65564.02][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [65564.02][cach] => stashed nl.sitecheck.opera.com. A, rank 020, 26 B total, incl. 0 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [65564.02][cach] => not overwriting NS opera.com.
2020-05-27 19:52:08 info kresd[30062]: [65564.02][resl] <= server: ‘185.26.183.160’ rtt: 26 ms
2020-05-27 19:52:08 info kresd[30062]: [65564.02][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:08 info kresd[30062]: [65564.02][resl] finished: 0, queries: 1, mempool: 81936 B
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘ssp.imedia.cz.’ type ‘A’ uid [33126.00]
2020-05-27 19:52:08 info kresd[30062]: [33126.00][iter] ‘ssp.imedia.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => skipping exact RR: rank 020 (min. 020), new TTL -394
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => skipping unfit NS RR: rank 002, new TTL -291
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => no NSEC
cached for zone: cz.
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[33126.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [33126.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [33126.01][zcut] found cut: cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [33126.01][resl] => id: ‘09583’ querying: ‘194.0.12.1#00053’ score: 11 zone cut: ‘cz.’ qname: ‘imEDia.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘d53-a.sdn.cz.’ type ‘A’ uid [13452.00]
2020-05-27 19:52:08 info kresd[30062]: [13452.00][iter] ‘d53-a.sdn.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [13452.01][cach] => skipping unfit CNAME RR: rank 020, new TTL -458
2020-05-27 19:52:08 info kresd[30062]: [13452.01][cach] => no NSEC
cached for zone: sdn.cz.
2020-05-27 19:52:08 info kresd[30062]: [13452.01][cach] => skipping zone: sdn.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[13452.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [13452.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [13452.01][zcut] found cut: sdn.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [13452.01][resl] => id: ‘57940’ querying: ‘77.75.74.80#00053’ score: 28 zone cut: ‘sdn.cz.’ qname: ‘D53-a.Sdn.CZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [33126.01][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 9583
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr QUERY: 1; ANSWER: 0; AUTHORITY: 4; ADDITIONAL: 5
2020-05-27 19:52:08 info kresd[30062]: imedia.cz. NS
2020-05-27 19:52:08 info kresd[30062]: imedia.cz. 3600 NS ams.seznam.cz.
2020-05-27 19:52:08 info kresd[30062]: imedia.cz. 3600 NS ans.seznam.cz.
2020-05-27 19:52:08 info kresd[30062]: imedia.cz. 3600 DS 51575 13 2 F710049BA2A7306CA186A003A9FF9D4A06B4F6A503C7ADB1DC399D997A8A0451
2020-05-27 19:52:08 info kresd[30062]: imedia.cz. 3600 RRSIG DS 13 2 3600 20200606111511 20200523210543 44987 cz. b1DIMRMuILbjhC5fBi4dIdD9gjVrk9vp5Vendhgme7EodukDGYOtP+UmZJT19hEw98gL0VSbzsC57qM9hIBUWQ==
2020-05-27 19:52:08 info kresd[30062]: ams.seznam.cz. 3600 A 77.75.75.230
2020-05-27 19:52:08 info kresd[30062]: ams.seznam.cz. 3600 AAAA 2a02:598:4444::4
2020-05-27 19:52:08 info kresd[30062]: ans.seznam.cz. 3600 A 77.75.74.80
2020-05-27 19:52:08 info kresd[30062]: ans.seznam.cz. 3600 AAAA 2a02:598:3333::3
2020-05-27 19:52:08 info kresd[30062]: [33126.01][iter] <= loaded 4 glue addresses
2020-05-27 19:52:08 info kresd[30062]: [33126.01][iter] <= referral response, follow
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => stashed imedia.cz. DS, rank 020, 140 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => stashed imedia.cz. NS, rank 002, 50 B total, incl. 0 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => not overwriting AAAA ans.seznam.cz.
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => not overwriting A ans.seznam.cz.
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => not overwriting AAAA ams.seznam.cz.
2020-05-27 19:52:08 info kresd[30062]: [33126.01][cach] => not overwriting A ams.seznam.cz.
2020-05-27 19:52:08 info kresd[30062]: [33126.01][resl] <= server: ‘194.0.12.1’ rtt: 9 ms
2020-05-27 19:52:08 info kresd[30062]: [33126.01][iter] ‘ssp.imedia.cz.’ type ‘A’ new uid was assigned .02, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [33126.02][resl] => id: ‘54267’ querying: ‘77.75.74.80#00053’ score: 28 zone cut: ‘imedia.cz.’ qname: ‘ssp.ImEdiA.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [13452.01][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 57940
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:08 info kresd[30062]: d53-a.sdn.cz. A
2020-05-27 19:52:08 info kresd[30062]: d53-a.sdn.cz. 30 CNAME ko.sdn.szn.cz.
2020-05-27 19:52:08 info kresd[30062]: d53-a.sdn.cz. 30 RRSIG CNAME 13 3 30 20200610163422 20200527150422 44072 sdn.cz. ZQMDcH7TcKHOi8EgCjltFtMv3AgflASmmzY+huugWHxAizOrhFHa36f0PwLR3A13Lg1LBMpWT5PgEdbDxiQ/uA==
2020-05-27 19:52:08 info kresd[30062]: [13452.01][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [13452.01][iter] <= cname chain, following
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘ko.sdn.szn.cz.’ type ‘A’ uid [13452.02]
2020-05-27 19:52:08 info kresd[30062]: [13452.01][cach] => stashed d53-a.sdn.cz. CNAME, rank 020, 124 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [13452.01][resl] <= server: ‘77.75.74.80’ rtt: 21 ms
2020-05-27 19:52:08 info kresd[30062]: [13452.02][iter] ‘ko.sdn.szn.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [13452.03][cach] => skipping exact RR: rank 020 (min. 020), new TTL -458
2020-05-27 19:52:08 info kresd[30062]: [13452.03][cach] => skipping unfit NS packet: rank 020, new TTL -188
2020-05-27 19:52:08 info kresd[30062]: [13452.03][cach] => no NSEC
cached for zone: szn.cz.
2020-05-27 19:52:08 info kresd[30062]: [13452.03][cach] => skipping zone: szn.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[13452.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [13452.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [13452.03][zcut] found cut: szn.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [13452.03][resl] => id: ‘17915’ querying: ‘77.75.74.80#00053’ score: 24 zone cut: ‘szn.cz.’ qname: ‘Sdn.szN.cz.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [33126.02][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 54267
2020-05-27 19:52:08 info kresd[30062]: ssp.imedia.cz. A
2020-05-27 19:52:08 info kresd[30062]: ssp.imedia.cz. 300 A 77.75.79.43
2020-05-27 19:52:08 info kresd[30062]: ssp.imedia.cz. 300 A 77.75.77.43
2020-05-27 19:52:08 info kresd[30062]: ssp.imedia.cz. 300 RRSIG A 13 3 300 20200605111328 20200522094328 41109 imedia.cz. njLjiHoXGIHmBKDDJFdmKYg+472706NOQEg8kWCBDH2tTfQzn8q/KvGycFYjC8K2U3/WBGUDLE3AgCYcFpBtxg==
2020-05-27 19:52:08 info kresd[30062]: [33126.02][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [33126.02][cach] => stashed ssp.imedia.cz. A, rank 020, 122 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [33126.02][resl] <= server: ‘77.75.74.80’ rtt: 26 ms
2020-05-27 19:52:08 info kresd[30062]: [33126.02][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:08 info kresd[30062]: [33126.02][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:08 info kresd[30062]: [13452.03][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 17915
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 4; ADDITIONAL: 1
2020-05-27 19:52:08 info kresd[30062]: sdn.szn.cz. NS
2020-05-27 19:52:08 info kresd[30062]: szn.cz. 300 SOA ans.seznam.cz. hostmaster.szn.cz. 2016428347 60 30 604800 300
2020-05-27 19:52:08 info kresd[30062]: 0emaldccrli0a7f3gcot6br1hucrsnkk.szn.cz. 300 NSEC3 1 0 10 20B2B039EC94B4EF 0esl0irpk09vhn7lakpam64el5kqdbco A MX TXT AAAA RRSIG
2020-05-27 19:52:08 info kresd[30062]: szn.cz. 300 RRSIG SOA 13 2 300 20200610163431 20200527150431 3119 szn.cz. Oan2FrhSlY2UkmcEF6MnwjbsEjxUONKSXfDdCiSLrMZ/qmuAxbxnQ86Uh+DRO2ptChdEJebFTn7AXmhZxy6mDQ==
2020-05-27 19:52:08 info kresd[30062]: 0emaldccrli0a7f3gcot6br1hucrsnkk.szn.cz. 300 RRSIG NSEC3 13 3 300 20200610163431 20200527150431 3119 szn.cz. fpV4pDsW8HwrECwyV9VMj6OuDo9wcHCT9NB9eqF3xyVm9hE7PYtfRGqnQYUayXbf1/XG3yhcuWpRVeY8dhDAww==
2020-05-27 19:52:08 info kresd[30062]: [13452.03][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [13452.03][iter] <= retrying with non-minimized name
2020-05-27 19:52:08 info kresd[30062]: [13452.03][cach] => stashed packet: rank 020, TTL 300, NS sdn.szn.cz. (404 B)
2020-05-27 19:52:08 info kresd[30062]: [13452.03][resl] <= server: ‘77.75.74.80’ rtt: 20 ms
2020-05-27 19:52:08 info kresd[30062]: [13452.03][iter] ‘ko.sdn.szn.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [13452.04][resl] => id: ‘30715’ querying: ‘77.75.74.80#00053’ score: 22 zone cut: ‘szn.cz.’ qname: ‘kO.SdN.Szn.CZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [13452.04][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 30715
2020-05-27 19:52:08 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 8; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. A
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.139
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.132
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.133
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.134
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.136
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.137
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 A 77.75.74.138
2020-05-27 19:52:08 info kresd[30062]: ko.sdn.szn.cz. 30 RRSIG A 13 4 30 20200610163431 20200527150431 3119 szn.cz. ELTqXw9cxJ0jXLRdovxyGd5Mq8vODJc4XQYNcFMlrT/Zxt02VNDqDIy0l7CejXkDQGCjZsjvg573Tl7ohDNcBA==
