Add a TRNG as a perk
“In computing, a hardware random number generator (TRNG, True Random Number Generator) is a device that generates random numbers from a physical process, rather than a computer program” Wikipedia
Using some cheap chips, such as a STM32F103, it’s possible to create a USB stick which can act as a TRNG and offer about 500-600 kbit/s throughput. The software is Open Source.
It should cost about $15-25 to manufacture and could be offered as a perk for no more than $30
“Apart from that, Turris Omnia also has SIM card slot, RTC with battery
backup, crypto chip for secure random number generation, dimmable RGB
LEDs, pin headers with GPIO, I²C, SPI and more.”
@elodg - It’s not a TRNG, see https://discourse.labs.nic.cz/t/which-trng-chip-are-you-using/218/3
I am not sure if its really needed - there are lot of them already, with USB, Ethernet or PCIe interface.
Yes, but the point was to provide one, which would be tested and known to work well and at a reasonable price for backers, shipped at the same time.
