My Turris Omnia crashed and, for unknown reasons, did not reboot (power on, but zero response on the network). I first tried to return to the latest snapshot, same issue. Then I returned to factory settings, Everything went fine, I reconfigured the box.
Then, I had two bad ideas, upgrading the software, and doing it too rapidly without thinking or recording what I did.
Now, I can no longer manage the Omnia:
Foris crashes “Unhandled Exception” with a long Python stack trace in the log,
Luci crashes “500 Internal Server Error”
I can log in with SSH but:
pkgupdate crashes with many SSL errors such as “Error relocating /usr/lib/libunbound.so.8: SSL_ctrl: symbol not found”
opkg crashes “Error loading shared library libssl.so.1.0.0: No such file or directory (needed by /usr/bin/curl)”
Indeed, I can see that /usr/lib has only libssl.so.1.1 while some apps are built with 1.0.0.
So, two questions:
Is there a way to repair the current system? Such as statically built versions of software somewhere?
If I return again to factory settings, is there a way to upgrade properly an old Omnia (2015) to a current system or is it hopeless?
Try rescue mode 4 to flash a newer Turris OS. Then use schnapps update-factory to get the newest factory image. Then you can reset the router using the latest factory image (or you may just use the system flashed in the first step).
If you’re more adveturous, this is the code that performs update-factory using raw btrfs CLI commands:
if btrfs subvolume create "$TMP_MNT_DIR"/@$NUMBER > /dev/null; then
if tar -C "$TMP_MNT_DIR"/@$NUMBER --numeric-owner -xpzvf "$TAR"; then
if [ -d "$TMP_MNT_DIR"/@factory ]; then
mv "$TMP_MNT_DIR"/@factory "$TMP_MNT_DIR"/@factory-old
else
echo "No factory image present, this will be the first one"
fi
mv "$TMP_MNT_DIR"/@$NUMBER "$TMP_MNT_DIR"/@factory
[ \! -d "$TMP_MNT_DIR"/@factory-old ] || btrfs subvolume delete -c "$TMP_MNT_DIR"/@factory-old
echo "Your factory image was updated!"
else
btrfs subvolume delete "$TMP_MNT_DIR"/@$NUMBER
die "Tarball seems to be corrupted"
fi
and if you are successfull and your Omnia will boot properly, then after you pass the guide log via ssh and use command as @peci1 metnioned to update your old factory image to newer one with command:
Please let me know if it works for you. If not I have one another option in my head.
It’s a shot in the dark, but I reset to factory recently, and I think I had an issue where the updater tried to rollback a 7.0.0 medkit to 9.x.x (which broke a lot of things including curl/updates). So when you setup from scratch, I would advise disabling the automatic updates and set it to “manual approval” mode, and double check which versions it wants to install.
I might be wrong though, and I didn’t bother taking extensive logs so YMMV
You don’t have to wait, if you use pkgupdate through ssh, then the upgrade should start. Staging part is over now. (Divided upgrade of routers to waves).
Actually, the next upgrade did break things again. Same problem, same solution. I had to go back two snapshots since the “Automatic post-update snapshot (TurrisOS 7.0.0 - hbs)” was broken as well. “Automatic pre-update snapshot (TurrisOS 6.5.2 - hbs)” worked.
I of course disabled automatic updates but, now, I have a question: why does my Omnia fail to go to TurrisOS 7? How to debug that?
One of the problems could be when you’re low on RAM during the update. Do you have many services or LXC containers configured? Did you configure swap space?
May I ask what do you use LXC containers for on a router?
I use full VMs in my laptops, but have never been smart enough to think of a use case for LXC containers.
Mostly to run software that is not packaged for OpenWRT, but is available in e.g. Debian. I use it to run NodeRed+InfluxDB+Grafana to log environmental data from sensors in my rooms.
