I first mention the clean installation of TOS 5 …but so far I have not been able to activate the DNS report function, is the error on my side or is it a property ?
*** Package tcpdump-mini and tcpdump are instalated.
Under “Advanced Report Settings”, I believe you also need to set “Report Interface” to br-lan and set “Report Directory”. You can set it to “/tmp” somewhere, but if you have persistent storage, you’ll get more history and it will not be cleared after reboot.
I didn’t get any data until I set the “Report Directory” for sure.
Yes , I had the wrong interface set up. But editing the “Report Directory” field is not possible in Luci … the field is grayed out. Is probably need to edit the /etc/init.d/adblock file, but there is a folder /tmp/ in multiple places in code and I can’t figure out which of the values I should edit - maybe all.
After router restart "DNS Report " working. Now the working directory
In /tmp/ folder are this file
adb_runtime.json
adb_report.json
adb_report.pcap0
adb_sources.json
EDIT 18:29: edit file /etc/init.d/adblock I failed and had to reinstall AdBlock
Did you select at least one input field and did you try to input a valid path? What you’ve marked is the grey default value (a HTML placeholder), just overwrite this … it’s standard in LuCI.
