On last Friday I tried it again, but the logfile isn’t complete or better not chronical.
Also in the logfile are older an new logs from other tries. On Friday I tried at 8pm start the mox with the module E. But I can’t see anything in the logs about it.
Apr 8 21:42:42 turris syslog-ng[2604]: syslog-ng starting up; version=‘3.35.1’
Apr 8 21:42:42 turris kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Apr 8 21:42:42 turris kernel: [ 0.000000] Linux version 4.14.269 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11413+89-9ced994057)) #0 SMP Mon Mar 7 08:30:00 2022
Apr 8 21:42:42 turris kernel: [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
Apr 8 21:42:42 turris kernel: [ 0.000000] Machine model: CZ.NIC Turris Mox Board
Apr 8 21:42:42 turris kernel: [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options ‘’)
Apr 8 21:42:42 turris kernel: [ 0.000000] bootconsole [ar3700_uart0] enabled
Apr 8 21:42:42 turris kernel: [ 0.000000] On node 0 totalpages: 131072
Apr 8 21:42:42 turris kernel: [ 0.000000] DMA zone: 2048 pages used for memmap
Apr 8 21:42:42 turris kernel: [ 0.000000] DMA zone: 0 pages reserved
Apr 8 21:42:42 turris kernel: [ 0.000000] DMA zone: 131072 pages, LIFO batch:31
Apr 8 21:42:42 turris kernel: [ 0.000000] psci: probing for conduit method from DT.
Apr 8 21:42:42 turris kernel: [ 0.000000] psci: PSCIv1.1 detected in firmware.
Apr 8 21:42:42 turris kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Apr 8 21:42:42 turris kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Apr 8 21:42:42 turris kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Apr 8 21:42:42 turris kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x494 with crng_init=0
Apr 8 21:42:42 turris kernel: [ 0.000000] percpu: Embedded 16 pages/cpu s26648 r8192 d30696 u65536
Apr 8 21:42:42 turris kernel: [ 0.000000] pcpu-alloc: s26648 r8192 d30696 u65536 alloc=164096
Apr 8 21:42:42 turris kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Apr 8 21:42:42 turris kernel: [ 0.000000] Detected VIPT I-cache on CPU0
Apr 8 21:42:42 turris kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
Apr 8 21:42:42 turris kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
Apr 8 21:42:42 turris kernel: [ 0.000000] Kernel command line: earlyprintk console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 mangled_fs=btrfs root=PARTUUID=c7b00dbc-01 rootflags=commit=5,subvol=@ rootwait rw cfg80211.freg=
Apr 8 21:42:42 turris kernel: [ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
Apr 8 21:42:42 turris kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
Apr 8 21:42:42 turris kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
Apr 8 21:42:42 turris kernel: [ 0.000000] Memory: 496300K/524288K available (7422K kernel code, 476K rwdata, 1940K rodata, 320K init, 304K bss, 27988K reserved, 0K cma-reserved)
Apr 8 21:42:42 turris kernel: [ 0.000000] Virtual kernel memory layout:
Apr 8 21:42:42 turris kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Apr 8 21:42:42 turris kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Apr 8 21:42:42 turris kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff80087c0000 ( 7424 KB)
Apr 8 21:42:42 turris kernel: [ 0.000000] .rodata : 0xffffff80087c0000 - 0xffffff80089b0000 ( 1984 KB)
Apr 8 21:42:42 turris kernel: [ 0.000000] .init : 0xffffff80089b0000 - 0xffffff8008a00000 ( 320 KB)
Apr 8 21:42:42 turris kernel: [ 0.000000] .data : 0xffffff8008a00000 - 0xffffff8008a77008 ( 477 KB)
Apr 8 21:42:42 turris kernel: [ 0.000000] .bss : 0xffffff8008a77008 - 0xffffff8008ac31a8 ( 305 KB)
Apr 8 21:42:42 turris kernel: [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
Apr 8 21:42:42 turris kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Apr 8 21:42:42 turris kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Apr 8 21:42:42 turris kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf00800000 ( 8 MB actual)
Apr 8 21:42:42 turris kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc020000000 ( 512 MB)
Apr 8 21:42:42 turris kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Apr 8 21:42:42 turris kernel: [ 0.000000] Hierarchical RCU implementation.
Apr 8 21:42:42 turris kernel: [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
Apr 8 21:42:42 turris kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Apr 8 21:42:42 turris kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Apr 8 21:42:42 turris kernel: [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Apr 8 21:42:42 turris kernel: [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Apr 8 21:42:42 turris kernel: [ 0.000000] GICv3: no VLPI support, no direct LPI support
Apr 8 21:42:42 turris kernel: [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
Apr 8 21:42:42 turris kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
Apr 8 21:42:42 turris kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
Apr 8 21:42:42 turris kernel: [ 0.000005] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
Apr 8 21:42:42 turris kernel: [ 0.008436] Console: colour dummy device 80x25
Apr 8 21:42:42 turris kernel: [ 0.012948] Calibrating delay loop (skipped), value calculated using timer frequency… 25.00 BogoMIPS (lpj=125000)
Apr 8 21:42:42 turris kernel: [ 0.023595] pid_max: default: 32768 minimum: 301
Apr 8 21:42:42 turris kernel: [ 0.028446] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Apr 8 21:42:42 turris kernel: [ 0.035186] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
Apr 8 21:42:42 turris kernel: [ 0.043435] ASID allocator initialised with 32768 entries
Apr 8 21:42:42 turris kernel: [ 0.049011] Hierarchical SRCU implementation.
Apr 8 21:42:42 turris kernel: [ 0.053892] smp: Bringing up secondary CPUs …
Apr 8 21:42:42 turris kernel: [ 0.058856] Detected VIPT I-cache on CPU1
Apr 8 21:42:42 turris kernel: [ 0.058888] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
Apr 8 21:42:42 turris kernel: [ 1.129314] CPU1: failed to come online
Apr 8 21:42:42 turris kernel: [ 1.129344] CPU1: Booted secondary processor [410fd034]
Apr 8 21:42:42 turris kernel: [ 1.133357] CPU1: failed in unknown state : 0x0
Apr 8 21:42:42 turris kernel: [ 1.170164] CPU1: shutdown
Apr 8 21:42:42 turris kernel: [ 1.172862] psci: CPU1 killed (polled 0 ms)
Apr 8 21:42:42 turris kernel: [ 1.177226] smp: Brought up 1 node, 1 CPU
Apr 8 21:42:42 turris kernel: [ 1.181302] SMP: Total of 1 processors activated.
