In my case, I was wondering why Foris/reForis are showing all dhcp leases correctly, while Luci shown all dynamic leases as expired. So i’ve checked “dhcp.lease” and “dhcp.lease.dynamic” files and make some changes (removed all expired ones from “dhcp.lease” files). After that I’ve checked logs and seen this “AP-STA-POSSIBLE-PSK-MISMATCH” messages (maybe those were present before my changes in lease files, i do not know). I’ve notice that 2,4G AP(regular) is having same mac address as 2,4G AP(guest).
So i’ve looked around OpenWRT/Turris and other forums for solution. Many users suggested to use
wpa_group_rekey=86400
together with disassoc_low_ack=0
and wpa_strict_rekey=1
eventually in combo with skip_inactivity_poll
and max_inactivity
I’ve tried to use suggested options. Nothing helped.
At the end 2,4G regular AP is having wpa_group_rekey=86400
, while guest AP is having wpa_group_rekey=86400
together with disassoc_low_ack=1
I had to rollback to previous snapshot (as in my case any changes in wireless uci config cause no wifi is working due not associated/not active device.)
After reboot to previous snapshot, all lease files were fine, each AP has own mac address and suprisingly no more errors about PSK-mismatch. Instead of those i have now correct disassociate/associate messages each 6 minutes.
In fact i did not change any configuration (resp. i am using same setup as before). So i am little bit confused, what actually solved this issue.
, I think that it has to be related to lease files somehow … )
What i also notice, that while having PSK-mismatch messages, all dhcp clients overview shown just IP. After rollback all were shown with IP and MAC (as defined in “hostnames” in luci).
Aside of that 5G AP now uses DFS and changes dynamically frequencies/channels on-fly (before that i had just one channel picked during radio init and it stays like that until wireless restart or router reboot).