2020-05-27 19:52:08 info kresd[30062]: [13452.04][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [13452.04][cach] => stashed ko.sdn.szn.cz. A, rank 020, 148 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [13452.04][resl] <= server: ‘77.75.74.80’ rtt: 22 ms
2020-05-27 19:52:08 info kresd[30062]: [13452.04][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:08 info kresd[30062]: [13452.04][resl] finished: 0, queries: 2, mempool: 16392 B
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘www.google-analytics.com.’ type ‘A’ uid [12518.00]
2020-05-27 19:52:08 info kresd[30062]: [12518.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘www.google-analytics.com.’ type ‘A’ uid [05500.00]
2020-05-27 19:52:08 info kresd[30062]: [05500.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:08 info kresd[30062]: [00000.00][plan] plan ‘login.szn.cz.’ type ‘A’ uid [47272.00]
2020-05-27 19:52:08 info kresd[30062]: [47272.00][iter] ‘login.szn.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:08 info kresd[30062]: [47272.01][cach] => skipping exact RR: rank 020 (min. 020), new TTL -188
2020-05-27 19:52:08 info kresd[30062]: [47272.01][cach] => no NSEC
2020-05-27 19:52:08 info kresd[30062]: [47272.01][cach] => skipping zone: szn.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:08 info kresd[2679]: Last message ‘[47272.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:08 info kresd[30062]: [47272.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:08 info kresd[30062]: [47272.01][zcut] found cut: szn.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:08 info kresd[30062]: [47272.01][resl] => id: ‘37679’ querying: ‘77.75.74.80#00053’ score: 22 zone cut: ‘szn.cz.’ qname: ‘LOgIN.Szn.cZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:08 info kresd[30062]: [47272.01][iter] <= answer received:
2020-05-27 19:52:08 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 37679
2020-05-27 19:52:08 info kresd[30062]: login.szn.cz. A
2020-05-27 19:52:08 info kresd[30062]: login.szn.cz. 300 A 77.75.78.55
2020-05-27 19:52:08 info kresd[30062]: login.szn.cz. 300 A 77.75.76.55
2020-05-27 19:52:08 info kresd[30062]: login.szn.cz. 300 RRSIG A 13 3 300 20200610163431 20200527150431 3119 szn.cz. ihGtUQdnJHZw28yQIbXKtcKbij+O6wcjCWW+ok+SArF4Cl7V0WeBlutiWo6GeNDeavWrfUMh/aDTNTPrYz2BYA==
2020-05-27 19:52:08 info kresd[30062]: [47272.01][iter] <= rcode: NOERROR
2020-05-27 19:52:08 info kresd[30062]: [47272.01][cach] => stashed login.szn.cz. A, rank 020, 118 B total, incl. 1 RRSIGs
2020-05-27 19:52:08 info kresd[30062]: [47272.01][resl] <= server: ‘77.75.74.80’ rtt: 20 ms
2020-05-27 19:52:08 info kresd[30062]: [47272.01][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:08 info kresd[30062]: [47272.01][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:09 info kresd[30062]: [00000.00][plan] plan ‘login.sreality.cz.’ type ‘A’ uid [54299.00]
2020-05-27 19:52:09 info kresd[30062]: [54299.00][iter] ‘login.sreality.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:09 info kresd[30062]: [54299.01][cach] => skipping unfit CNAME RR: rank 020, new TTL -188
2020-05-27 19:52:09 info kresd[30062]: [54299.01][cach] => no NSEC
2020-05-27 19:52:09 info kresd[30062]: [54299.01][cach] => skipping zone: sreality.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:09 info kresd[2679]: Last message ‘[54299.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:09 info kresd[30062]: [54299.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:09 info kresd[30062]: [54299.01][zcut] found cut: sreality.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:09 info kresd[30062]: [54299.01][resl] => id: ‘05259’ querying: ‘77.75.74.80#00053’ score: 21 zone cut: ‘sreality.cz.’ qname: ‘logiN.SReAlITY.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:09 info kresd[30062]: [54299.01][iter] <= answer received:
2020-05-27 19:52:09 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 5259
2020-05-27 19:52:09 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:09 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:09 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:52:09 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:09 info kresd[30062]: login.sreality.cz. A
2020-05-27 19:52:09 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:09 info kresd[30062]: login.sreality.cz. 300 CNAME login.szn.cz.
2020-05-27 19:52:09 info kresd[30062]: login.sreality.cz. 300 RRSIG CNAME 13 3 300 20200609101354 20200526084354 54346 sreality.cz. yXGOgA2p96G64jShgKHG2meL/F2QAuQjtQR4Oms3cHNsAIMgabYqgWODphV0uDL7LFTch+exzy75b/38Y/BBRA==
2020-05-27 19:52:09 info kresd[30062]: [54299.01][iter] <= rcode: NOERROR
2020-05-27 19:52:09 info kresd[30062]: [54299.01][iter] <= cname chain, following
2020-05-27 19:52:09 info kresd[30062]: [00000.00][plan] plan ‘login.szn.cz.’ type ‘A’ uid [54299.02]
2020-05-27 19:52:09 info kresd[30062]: [54299.01][cach] => stashed login.sreality.cz. CNAME, rank 020, 128 B total, incl. 1 RRSIGs
2020-05-27 19:52:09 info kresd[30062]: [54299.01][resl] <= server: ‘77.75.74.80’ rtt: 26 ms
2020-05-27 19:52:09 info kresd[30062]: [54299.02][iter] ‘login.szn.cz.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:09 info kresd[30062]: [54299.03][cach] => satisfied by exact RRset: rank 020, new TTL 299
2020-05-27 19:52:09 info kresd[30062]: [54299.03][iter] <= answer received:
2020-05-27 19:52:09 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 39605
2020-05-27 19:52:09 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
2020-05-27 19:52:09 info kresd[30062]: login.szn.cz. A
2020-05-27 19:52:09 info kresd[30062]: login.szn.cz. 299 A 77.75.76.55
2020-05-27 19:52:09 info kresd[30062]: login.szn.cz. 299 A 77.75.78.55
2020-05-27 19:52:09 info kresd[30062]: login.szn.cz. 300 RRSIG A 13 3 300 20200610163431 20200527150431 3119 szn.cz. ihGtUQdnJHZw28yQIbXKtcKbij+O6wcjCWW+ok+SArF4Cl7V0WeBlutiWo6GeNDeavWrfUMh/aDTNTPrYz2BYA==
2020-05-27 19:52:09 info kresd[30062]: [54299.03][iter] <= rcode: NOERROR
2020-05-27 19:52:09 info kresd[30062]: [54299.03][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:09 info kresd[30062]: [54299.03][resl] finished: 0, queries: 2, mempool: 16392 B
2020-05-27 19:52:09 info kresd[30062]: [00000.00][plan] plan ‘i.im.cz.’ type ‘A’ uid [42475.00]
2020-05-27 19:52:09 info kresd[30062]: [42475.00][iter] ‘i.im.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:09 info kresd[30062]: [42475.01][cach] => skipping exact RR: rank 020 (min. 020), new TTL -188
2020-05-27 19:52:09 info kresd[30062]: [42475.01][cach] => no NSEC
cached for zone: im.cz.
2020-05-27 19:52:09 info kresd[30062]: [42475.01][cach] => skipping zone: im.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:09 info kresd[2679]: Last message ‘[42475.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:09 info kresd[30062]: [42475.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:09 info kresd[30062]: [42475.01][zcut] found cut: im.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:09 info kresd[30062]: [42475.01][resl] => id: ‘17702’ querying: ‘77.75.74.80#00053’ score: 23 zone cut: ‘im.cz.’ qname: ‘I.im.CZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:09 info kresd[30062]: [42475.01][iter] <= answer received:
2020-05-27 19:52:09 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 17702
2020-05-27 19:52:09 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:09 info kresd[30062]: i.im.cz. A
2020-05-27 19:52:09 info kresd[30062]: i.im.cz. 300 A 77.75.76.2
2020-05-27 19:52:09 info kresd[30062]: i.im.cz. 300 A 77.75.78.2
2020-05-27 19:52:09 info kresd[30062]: i.im.cz. 300 RRSIG A 13 3 300 20200609101329 20200526084329 24964 im.cz. PE6N5Ve9Y9ev80HK4XaDaXJ7XAFnaNk3M8pL26/9Ob6m69bj9tRRwb1BzXklGgpwDo5PIWpkLNf1VMPUvPxNTQ==
2020-05-27 19:52:09 info kresd[30062]: [42475.01][iter] <= rcode: NOERROR
2020-05-27 19:52:09 info kresd[30062]: [42475.01][cach] => stashed i.im.cz. A, rank 020, 118 B total, incl. 1 RRSIGs
2020-05-27 19:52:09 info kresd[30062]: [42475.01][resl] <= server: ‘77.75.74.80’ rtt: 19 ms
2020-05-27 19:52:09 info kresd[30062]: [42475.01][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:09 info kresd[30062]: [42475.01][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:11 info kresd[30062]: [00000.00][plan] plan ‘h.imedia.cz.’ type ‘A’ uid [10378.00]
2020-05-27 19:52:11 info kresd[30062]: [10378.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:11 info kresd[30062]: [00000.00][plan] plan ‘1.im.cz.’ type ‘A’ uid [30084.00]
2020-05-27 19:52:11 info kresd[30062]: [30084.00][iter] ‘1.im.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:11 info kresd[30062]: [30084.01][cach] => skipping exact RR: rank 020 (min. 020), new TTL -191
2020-05-27 19:52:11 info kresd[30062]: [30084.01][cach] => no NSEC
2020-05-27 19:52:11 info kresd[30062]: [30084.01][cach] => skipping zone: im.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:11 info kresd[2679]: Last message ‘[30084.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:11 info kresd[30062]: [30084.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:11 info kresd[30062]: [30084.01][zcut] found cut: im.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:11 info kresd[30062]: [30084.01][resl] => id: ‘01179’ querying: ‘77.75.74.80#00053’ score: 21 zone cut: ‘im.cz.’ qname: ‘1.Im.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:11 info kresd[30062]: [00000.00][plan] plan ‘geo.seznam.cz.’ type ‘A’ uid [08994.00]
2020-05-27 19:52:11 info kresd[30062]: [08994.00][iter] ‘geo.seznam.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:11 info kresd[30062]: [08994.01][cach] => skipping exact RR: rank 020 (min. 020), new TTL -10385
2020-05-27 19:52:11 info kresd[30062]: [08994.01][cach] => no NSEC
cached for zone: seznam.cz.