Apr 8 21:42:42 turris kernel: [ 1.186123] CPU features: detected: GIC system register CPU interface
Apr 8 21:42:42 turris kernel: [ 1.192756] CPU features: detected: 32-bit EL0 Support
Apr 8 21:42:42 turris kernel: [ 1.198044] CPU: All CPU(s) started at EL2
Apr 8 21:42:42 turris kernel: [ 1.202256] alternatives: patching kernel code
Apr 8 21:42:42 turris kernel: [ 1.207486] devtmpfs: initialized
Apr 8 21:42:42 turris kernel: [ 1.213160] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Apr 8 21:42:42 turris kernel: [ 1.223271] futex hash table entries: 512 (order: 4, 65536 bytes)
Apr 8 21:42:42 turris kernel: [ 1.229588] xor: measuring software checksum speed
Apr 8 21:42:42 turris kernel: [ 1.334483] 8regs : 1918.800 MB/sec
Apr 8 21:42:42 turris kernel: [ 1.434516] 8regs_prefetch: 1710.400 MB/sec
Apr 8 21:42:42 turris kernel: [ 1.534548] 32regs : 2358.800 MB/sec
Apr 8 21:42:42 turris kernel: [ 1.634584] 32regs_prefetch: 1984.400 MB/sec
Apr 8 21:42:42 turris kernel: [ 1.639251] xor: using function: 32regs (2358.800 MB/sec)
Apr 8 21:42:42 turris kernel: [ 1.644816] pinctrl core: initialized pinctrl subsystem
Apr 8 21:42:42 turris kernel: [ 1.651543] NET: Registered protocol family 16
Apr 8 21:42:42 turris kernel: [ 1.656731] cpuidle: using governor ladder
Apr 8 21:42:42 turris kernel: [ 1.660967] vdso: 2 pages (1 code @ ffffff80087c5000, 1 data @ ffffff8008a04000)
Apr 8 21:42:42 turris kernel: [ 1.668538] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Apr 8 21:42:42 turris kernel: [ 1.676938] DMA: preallocated 256 KiB pool for atomic allocations
Apr 8 21:42:42 turris kernel: [ 1.684375] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
Apr 8 21:42:42 turris kernel: [ 1.693304] console [ttyMV0] enabled
Apr 8 21:42:42 turris kernel: [ 1.700620] bootconsole [ar3700_uart0] disabled
Apr 8 21:42:42 turris kernel: [ 1.900218] raid6: int64x1 gen() 321 MB/s
Apr 8 21:42:42 turris kernel: [ 2.070273] raid6: int64x1 xor() 317 MB/s
Apr 8 21:42:42 turris kernel: [ 2.240391] raid6: int64x2 gen() 521 MB/s
Apr 8 21:42:42 turris kernel: [ 2.410436] raid6: int64x2 xor() 450 MB/s
Apr 8 21:42:42 turris kernel: [ 2.580499] raid6: int64x4 gen() 779 MB/s
Apr 8 21:42:42 turris kernel: [ 2.750577] raid6: int64x4 xor() 551 MB/s
Apr 8 21:42:42 turris kernel: [ 2.920640] raid6: int64x8 gen() 939 MB/s
Apr 8 21:42:42 turris kernel: [ 3.090708] raid6: int64x8 xor() 562 MB/s
Apr 8 21:42:42 turris kernel: [ 3.260776] raid6: neonx1 gen() 594 MB/s
Apr 8 21:42:42 turris kernel: [ 3.430851] raid6: neonx1 xor() 625 MB/s
Apr 8 21:42:42 turris kernel: [ 3.600956] raid6: neonx2 gen() 986 MB/s
Apr 8 21:42:42 turris kernel: [ 3.770977] raid6: neonx2 xor() 947 MB/s
Apr 8 21:42:42 turris kernel: [ 3.941077] raid6: neonx4 gen() 1313 MB/s
Apr 8 21:42:42 turris kernel: [ 4.111127] raid6: neonx4 xor() 1171 MB/s
Apr 8 21:42:42 turris kernel: [ 4.281209] raid6: neonx8 gen() 1297 MB/s
Apr 8 21:42:42 turris kernel: [ 4.451277] raid6: neonx8 xor() 1132 MB/s
Apr 8 21:42:42 turris kernel: [ 4.455509] raid6: using algorithm neonx4 gen() 1313 MB/s
Apr 8 21:42:42 turris kernel: [ 4.460993] raid6: … xor() 1171 MB/s, rmw enabled
Apr 8 21:42:42 turris kernel: [ 4.466393] raid6: using neon recovery algorithm
Apr 8 21:42:42 turris kernel: [ 4.471696] SCSI subsystem initialized
Apr 8 21:42:42 turris kernel: [ 4.477648] libata version 3.00 loaded.
Apr 8 21:42:42 turris kernel: [ 4.477843] usbcore: registered new interface driver usbfs
Apr 8 21:42:42 turris kernel: [ 4.483105] usbcore: registered new interface driver hub
Apr 8 21:42:42 turris kernel: [ 4.488826] usbcore: registered new device driver usb
Apr 8 21:42:42 turris kernel: [ 4.494438] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
Apr 8 21:42:42 turris kernel: [ 4.509802] clocksource: Switched to clocksource arch_sys_counter
Apr 8 21:42:42 turris kernel: [ 4.526966] NET: Registered protocol family 2
Apr 8 21:42:42 turris kernel: [ 4.531319] IP idents hash table entries: 8192 (order: 4, 65536 bytes)
Apr 8 21:42:42 turris kernel: [ 4.538676] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Apr 8 21:42:42 turris kernel: [ 4.545843] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
Apr 8 21:42:42 turris kernel: [ 4.552693] TCP: Hash tables configured (established 4096 bind 4096)
Apr 8 21:42:42 turris kernel: [ 4.558992] UDP hash table entries: 256 (order: 1, 8192 bytes)
Apr 8 21:42:42 turris kernel: [ 4.564860] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Apr 8 21:42:42 turris kernel: [ 4.571608] NET: Registered protocol family 1
Apr 8 21:42:42 turris kernel: [ 4.576277] PCI: CLS 0 bytes, default 128
Apr 8 21:42:42 turris kernel: [ 4.578229] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Apr 8 21:42:42 turris kernel: [ 4.590881] Crashlog allocated RAM at address 0x3f00000
Apr 8 21:42:42 turris kernel: [ 4.597119] workingset: timestamp_bits=46 max_order=17 bucket_order=0
Apr 8 21:42:42 turris kernel: [ 4.607414] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Apr 8 21:42:42 turris kernel: [ 4.613324] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Apr 8 21:42:42 turris kernel: [ 4.632923] io scheduler noop registered
Apr 8 21:42:42 turris kernel: [ 4.636987] io scheduler deadline registered (default)
Apr 8 21:42:42 turris kernel: [ 4.642280] io scheduler bfq registered
Apr 8 21:42:42 turris kernel: [ 4.650656] OF: PCI: host bridge /soc/pcie@d0070000 ranges:
Apr 8 21:42:42 turris kernel: [ 4.656262] OF: PCI: MEM 0xe8000000…0xefefffff → 0xe8000000
Apr 8 21:42:42 turris kernel: [ 4.662131] OF: PCI: IO 0xefff0000…0xefffffff → 0xefff0000
Apr 8 21:42:42 turris kernel: [ 4.668723] advk-pcie d0070000.pcie: issuing PERST via reset GPIO for 10ms
Apr 8 21:42:42 turris kernel: [ 4.779710] advk-pcie d0070000.pcie: link up
Apr 8 21:42:42 turris kernel: [ 4.784028] advk-pcie d0070000.pcie: PCI host bridge to bus 0000:00
Apr 8 21:42:42 turris kernel: [ 4.790269] pci_bus 0000:00: root bus resource [bus 00-ff]
Apr 8 21:42:42 turris kernel: [ 4.796273] pci_bus 0000:00: root bus resource [mem 0xe8000000-0xefefffff]
Apr 8 21:42:42 turris kernel: [ 4.803035] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0xefff0000-0xefffffff])
Apr 8 21:42:42 turris kernel: [ 4.813254] pci 0000:00:00.0: [168c:003c] type 00 class 0x028000
