Thanks for your help so far!
Output:
/etc/init.d/adblock status
root@turris:~# /etc/init.d/adblock status
::: adblock runtime information
+ adblock_status : enabled
+ adblock_version : 3.5.1
+ overall_domains : 74635 (normal mode)
+ fetch_utility : /usr/bin/wget (built-in)
+ dns_backend : kresd (/etc/kresd)
+ last_rundate : 05.03.2018 18:03:59
+ system_release : Turris Omnia, OpenWrt omnia 15.05/3.9.5
/etc/config/resolver
config resolver 'common'
list interface '0.0.0.0'
list interface '::0'
option port '53'
option keyfile '/etc/root.keys'
option verbose '0'
option msg_buffer_size '4096'
option msg_cache_size '20M'
option net_ipv6 '1'
option net_ipv4 '1'
option forward_upstream '1'
option prefered_resolver 'kresd'
option ignore_root_key '0'
option prefetch 'yes'
option static_domains '1'
option dynamic_domains '0'
config resolver 'kresd'
option rundir '/tmp/kresd'
option log_stderr '1'
option log_stdout '1'
option forks '1'
list rpz_file '/etc/kresd/adb_list.overall'
option keep_cache '1'
config resolver 'unbound'
option outgoing_range '60'
option outgoing_num_tcp '1'
option incoming_num_tcp '1'
option msg_cache_slabs '1'
option num_queries_per_thread '30'
option rrset_cache_size '100K'
option rrset_cache_slabs '1'
option infra_cache_slabs '1'
option infra_cache_numhosts '200'
list access_control '0.0.0.0/0 allow'
list access_control '::0/0 allow'
option pidfile '/var/run/unbound.pid'
option root_hints '/etc/unbound/named.cache'
option target_fetch_policy '2 1 0 0 0'
option harden_short_bufsize 'yes'
option harden_large_queries 'yes'
option qname_minimisation 'yes'
option harden_below_nxdomain 'yes'
option key_cache_size '100k'
option key_cache_slabs '1'
option neg_cache_size '10k'
option prefetch_key 'yes'
config resolver 'unbound_remote_control'
option control_enable 'yes'
option control_use_cert 'no'
list control_interface '127.0.0.1'
/etc/config/adblock
config adblock 'global'
option adb_enabled '1'
option adb_dns 'kresd'
option adb_fetchutil 'wget'
option adb_trigger 'timed'
config adblock 'extra'
option adb_forcesrt '0'
option adb_backup '0'
option adb_maxqueue '16'
option adb_debug '0'
option adb_forcedns '1'
config source 'adaway'
option adb_src 'https://adaway.org/hosts.txt'
option adb_src_rset '/^127\.0\.0\.1[[:space:]]+([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[:space:]]|$)/{print tolower(\$2)}'
option adb_src_desc 'focus on mobile ads, infrequent updates, approx. 400 entries'
option enabled '1'
config source 'adguard'
option adb_src 'https://filters.adtidy.org/windows/filters/15.txt'
option adb_src_rset 'BEGIN{FS=\"[/|^|\r]\"}/^\|\|([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([\/\^\r]|$)/{print tolower(\$3)}'
option adb_src_desc 'combined adguard dns filter list, frequent updates, approx. 17.000 entries'
option enabled '1'
config source 'bitcoin'
option adb_src 'https://raw.githubusercontent.com/hoshsadiq/adblock- nocoin-list/master/hosts.txt'
option adb_src_rset '/^0\.0\.0\.0[[:space:]]+([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[:space:]]|$)/{print tolower(\$2)}'
option adb_src_desc 'focus on malicious bitcoin mining sites, infrequent updates, approx. 80 entries'
option enabled '0'
config source 'blacklist'
option adb_src '/etc/adblock/adblock.blacklist'
option adb_src_rset '/^([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[: space:]]|$)/{print tolower(\$1)}'
option adb_src_desc 'static local domain blacklist, always deny these domains'
option enabled '1'
config source 'disconnect'