2020-05-27 19:52:11 info kresd[30062]: [08994.01][cach] => skipping zone: seznam.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:11 info kresd[2679]: Last message ‘[08994.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:11 info kresd[30062]: [08994.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:11 info kresd[30062]: [08994.01][zcut] found cut: seznam.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:11 info kresd[30062]: [08994.01][resl] => id: ‘46453’ querying: ‘77.75.74.80#00053’ score: 21 zone cut: ‘seznam.cz.’ qname: ‘GEO.SeZnAM.CZ.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:11 info kresd[30062]: [00000.00][plan] plan ‘h.imedia.cz.’ type ‘A’ uid [60527.00]
2020-05-27 19:52:11 info kresd[30062]: [60527.00][resl] finished: 0, queries: 1, mempool: 32784 B
2020-05-27 19:52:11 info kresd[30062]: [30084.01][iter] <= answer received:
2020-05-27 19:52:11 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 1179
2020-05-27 19:52:11 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:11 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:11 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:52:11 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:11 info kresd[30062]: 1.im.cz. A
2020-05-27 19:52:11 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:11 info kresd[30062]: 1.im.cz. 300 A 77.75.78.22
2020-05-27 19:52:11 info kresd[30062]: 1.im.cz. 300 A 77.75.76.22
2020-05-27 19:52:11 info kresd[30062]: 1.im.cz. 300 RRSIG A 13 3 300 20200609101329 20200526084329 24964 im.cz. b+F5elPg4wtRQRms1Y9HFQJgEuXsy8lU04ORaQ7vxep/cYb/iMhHMBIogZ2xb0ZevY9MTAZYA/Jcz1DbR09X3w==
2020-05-27 19:52:11 info kresd[30062]: [30084.01][iter] <= rcode: NOERROR
2020-05-27 19:52:11 info kresd[30062]: [30084.01][cach] => stashed 1.im.cz. A, rank 020, 118 B total, incl. 1 RRSIGs
2020-05-27 19:52:11 info kresd[30062]: [30084.01][resl] <= server: ‘77.75.74.80’ rtt: 20 ms
2020-05-27 19:52:11 info kresd[30062]: [30084.01][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:11 info kresd[30062]: [30084.01][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:11 info kresd[30062]: [08994.01][iter] <= answer received:
2020-05-27 19:52:11 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 46453
2020-05-27 19:52:11 info kresd[30062]: geo.seznam.cz. A
2020-05-27 19:52:11 info kresd[30062]: geo.seznam.cz. 300 A 77.75.78.146
2020-05-27 19:52:11 info kresd[30062]: geo.seznam.cz. 300 A 77.75.76.146
2020-05-27 19:52:11 info kresd[30062]: geo.seznam.cz. 300 RRSIG A 13 3 300 20200610070656 20200527053656 36313 seznam.cz. +vdslEc9FXacep9d/4DDQ9Y86wh0kphfhUuHQM10CqCWIzhO9OFcoW8786Dmz2b1SLkngSZm/6ai3NN0R193ww==
2020-05-27 19:52:11 info kresd[30062]: [08994.01][iter] <= rcode: NOERROR
2020-05-27 19:52:11 info kresd[30062]: [08994.01][cach] => stashed geo.seznam.cz. A, rank 020, 122 B total, incl. 1 RRSIGs
2020-05-27 19:52:11 info kresd[30062]: [08994.01][resl] <= server: ‘77.75.74.80’ rtt: 20 ms
2020-05-27 19:52:11 info kresd[30062]: [08994.01][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:11 info kresd[30062]: [08994.01][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:11 info kresd[30062]: [00000.00][plan] plan ‘www.google-analytics.com.’ type ‘A’ uid [29678.00]
2020-05-27 19:52:11 info kresd[30062]: [29678.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:12 info kresd[30062]: [00000.00][plan] plan ‘h.imedia.cz.’ type ‘A’ uid [04636.00]
2020-05-27 19:52:12 info kresd[30062]: [04636.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:13 info kresd[30062]: [00000.00][plan] plan ‘www.google-analytics.com.’ type ‘A’ uid [51193.00]
2020-05-27 19:52:13 info kresd[30062]: [51193.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:13 info kresd[30062]: [00000.00][plan] plan ‘www.google-analytics.com.’ type ‘A’ uid [27732.00]
2020-05-27 19:52:13 info kresd[30062]: [27732.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:15 info kresd[30062]: [00000.00][plan] plan ‘www.centrum.cz.’ type ‘A’ uid [26416.00]
2020-05-27 19:52:15 info kresd[30062]: [26416.00][iter] ‘www.centrum.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:15 info kresd[30062]: [26416.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 256
2020-05-27 19:52:15 info kresd[30062]: [26416.01][cach] => no NSEC
cached for zone: centrum.cz.
2020-05-27 19:52:15 info kresd[30062]: [26416.01][cach] => skipping zone: centrum.cz., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:15 info kresd[2679]: Last message ‘[26416.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:15 info kresd[30062]: [26416.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:15 info kresd[30062]: [26416.01][zcut] found cut: centrum.cz. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:15 info kresd[30062]: [26416.01][resl] => id: ‘55262’ querying: ‘173.245.58.138#00053’ score: 10 zone cut: ‘centrum.cz.’ qname: ‘wWw.centRuM.Cz.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:15 info kresd[30062]: [26416.01][iter] <= answer received:
2020-05-27 19:52:15 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 55262
2020-05-27 19:52:15 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:15 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:15 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:52:15 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:15 info kresd[30062]: www.centrum.cz. A
2020-05-27 19:52:15 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:15 info kresd[30062]: www.centrum.cz. 300 CNAME d3ngxn1oh0qgdy.cloudfront.net.
2020-05-27 19:52:15 info kresd[30062]: www.centrum.cz. 300 RRSIG CNAME 13 3 300 20200528185215 20200526165215 34505 centrum.cz. YPgNk7BMiYMB/BifZUQwMkbLJfRMus9rdeegWGyIQV4NBDEk/nEGMkXgLiuSHFlha12GymiRqri3WhO7QXHCeA==
2020-05-27 19:52:16 info kresd[30062]: [26416.01][iter] <= rcode: NOERROR
2020-05-27 19:52:16 info kresd[30062]: [26416.01][iter] <= cname chain, following
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘d3ngxn1oh0qgdy.cloudfront.net.’ type ‘A’ uid [26416.02]
2020-05-27 19:52:16 info kresd[30062]: [26416.01][cach] => not overwriting CNAME www.centrum.cz.
2020-05-27 19:52:16 info kresd[30062]: [26416.01][resl] <= server: ‘173.245.58.138’ rtt: 19 ms
2020-05-27 19:52:16 info kresd[30062]: [26416.02][iter] ‘d3ngxn1oh0qgdy.cloudfront.net.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:16 info kresd[30062]: [26416.03][cach] => satisfied by exact RRset: rank 020, new TTL 16
2020-05-27 19:52:16 info kresd[30062]: [26416.03][iter] <= answer received:
2020-05-27 19:52:16 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 53212
2020-05-27 19:52:16 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
2020-05-27 19:52:16 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:16 info kresd[30062]: d3ngxn1oh0qgdy.cloudfront.net. A
2020-05-27 19:52:16 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:16 info kresd[30062]: d3ngxn1oh0qgdy.cloudfront.net. 16 A 52.222.167.53
2020-05-27 19:52:16 info kresd[30062]: d3ngxn1oh0qgdy.cloudfront.net. 16 A 52.222.167.89
2020-05-27 19:52:16 info kresd[30062]: d3ngxn1oh0qgdy.cloudfront.net. 16 A 52.222.167.170
2020-05-27 19:52:16 info kresd[30062]: d3ngxn1oh0qgdy.cloudfront.net. 16 A 52.222.167.173
2020-05-27 19:52:16 info kresd[30062]: [26416.03][iter] <= rcode: NOERROR
2020-05-27 19:52:16 info kresd[30062]: [26416.03][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:16 info kresd[30062]: [26416.03][resl] finished: 0, queries: 2, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘fonts.googleapis.com.’ type ‘A’ uid [28223.00]
2020-05-27 19:52:16 info kresd[30062]: [28223.00][iter] ‘fonts.googleapis.com.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:16 info kresd[30062]: [28223.01][cach] => satisfied by exact RRset: rank 020, new TTL 256
2020-05-27 19:52:16 info kresd[30062]: [28223.01][iter] <= answer received:
2020-05-27 19:52:16 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 32957
2020-05-27 19:52:16 info kresd[30062]: fonts.googleapis.com. A
2020-05-27 19:52:16 info kresd[30062]: fonts.googleapis.com. 256 A 216.58.201.106
2020-05-27 19:52:16 info kresd[30062]: [28223.01][iter] <= rcode: NOERROR
2020-05-27 19:52:16 info kresd[30062]: [28223.01][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:16 info kresd[30062]: [28223.01][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [39837.00]
2020-05-27 19:52:16 info kresd[30062]: [39837.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [38304.00]
2020-05-27 19:52:16 info kresd[30062]: [38304.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [47481.00]
2020-05-27 19:52:16 info kresd[30062]: [47481.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [20597.00]
2020-05-27 19:52:16 info kresd[30062]: [20597.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [54969.00]
2020-05-27 19:52:16 info kresd[30062]: [54969.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [15658.00]
2020-05-27 19:52:16 info kresd[30062]: [15658.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:16 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [04368.00]
2020-05-27 19:52:16 info kresd[30062]: [04368.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:18 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [43485.00]
2020-05-27 19:52:18 info kresd[30062]: [43485.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:18 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [41787.00]
2020-05-27 19:52:18 info kresd[30062]: [41787.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [13103.00]
2020-05-27 19:52:19 info kresd[30062]: [13103.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [52146.00]
2020-05-27 19:52:19 info kresd[30062]: [52146.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [04371.00]
2020-05-27 19:52:19 info kresd[30062]: [04371.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [56276.00]
2020-05-27 19:52:19 info kresd[30062]: [56276.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [22968.00]
2020-05-27 19:52:19 info kresd[30062]: [22968.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [08531.00]
2020-05-27 19:52:19 info kresd[30062]: [08531.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [22310.00]
2020-05-27 19:52:19 info kresd[30062]: [22310.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [64504.00]
2020-05-27 19:52:19 info kresd[30062]: [64504.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [52063.00]
2020-05-27 19:52:19 info kresd[30062]: [52063.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [01690.00]
2020-05-27 19:52:19 info kresd[30062]: [01690.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:19 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [05259.00]
2020-05-27 19:52:19 info kresd[30062]: [05259.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [19095.00]
2020-05-27 19:52:21 info kresd[30062]: [19095.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [09156.00]
2020-05-27 19:52:21 info kresd[30062]: [09156.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [15311.00]
2020-05-27 19:52:21 info kresd[30062]: [15311.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [59900.00]
2020-05-27 19:52:21 info kresd[30062]: [59900.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘speeddials.opera.com.’ type ‘A’ uid [26421.00]
2020-05-27 19:52:21 info kresd[30062]: [26421.00][iter] ‘speeddials.opera.com.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:21 info kresd[30062]: [26421.01][cach] => skipping unfit CNAME RR: rank 020, new TTL -2
2020-05-27 19:52:21 info kresd[30062]: [26421.01][cach] => no NSEC
2020-05-27 19:52:21 info kresd[30062]: [26421.01][cach] => skipping zone: opera.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:21 info kresd[2679]: Last message ‘[26421.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:21 info kresd[30062]: [26421.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:21 info kresd[30062]: [26421.01][zcut] found cut: opera.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:21 info kresd[30062]: [26421.01][resl] => id: ‘12497’ querying: ‘185.26.183.160#00053’ score: 23 zone cut: ‘opera.com.’ qname: ‘sPEEddiaLs.OPera.cOM.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [63950.00]
2020-05-27 19:52:21 info kresd[30062]: [63950.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [47205.00]
2020-05-27 19:52:21 info kresd[30062]: [47205.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [06390.00]
2020-05-27 19:52:21 info kresd[30062]: [06390.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [58066.00]
2020-05-27 19:52:21 info kresd[30062]: [58066.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [26421.01][iter] <= answer received:
2020-05-27 19:52:21 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 12497
2020-05-27 19:52:21 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 1; AUTHORITY: 6; ADDITIONAL: 7
2020-05-27 19:52:21 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:21 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:52:21 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:21 info kresd[30062]: speeddials.opera.com. A
2020-05-27 19:52:21 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:21 info kresd[30062]: speeddials.opera.com. 60 CNAME speeddials.geo.opera.com.