Apr 8 21:42:42 turris kernel: [ 4.813358] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Apr 8 21:42:42 turris kernel: [ 4.813468] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Apr 8 21:42:42 turris kernel: [ 4.813680] pci 0000:00:00.0: supports D1 D2
Apr 8 21:42:42 turris kernel: [ 4.813829] pci 0000:00:00.0: BAR 0: assigned [mem 0xe8000000-0xe81fffff 64bit]
Apr 8 21:42:42 turris kernel: [ 4.821075] pci 0000:00:00.0: BAR 6: assigned [mem 0xe8200000-0xe820ffff pref]
Apr 8 21:42:42 turris kernel: [ 4.829668] mv_xor d0060900.xor: Marvell shared XOR driver
Apr 8 21:42:42 turris kernel: [ 4.890302] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Apr 8 21:42:42 turris kernel: [ 4.960299] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Apr 8 21:42:42 turris kernel: [ 4.968625] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Apr 8 21:42:42 turris kernel: [ 4.978507] cacheinfo: Unable to detect cache hierarchy for CPU 0
Apr 8 21:42:42 turris kernel: [ 4.990541] loop: module loaded
Apr 8 21:42:42 turris kernel: [ 5.002088] random: fast init done
Apr 8 21:42:42 turris kernel: [ 5.009666] m25p80 spi0.0: w25q64dw (8192 Kbytes)
Apr 8 21:42:42 turris kernel: [ 5.014837] 5 fixed-partitions partitions found on MTD device spi0.0
Apr 8 21:42:42 turris kernel: [ 5.021427] Creating 5 MTD partitions on “spi0.0”:
Apr 8 21:42:42 turris kernel: [ 5.026025] 0x000000000000-0x000000020000 : “secure-firmware”
Apr 8 21:42:42 turris kernel: [ 5.032755] 0x000000020000-0x000000180000 : “u-boot”
Apr 8 21:42:42 turris kernel: [ 5.038382] 0x000000180000-0x000000190000 : “u-boot-env”
Apr 8 21:42:42 turris kernel: [ 5.044534] 0x000000190000-0x0000007f0000 : “Rescue system”
Apr 8 21:42:42 turris kernel: [ 5.051288] 0x0000007f0000-0x000000800000 : “dtb”
Apr 8 21:42:42 turris kernel: [ 5.057293] moxtet spi0.1: Found SD Turris Mox CPU module
Apr 8 21:42:42 turris kernel: [ 5.062603] moxtet spi0.1: PCIe module found
Apr 8 21:42:42 turris kernel: [ 5.066931] moxtet spi0.1: Topaz Switch module found
Apr 8 21:42:42 turris kernel: [ 5.077194] mv88e6085 d0032004.mdio-mii:02: switch 0x3400 detected: Marvell 88E6141, revision 0
Apr 8 21:42:42 turris kernel: [ 5.112845] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:cc:38
Apr 8 21:42:42 turris kernel: [ 5.122149] mvneta d0040000.ethernet eth1: Using device tree mac address d8:58:d7:00:cc:39
Apr 8 21:42:42 turris kernel: [ 5.130593] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Apr 8 21:42:42 turris kernel: [ 5.137354] ehci-pci: EHCI PCI platform driver
Apr 8 21:42:42 turris kernel: [ 5.141637] ehci-platform: EHCI generic platform driver
Apr 8 21:42:42 turris kernel: [ 5.147149] ehci-orion: EHCI orion driver
Apr 8 21:42:42 turris kernel: [ 5.151619] orion-ehci d005e000.usb: EHCI Host Controller
Apr 8 21:42:42 turris kernel: [ 5.157224] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
Apr 8 21:42:42 turris kernel: [ 5.164979] orion-ehci d005e000.usb: irq 13, io mem 0xd005e000
Apr 8 21:42:42 turris kernel: [ 5.199732] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
Apr 8 21:42:42 turris kernel: [ 5.206487] hub 1-0:1.0: USB hub found
Apr 8 21:42:42 turris kernel: [ 5.210429] hub 1-0:1.0: 1 port detected
Apr 8 21:42:42 turris kernel: [ 5.215397] usbcore: registered new interface driver usb-storage
Apr 8 21:42:42 turris kernel: [ 5.221784] i2c /dev entries driver
Apr 8 21:42:42 turris kernel: [ 5.227508] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec
Apr 8 21:42:42 turris kernel: [ 5.234778] sdhci: Secure Digital Host Controller Interface driver
Apr 8 21:42:42 turris kernel: [ 5.240935] sdhci: Copyright(c) Pierre Ossman
Apr 8 21:42:42 turris kernel: [ 5.245374] sdhci-pltfm: SDHCI platform and OF driver helper
Apr 8 21:42:42 turris kernel: [ 5.251627] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
Apr 8 21:42:42 turris kernel: [ 5.257393] xenon-sdhci d00d8000.sdhci: Got CD GPIO
Apr 8 21:42:42 turris kernel: [ 5.263287] NET: Registered protocol family 10
Apr 8 21:42:42 turris kernel: [ 5.270957] Segment Routing with IPv6
Apr 8 21:42:42 turris kernel: [ 5.274532] NET: Registered protocol family 17
Apr 8 21:42:42 turris kernel: [ 5.279278] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Apr 8 21:42:42 turris kernel: [ 5.293268] 8021q: 802.1Q VLAN Support v1.8
Apr 8 21:42:42 turris kernel: [ 5.300530] Btrfs loaded, crc32c=crc32c-arm64-ce
Apr 8 21:42:42 turris kernel: [ 5.310028] rtc-ds1307 0-006f: registered as rtc0
Apr 8 21:42:42 turris kernel: [ 5.314772] i2c i2c-0: PXA I2C adapter
Apr 8 21:42:42 turris kernel: [ 5.319018] mv88e6085 d0032004.mdio-mii:02: switch 0x3400 detected: Marvell 88E6141, revision 0
Apr 8 21:42:42 turris kernel: [ 5.348369] DSA: switch 0 0 parsed
Apr 8 21:42:42 turris kernel: [ 5.351954] DSA: tree 0 parsed
Apr 8 21:42:42 turris kernel: [ 6.061660] mv88e6085 d0032004.mdio-mii:02 lan1 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:11] driver [Marvell 88E6390]
Apr 8 21:42:42 turris kernel: [ 6.181664] mv88e6085 d0032004.mdio-mii:02 lan2 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:12] driver [Marvell 88E6390]
Apr 8 21:42:42 turris kernel: [ 6.291664] mv88e6085 d0032004.mdio-mii:02 lan3 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:13] driver [Marvell 88E6390]
Apr 8 21:42:42 turris kernel: [ 6.411665] mv88e6085 d0032004.mdio-mii:02 lan4 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:14] driver [Marvell 88E6390]
Apr 8 21:42:42 turris kernel: [ 6.428764] xhci-hcd d0058000.usb: xHCI Host Controller
Apr 8 21:42:42 turris kernel: [ 6.433970] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
Apr 8 21:42:42 turris kernel: [ 6.441941] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
Apr 8 21:42:42 turris kernel: [ 6.451082] xhci-hcd d0058000.usb: irq 12, io mem 0xd0058000
Apr 8 21:42:42 turris kernel: [ 6.458233] hub 2-0:1.0: USB hub found
Apr 8 21:42:42 turris kernel: [ 6.461983] hub 2-0:1.0: 1 port detected
Apr 8 21:42:42 turris kernel: [ 6.466385] xhci-hcd d0058000.usb: xHCI Host Controller
Apr 8 21:42:42 turris kernel: [ 6.471562] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
Apr 8 21:42:42 turris kernel: [ 6.479348] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
Apr 8 21:42:42 turris kernel: [ 6.486241] usb usb3: We don’t know the algorithms for LPM for this host, disabling LPM.
