I bought a Compex WLE7002E56 QCA9274 hoping the ath12k drivers would work but unfortunately I can’t find a working board / firmware-x.bin combination. Does anyone here know if it’s supported by any of the existing Ath12 firmware which works?
this is error from linux-firmware.tar.gz - hw2.0 « QCN9274 « ath12k - kernel/git/firmware/linux-firmware.git - Repository of firmware blobs for use with the Linux kernel
or from this repo…QCN9274/hw2.0 · main · CodeLinaro / ath-firmware / ath12k-firmware · GitLab
the error is the same:
[ 11.505433] ath12k_pci 0000:07:00.0: BAR 0: assigned [mem 0xa1000000-0xa11fffff 64bit]
[ 11.513866] ath12k_pci 0000:07:00.0: MSI vectors: 16
[ 11.518957] ath12k_pci 0000:07:00.0: Hardware name: qcn9274 hw2.0
[ 12.811478] ath12k_pci 0000:07:00.0: qmi dma allocation failed (29360128 B type 1), will try later with small size
[ 12.833094] ath12k_pci 0000:07:00.0: memory type 10 not supported
[ 12.844839] ath12k_pci 0000:07:00.0: chip_id 0x0 chip_family 0xb board_id 0x1006 soc_id 0x401a2200
[ 12.854037] ath12k_pci 0000:07:00.0: fw_version 0x141580c7 fw_build_timestamp 2024-11-11 11:03 fw_build_id QC_IMAGE_VERSION_STRING=WLAN.WBE.1.4.1-00199-QCAHKSWPL_SILICONZ-1
[ 12.985654] ath12k_pci 0000:07:00.0: failed to fetch board data for bus=pci,qmi-chip-id=0,qmi-board-id=4102 from ath12k/QCN9274/hw2.0/board-2.bin
[ 12.998942] ath12k_pci 0000:07:00.0: failed to fetch board.bin from QCN9274/hw2.0
[ 13.006632] ath12k_pci 0000:07:00.0: qmi failed to load bdf:
[ 13.012445] ath12k_pci 0000:07:00.0: qmi failed to load board data file:-12
Cheers!