2020-05-27 19:52:21 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:52:21 info kresd[30062]: geo.opera.com. 60 NS geo8.opera.technology.
2020-05-27 19:52:21 info kresd[30062]: geo.opera.com. 60 NS geo10.opera.technology.
2020-05-27 19:52:21 info kresd[30062]: geo.opera.com. 60 NS geo7.opera.technology.
2020-05-27 19:52:21 info kresd[30062]: geo.opera.com. 60 NS geo5.opera.technology.
2020-05-27 19:52:21 info kresd[30062]: geo.opera.com. 60 NS geo9.opera.technology.
2020-05-27 19:52:21 info kresd[30062]: geo.opera.com. 60 NS geo6.opera.technology.
2020-05-27 19:52:21 info kresd[30062]: ;; ADDITIONAL SECTION
2020-05-27 19:52:21 info kresd[30062]: geo5.opera.technology. 3600 A 107.167.110.153
2020-05-27 19:52:21 info kresd[30062]: geo6.opera.technology. 3600 A 185.26.182.77
2020-05-27 19:52:21 info kresd[30062]: geo7.opera.technology. 3600 A 185.26.182.91
2020-05-27 19:52:21 info kresd[30062]: geo8.opera.technology. 3600 A 107.167.110.154
2020-05-27 19:52:21 info kresd[30062]: geo9.opera.technology. 3600 A 185.26.182.102
2020-05-27 19:52:21 info kresd[30062]: geo10.opera.technology. 3600 A 82.145.216.11
2020-05-27 19:52:21 info kresd[30062]: [26421.01][iter] <= rcode: NOERROR
2020-05-27 19:52:21 info kresd[30062]: [26421.01][iter] <= cname chain, following
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘speeddials.geo.opera.com.’ type ‘A’ uid [26421.02]
2020-05-27 19:52:21 info kresd[30062]: [26421.01][cach] => stashed speeddials.opera.com. CNAME, rank 020, 42 B total, incl. 0 RRSIGs
2020-05-27 19:52:21 info kresd[30062]: [26421.01][cach] => not overwriting NS geo.opera.com.
2020-05-27 19:52:21 info kresd[30062]: [26421.01][resl] <= server: ‘185.26.183.160’ rtt: 25 ms
2020-05-27 19:52:21 info kresd[30062]: [26421.02][iter] ‘speeddials.geo.opera.com.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:21 info kresd[30062]: [26421.03][cach] => skipping unfit CNAME RR: rank 020, new TTL -2
2020-05-27 19:52:21 info kresd[30062]: [26421.03][cach] => no NSEC
2020-05-27 19:52:21 info kresd[30062]: [26421.03][cach] => skipping zone: geo.opera.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:21 info kresd[2679]: Last message ‘[26421.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:21 info kresd[30062]: [26421.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:21 info kresd[30062]: [26421.03][zcut] found cut: geo.opera.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:21 info kresd[30062]: [26421.03][resl] => id: ‘62206’ querying: ‘185.26.182.102#00053’ score: 10 zone cut: ‘geo.opera.com.’ qname: ‘spEEddiAlS.geO.OPeRa.Com.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:21 info kresd[30062]: [26421.03][iter] <= answer received:
2020-05-27 19:52:21 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 62206
2020-05-27 19:52:21 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 1; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:21 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1680 B; ext-rcode: Unused
2020-05-27 19:52:21 info kresd[30062]: speeddials.geo.opera.com. A
2020-05-27 19:52:21 info kresd[30062]: speeddials.geo.opera.com. 60 CNAME nl.speeddials.opera.com.
2020-05-27 19:52:21 info kresd[30062]: [26421.03][iter] <= rcode: NOERROR
2020-05-27 19:52:21 info kresd[30062]: [26421.03][iter] <= cname chain, following
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘nl.speeddials.opera.com.’ type ‘A’ uid [26421.04]
2020-05-27 19:52:21 info kresd[30062]: [26421.03][cach] => stashed speeddials.geo.opera.com. CNAME, rank 020, 42 B total, incl. 0 RRSIGs
2020-05-27 19:52:21 info kresd[30062]: [26421.03][resl] <= server: ‘185.26.182.102’ rtt: 24 ms
2020-05-27 19:52:21 info kresd[30062]: [26421.04][iter] ‘nl.speeddials.opera.com.’ type ‘A’ new uid was assigned .05, parent uid .00
2020-05-27 19:52:21 info kresd[30062]: [26421.05][cach] => skipping exact RR: rank 020 (min. 020), new TTL -2
2020-05-27 19:52:21 info kresd[30062]: [26421.05][cach] => no NSEC
2020-05-27 19:52:21 info kresd[30062]: [26421.05][cach] => skipping zone: opera.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:21 info kresd[2679]: Last message ‘[26421.05][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:21 info kresd[30062]: [26421.05][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:21 info kresd[30062]: [26421.05][zcut] found cut: opera.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:21 info kresd[30062]: [26421.05][resl] => id: ‘27823’ querying: ‘185.26.183.160#00053’ score: 24 zone cut: ‘opera.com.’ qname: ‘sPEEdDIALs.OPERA.cOm.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [44281.00]
2020-05-27 19:52:21 info kresd[30062]: [44281.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [25899.00]
2020-05-27 19:52:21 info kresd[30062]: [25899.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [26421.05][iter] <= answer received:
2020-05-27 19:52:21 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 27823
2020-05-27 19:52:21 info kresd[30062]: speeddials.opera.com. NS
2020-05-27 19:52:21 info kresd[30062]: [26421.05][iter] <= rcode: NOERROR
2020-05-27 19:52:21 info kresd[30062]: [26421.05][iter] <= retrying with non-minimized name
2020-05-27 19:52:21 info kresd[30062]: [26421.05][resl] <= server: ‘185.26.183.160’ rtt: 33 ms
2020-05-27 19:52:21 info kresd[30062]: [26421.05][iter] ‘nl.speeddials.opera.com.’ type ‘A’ new uid was assigned .06, parent uid .00
2020-05-27 19:52:21 info kresd[30062]: [26421.06][resl] => id: ‘10791’ querying: ‘185.26.183.160#00053’ score: 28 zone cut: ‘opera.com.’ qname: ‘Nl.sPeEdDialS.oPeRA.com.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [32240.00]
2020-05-27 19:52:21 info kresd[30062]: [32240.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [20051.00]
2020-05-27 19:52:21 info kresd[30062]: [20051.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [34555.00]
2020-05-27 19:52:21 info kresd[30062]: [34555.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [42255.00]
2020-05-27 19:52:21 info kresd[30062]: [42255.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [26421.06][iter] <= answer received:
2020-05-27 19:52:21 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 10791
2020-05-27 19:52:21 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 4; AUTHORITY: 4; ADDITIONAL: 6
2020-05-27 19:52:21 info kresd[30062]: nl.speeddials.opera.com. A
2020-05-27 19:52:21 info kresd[30062]: nl.speeddials.opera.com. 60 A 185.26.182.94
2020-05-27 19:52:21 info kresd[30062]: nl.speeddials.opera.com. 60 A 185.26.182.112
2020-05-27 19:52:21 info kresd[30062]: nl.speeddials.opera.com. 60 A 185.26.182.111
2020-05-27 19:52:21 info kresd[30062]: nl.speeddials.opera.com. 60 A 185.26.182.93
2020-05-27 19:52:21 info kresd[30062]: opera.com. 604800 NS nic1.opera.com.
2020-05-27 19:52:21 info kresd[30062]: opera.com. 604800 NS nic4.opera.com.
2020-05-27 19:52:21 info kresd[30062]: opera.com. 604800 NS nic3.opera.com.
2020-05-27 19:52:21 info kresd[30062]: opera.com. 604800 NS nic2.opera.no.
2020-05-27 19:52:21 info kresd[30062]: nic1.opera.com. 86400 A 185.26.183.160
2020-05-27 19:52:21 info kresd[30062]: nic2.opera.no. 86400 A 37.228.109.145
2020-05-27 19:52:21 info kresd[30062]: nic3.opera.com. 3600 A 103.83.123.78
2020-05-27 19:52:21 info kresd[30062]: nic4.opera.com. 300 A 107.167.127.230
2020-05-27 19:52:21 info kresd[30062]: nic1.opera.com. 86400 AAAA 2001:4c28:4000:727:185:26:183:160
2020-05-27 19:52:21 info kresd[30062]: [26421.06][iter] <= rcode: NOERROR
2020-05-27 19:52:21 info kresd[30062]: [26421.06][cach] => stashed nl.speeddials.opera.com. A, rank 020, 38 B total, incl. 0 RRSIGs
2020-05-27 19:52:21 info kresd[30062]: [26421.06][cach] => not overwriting NS opera.com.
2020-05-27 19:52:21 info kresd[30062]: [26421.06][resl] <= server: ‘185.26.183.160’ rtt: 19 ms
2020-05-27 19:52:21 info kresd[30062]: [26421.06][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:21 info kresd[30062]: [26421.06][resl] finished: 0, queries: 3, mempool: 16392 B
2020-05-27 19:52:21 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [25379.00]
2020-05-27 19:52:21 info kresd[30062]: [25379.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [18542.00]
2020-05-27 19:52:22 info kresd[30062]: [18542.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘fonts.gstatic.com.’ type ‘A’ uid [60907.00]
2020-05-27 19:52:22 info kresd[30062]: [60907.00][iter] ‘fonts.gstatic.com.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [60907.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 250
2020-05-27 19:52:22 info kresd[30062]: [60907.01][cach] => no NSEC
cached for zone: gstatic.com.
2020-05-27 19:52:22 info kresd[30062]: [60907.01][cach] => skipping zone: gstatic.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[60907.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [60907.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [60907.01][zcut] found cut: gstatic.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [60907.01][resl] => id: ‘12108’ querying: ‘216.239.32.10#00053’ score: 28 zone cut: ‘gstatic.com.’ qname: ‘foNTS.GsTATIC.Com.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [39864.00]
2020-05-27 19:52:22 info kresd[30062]: [39864.00][resl] finished: 0, queries: 1, mempool: 32784 B
2020-05-27 19:52:22 info kresd[30062]: [60907.01][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 12108
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: ;; EDNS PSEUDOSECTION:
2020-05-27 19:52:22 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 512 B; ext-rcode: Unused
2020-05-27 19:52:22 info kresd[30062]: ;; QUESTION SECTION
2020-05-27 19:52:22 info kresd[30062]: fonts.gstatic.com. A
2020-05-27 19:52:22 info kresd[30062]: ;; ANSWER SECTION
2020-05-27 19:52:22 info kresd[30062]: fonts.gstatic.com. 300 CNAME gstaticadssl.l.google.com.
