is there a way how to block ads with Omnia? I did use unbound with list of ad servers on old Turris router, but it doesn’t work with Omnia (probably thanks to Knotd resolver). Old guide is here (in CZ): http://www.s474n.com/project-turris-blokovani-reklam-a-trackeru/
Thanks!
An easy solution that I implemented is to set up a LXC container and install PiHole into that, works just fine and takes up very little resources on the Omnia.
You can set up a LXC container through the LuCI interface, log into it via command line and install PiHole by following their easy installer on their web site. Then just re-configure your DHCP to point to the PiHole server for DNS for your network.
Just a custom script.
You can use the same list of blocked hosts as pi-hole.
Keep the default resolver.
I have 35k blocked sites
