Antenna to e side plate to short?
I ordered a mox + wifi upgrade. I want to add g-extension, 8port ether extension + sfp extension.
But the problem is the antenna cable to extension side is to short to extend allready for 8port eth + sfp.
What can I do? There are missing (without extra G extension) 5 mm cable length.
I have the same question… I would like to (I have to) order the boards in this way:
  • Mox A
  • Mox G
  • Mox E
  • Mox C
But antenna from Mox G to the side plate is too short. Can I “unstuck” it and place it to some other part?