2020-05-27 19:52:22 info kresd[30062]: gstaticadssl.l.google.com. 300 A 172.217.23.195
2020-05-27 19:52:22 info kresd[30062]: [60907.01][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [60907.01][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘gstaticadssl.l.google.com.’ type ‘A’ uid [60907.02]
2020-05-27 19:52:22 info kresd[30062]: [60907.01][cach] => not overwriting CNAME fonts.gstatic.com.
2020-05-27 19:52:22 info kresd[30062]: [60907.01][resl] <= server: ‘216.239.32.10’ rtt: 24 ms
2020-05-27 19:52:22 info kresd[30062]: [60907.02][iter] ‘gstaticadssl.l.google.com.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [60907.03][cach] => satisfied by exact RRset: rank 020, new TTL 250
2020-05-27 19:52:22 info kresd[30062]: [60907.03][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 3363
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
2020-05-27 19:52:22 info kresd[30062]: gstaticadssl.l.google.com. A
2020-05-27 19:52:22 info kresd[30062]: gstaticadssl.l.google.com. 250 A 172.217.23.195
2020-05-27 19:52:22 info kresd[30062]: [60907.03][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [60907.03][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:22 info kresd[30062]: [60907.03][resl] finished: 0, queries: 2, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [29860.00]
2020-05-27 19:52:22 info kresd[30062]: [29860.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [59650.00]
2020-05-27 19:52:22 info kresd[30062]: [59650.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [31010.00]
2020-05-27 19:52:22 info kresd[30062]: [31010.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘a.cele.cz.’ type ‘A’ uid [17989.00]
2020-05-27 19:52:22 info kresd[30062]: [17989.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [27622.00]
2020-05-27 19:52:22 info kresd[30062]: [27622.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [39803.00]
2020-05-27 19:52:22 info kresd[30062]: [39803.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [49386.00]
2020-05-27 19:52:22 info kresd[30062]: [49386.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [46081.00]
2020-05-27 19:52:22 info kresd[30062]: [46081.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [12435.00]
2020-05-27 19:52:22 info kresd[30062]: [12435.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [38432.00]
2020-05-27 19:52:22 info kresd[30062]: [38432.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘hpxs.xsd.cz.’ type ‘A’ uid [01321.00]
2020-05-27 19:52:22 info kresd[30062]: [01321.00][resl] finished: 0, queries: 1, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘crl.globalsign.net.’ type ‘A’ uid [02129.00]
2020-05-27 19:52:22 info kresd[30062]: [02129.00][iter] ‘crl.globalsign.net.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [02129.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 2810
2020-05-27 19:52:22 info kresd[30062]: [02129.01][cach] => no NSEC* cached for zone: globalsign.net.
2020-05-27 19:52:22 info kresd[30062]: [02129.01][cach] => skipping zone: globalsign.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[02129.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [02129.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [02129.01][zcut] found cut: globalsign.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [02129.01][resl] => id: ‘23173’ querying: ‘198.51.45.71#00053’ score: 10 zone cut: ‘globalsign.net.’ qname: ‘crL.GLObaLsiGn.nEt.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘crl.globalsign.net.’ type ‘AAAA’ uid [40206.00]
2020-05-27 19:52:22 info kresd[30062]: [40206.00][iter] ‘crl.globalsign.net.’ type ‘AAAA’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [40206.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 2810
2020-05-27 19:52:22 info kresd[30062]: [40206.01][cach] => no NSEC* cached for zone: globalsign.net.
2020-05-27 19:52:22 info kresd[30062]: [40206.01][cach] => skipping zone: globalsign.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[40206.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [40206.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [40206.01][zcut] found cut: globalsign.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [40206.01][resl] => id: ‘55511’ querying: ‘198.51.44.71#00053’ score: 10 zone cut: ‘globalsign.net.’ qname: ‘cRL.GLOBalSigN.nEt.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [40206.01][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 55511
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 1; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4096 B; ext-rcode: Unused
2020-05-27 19:52:22 info kresd[30062]: crl.globalsign.net. AAAA
2020-05-27 19:52:22 info kresd[30062]: crl.globalsign.net. 21600 CNAME global.prd.cdn.globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [40206.01][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [40206.01][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘global.prd.cdn.globalsign.com.’ type ‘AAAA’ uid [40206.02]
2020-05-27 19:52:22 info kresd[30062]: [40206.01][cach] => not overwriting CNAME crl.globalsign.net.
2020-05-27 19:52:22 info kresd[30062]: [40206.01][resl] <= server: ‘198.51.44.71’ rtt: 18 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.02][iter] ‘global.prd.cdn.globalsign.com.’ type ‘AAAA’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [40206.03][cach] => skipping unfit CNAME RR: rank 020, new TTL -78
2020-05-27 19:52:22 info kresd[30062]: [40206.03][cach] => skipping unfit NS packet: rank 020, new TTL -200
2020-05-27 19:52:22 info kresd[30062]: [40206.03][cach] => no NSEC* cached for zone: globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [40206.03][cach] => skipping zone: globalsign.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[40206.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [40206.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [40206.03][zcut] found cut: globalsign.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [40206.03][resl] => id: ‘13086’ querying: ‘198.51.44.71#00053’ score: 18 zone cut: ‘globalsign.com.’ qname: ‘cDN.GlObaLSIGN.com.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [02129.01][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 23173
2020-05-27 19:52:22 info kresd[30062]: [02129.01][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [02129.01][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘global.prd.cdn.globalsign.com.’ type ‘A’ uid [02129.02]
2020-05-27 19:52:22 info kresd[30062]: [02129.01][cach] => not overwriting CNAME crl.globalsign.net.
2020-05-27 19:52:22 info kresd[30062]: [02129.01][resl] <= server: ‘198.51.45.71’ rtt: 18 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.02][iter] ‘global.prd.cdn.globalsign.com.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [02129.03][cach] => skipping unfit CNAME RR: rank 020, new TTL -78
2020-05-27 19:52:22 info kresd[30062]: [02129.03][cach] => skipping unfit NS packet: rank 020, new TTL -200
2020-05-27 19:52:22 info kresd[30062]: [02129.03][cach] => no NSEC* cached for zone: globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [02129.03][cach] => skipping zone: globalsign.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[02129.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [02129.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [02129.03][zcut] found cut: globalsign.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [40206.01][resl] => id: ‘34388’ querying: ‘198.51.44.7#00053’ score: 10 zone cut: ‘globalsign.net.’ qname: ‘CRl.GlobaLsiGN.Net.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [02129.01][resl] => id: ‘36832’ querying: ‘198.51.44.7#00053’ score: 10 zone cut: ‘globalsign.net.’ qname: ‘Crl.GloBAlSIGn.NeT.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [02129.03][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 13086
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 4; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsign.com. NS
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsign.com. 3600 NS dns1.p07.nsone.net.
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsign.com. 3600 NS dns2.p07.nsone.net.
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsign.com. 3600 NS dns3.p07.nsone.net.
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsign.com. 3600 NS dns4.p07.nsone.net.
2020-05-27 19:52:22 info kresd[30062]: [02129.03][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [02129.03][iter] <= continuing with qname minimization
2020-05-27 19:52:22 info kresd[30062]: [02129.03][resl] <= server: ‘198.51.44.7’ rtt: >= 16 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.03][iter] ‘global.prd.cdn.globalsign.com.’ type ‘A’ new uid was assigned .04, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [02129.04][resl] => id: ‘45537’ querying: ‘198.51.45.71#00053’ score: 18 zone cut: ‘cdn.globalsign.com.’ qname: ‘Prd.CDn.GlOBAlsigN.cOM.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [40206.03][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: [40206.03][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [40206.03][iter] <= continuing with qname minimization
2020-05-27 19:52:22 info kresd[30062]: [40206.03][resl] <= server: ‘198.51.44.71’ rtt: 16 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.03][iter] ‘global.prd.cdn.globalsign.com.’ type ‘AAAA’ new uid was assigned .04, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 34388
2020-05-27 19:52:22 info kresd[30062]: [40206.01][resl] <= server: ‘198.51.44.7’ rtt: 20 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.03][resl] => id: ‘32694’ querying: ‘198.51.44.71#00053’ score: 17 zone cut: ‘globalsign.com.’ qname: ‘cDn.gLObalsiGn.COm.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 36832
2020-05-27 19:52:22 info kresd[30062]: [02129.01][resl] <= server: ‘198.51.44.7’ rtt: 22 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.04][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 45537
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 1; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: prd.cdn.globalsign.com. NS
2020-05-27 19:52:22 info kresd[30062]: ;; AUTHORITY SECTION
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsign.com. 3600 SOA dns1.p07.nsone.net. dns-admin.globalsign.com. 1586105177 43200 7200 1209600 3600
2020-05-27 19:52:22 info kresd[30062]: [40206.04][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [40206.04][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [40206.04][cach] => stashed packet: rank 020, TTL 3600, NS prd.cdn.globalsign.com. (127 B)
2020-05-27 19:52:22 info kresd[30062]: [40206.04][resl] <= server: ‘198.51.44.7’ rtt: >= 28 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.04][iter] ‘global.prd.cdn.globalsign.com.’ type ‘AAAA’ new uid was assigned .05, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [40206.05][resl] => id: ‘13223’ querying: ‘198.51.44.71#00053’ score: 17 zone cut: ‘cdn.globalsign.com.’ qname: ‘GlObal.PRd.CdN.GlobaLSIgN.COM.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [02129.04][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: [02129.04][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [02129.04][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [02129.04][cach] => not overwriting NS prd.cdn.globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [02129.04][resl] <= server: ‘198.51.45.71’ rtt: 28 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.04][iter] ‘global.prd.cdn.globalsign.com.’ type ‘A’ new uid was assigned .05, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [02129.05][resl] => id: ‘10523’ querying: ‘198.51.44.71#00053’ score: 17 zone cut: ‘cdn.globalsign.com.’ qname: ‘GloBaL.pRD.CDN.GLOBalsign.CoM.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 32694
2020-05-27 19:52:22 info kresd[30062]: [02129.03][resl] <= server: ‘198.51.44.71’ rtt: 16 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.04][resl] => id: ‘31738’ querying: ‘198.51.44.71#00053’ score: 16 zone cut: ‘cdn.globalsign.com.’ qname: ‘pRD.CdN.GLobaLSIGN.COm.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [40206.03][resl] <= server: ‘198.51.44.71’ rtt: 18 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.05][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 10523
2020-05-27 19:52:22 info kresd[30062]: global.prd.cdn.globalsign.com. A
2020-05-27 19:52:22 info kresd[30062]: global.prd.cdn.globalsign.com. 900 CNAME cdn.globalsigncdn.com.cdn.cloudflare.net.
