Hi, it may be something very basic, but I dont know how to solve this (yes, I tried google with no result
Adblock suddenly stopped loading lists from sources saying in lo there is no online timestamp - source skipped
LOG:
2016-12-15T19:05:10+01:00 notice adblock[2256]: info : adblock service started due to âifupâ of âwanâ interface
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : domain adblock processing started (1.3.3, r47055, 15.12.2016 20:05:10)
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : backup/restore will be disabled
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : created volatile firewall rulesets
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : created volatile uhttpd instances
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : => processing source âadawayâ
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : no online timestamp
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : source download failed, skipped
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : => processing source âblacklistâ
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : empty source download, skipped
2016-12-15T19:05:10+01:00 notice adblock[2452]: info : => processing source âdisconnectâ
Could sb tell me what I did wrong? I followed this howto
It most likely has to do with DNS. TO doesnât use dnsmasq for DNS resolving but it uses Knot DNS. I am not sure how up to date the guide you used is + we got an update which might updated dnsmasq/knot version and/or configuration files. So probably a configuration/autoupdate problem somewhere. Unfortunately, I canât help you there since I donât use the adblock package.
Syslog doesnât reveal that much however this line leads me to the conclusion above:
2016-12-16T10:51:32+01:00 err ntpdate[1798]: name server cannot be used: Try again (-3)
