Ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 0 ar-state 1): 0
I suppose this might be related to the 7.3.1 branch. I have problem with ATH10k card reporting this. I tried several cards from different sources all type WLE900VX.
Can anybody help?
[ 259.687747] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 1: -110
[ 259.687764] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 1 when adding a new sta: -110
[ 262.727540] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 1: -110
[ 262.727557] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 1 when adding a new sta: -110
[ 269.296889] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 1: -110
[ 269.296906] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 1 when adding a new sta: -110
[ 274.406486] ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 0 ar-state 1): 0
[ 279.526112] ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 0 ar-state 1): 0
[ 284.645766] ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 0 ar-state 1): 0
[ 287.695632] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 1: -110
[ 287.695648] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 1 when adding a new sta: -110
[ 290.735521] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 1: -110
[ 290.735539] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 1 when adding a new sta: -110
[ 293.765412] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 1: -110
[ 293.765428] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 1 when adding a new sta: -110
[ 298.885223] ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 0 ar-state 1): 0
[ 302.015127] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 2: -110
[ 302.015145] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 2 when adding a new sta: -110
[ 305.045019] ath10k_pci 0000:02:00.0: failed to wait for created wmi peer 38:2c:e5:f1:ed:bd on vdev 2: -110
[ 305.045038] ath10k_pci 0000:02:00.0: failed to add peer 38:2c:e5:f1:ed:bd for vdev 2 when adding a new sta: -110
root@turris:~#
Use -ct drivers then it will complain less.
which packages should I install?
To se moc nepovedlo…
root@turris:~# dmesg |grep -i ath
[ 11.929446] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by mount (753)
[ 14.458294] ath10k 5.15 driver, optimized for CT firmware, probing pci device: 0x3c.
[ 14.468143] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 27.720477] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 27.729757] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[ 27.739109] ath10k_pci 0000:02:00.0: firmware ver 10.1-ct-8x-__fH-022-ecad3248 api 2 features wmi-10.x,mfp,txstatus-noack,wmi-10.x-CT,ratemask-CT,txrate-CT,get-temp-CT,tx-rc-CT,cust-stats-CT,retry-gt2-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT crc32 1b2a161c
[ 27.787033] ath10k_pci 0000:02:00.0: Loading BDF type 0
[ 27.805760] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 28.663192] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[ 28.680195] ath10k_pci 0000:02:00.0: wmi print ‘P 128 V 8 T 410’
[ 28.686240] ath10k_pci 0000:02:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
[ 28.694270] ath10k_pci 0000:02:00.0: wmi print ‘alloc rem: 25000 iram: 38944’
[ 28.760421] ath10k_pci 0000:02:00.0: htt-ver 2.2 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 28.770116] ath10k_pci 0000:02:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
[ 28.888110] ath: EEPROM regdomain: 0x0
[ 28.888118] ath: EEPROM indicates default country code should be used
[ 28.888121] ath: doing EEPROM country->regdmn map search
[ 28.888124] ath: country maps to regdmn code: 0x3a
[ 28.888127] ath: Country alpha2 being used: US
[ 28.888130] ath: Regpair used: 0x3a
[ 39.418419] ath: EEPROM regdomain: 0x80cb
[ 39.418429] ath: EEPROM indicates we should expect a country code
[ 39.418432] ath: doing EEPROM country->regdmn map search
[ 39.418434] ath: country maps to regdmn code: 0x37
[ 39.418438] ath: Country alpha2 being used: CZ
[ 39.418440] ath: Regpair used: 0x37
[ 39.418442] ath: regdomain 0x80cb dynamically updated by user
[ 42.108393] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[ 42.117760] ath10k_pci 0000:02:00.0: wmi print ‘P 128 V 8 T 410’
[ 42.117805] ath10k_pci 0000:02:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
[ 42.118380] ath10k_pci 0000:02:00.0: wmi print ‘alloc rem: 25000 iram: 38944’
[ 42.177658] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
[ 42.185137] ath10k_pci 0000:02:00.0: rts threshold -1
[ 42.369231] ath10k_pci 0000:02:00.0: rts threshold -1
[ 42.538982] ath10k_pci 0000:02:00.0: rts threshold -1
[ 47.046817] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 47.268416] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 48.156781] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 55.046849] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 56.496793] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 56.626750] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 57.347384] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 58.856836] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 60.886773] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 63.754286] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 66.143880] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 67.766854] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 69.569431] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 69.688915] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 73.095517] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 75.476387] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 76.920936] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 83.846988] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 85.222672] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 85.561490] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 86.259319] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 92.221336] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 93.737010] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 94.973628] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 101.096110] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 103.969173] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 104.797238] ath10k_pci 0000:02:00.0: mac flush vdev 1 drop 0 queues 0x2 ar->paused: 0x0 arvif->paused: 0x0
[ 105.385889] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 108.319285] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 109.466808] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 110.364941] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 115.085209] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 115.913606] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 116.801930] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 118.997718] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 124.088641] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 125.426379] ath10k_pci 0000:02:00.0: mac flush vdev 1 drop 0 queues 0x2 ar->paused: 0x0 arvif->paused: 0x0
[ 125.566139] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 129.479808] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 130.907981] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 134.715136] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 140.980483] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 144.198269] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 144.328168] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 144.617917] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 147.665833] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 148.185484] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 150.953613] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 156.310176] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 159.108436] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 163.985383] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 164.285202] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 164.744935] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 166.753727] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 171.700846] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 173.040045] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 176.278215] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 177.427603] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 181.535371] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 183.894120] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 184.383863] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 184.843640] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 185.113496] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 188.341839] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 190.210897] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 194.648719] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 203.964265] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 204.094219] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 204.464038] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 204.553977] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 209.861589] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 210.241419] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 214.059784] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 217.568289] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 219.867358] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
[ 221.176830] ath10k_pci 0000:02:00.0: mac flush vdev 2 drop 0 queues 0x4 ar->paused: 0x0 arvif->paused: 0x0
to zasila ten log jeste vic. uvidim jak to bude se stabilitou
I said it will complain less. Instead of failing to flush queue it informs about that each time. Safe to ignore.
the problem is the 2.4 GHz WiFi simply stop work after few minutes after restart. It started with latest version.
BTW I have three different virtual ESSIDs + one MESH ESSID connected to this 2.4 GHz interface
try only 20 Mhz mode with 2,4 Ghz Wifi. if already 20 Mhz, change to 40 Mhz and back. Solved for me
