When I got my Turris Omnia, the antenna mounting studs were a little loose. So I followed the emailed directions and opened up the case to tighten them down. But one of the three antennas was completely disconnected β the wires that were clearly supposed to be soldered to it were hanging loose. See photo of loose wires.
What is my remedy? Can I fix this myself? Send it back for repair or replacement?
Actualy from Compex WLE900 goes 5GHz pigtails and from second one goes 2.4GHz pigtails. When you look closely on signal combiners, you can notice small labels which one is 5GHz and 2.4GHz, so connect pigtails on correct ones.
which card are you using for the 2.4ghz wifi? i beleive im using the smaller card with only 2 wires running out of it and my signal starts going down as soon as i walk in the next room of the home.