2020-05-27 19:52:22 info kresd[30062]: [02129.05][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [02129.05][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘cdn.globalsigncdn.com.cdn.cloudflare.net.’ type ‘A’ uid [02129.06]
2020-05-27 19:52:22 info kresd[30062]: [02129.05][cach] => stashed global.prd.cdn.globalsign.com. CNAME, rank 020, 58 B total, incl. 0 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [02129.05][resl] <= server: ‘198.51.44.71’ rtt: 16 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.06][iter] ‘cdn.globalsigncdn.com.cdn.cloudflare.net.’ type ‘A’ new uid was assigned .07, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [02129.07][cach] => skipping exact RR: rank 020 (min. 020), new TTL -588
2020-05-27 19:52:22 info kresd[30062]: [02129.07][cach] => skipping unfit NS packet: rank 020, new TTL 2712
2020-05-27 19:52:22 info kresd[30062]: [02129.07][cach] => no NSEC* cached for zone: cloudflare.net.
2020-05-27 19:52:22 info kresd[30062]: [02129.07][cach] => skipping zone: cloudflare.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[02129.07][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [02129.07][zcut] found cut: cloudflare.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] => id: ‘01485’ querying: ‘2400:cb00:2049:1::adf5:3b1f#00053’ score: 10 zone cut: ‘cloudflare.net.’ qname: ‘Cdn.GlObalSIGNcDN.Com.CDn.ClOUdfLarE.nEt.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [40206.05][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 13223
2020-05-27 19:52:22 info kresd[30062]: global.prd.cdn.globalsign.com. AAAA
2020-05-27 19:52:22 info kresd[30062]: [40206.05][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [40206.05][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘cdn.globalsigncdn.com.cdn.cloudflare.net.’ type ‘AAAA’ uid [40206.06]
2020-05-27 19:52:22 info kresd[30062]: [40206.05][cach] => not overwriting CNAME global.prd.cdn.globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [40206.05][resl] <= server: ‘198.51.44.71’ rtt: 21 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.06][iter] ‘cdn.globalsigncdn.com.cdn.cloudflare.net.’ type ‘AAAA’ new uid was assigned .07, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [40206.07][cach] => skipping exact RR: rank 020 (min. 020), new TTL -677
2020-05-27 19:52:22 info kresd[30062]: [40206.07][cach] => skipping unfit NS packet: rank 020, new TTL 2712
2020-05-27 19:52:22 info kresd[30062]: [40206.07][cach] => no NSEC* cached for zone: cloudflare.net.
2020-05-27 19:52:22 info kresd[30062]: [40206.07][cach] => skipping zone: cloudflare.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[40206.07][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [40206.07][zcut] found cut: cloudflare.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] => id: ‘50040’ querying: ‘2400:cb00:2049:1::c629:df1f#00053’ score: 10 zone cut: ‘cloudflare.net.’ qname: ‘CDN.globALSIgNcdN.cOm.cdn.CloudfLARe.net.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 31738
2020-05-27 19:52:22 info kresd[30062]: [40206.04][cach] => not overwriting NS prd.cdn.globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [40206.04][resl] <= server: ‘198.51.44.71’ rtt: 19 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.05][resl] => id: ‘44444’ querying: ‘198.51.44.71#00053’ score: 18 zone cut: ‘cdn.globalsign.com.’ qname: ‘GLObal.prD.CDn.glOBaLSigN.CoM.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [02129.04][resl] <= server: ‘198.51.44.71’ rtt: 19 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.05][resl] => id: ‘25920’ querying: ‘198.51.44.7#00053’ score: 28 zone cut: ‘cdn.globalsign.com.’ qname: ‘GLobaL.pRd.cDn.GlobAlsiGN.cOM.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 25920
2020-05-27 19:52:22 info kresd[30062]: [02129.05][cach] => not overwriting CNAME global.prd.cdn.globalsign.com.
2020-05-27 19:52:22 info kresd[30062]: [02129.05][resl] <= server: ‘198.51.44.7’ rtt: 17 ms
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 44444
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] => id: ‘01485’ querying: ‘173.245.59.31#00053’ score: 10 zone cut: ‘cloudflare.net.’ qname: ‘Cdn.GlObalSIGNcDN.Com.CDn.ClOUdfLarE.nEt.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] => id: ‘50040’ querying: ‘198.41.223.31#00053’ score: 10 zone cut: ‘cloudflare.net.’ qname: ‘CDN.globALSIgNcdN.cOm.cdn.CloudfLARe.net.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [02129.07][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 1485
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. A
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. 300 A 104.18.20.226
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. 300 A 104.18.21.226
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. 300 RRSIG A 13 6 300 20200528185222 20200526165222 34505 cloudflare.net. bmvpC7S5scJqfT4uMktMkJeXjvUBhC6onFJNAPekSLzq7A1kYU2r+kZK3KlL75JB4DnsIUmNGBWP2z/kx6rsUQ==
2020-05-27 19:52:22 info kresd[30062]: [02129.07][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [02129.07][cach] => stashed cdn.globalsigncdn.com.cdn.cloudflare.net. A, rank 020, 126 B total, incl. 1 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] <= server: ‘2400:cb00:2049:1::c629:de83’ rtt: >= 83 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] finished: 0, queries: 3, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [02129.07][cach] => not overwriting A cdn.globalsigncdn.com.cdn.cloudflare.net.
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] <= server: ‘2400:cb00:2049:1::adf5:3b1f’ rtt: >= 111 ms
2020-05-27 19:52:22 info kresd[30062]: [02129.07][resl] <= server: ‘173.245.59.31’ rtt: 11 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.07][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 50040
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. AAAA
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. 300 AAAA 2606:4700::6812:14e2
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. 300 AAAA 2606:4700::6812:15e2
2020-05-27 19:52:22 info kresd[30062]: cdn.globalsigncdn.com.cdn.cloudflare.net. 300 RRSIG AAAA 13 6 300 20200528185222 20200526165222 34505 cloudflare.net. abwcoNxLmn3WcgaVk54mZRItdBKo42W5D6+arTl7mfIX+bD9hAIeDvhki6nyQS966ROvz+u+i6jp7X/X2LJrwA==
2020-05-27 19:52:22 info kresd[30062]: [40206.07][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [40206.07][cach] => stashed cdn.globalsigncdn.com.cdn.cloudflare.net. AAAA, rank 020, 150 B total, incl. 1 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] <= server: ‘2400:cb00:2049:1::adf5:3b1f’ rtt: >= 85 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] AD: request NOT classified as SECURE
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] finished: 0, queries: 3, mempool: 16392 B
2020-05-27 19:52:22 info kresd[30062]: [40206.07][cach] => not overwriting AAAA cdn.globalsigncdn.com.cdn.cloudflare.net.
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] <= server: ‘2400:cb00:2049:1::c629:df1f’ rtt: >= 112 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] <= server: ‘198.41.223.31’ rtt: 12 ms
2020-05-27 19:52:22 info kresd[30062]: [40206.07][resl] finished: 0, queries: 3, mempool: 32784 B
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘ctldl.windowsupdate.com.’ type ‘A’ uid [19843.00]
2020-05-27 19:52:22 info kresd[30062]: [19843.00][iter] ‘ctldl.windowsupdate.com.’ type ‘A’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [19843.01][cach] => skipping unfit CNAME RR: rank 020, new TTL -200
2020-05-27 19:52:22 info kresd[30062]: [19843.01][cach] => no NSEC* cached for zone: windowsupdate.com.
2020-05-27 19:52:22 info kresd[30062]: [19843.01][cach] => skipping zone: windowsupdate.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[19843.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [19843.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [19843.01][zcut] found cut: windowsupdate.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [19843.01][resl] => id: ‘64969’ querying: ‘2603:1061::cd#00053’ score: 10 zone cut: ‘windowsupdate.com.’ qname: ‘CTlDL.wIndoWsUPDAte.coM.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘ctldl.windowsupdate.com.’ type ‘AAAA’ uid [30964.00]
2020-05-27 19:52:22 info kresd[30062]: [30964.00][iter] ‘ctldl.windowsupdate.com.’ type ‘AAAA’ new uid was assigned .01, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [30964.01][cach] => skipping unfit CNAME RR: rank 020, new TTL -200
2020-05-27 19:52:22 info kresd[30062]: [30964.01][cach] => no NSEC* cached for zone: windowsupdate.com.
2020-05-27 19:52:22 info kresd[30062]: [30964.01][cach] => skipping zone: windowsupdate.com., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[30964.01][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [30964.01][zcut] found cut: windowsupdate.com. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] => id: ‘20041’ querying: ‘13.107.160.205#00053’ score: 10 zone cut: ‘windowsupdate.com.’ qname: ‘ctldl.winDOWSuPdAte.COM.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.01][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 20041
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 1; AUTHORITY: 0; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: ;; Version: 0; flags: do; UDP size: 4000 B; ext-rcode: Unused
2020-05-27 19:52:22 info kresd[30062]: ctldl.windowsupdate.com. AAAA
2020-05-27 19:52:22 info kresd[30062]: ctldl.windowsupdate.com. 3600 CNAME audownload.windowsupdate.nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.01][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [30964.01][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘audownload.windowsupdate.nsatc.net.’ type ‘AAAA’ uid [30964.02]
2020-05-27 19:52:22 info kresd[30062]: [30964.01][cach] => stashed ctldl.windowsupdate.com. CNAME, rank 020, 52 B total, incl. 0 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] <= server: ‘13.107.160.205’ rtt: 21 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.02][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘AAAA’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [30964.03][cach] => skipping unfit CNAME RR: rank 020, new TTL -378
2020-05-27 19:52:22 info kresd[30062]: [30964.03][cach] => skipping unfit NS packet: rank 020, new TTL -78
2020-05-27 19:52:22 info kresd[30062]: [30964.03][cach] => no NSEC* cached for zone: nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.03][cach] => skipping zone: nsatc.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[30964.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [30964.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [30964.03][zcut] found cut: nsatc.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [30964.03][plan] plan ‘eu-b.prod1.footprint.net.’ type ‘AAAA’ uid [30964.04]
2020-05-27 19:52:22 info kresd[30062]: [30964.04][iter] ‘eu-b.prod1.footprint.net.’ type ‘AAAA’ new uid was assigned .05, parent uid .03
2020-05-27 19:52:22 info kresd[30062]: [30964.05][cach] => skipping unfit NS packet: rank 020, new TTL 4766
2020-05-27 19:52:22 info kresd[30062]: [30964.05][cach] => no NSEC* cached for zone: footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.05][cach] => skipping zone: footprint.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message '[30964.05][cach] ’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [30964.05][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [30964.05][zcut] found cut: footprint.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [30964.05][resl] => id: ‘25059’ querying: ‘2620:11b:e0f0:5300::1#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘pROd1.footpRiNt.nET.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 3600
2020-05-27 19:52:22 info kresd[30062]: [30964.01][cach] => skipping unfit CNAME RR: rank 020, new TTL 3600
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] => id: ‘04166’ querying: ‘2620:1ec:8ec::cd#00053’ score: 10 zone cut: ‘windowsupdate.com.’ qname: ‘ctlDl.WindOwSupdate.CoM.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.01][resl] => id: ‘64969’ querying: ‘40.90.4.205#00053’ score: 10 zone cut: ‘windowsupdate.com.’ qname: ‘CTlDL.wIndoWsUPDAte.coM.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.01][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 64969
2020-05-27 19:52:22 info kresd[30062]: [19843.01][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [19843.01][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘audownload.windowsupdate.nsatc.net.’ type ‘A’ uid [19843.02]
2020-05-27 19:52:22 info kresd[30062]: [19843.01][cach] => not overwriting CNAME ctldl.windowsupdate.com.