Apr 8 21:42:42 turris kernel: [ 6.495154] hub 3-0:1.0: USB hub found
Apr 8 21:42:42 turris kernel: [ 6.499005] hub 3-0:1.0: 1 port detected
Apr 8 21:42:42 turris kernel: [ 6.503861] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
Apr 8 21:42:42 turris kernel: [ 6.569712] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
Apr 8 21:42:42 turris kernel: [ 6.577814] xenon-sdhci d00d8000.sdhci: Got CD GPIO
Apr 8 21:42:42 turris kernel: [ 6.622955] sdio_read_cccr card report SDIO_UHS_DDR50
Apr 8 21:42:42 turris kernel: [ 6.628008] sdio_read_cccr card report SDIO_UHS_SDR50
Apr 8 21:42:42 turris kernel: [ 6.633240] sdio_read_cccr card report SDIO_UHS_SDR104
Apr 8 21:42:42 turris kernel: [ 6.639914] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
Apr 8 21:42:42 turris kernel: [ 6.656305] armada-37xx-rwtm-mailbox d00b0000.mailbox: Trust Status: 00000000
Apr 8 21:42:42 turris kernel: [ 6.776599] Turris Mox serial number 0000000D300089FE
Apr 8 21:42:42 turris kernel: [ 6.781660] board version 22
Apr 8 21:42:42 turris kernel: [ 6.785329] burned RAM size 512 MiB
Apr 8 21:42:42 turris kernel: [ 7.146357] rtc-ds1307 0-006f: setting system clock to 2022-04-08 19:42:19 UTC (1649446939)
Apr 8 21:42:42 turris kernel: [ 7.155836] xenon-sdhci d00d0000.sdhci: Timing issue might occur in DDR mode
Apr 8 21:42:42 turris kernel: [ 7.165126] Waiting for root device PARTUUID=c7b00dbc-01…
Apr 8 21:42:42 turris kernel: [ 7.171420] mmc0: new ultra high speed DDR50 SDIO card at address 0001
Apr 8 21:42:42 turris kernel: [ 7.178522] random: crng init done
Apr 8 21:42:42 turris kernel: [ 7.486916] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
Apr 8 21:42:42 turris kernel: [ 7.495511] mmcblk1: mmc1:aaaa SA16G 14.8 GiB
Apr 8 21:42:42 turris kernel: [ 7.505156] mmcblk1: p1
Apr 8 21:42:42 turris kernel: [ 7.540827] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Apr 8 21:42:42 turris kernel: [ 7.548391] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 1th superblock
Apr 8 21:42:42 turris kernel: [ 7.557863] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Apr 8 21:42:42 turris kernel: [ 7.565306] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 2th superblock
Apr 8 21:42:42 turris kernel: [ 7.573078] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Apr 8 21:42:42 turris kernel: [ 7.580305] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 1th superblock
Apr 8 21:42:42 turris kernel: [ 7.588294] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Apr 8 21:42:42 turris kernel: [ 7.595863] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 2th superblock
Apr 8 21:42:42 turris kernel: [ 7.605444] BTRFS: device label turris devid 1 transid 966 /dev/root
Apr 8 21:42:42 turris kernel: [ 7.614006] BTRFS info (device mmcblk1p1): disk space caching is enabled
Apr 8 21:42:42 turris kernel: [ 7.620839] BTRFS info (device mmcblk1p1): has skinny extents
Apr 8 21:42:42 turris kernel: [ 7.638979] BTRFS info (device mmcblk1p1): enabling ssd optimizations
Apr 8 21:42:42 turris kernel: [ 7.651873] VFS: Mounted root (btrfs filesystem) on device 0:12.
Apr 8 21:42:42 turris kernel: [ 7.658552] devtmpfs: mounted
Apr 8 21:42:42 turris kernel: [ 7.661904] Freeing unused kernel memory: 320K
Apr 8 21:42:42 turris kernel: 7.751751] init: Console is alive
Apr 8 21:42:42 turris kernel: 7.755066] init: - watchdog -
Apr 8 21:42:42 turris kernel: [ 7.920282] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
Apr 8 21:42:42 turris kernel: [ 7.968212] usb-storage 3-1:1.0: USB Mass Storage device detected
Apr 8 21:42:42 turris kernel: [ 7.976843] scsi host0: usb-storage 3-1:1.0
Apr 8 21:42:42 turris kernel: 8.107062] kmodloader: loading kernel modules from /etc/modules-boot.d/
Apr 8 21:42:42 turris kernel: [ 8.127812] usbcore: registered new interface driver uas
Apr 8 21:42:42 turris kernel: 8.133968] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Apr 8 21:42:42 turris kernel: 8.151826] init: - preinit -
Apr 8 21:42:42 turris kernel: [ 9.031474] scsi 0:0:0:0: Direct-Access Kingston DataTraveler 3.0 PQ: 0 ANSI: 6
Apr 8 21:42:42 turris kernel: [ 9.050085] sd 0:0:0:0: [sda] 30218842 512-byte logical blocks: (15.5 GB/14.4 GiB)
Apr 8 21:42:42 turris kernel: [ 9.059827] sd 0:0:0:0: [sda] Write Protect is off
Apr 8 21:42:42 turris kernel: [ 9.064528] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
Apr 8 21:42:42 turris kernel: [ 9.064748] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
Apr 8 21:42:42 turris kernel: [ 9.078303] sd 0:0:0:0: [sda] Attached SCSI removable disk
Apr 8 21:42:42 turris kernel: 9.344232] mount_root: mounting /dev/root
Apr 8 21:42:42 turris kernel: [ 9.441220] BTRFS info (device mmcblk1p1): disk space caching is enabled
Apr 8 21:42:42 turris kernel: 9.626253] urandom-seed: Seeding with /etc/urandom.seed
Apr 8 21:42:42 turris kernel: 9.869680] procd: - early -
Apr 8 21:42:42 turris kernel: 9.873263] procd: - watchdog -
Apr 8 21:42:42 turris kernel: 10.477634] procd: - watchdog -
Apr 8 21:42:42 turris kernel: 10.481817] procd: - ubus -
Apr 8 21:42:42 turris kernel: 10.540486] procd: - init -
Apr 8 21:42:42 turris kernel: 10.654717] kmodloader: loading kernel modules from /etc/modules.d/*
Apr 8 21:42:42 turris kernel: [ 10.674934] zram: Added device: zram0
Apr 8 21:42:42 turris kernel: [ 10.689242] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Apr 8 21:42:42 turris kernel: [ 10.718408] ip6_tables: (C) 2000-2006 Netfilter Core Team
Apr 8 21:42:42 turris kernel: [ 10.751549] Netfilter messages via NETLINK v0.30.
