I’d like to create a decided, always-operational VPN LAN, by assigning port 4, port 6, and eth2 (assigned to VLAN 2 by default) to a separate subnet.
I’m a networking n00b, so I was hoping to get someone with more experience to check my work before I do something that is going to cause me a lot of head aches.
Thus far, I have an operational, operational VPN client and guest WiFi network.
Current settings
OpenVPN
I have the OpenVPN client configured and functioning as expected.
Additions to /etc/config/network
config interface 'vpn_interface'
option proto 'none'
option ifname 'tun0'
Additions to /etc/config/firewall
config zone
option name 'vpn_zone'
option input 'REJECT'
option forward 'REJECT'
option output 'ACCEPT'
option masq '1'
option mtu_fix '1'
option network 'vpn_interface'
config forwarding
option src 'lan'
option dest 'vpn_zone'
Guest network
config interface 'guest_interface'
option _orig_ifname 'wlan1'
option _orig_bridge 'false'
option proto 'static'
option ipaddr '192.168.2.1'
Additions to /etc/config/dhcp
config dhcp 'guest_interface'
option start '100'
option leasetime '12h'
option limit '150'
option interface 'guest_interface'
list dhcp_option '6,192.168.2.1'
config zone
option name 'guest_zone'
option network 'guest_interface'
option input 'ACCEPT'
config forwarding
option dest 'wan'
option src 'guest_zone'
config rule
option target 'ACCEPT'
option proto 'tcp udp'
option dest_port '5353'
option name 'Allow Guest DNS Access'
config rule
option proto 'udp'
option dest_port '67-68'
option name 'Allow Guest DHCP Access'
Proposed settings
Changes to /etc/config/network
# remove eth2 from 'lan'
config interface 'lan'
option force_link '1'
option type 'bridge'
option ipaddr '192.168.1.1'
option ip6assign '60'
option _orig_ifname 'eth0 wlan0' #changed
option _orig_bridge 'true'
option ifname 'eth0' # changed
#add eth2 to guest; bridge connection
option _orig_ifname 'eth2 wlan1' # changed
option _orig_bridge 'true' # changed
option type 'bridge' # new
option ifname 'eth2' # new
Changes to /etc/config/firewall
# forward the guest network's traffic to the VPN
config forwarding
option src 'guest_interface'
Questions
- Do I need to tag the VLAN ports? I’m thinking ‘no’ as each VLAN is assigned to its own Ethernet port (
eth0
andeht2
). - Do I need to bridge the connections? I added this to the
guest_interface
. What does bridging do? - Are there any other changes that I need to make?