2020-05-27 19:52:22 info kresd[30062]: [19843.01][resl] <= server: ‘2620:1ec:8ec::cd’ rtt: >= 98 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.02][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘A’ new uid was assigned .03, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [19843.03][cach] => skipping unfit CNAME RR: rank 020, new TTL -378
2020-05-27 19:52:22 info kresd[30062]: [19843.03][cach] => skipping unfit NS packet: rank 020, new TTL -78
2020-05-27 19:52:22 info kresd[30062]: [19843.03][cach] => no NSEC* cached for zone: nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.03][cach] => skipping zone: nsatc.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[19843.03][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [19843.03][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [19843.03][zcut] found cut: nsatc.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [19843.03][plan] plan ‘eu-a.prod1.footprint.net.’ type ‘AAAA’ uid [19843.04]
2020-05-27 19:52:22 info kresd[30062]: [19843.04][iter] ‘eu-a.prod1.footprint.net.’ type ‘AAAA’ new uid was assigned .05, parent uid .03
2020-05-27 19:52:22 info kresd[30062]: [19843.05][cach] => skipping unfit NS packet: rank 020, new TTL 4766
2020-05-27 19:52:22 info kresd[30062]: [19843.05][cach] => no NSEC* cached for zone: footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.05][cach] => skipping zone: footprint.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message '[19843.05][cach] ’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [19843.05][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [19843.05][zcut] found cut: footprint.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [19843.01][resl] <= server: ‘2603:1061::cd’ rtt: >= 121 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.01][resl] <= server: ‘40.90.4.205’ rtt: 21 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.05][resl] => id: ‘25059’ querying: ‘8.254.13.1#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘pROd1.footpRiNt.nET.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] => id: ‘04166’ querying: ‘64.4.48.205#00053’ score: 10 zone cut: ‘windowsupdate.com.’ qname: ‘ctlDl.WindOwSupdate.CoM.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 4166
2020-05-27 19:52:22 info kresd[30062]: [30964.01][cach] => not overwriting CNAME ctldl.windowsupdate.com.
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] <= server: ‘2620:1ec:8ec::cd’ rtt: >= 124 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.01][resl] <= server: ‘64.4.48.205’ rtt: 24 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.03][plan] plan ‘eu-a.prod1.footprint.net.’ type ‘AAAA’ uid [30964.04]
2020-05-27 19:52:22 info kresd[30062]: [30964.04][iter] ‘eu-a.prod1.footprint.net.’ type ‘AAAA’ new uid was assigned .05, parent uid .03
2020-05-27 19:52:22 info kresd[30062]: [30964.05][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 25059
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 0; AUTHORITY: 1; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: prod1.footprint.net. NS
2020-05-27 19:52:22 info kresd[30062]: footprint.net. 7200 SOA internal.footprint.net. dns.level3.com. 12727 1800 900 604800 7200
2020-05-27 19:52:22 info kresd[30062]: [30964.05][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [30964.05][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [30964.05][cach] => not overwriting NS prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.05][resl] <= server: ‘8.254.14.1’ rtt: >= 0 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.05][iter] ‘eu-a.prod1.footprint.net.’ type ‘AAAA’ new uid was assigned .06, parent uid .03
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] => id: ‘04836’ querying: ‘2620:11b:e0f0:5300::1#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘EU-a.ProD1.fOoTPRInT.NET.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.05][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: [19843.05][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [19843.05][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [19843.05][cach] => not overwriting NS prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.05][resl] <= server: ‘2620:11b:e0f1:5300::1’ rtt: >= 26 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.05][iter] ‘eu-a.prod1.footprint.net.’ type ‘AAAA’ new uid was assigned .06, parent uid .03
2020-05-27 19:52:22 info kresd[30062]: [19843.05][resl] <= server: ‘2620:11b:e0f0:5300::1’ rtt: >= 26 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.05][resl] <= server: ‘2620:11b:e0f0:5300::1’ rtt: >= 126 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.05][resl] <= server: ‘8.254.13.1’ rtt: 26 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.05][iter] ‘eu-b.prod1.footprint.net.’ type ‘AAAA’ new uid was assigned .06, parent uid .03
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] => id: ‘39624’ querying: ‘2620:11b:e0f1:5300::1#00053’ score: 26 zone cut: ‘footprint.net.’ qname: ‘Eu-b.Prod1.FoOTprINT.NEt.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] => id: ‘39624’ querying: ‘8.254.13.2#00053’ score: 26 zone cut: ‘footprint.net.’ qname: ‘Eu-b.Prod1.FoOTprINT.NEt.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.06][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 39624
2020-05-27 19:52:22 info kresd[30062]: eu-b.prod1.footprint.net. AAAA
2020-05-27 19:52:22 info kresd[30062]: [30964.06][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [30964.06][cach] => stashed packet: rank 020, TTL 7200, AAAA eu-b.prod1.footprint.net. (124 B)
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] <= server: ‘2620:11b:e0f1:5300::1’ rtt: >= 75 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.03][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘AAAA’ new uid was assigned .07, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [30964.07][plan] plan ‘eu-b.prod1.footprint.net.’ type ‘A’ uid [30964.08]
2020-05-27 19:52:22 info kresd[30062]: [30964.08][iter] ‘eu-b.prod1.footprint.net.’ type ‘A’ new uid was assigned .09, parent uid .07
2020-05-27 19:52:22 info kresd[30062]: [30964.09][cach] => skipping exact RR: rank 020 (min. 000), new TTL -3395
2020-05-27 19:52:22 info kresd[30062]: [30964.09][cach] => skipping unfit NS packet: rank 020, new TTL 4766
2020-05-27 19:52:22 info kresd[30062]: [30964.09][cach] => no NSEC* cached for zone: footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.09][cach] => skipping zone: footprint.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message '[30964.09][cach] ’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [30964.09][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [30964.09][zcut] found cut: footprint.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [30964.09][resl] => id: ‘13447’ querying: ‘8.254.13.3#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘prOD1.FoOtPriNt.nET.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.09][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 13447
2020-05-27 19:52:22 info kresd[30062]: [30964.09][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [30964.09][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [30964.09][cach] => not overwriting NS prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.09][resl] <= server: ‘8.254.13.3’ rtt: 24 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.09][iter] ‘eu-b.prod1.footprint.net.’ type ‘A’ new uid was assigned .10, parent uid .07
2020-05-27 19:52:22 info kresd[30062]: [30964.10][resl] => id: ‘08952’ querying: ‘8.254.13.2#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘eu-b.proD1.FOOTPRInT.Net.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] => id: ‘04836’ querying: ‘8.254.13.1#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘EU-a.ProD1.fOoTPRInT.NET.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.06][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 4836
2020-05-27 19:52:22 info kresd[30062]: eu-a.prod1.footprint.net. AAAA
2020-05-27 19:52:22 info kresd[30062]: [19843.06][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [19843.06][cach] => stashed packet: rank 020, TTL 7200, AAAA eu-a.prod1.footprint.net. (124 B)
2020-05-27 19:52:22 info kresd[30062]: [19843.06][resl] <= server: ‘8.254.13.3’ rtt: >= 125 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.06][resl] <= server: ‘2620:11b:e0f1:5300::2’ rtt: >= 25 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.03][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘A’ new uid was assigned .07, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [19843.07][plan] plan ‘eu-a.prod1.footprint.net.’ type ‘A’ uid [19843.08]
2020-05-27 19:52:22 info kresd[30062]: [19843.08][iter] ‘eu-a.prod1.footprint.net.’ type ‘A’ new uid was assigned .09, parent uid .07
2020-05-27 19:52:22 info kresd[30062]: [19843.09][cach] => skipping exact RR: rank 020 (min. 000), new TTL -634
2020-05-27 19:52:22 info kresd[30062]: [19843.09][cach] => skipping unfit NS packet: rank 020, new TTL 4766
2020-05-27 19:52:22 info kresd[30062]: [19843.09][cach] => no NSEC* cached for zone: footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.09][cach] => skipping zone: footprint.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message '[19843.09][cach] ’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [19843.09][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [19843.09][zcut] found cut: footprint.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [19843.09][resl] => id: ‘36531’ querying: ‘8.254.13.2#00053’ score: 10 zone cut: ‘footprint.net.’ qname: ‘prod1.FOoTpRiNT.net.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.06][cach] => not overwriting AAAA eu-a.prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.06][resl] <= server: ‘2620:11b:e0f1:5300::2’ rtt: >= 125 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.06][resl] <= server: ‘8.254.14.2’ rtt: >= 25 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.06][cach] => not overwriting AAAA eu-a.prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] <= server: ‘2620:11b:e0f0:5300::1’ rtt: >= 125 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.06][resl] <= server: ‘8.254.13.1’ rtt: 25 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.07][plan] plan ‘eu-a.prod1.footprint.net.’ type ‘A’ uid [30964.08]
2020-05-27 19:52:22 info kresd[30062]: [30964.08][iter] ‘eu-a.prod1.footprint.net.’ type ‘A’ new uid was assigned .09, parent uid .07
2020-05-27 19:52:22 info kresd[30062]: [30964.09][cach] => skipping exact RR: rank 020 (min. 000), new TTL -634
2020-05-27 19:52:22 info kresd[30062]: [30964.10][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 8952
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 4; AUTHORITY: 5; ADDITIONAL: 9
2020-05-27 19:52:22 info kresd[30062]: eu-b.prod1.footprint.net. 1800 A 4.26.227.27
2020-05-27 19:52:22 info kresd[30062]: eu-b.prod1.footprint.net. 1800 A 8.254.119.155
2020-05-27 19:52:22 info kresd[30062]: eu-b.prod1.footprint.net. 1800 A 198.78.218.25
2020-05-27 19:52:22 info kresd[30062]: eu-b.prod1.footprint.net. 1800 A 4.23.39.155
