About a month ago, right after an update, the 4G connection stopped working. However, if I rolled back to a previous working state it did work. So, I turned off auto updates and just kept on using it. Tried many times over weeks to install the updates, but always the same problem.
Have now Performed a factory reset from Reforis and successfully reached the ‘Guide Finished’ page.
Of course the updater has failed as I only have the Quectel EC25-E modem to connect to the outside world (for which I need the LTE stuff)
I take a look at Network settings and all the interface are showing. I setup wifi and connect with my mobile phone hotspot, then download and install all updates successfully. After a reboot, I can still see all interfaces in Reforis and Luci.
Now I download the ‘Extensions of network protocols for 3G/LTE’ via wifi However, after installing, the Reforis Network Interfaces page is blank. All you see is ‘An unknown API error occurred’. A Reboot changes nothing. Still the same error
In Luci I can can only see four square boxes that show the status. There is no menu above them or anything clickable to configure anything.
Logging out of Reforis is not possible. The top right logout button does nothing.
I reboot from within Reforis, but still same problem.
I simply do not know what I’ve done wrong. Completely stuck here.
I’m using Brave browser on Linux
Any ideas?