Apr 8 21:42:42 turris kernel: [ 10.774095] ip_set: protocol 6
Apr 8 21:42:42 turris kernel: [ 10.841652] Loading modules backported from Linux version v4.19.221-0-g5fd3cce374df
Apr 8 21:42:42 turris kernel: [ 10.849240] Backport generated by backports.git v4.19.221-1-0-g07fffc43
Apr 8 21:42:42 turris kernel: [ 10.948387] hidraw: raw HID events driver (C) Jiri Kosina
Apr 8 21:42:42 turris kernel: [ 10.971156] Mirror/redirect action on
Apr 8 21:42:42 turris kernel: [ 11.001025] u32 classifier
Apr 8 21:42:42 turris kernel: [ 11.003571] input device check on
Apr 8 21:42:42 turris kernel: [ 11.007530] Actions configured
Apr 8 21:42:42 turris kernel: [ 11.053870] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
Apr 8 21:42:42 turris kernel: [ 11.060269] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
Apr 8 21:42:42 turris kernel: [ 11.087461] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x3c.
Apr 8 21:42:42 turris kernel: [ 11.096538] ath10k_pci 0000:00:00.0: enabling device (0000 → 0002)
Apr 8 21:42:42 turris kernel: [ 11.103490] ath10k_pci 0000:00:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Apr 8 21:42:42 turris kernel: [ 11.343104] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:00:00.0.txt failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.354040] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.369666] firmware ath10k!fwcfg-pci-0000:00:00.0.txt: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.378876] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.389542] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.405881] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.415486] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.426243] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.442440] firmware ath10k!cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.451620] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-5.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.462822] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.478836] firmware ath10k!QCA988X!hw2.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.488734] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-2.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.499947] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.524208] firmware ath10k!QCA988X!hw2.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.534125] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.544800] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.561479] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.571025] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-5.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.581953] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.598117] firmware ath10k!QCA988X!hw2.0!firmware-5.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.607665] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-4.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.618720] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.634894] firmware ath10k!QCA988X!hw2.0!firmware-4.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.644347] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-3.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.655097] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.671333] firmware ath10k!QCA988X!hw2.0!firmware-3.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.685585] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Apr 8 21:42:42 turris kernel: [ 11.695280] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Apr 8 21:42:42 turris kernel: [ 11.705777] ath10k_pci 0000:00:00.0: firmware ver 10.1-ct-8x-__fW-022-538f0906 api 2 features wmi-10.x,has-wmi-mgmt-tx,mfp,txstatus-noack,wmi-10.x-CT,ratemask-CT,txrate-CT,get-temp-CT,tx-rc-CT,cust-stats-CT,retry-gt2-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT crc32 e1c91a74
Apr 8 21:42:42 turris kernel: [ 11.759345] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
Apr 8 21:42:42 turris kernel: [ 11.769822] ath10k_pci 0000:00:00.0: Falling back to user helper
Apr 8 21:42:42 turris kernel: [ 11.792402] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
Apr 8 21:42:42 turris kernel: [ 11.803512] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Apr 8 21:42:42 turris kernel: [ 12.735636] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Apr 8 21:42:42 turris kernel: [ 12.752707] ath10k_pci 0000:00:00.0: wmi print ‘P 128 V 8 T 410’
Apr 8 21:42:42 turris kernel: [ 12.758536] ath10k_pci 0000:00:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
Apr 8 21:42:42 turris kernel: [ 12.766950] ath10k_pci 0000:00:00.0: wmi print ‘alloc rem: 20984 iram: 25656’
Apr 8 21:42:42 turris kernel: [ 12.819902] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Apr 8 21:42:42 turris kernel: [ 12.833628] ath10k_pci 0000:00:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
Apr 8 21:42:42 turris kernel: [ 12.957841] ath: EEPROM regdomain: 0x0
Apr 8 21:42:42 turris kernel: [ 12.957855] ath: EEPROM indicates default country code should be used
Apr 8 21:42:42 turris kernel: [ 12.957860] ath: doing EEPROM country->regdmn map search
Apr 8 21:42:42 turris kernel: [ 12.957870] ath: country maps to regdmn code: 0x3a
Apr 8 21:42:42 turris kernel: [ 12.957877] ath: Country alpha2 being used: US
Apr 8 21:42:42 turris kernel: [ 12.957882] ath: Regpair used: 0x3a
Apr 8 21:42:42 turris kernel: [ 12.989427] Bluetooth: Core ver 2.22
Apr 8 21:42:42 turris kernel: [ 12.993365] NET: Registered protocol family 31
Apr 8 21:42:42 turris kernel: [ 12.997606] Bluetooth: HCI device and connection manager initialized
Apr 8 21:42:42 turris kernel: [ 13.004395] Bluetooth: HCI socket layer initialized
Apr 8 21:42:42 turris kernel: [ 13.009132] Bluetooth: L2CAP socket layer initialized
Apr 8 21:42:42 turris kernel: [ 13.014824] Bluetooth: SCO socket layer initialized
Apr 8 21:42:42 turris kernel: [ 13.030813] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Apr 8 21:42:42 turris kernel: [ 13.035880] Bluetooth: BNEP filters: protocol multicast
Apr 8 21:42:42 turris kernel: [ 13.041805] Bluetooth: BNEP socket layer initialized
Apr 8 21:42:42 turris kernel: [ 13.064190] Bridge firewalling registered
Apr 8 21:42:42 turris kernel: [ 13.083229] Bluetooth: vendor=0x2df, device=0x9142, class=255, fn=2
Apr 8 21:42:42 turris kernel: [ 14.715739] Bluetooth: FW download over, size 626760 bytes
Apr 8 21:42:42 turris kernel: [ 14.960100] sdio platform data not available
Apr 8 21:42:42 turris kernel: [ 14.970059] usbcore: registered new interface driver btusb
Apr 8 21:42:42 turris kernel: [ 14.996662] Ebtables v2.0 registered
Apr 8 21:42:42 turris kernel: [ 15.002233] Bluetooth: HCI UART driver ver 2.3
Apr 8 21:42:42 turris kernel: [ 15.006848] Bluetooth: HCI UART protocol H4 registered
Apr 8 21:42:42 turris kernel: [ 15.012108] Bluetooth: HCI UART protocol BCSP registered
Apr 8 21:42:42 turris kernel: [ 15.017303] Bluetooth: HCI UART protocol ATH3K registered
Apr 8 21:42:42 turris kernel: [ 15.025401] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Apr 8 21:42:42 turris kernel: [ 15.031307] Bluetooth: HIDP socket layer initialized
Apr 8 21:42:42 turris kernel: [ 15.039019] ip_tables: (C) 2000-2006 Netfilter Core Team
Apr 8 21:42:42 turris kernel: [ 15.070589] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
Apr 8 21:42:42 turris kernel: [ 15.083674] ctnetlink v0.93: registering with nfnetlink.