2020-05-27 19:52:22 info kresd[30062]: footprint.net. 86400 NS ns105.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: footprint.net. 86400 NS ns100.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: footprint.net. 86400 NS ns101.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: footprint.net. 86400 NS ns102.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: footprint.net. 86400 NS ns103.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: ;; ADDITIONAL SECTION
2020-05-27 19:52:22 info kresd[30062]: ns100.footprint.net. 86400 A 8.254.13.1
2020-05-27 19:52:22 info kresd[30062]: ns100.footprint.net. 86400 AAAA 2620:11b:e0f0:5300::1
2020-05-27 19:52:22 info kresd[30062]: ns101.footprint.net. 86400 A 8.254.14.1
2020-05-27 19:52:22 info kresd[30062]: ns102.footprint.net. 86400 A 8.254.13.3
2020-05-27 19:52:22 info kresd[30062]: ns103.footprint.net. 86400 A 8.254.13.2
2020-05-27 19:52:22 info kresd[30062]: ns103.footprint.net. 86400 AAAA 2620:11b:e0f1:5300::1
2020-05-27 19:52:22 info kresd[30062]: ns105.footprint.net. 86400 A 8.254.14.2
2020-05-27 19:52:22 info kresd[30062]: ns105.footprint.net. 86400 AAAA 2620:11b:e0f1:5300::2
2020-05-27 19:52:22 info kresd[30062]: [30964.10][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [30964.10][cach] => stashed eu-b.prod1.footprint.net. A, rank 020, 38 B total, incl. 0 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [30964.10][resl] <= server: ‘8.254.13.2’ rtt: 42 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.07][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘AAAA’ new uid was assigned .11, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [30964.11][resl] => id: ‘21640’ querying: ‘4.26.227.27#00053’ score: 10 zone cut: ‘nsatc.net.’ qname: ‘WiNDOWsUPdaTE.nsATC.nEt.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 36531
2020-05-27 19:52:22 info kresd[30062]: [30964.09][resl] <= server: ‘8.254.13.2’ rtt: 43 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.09][iter] ‘eu-a.prod1.footprint.net.’ type ‘A’ new uid was assigned .10, parent uid .07
2020-05-27 19:52:22 info kresd[30062]: [30964.10][resl] => id: ‘46708’ querying: ‘8.254.14.1#00053’ score: 11 zone cut: ‘footprint.net.’ qname: ‘Eu-a.pROD1.fooTpRInt.net.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.09][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: [19843.09][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [19843.09][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [19843.09][cach] => not overwriting NS prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.09][resl] <= server: ‘8.254.13.2’ rtt: 43 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.09][iter] ‘eu-a.prod1.footprint.net.’ type ‘A’ new uid was assigned .10, parent uid .07
2020-05-27 19:52:22 info kresd[30062]: [30964.11][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NXDOMAIN; id: 21640
2020-05-27 19:52:22 info kresd[30062]: ;; Version: 0; flags: ; UDP size: 1200 B; ext-rcode: Unused
2020-05-27 19:52:22 info kresd[30062]: windowsupdate.nsatc.net. NS
2020-05-27 19:52:22 info kresd[30062]: nsatc.net. 900 SOA admin.nsatc.net. dns.level3.net. 1589318113 10800 2700 3600000 900
2020-05-27 19:52:22 info kresd[30062]: [30964.11][iter] <= rcode: NXDOMAIN
2020-05-27 19:52:22 info kresd[30062]: [30964.11][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [30964.11][cach] => stashed packet: rank 020, TTL 900, NS windowsupdate.nsatc.net. (117 B)
2020-05-27 19:52:22 info kresd[30062]: [30964.11][resl] <= server: ‘4.26.227.27’ rtt: 35 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.11][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘AAAA’ new uid was assigned .12, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [30964.12][resl] => id: ‘20398’ querying: ‘8.254.119.155#00053’ score: 10 zone cut: ‘nsatc.net.’ qname: ‘auDoWnlOad.WinDoWSUPdatE.nsAtc.net.’ qtype: ‘AAAA’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.10][resl] => id: ‘46708’ querying: ‘8.254.13.1#00053’ score: 11 zone cut: ‘footprint.net.’ qname: ‘Eu-a.pROD1.fooTpRInt.net.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.10][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 46708
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa cd QUERY: 1; ANSWER: 5; AUTHORITY: 5; ADDITIONAL: 9
2020-05-27 19:52:22 info kresd[30062]: eu-a.prod1.footprint.net. 1800 A 198.78.208.155
2020-05-27 19:52:22 info kresd[30062]: eu-a.prod1.footprint.net. 1800 A 199.93.59.27
2020-05-27 19:52:22 info kresd[30062]: eu-a.prod1.footprint.net. 1800 A 8.253.92.27
2020-05-27 19:52:22 info kresd[30062]: eu-a.prod1.footprint.net. 1800 A 8.254.37.27
2020-05-27 19:52:22 info kresd[30062]: eu-a.prod1.footprint.net. 1800 A 8.254.92.155
2020-05-27 19:52:22 info kresd[30062]: [19843.10][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [19843.10][cach] => stashed eu-a.prod1.footprint.net. A, rank 020, 44 B total, incl. 0 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [19843.10][resl] <= server: ‘8.254.13.2’ rtt: >= 23 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.07][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘A’ new uid was assigned .11, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [19843.11][resl] => id: ‘42231’ querying: ‘198.78.208.155#00053’ score: 10 zone cut: ‘nsatc.net.’ qname: ‘wINdoWSuPdAtE.NSaTC.NEt.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [19843.10][cach] => not overwriting A eu-a.prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.10][resl] <= server: ‘8.254.14.2’ rtt: >= 23 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.10][cach] => not overwriting A eu-a.prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.10][resl] <= server: ‘8.254.14.1’ rtt: 23 ms
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NXDOMAIN; id: 42231
2020-05-27 19:52:22 info kresd[30062]: [30964.11][cach] => not overwriting NS windowsupdate.nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.11][resl] <= server: ‘198.78.208.155’ rtt: 22 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.11][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: [19843.11][iter] <= rcode: NXDOMAIN
2020-05-27 19:52:22 info kresd[30062]: [19843.11][iter] <= retrying with non-minimized name
2020-05-27 19:52:22 info kresd[30062]: [19843.11][cach] => not overwriting NS windowsupdate.nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [19843.11][resl] <= server: ‘198.78.208.155’ rtt: 22 ms
2020-05-27 19:52:22 info kresd[30062]: [19843.11][iter] ‘audownload.windowsupdate.nsatc.net.’ type ‘A’ new uid was assigned .12, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [19843.12][resl] => id: ‘05073’ querying: ‘199.93.59.27#00053’ score: 10 zone cut: ‘nsatc.net.’ qname: ‘AuDoWNlOAd.wIndOWsupDATE.NsAtc.NEt.’ qtype: ‘A’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.12][iter] <= answer received:
2020-05-27 19:52:22 info kresd[30062]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 20398
2020-05-27 19:52:22 info kresd[30062]: ;; Flags: qr aa QUERY: 1; ANSWER: 1; AUTHORITY: 2; ADDITIONAL: 1
2020-05-27 19:52:22 info kresd[30062]: audownload.windowsupdate.nsatc.net. AAAA
2020-05-27 19:52:22 info kresd[30062]: audownload.windowsupdate.nsatc.net. 600 CNAME auto.au.download.windowsupdate.com.c.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: nsatc.net. 86400 NS eu-a.prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: nsatc.net. 86400 NS eu-b.prod1.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.12][iter] <= rcode: NOERROR
2020-05-27 19:52:22 info kresd[30062]: [30964.12][iter] <= cname chain, following
2020-05-27 19:52:22 info kresd[30062]: [00000.00][plan] plan ‘auto.au.download.windowsupdate.com.c.footprint.net.’ type ‘AAAA’ uid [30964.13]
2020-05-27 19:52:22 info kresd[30062]: [30964.12][cach] => stashed audownload.windowsupdate.nsatc.net. CNAME, rank 020, 68 B total, incl. 0 RRSIGs
2020-05-27 19:52:22 info kresd[30062]: [30964.12][cach] => not overwriting NS nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.12][resl] <= server: ‘199.93.59.27’ rtt: >= 0 ms
2020-05-27 19:52:22 info kresd[30062]: [30964.13][iter] ‘auto.au.download.windowsupdate.com.c.footprint.net.’ type ‘AAAA’ new uid was assigned .14, parent uid .00
2020-05-27 19:52:22 info kresd[30062]: [30964.14][cach] => skipping exact RR: rank 020 (min. 020), new TTL -4049
2020-05-27 19:52:22 info kresd[30062]: [30964.14][cach] => skipping unfit NS packet: rank 020, new TTL 192
2020-05-27 19:52:22 info kresd[30062]: [30964.14][cach] => no NSEC* cached for zone: c.footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.14][cach] => skipping zone: c.footprint.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message ‘[30964.14][cach] =’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [30964.14][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [30964.14][zcut] found cut: c.footprint.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [30964.14][plan] plan ‘eu-b.dns.footprint.net.’ type ‘AAAA’ uid [30964.15]
2020-05-27 19:52:22 info kresd[30062]: [30964.15][iter] ‘eu-b.dns.footprint.net.’ type ‘AAAA’ new uid was assigned .16, parent uid .14
2020-05-27 19:52:22 info kresd[30062]: [30964.16][cach] => skipping unfit NS packet: rank 020, new TTL 2801
2020-05-27 19:52:22 info kresd[30062]: [30964.16][cach] => no NSEC* cached for zone: footprint.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.16][cach] => skipping zone: footprint.net., NSEC, hash 0;new TTL -123456789, ret -2
2020-05-27 19:52:22 info kresd[2679]: Last message '[30964.16][cach] ’ repeated 1 times, suppressed by syslog-ng on turris
2020-05-27 19:52:22 info kresd[30062]: [30964.16][resl] => going insecure because there’s no covering TA
2020-05-27 19:52:22 info kresd[30062]: [30964.16][zcut] found cut: footprint.net. (rank 002 return codes: DS -2, DNSKEY -2)
2020-05-27 19:52:22 info kresd[30062]: [30964.16][resl] => id: ‘41330’ querying: ‘8.254.14.2#00053’ score: 25 zone cut: ‘footprint.net.’ qname: ‘dNs.FOotpRint.neT.’ qtype: ‘NS’ proto: ‘udp’
2020-05-27 19:52:22 info kresd[30062]: [30964.12][cach] => not overwriting CNAME audownload.windowsupdate.nsatc.net.
2020-05-27 19:52:22 info kresd[30062]: [30964.12][resl] <= server: ‘8.254.119.155’ rtt: 37 ms
About the other log from last week, more www.centrum.cz requests in there and a few **.sreality.cz, but it’s all the same, just sometimes it’s partially or fully satisfied from cache and Seznam uses its own servers instead of CloudFront. All seems successful with four/two addresses returned (respectively).
@JardaB: OK, now I think it’s clear that the detection of non-working IPv6 is broken in your case, and that might be the main cause for the problems you experience. In some zones this leads to a large part of queries to upstream getting no reply, which increases delays and can even cause client-observable failures because of timeouts.
I’m still puzzled why the detection fails, as the diagnostics show you using Turris OS 3.11.16 and I only know about a breakage that appeared newly in and 3.11.17 RC and HBT 5.0.0 (at some moment).
Well, you probably want a workaround now: that would be editing /etc/config/resolver, section 'common', setting option net_ipv6 '1' to value '0'. I’m no good with OpenWrt UCI, so maybe there’s a nicer way of achieving the same.
