Atheros AR9287 2.4 GHz Wifi drops out frequently
Hi everybody!
I’ve been owning a Turris Omnia 2020 for a couple of months and generally speaking, I’m very happy about my investment!
Unfortunately I noticed that 2,4 GHz Wifi drops out from time to time. That means: Clients lose Wifi connection and won’t reconnect successfully. Instead, the client’s network adapter needs to be restarted (or device rebooted) or the 2,4 GHz adapter of the Turris Omnia needs to be restartet. It seems like Wifi communication is “stuck”. When looking at the syslog (or kernel log), I see the following just when the issue occurs:
[226722.571131] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00008040
[226722.980705] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00008040
[226723.390306] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00004040
[226723.799881] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00008040
[226724.209449] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00006040
[226724.619045] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00006040
[226725.028612] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00008040
[226725.438202] ath: phy1: DMA failed to stop in 10 ms AR_CR=0x00000024 AR_DIAG_SW=0x42100020 DMADBG_7=0x00008040
These are the only lines that are logged - no more error messages or other hints what might be wrong.
The problem occurs randomly - I could not reproduce it on purpose. Sometimes it happens more frequently than usual.
My Turris Omnia has the latest updates (TurrisOS 5.1.10 a5672f6b96f393145070ad17c8eb1d15ef49ad2e) and was only slightly modified: I inserted a mSATA SSD to PCIe slot 1, put the 5 GHz Wifi card into slot 2 and the 2,4 GHz card is in slot 3 (near the edge of the case).
As I cannot find any pattern with this issue, I’m seeking help here. Is there anybody facing the same or similar issues?
The problem does only occur on 2,4 GHz Wifi with different devices (Windows 10 laptop, iPhone, iPad, Android phone). 5 GHz Wifi is totally fine.
I’ve tried
  • switching Wifi channels
  • switching from 40 MHz channel width to 20 MHz.
  • heavy use of USB 3.0 slot (there are reports that USB interferes with 2.4 GHz wifi - I could not find a problem)
Update 2021-04-01:
I might have fixed it by setting the adapter from HT40 mode to HT 20 mode (20 MHz bandwidth) and restarting + reconnecting all devices. The Wifi has been stable for a few days, now. It might be related to this: https://svn.dd-wrt.com/ticket/2952?cversion=0&cnum_hist=73#comment:110
Update one year later:
The HT 40 vs HT 20 mode change did not have the drsired effect. The cause of the problem seems to be my iPad Air Gen 2: If it is turned on and connected to the Wifi, it causes those issues from time to time.
If it is turned off, the Wifi problems seem to be gone.
I’ve moved the iPad to the 5 GHz Wifi (enforced via MAC filter) - let’s see ifthis brings some peace to my network.
I had same problem with that adapter, but only with 1 Windows client(there is actually only 1 Windows client), workaround was to reconnect wifi from that Windows laptop. Seems after upgrading Windows problem disappeared. On the other hand never observed such problem from other clients such as Linux and Android, either they are smart enough to reconnect or not having such problem at all.