Apr 8 21:42:42 turris kernel: [ 15.128411] Bluetooth: RFCOMM TTY layer initialized
Apr 8 21:42:42 turris kernel: [ 15.133562] Bluetooth: RFCOMM socket layer initialized
Apr 8 21:42:42 turris kernel: [ 15.138456] Bluetooth: RFCOMM ver 1.11
Apr 8 21:42:42 turris kernel: [ 15.145969] usbcore: registered new interface driver ums-alauda
Apr 8 21:42:42 turris kernel: [ 15.154023] usbcore: registered new interface driver ums-cypress
Apr 8 21:42:42 turris kernel: [ 15.161604] usbcore: registered new interface driver ums-datafab
Apr 8 21:42:42 turris kernel: [ 15.168907] usbcore: registered new interface driver ums-freecom
Apr 8 21:42:42 turris kernel: [ 15.176630] usbcore: registered new interface driver ums-isd200
Apr 8 21:42:42 turris kernel: [ 15.184467] usbcore: registered new interface driver ums-jumpshot
Apr 8 21:42:42 turris kernel: [ 15.192175] usbcore: registered new interface driver ums-karma
Apr 8 21:42:42 turris kernel: [ 15.199345] usbcore: registered new interface driver ums-sddr09
Apr 8 21:42:42 turris kernel: [ 15.205690] mwifiex_sdio mmc0:0001:1: WLAN is not the winner! Skip FW dnld
Apr 8 21:42:42 turris kernel: [ 15.214135] usbcore: registered new interface driver ums-sddr55
Apr 8 21:42:42 turris kernel: [ 15.221633] usbcore: registered new interface driver ums-usbat
Apr 8 21:42:42 turris kernel: [ 15.270171] xt_time: kernel timezone is -0000
Apr 8 21:42:42 turris kernel: [ 15.294772] PPP generic driver version 2.4.2
Apr 8 21:42:42 turris kernel: [ 15.302149] NET: Registered protocol family 24
Apr 8 21:42:42 turris kernel: 15.324194] kmodloader: done loading kernel modules from /etc/modules.d/*
Apr 8 21:42:42 turris kernel: [ 15.569982] mwifiex_sdio mmc0:0001:1: WLAN FW is active
Apr 8 21:42:42 turris kernel: [ 15.605400] mwifiex_sdio mmc0:0001:1: Unknown api_id: 3
Apr 8 21:42:42 turris kernel: [ 15.610614] mwifiex_sdio mmc0:0001:1: Unknown api_id: 4
Apr 8 21:42:42 turris kernel: [ 15.616222] mwifiex_sdio mmc0:0001:1: Unknown GET_HW_SPEC TLV type: 0x217
Apr 8 21:42:42 turris kernel: [ 15.659165] mwifiex_sdio mmc0:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.10.p56)
Apr 8 21:42:42 turris kernel: [ 15.667634] mwifiex_sdio mmc0:0001:1: driver_version = mwifiex 1.0 (16.68.10.p56)
Apr 8 21:42:42 turris kernel: [ 16.194660] zram0: detected capacity change from 0 to 253755392
Apr 8 21:42:42 turris kernel: [ 16.220314] Adding 247804k swap on /dev/zram0. Priority:-2 extents:1 across:247804k SS
Apr 8 21:42:42 turris kernel: [ 20.655587] IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
Apr 8 21:42:42 turris kernel: [ 20.686588] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Apr 8 21:42:42 turris kernel: [ 20.746226] mvneta d0040000.ethernet eth1: configuring for inband/2500base-x link mode
Apr 8 21:42:42 turris kernel: [ 20.755326] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Apr 8 21:42:42 turris kernel: [ 20.953226] mvneta d0040000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Apr 8 21:42:42 turris kernel: [ 20.970504] mv88e6085 d0032004.mdio-mii:02 lan1: configuring for phy/ link mode
Apr 8 21:42:42 turris kernel: [ 21.012774] br-lan: port 1(lan1) entered blocking state
Apr 8 21:42:42 turris kernel: [ 21.018019] br-lan: port 1(lan1) entered disabled state
Apr 8 21:42:42 turris kernel: [ 21.070780] device lan1 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 21.075573] device eth1 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 21.132900] mv88e6085 d0032004.mdio-mii:02 lan2: configuring for phy/ link mode
Apr 8 21:42:42 turris kernel: [ 21.140380] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Apr 8 21:42:42 turris kernel: [ 21.172204] br-lan: port 2(lan2) entered blocking state
Apr 8 21:42:42 turris kernel: [ 21.177537] br-lan: port 2(lan2) entered disabled state
Apr 8 21:42:42 turris kernel: [ 21.229865] device lan2 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 21.280230] mv88e6085 d0032004.mdio-mii:02 lan3: configuring for phy/ link mode
Apr 8 21:42:42 turris kernel: [ 21.318876] br-lan: port 3(lan3) entered blocking state
Apr 8 21:42:42 turris kernel: [ 21.324083] br-lan: port 3(lan3) entered disabled state
Apr 8 21:42:42 turris kernel: [ 21.402046] device lan3 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 21.476695] mv88e6085 d0032004.mdio-mii:02 lan4: configuring for phy/ link mode
Apr 8 21:42:42 turris kernel: [ 21.527991] br-lan: port 4(lan4) entered blocking state
Apr 8 21:42:42 turris kernel: [ 21.533026] br-lan: port 4(lan4) entered disabled state
Apr 8 21:42:42 turris kernel: [ 21.556638] BTRFS: device label srv devid 1 transid 103 /dev/sda
Apr 8 21:42:42 turris kernel: [ 21.586583] device lan4 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 21.631428] BTRFS info (device sda): disk space caching is enabled
Apr 8 21:42:42 turris kernel: [ 21.637583] BTRFS info (device sda): has skinny extents
Apr 8 21:42:42 turris kernel: [ 21.780244] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
Apr 8 21:42:42 turris kernel: [ 21.806947] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
Apr 8 21:42:42 turris kernel: [ 21.815704] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Apr 8 21:42:42 turris kernel: [ 23.039288] ath: EEPROM regdomain: 0x8028
Apr 8 21:42:42 turris kernel: [ 23.039295] ath: EEPROM indicates we should expect a country code
Apr 8 21:42:42 turris kernel: [ 23.039299] ath: doing EEPROM country->regdmn map search
Apr 8 21:42:42 turris kernel: [ 23.039302] ath: country maps to regdmn code: 0x37
Apr 8 21:42:42 turris kernel: [ 23.039306] ath: Country alpha2 being used: AT
Apr 8 21:42:42 turris kernel: [ 23.039309] ath: Regpair used: 0x37
Apr 8 21:42:42 turris kernel: [ 23.039313] ath: regdomain 0x8028 dynamically updated by user
Apr 8 21:42:42 turris kernel: [ 23.052721] mv88e6085 d0032004.mdio-mii:02 lan2: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 8 21:42:42 turris kernel: [ 23.129467] br-lan: port 2(lan2) entered blocking state
Apr 8 21:42:42 turris kernel: [ 23.134852] br-lan: port 2(lan2) entered forwarding state
Apr 8 21:42:42 turris kernel: [ 23.203740] mwifiex_sdio mmc0:0001:1: CMD_RESP: cmd 0x20 error, result=0x1
Apr 8 21:42:42 turris kernel: [ 23.261501] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Apr 8 21:42:42 turris kernel: [ 23.314505] mv88e6085 d0032004.mdio-mii:02 lan3: Link is Up - 100Mbps/Full - flow control off
