Adblock not working
I just installed Adblock on TO (V4.0.5). Adblock is enabled and started, several block list sources are enable but Adblock doesn’t seem to work.
This isn’t suppose to happen when Adblock is functioning correctly.
/etc/kresd$ nslookup securepubads.g.doubleclick.net localhost
Server: localhost
Address: ::1#53
securepubads.g.doubleclick.net canonical name = partnerad.l.doubleclick.net
Address 1: 172.217.168.226
Also i noticed something strange in that overall_domains : 0 (normal mode)
/etc/kresd$ /etc/init.d/adblock status
::: adblock runtime information
  • adblock_status : enabled
  • adblock_version : 3.5.5-2
  • overall_domains : 0 (normal mode)
  • fetch_utility : /bin/wget (built-in)
  • dns_backend : kresd (/etc/kresd)
  • last_rundate : 25.02.2020 19:08:02
  • system_release : Turris Omnia, TurrisOS 4.0.5 ab9d1bf/4.0.5
Alltough the logfile writes
Feb 25 18:24:03 TurrisJK adblock-3.5.5-2[11485]: blocklist with overall 0 domains loaded successfully (Turris Omnia, TurrisOS 4.0.5 ab9d1bf/4.0.5)
How can i fix Adblock?
TIA
Well it seems I have the same problem…
root@turris:~# /etc/init.d/adblock status
  + adblock_status  : enabled
  + adblock_version : 3.8.15
  + overall_domains : 0
  + fetch_utility   : /usr/bin/wget (built-in)
  + dns_backend     : kresd, /etc/kresd
  + dns_variant     : nxdomain, false
  + backup_dir      : /tmp
  + last_rundate    : 25.02.2020 20:14:58
  + system_release  : Turris Omnia, TurrisOS 5.0.0 af79c3bccce6781c7045bd09d37585a96c0a6137
Logfile:
Feb 25 19:14:53 turris adblock-3.8.15[15034]: adblock instance started ::: action: reload, priority: 0, pid: 15034
Feb 25 19:14:58 turris adblock-3.8.15[15034]: blocklist with overall 0 domains loaded successfully (Turris Omnia, TurrisOS 5.0.0 af79c3bccce6781c7045bd09d37585a96c0a6137)
Got it working by installing libustream-ssl and choosing uclient-fetch.
Edit: Curl seems to work also and doesn’t need libustream.
It works on my site, I’m using curl to download the blocklists:
Thanks, changing to curl helped.
Had similar issue, but curl did not helped. My solution was the setup over shell = setup over luci was not working