Apr 8 21:42:42 turris kernel: [ 23.393844] br-lan: port 3(lan3) entered blocking state
Apr 8 21:42:42 turris kernel: [ 23.399273] br-lan: port 3(lan3) entered forwarding state
Apr 8 21:42:42 turris kernel: [ 24.356985] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Apr 8 21:42:42 turris kernel: [ 24.423513] br-lan: port 5(wlan1) entered blocking state
Apr 8 21:42:42 turris kernel: [ 24.428849] br-lan: port 5(wlan1) entered disabled state
Apr 8 21:42:42 turris kernel: [ 24.434514] device wlan1 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 24.673505] mv88e6085 d0032004.mdio-mii:02 lan4: Link is Up - 1Gbps/Full - flow control rx/tx
Apr 8 21:42:42 turris kernel: [ 24.749862] br-lan: port 4(lan4) entered blocking state
Apr 8 21:42:42 turris kernel: [ 24.755292] br-lan: port 4(lan4) entered forwarding state
Apr 8 21:42:42 turris kernel: [ 26.071871] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Apr 8 21:42:42 turris kernel: [ 26.961744] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Apr 8 21:42:42 turris kernel: [ 26.979346] ath10k_pci 0000:00:00.0: wmi print ‘P 128 V 8 T 410’
Apr 8 21:42:42 turris kernel: [ 26.985556] ath10k_pci 0000:00:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
Apr 8 21:42:42 turris kernel: [ 26.993757] ath10k_pci 0000:00:00.0: wmi print ‘alloc rem: 20984 iram: 25656’
Apr 8 21:42:42 turris kernel: [ 27.062523] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Apr 8 21:42:42 turris kernel: [ 27.084050] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Apr 8 21:42:42 turris kernel: [ 27.105632] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Apr 8 21:42:42 turris kernel: [ 27.213816] br-lan: port 6(wlan0) entered blocking state
Apr 8 21:42:42 turris kernel: [ 27.219407] br-lan: port 6(wlan0) entered disabled state
Apr 8 21:42:42 turris kernel: [ 27.224898] device wlan0 entered promiscuous mode
Apr 8 21:42:42 turris kernel: [ 27.455385] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Apr 8 21:42:42 turris kernel: [ 27.462166] br-lan: port 5(wlan1) entered blocking state
Apr 8 21:42:42 turris kernel: [ 27.467227] br-lan: port 5(wlan1) entered forwarding state
Apr 8 19:42:43 turris hostapd: wlan0: ACS-COMPLETED freq=2412 channel=1
Apr 8 19:42:43 turris hostapd: Using interface wlan0 with hwaddr 04:f0:21:45:d9:4f and ssid “AndiNet”
Apr 8 21:42:43 turris kernel: [ 30.734373] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Apr 8 21:42:43 turris kernel: [ 30.740992] br-lan: port 6(wlan0) entered blocking state
Apr 8 21:42:43 turris kernel: [ 30.746059] br-lan: port 6(wlan0) entered forwarding state
Apr 8 19:42:43 turris hostapd: wlan0: interface state ACS->ENABLED
Apr 8 19:42:43 turris hostapd: wlan0: AP-ENABLED
Apr 8 19:42:43 turris sentinel-dynfw-client[1952]: 2022-04-08 21:42:43,267 - WARNING - Unable to renew certificate (another try after 2 sec): [Errno -3] Try again
Apr 8 19:42:43 turris netifd: Network device ‘wlan0’ link is up
Apr 8 21:42:39 turris dnsmasq[2801]: started, version 2.80 DNS disabled
Apr 8 21:42:49 turris dnsmasq[2801]: overflow: 5 log entries lost
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Apr 8 19:42:52 turris ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Apr 8 19:42:53 turris ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Apr 8 19:42:53 turris ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Apr 8 19:42:53 turris ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Apr 8 19:42:53 turris ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Apr 8 19:42:54 turris crond[3543]: (CRON) STARTUP (1.5.7)
Apr 8 19:42:54 turris crond[3543]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 93% if used.)
Apr 8 19:42:54 turris crond[3543]: (CRON) INFO (running with inotify support)
Apr 8 19:42:57 turris turris: Router Turris successfully started.
Apr 8 19:42:57 turris procd: - init complete -
Apr 8 21:42:59 turris dnsmasq-dhcp[2801]: DHCPDISCOVER(br-lan) 192.168.1.238 b8:27:eb:bf:0f:b6
Apr 8 21:42:59 turris dnsmasq-dhcp[2801]: DHCPOFFER(br-lan) 192.168.1.238 b8:27:eb:bf:0f:b6
Apr 8 21:43:00 turris dnsmasq-dhcp[2801]: DHCPREQUEST(br-lan) 192.168.1.238 b8:27:eb:bf:0f:b6
Apr 8 21:43:00 turris dnsmasq-dhcp[2801]: DHCPACK(br-lan) 192.168.1.238 b8:27:eb:bf:0f:b6 co2lampel
Apr 8 19:43:02 turris /dhcp_host_domain_ng.py: DHCP add new hostname [co2lampel,192.168.1.238]
Apr 8 19:43:02 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 21:43:09 turris sentinel: INFO [certgen.action_spec_init:89] Valid certificate found
Apr 8 19:43:10 turris firewall: Reloading firewall due to ifup of lan (br-lan)
Apr 8 21:43:14 turris dnsmasq-dhcp[2801]: DHCPREQUEST(br-lan) 192.168.1.156 78:c4:0e:83:c1:53
Apr 8 21:43:14 turris dnsmasq-dhcp[2801]: DHCPACK(br-lan) 192.168.1.156 78:c4:0e:83:c1:53 Fronius_32274746
Apr 8 19:43:16 turris /dhcp_host_domain_ng.py: DHCP add new hostname [Fronius_32274746,192.168.1.156]
Apr 8 19:43:16 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:43:28 turris firewall: Reloading firewall due to ifup of wan (eth0)
Apr 8 21:43:29 turris dnsmasq-dhcp[2801]: read /etc/ethers - 0 addresses
Apr 8 19:43:30 turris /dhcp_host_domain_ng.py: DHCP update hostname [Fronius_32274746,192.168.1.156]
Apr 8 19:43:30 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:43:32 turris /dhcp_host_domain_ng.py: DHCP update hostname [co2lampel,192.168.1.238]
Apr 8 19:43:32 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:43:42 turris hostapd: wlan0: STA b8:27:eb:bf:0f:b6 IEEE 802.11: authenticated
Apr 8 19:43:42 turris hostapd: wlan0: STA b8:27:eb:bf:0f:b6 IEEE 802.11: associated (aid 1)
Apr 8 19:43:42 turris hostapd: wlan0: AP-STA-CONNECTED b8:27:eb:bf:0f:b6
Apr 8 19:43:42 turris hostapd: wlan0: STA b8:27:eb:bf:0f:b6 RADIUS: starting accounting session CC372516071CC65D
Apr 8 19:43:42 turris hostapd: wlan0: STA b8:27:eb:bf:0f:b6 WPA: pairwise key handshake completed (RSN)
Apr 8 21:43:42 turris dnsmasq-dhcp[2801]: DHCPREQUEST(br-lan) 192.168.1.238 b8:27:eb:bf:0f:b6
Apr 8 21:43:42 turris dnsmasq-dhcp[2801]: DHCPACK(br-lan) 192.168.1.238 b8:27:eb:bf:0f:b6 co2lampel
Apr 8 19:43:42 turris /dhcp_host_domain_ng.py: DHCP update hostname [co2lampel,192.168.1.238]
Apr 8 19:43:43 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:45:01 turris crond[4571]: (root) CMD (/usr/bin/notifier)
Apr 8 19:45:01 turris crond[4570]: (root) CMDOUT (There is no message to send.)
Apr 8 19:45:02 turris crond[4570]: (root) CMDEND (/usr/bin/notifier)
Apr 8 21:45:29 turris dnsmasq-dhcp[2801]: read /etc/ethers - 0 addresses
Apr 8 19:45:30 turris /dhcp_host_domain_ng.py: DHCP update hostname [Fronius_32274746,192.168.1.156]
Apr 8 19:45:30 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:45:31 turris /dhcp_host_domain_ng.py: DHCP update hostname [co2lampel,192.168.1.238]
Apr 8 19:45:31 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:45:33 turris ATLAS[1997]: And we are done
Apr 8 19:45:34 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 19:45:34 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 19:47:12 turris odhcpd[2049]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Apr 8 19:48:34 turris ATLAS[1997]: And we are done
Apr 8 19:48:35 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 19:48:35 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 21:49:54 turris dnsmasq-dhcp[2801]: DHCPDISCOVER(br-lan) 56:35:e3:59:4d:79
Apr 8 21:49:54 turris dnsmasq-dhcp[2801]: DHCPOFFER(br-lan) 192.168.1.223 56:35:e3:59:4d:79
Apr 8 21:49:54 turris dnsmasq-dhcp[2801]: DHCPREQUEST(br-lan) 192.168.1.223 56:35:e3:59:4d:79
Apr 8 21:49:54 turris dnsmasq-dhcp[2801]: DHCPACK(br-lan) 192.168.1.223 56:35:e3:59:4d:79
Apr 8 19:49:54 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 19:50:01 turris crond[5043]: (root) CMD (/usr/bin/notifier)
Apr 8 19:50:01 turris crond[5042]: (root) CMDOUT (There is no message to send.)
Apr 8 19:50:01 turris crond[5042]: (root) CMDEND (/usr/bin/notifier)
Apr 8 19:51:35 turris ATLAS[1997]: And we are done
Apr 8 19:51:35 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 19:51:35 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 19:51:47 turris odhcpd[2049]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Apr 8 19:54:36 turris ATLAS[1997]: And we are done
Apr 8 19:54:36 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 19:54:36 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 19:55:01 turris crond[5493]: (root) CMD (/usr/bin/notifier)
Apr 8 19:55:01 turris crond[5492]: (root) CMDOUT (There is no message to send.)
Apr 8 19:55:01 turris crond[5492]: (root) CMDEND (/usr/bin/notifier)
Apr 8 19:55:35 turris hostapd: wlan0: AP-STA-POLL-OK b8:27:eb:bf:0f:b6
Apr 8 19:57:03 turris odhcpd[2049]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Apr 8 19:57:36 turris ATLAS[1997]: enough space free, no need to do anything
Apr 8 19:57:36 turris ATLAS[1997]: And we are done
Apr 8 19:57:37 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 19:57:37 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 21:59:45 turris dnsmasq-dhcp[2801]: DHCPDISCOVER(br-lan) b2:14:bc:7c:c2:d1
Apr 8 21:59:45 turris dnsmasq-dhcp[2801]: DHCPOFFER(br-lan) 192.168.1.190 b2:14:bc:7c:c2:d1
Apr 8 21:59:45 turris dnsmasq-dhcp[2801]: DHCPREQUEST(br-lan) 192.168.1.190 b2:14:bc:7c:c2:d1
Apr 8 21:59:45 turris dnsmasq-dhcp[2801]: DHCPACK(br-lan) 192.168.1.190 b2:14:bc:7c:c2:d1
Apr 8 19:59:46 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 22:00:00 turris dnsmasq-dhcp[2801]: DHCPDISCOVER(br-lan) fe:ce:ef:91:af:c4
Apr 8 22:00:00 turris dnsmasq-dhcp[2801]: DHCPOFFER(br-lan) 192.168.1.155 fe:ce:ef:91:af:c4
Apr 8 22:00:00 turris dnsmasq-dhcp[2801]: DHCPREQUEST(br-lan) 192.168.1.155 fe:ce:ef:91:af:c4
Apr 8 22:00:00 turris dnsmasq-dhcp[2801]: DHCPACK(br-lan) 192.168.1.155 fe:ce:ef:91:af:c4 Pixel-5
Apr 8 20:00:01 turris crond[5912]: (root) CMD (/usr/bin/notifier)
Apr 8 20:00:01 turris crond[5911]: (root) CMDOUT (There is no message to send.)
Apr 8 20:00:01 turris crond[5911]: (root) CMDEND (/usr/bin/notifier)
Apr 8 20:00:01 turris /dhcp_host_domain_ng.py: DHCP add new hostname [Pixel-5,192.168.1.155]
Apr 8 20:00:01 turris /dhcp_host_domain_ng.py: Refresh kresd leases
Apr 8 20:00:37 turris ATLAS[1997]: enough space free, no need to do anything
Apr 8 20:00:37 turris ATLAS[1997]: And we are done
Apr 8 20:00:38 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 20:00:38 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 20:03:15 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 IEEE 802.11: authenticated
Apr 8 20:03:15 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 IEEE 802.11: associated (aid 2)
Apr 8 20:03:15 turris hostapd: wlan0: AP-STA-CONNECTED fe:ce:ef:91:af:c4
Apr 8 20:03:15 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 RADIUS: starting accounting session B999D25865F217DE
Apr 8 20:03:15 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 WPA: pairwise key handshake completed (RSN)
Apr 8 20:03:38 turris ATLAS[1997]: enough space free, no need to do anything
Apr 8 20:03:38 turris ATLAS[1997]: And we are done
Apr 8 20:03:39 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 20:03:39 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 20:05:01 turris crond[6361]: (root) CMD (/usr/bin/notifier)
Apr 8 20:05:01 turris crond[6360]: (root) CMDOUT (There is no message to send.)
Apr 8 20:05:01 turris crond[6360]: (root) CMDEND (/usr/bin/notifier)
Apr 8 20:05:36 turris odhcpd[2049]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Apr 8 20:06:22 turris hostapd: wlan0: AP-STA-DISCONNECTED fe:ce:ef:91:af:c4
Apr 8 20:06:22 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 IEEE 802.11: authenticated
Apr 8 20:06:22 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 IEEE 802.11: associated (aid 2)
Apr 8 20:06:22 turris hostapd: wlan0: AP-STA-CONNECTED fe:ce:ef:91:af:c4
Apr 8 20:06:22 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 RADIUS: starting accounting session B999D25865F217DE
Apr 8 20:06:22 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 WPA: pairwise key handshake completed (RSN)
Apr 8 20:06:39 turris ATLAS[1997]: enough space free, no need to do anything
Apr 8 20:06:39 turris ATLAS[1997]: And we are done
Apr 8 20:06:39 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/v6addr.txt’ exists
Apr 8 20:06:39 turris ATLAS[1997]: condmv: not moving, destination ‘/usr/libexec/atlas-probe-scripts/data/out/simpleping’ exists
Apr 8 20:09:12 turris hostapd: wlan0: AP-STA-DISCONNECTED fe:ce:ef:91:af:c4
Apr 8 20:09:12 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 IEEE 802.11: authenticated
Apr 8 20:09:12 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 IEEE 802.11: associated (aid 2)
Apr 8 20:09:12 turris hostapd: wlan0: AP-STA-CONNECTED fe:ce:ef:91:af:c4
Apr 8 20:09:12 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 RADIUS: starting accounting session B999D25865F217DE
Apr 8 20:09:12 turris hostapd: wlan0: STA fe:ce:ef:91:af:c4 WPA: pairwise key handshake completed (RSN)
Apr 8 20:09:39 turris ATLAS[1997]: enough space free, no need to do anything