option adb_src 'https://s3.amazonaws.com/lists.disconnect.me/ simple_malvertising.txt'
option adb_src_desc 'mozilla driven blocklist, numerous updates on the same day, approx. 4.700 entries'
option enabled '1'
config source 'dshield'
option adb_src 'https://www.dshield.org/feeds/suspiciousdomains_Low.txt'
option adb_src_desc 'generic blocklist, daily updates, approx. 3.500 entries'
option enabled '0'
config source 'feodo'
option adb_src 'https://feodotracker.abuse.ch/blocklist/? download=domainblocklist'
option adb_src_desc 'focus on feodo botnet, daily updates, approx. 0-10 entries'
option enabled '0'
config source 'hphosts'
option adb_src 'https://hosts-file.net/ad_servers.txt'
option adb_src_rset '/^127\.0\.0\.1[[:space:]]+([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[:space:]]|\$)+/{print tolower(\$2)}'
option adb_src_desc 'broad blocklist, monthly updates, approx. 19.200 entries'
option enabled '0'
config source 'malware'
option adb_src 'https://mirror.espoch.edu.ec/malwaredomains/justdomains'
option adb_src_desc 'broad blocklist, daily updates, approx. 18.300 entries'
option enabled '1'
config source 'malwarelist'
option adb_src 'http://www.malwaredomainlist.com/hostslist/hosts.txt'
option adb_src_desc 'focus on malware, daily updates, approx. 1.200 entries'
option enabled '0'
config source 'openphish'
option adb_src 'https://openphish.com/feed.txt'
option adb_src_rset 'BEGIN{FS=\"/\"}/^http[s]?:\/\/([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+(\/|$)/{print tolower(\$3)}'
option adb_src_desc 'focus on phishing, numerous updates on the same day, approx. 2.400 entries'
option enabled '0'
config source 'ransomware'
option adb_src 'https://ransomwaretracker.abuse.ch/downloads/RW_DOMBL. txt'
option adb_src_desc 'focus on ransomware, numerous updates on the same day, approx. 1900 entries'
option enabled '0'
config source 'reg_cn'
option adb_src 'https://easylist-downloads.adblockplus.org/ easylistchina+easylist.txt'
option adb_src_rset 'BEGIN{FS=\"[|^]\"}/^\|\|([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+\^("\\\$third-party")?$/{print tolower(\$3)}'
option adb_src_desc 'focus on chinese ads plus generic easylist additions, daily updates, approx. 11.700 entries'
option enabled '0'
config source 'reg_cz'
option adb_src 'https://raw.githubusercontent.com/qxstyles/turris-hole- czech-block-list/master/turris-hole-czech-block-list'
option adb_src_desc 'focus on czech ads maintained by Turris Omnia Users, infrequent updates, approx. 100 entries'
option enabled '0'
config source 'reg_de'
option adb_src 'https://easylist-downloads.adblockplus.org/ easylistgermany+easylist.txt'
option adb_src_desc 'focus on german ads plus generic easylist additions, daily updates, approx. 9.200 entries'
option enabled '0'
config source 'reg_id'
option adb_src 'https://easylist-downloads.adblockplus.org/abpindo+ easylist.txt'
option adb_src_desc 'focus on indonesian ads plus generic easylist additions, weekly updates, approx. 9.600 entries'
option enabled '0'
config source 'reg_nl'
option adb_src 'https://easylist-downloads.adblockplus.org/ easylistdutch+easylist.txt'
option adb_src_desc 'focus on dutch ads plus generic easylist additions, weekly updates, approx. 9.400 entries'
option enabled '0'
config source 'reg_pl'
option adb_src 'http://adblocklist.org/adblock-pxf-polish.txt'
option adb_src_desc 'focus on polish ads, daily updates, approx. 90 entries'
option enabled '0'
config source 'reg_ro'
option adb_src 'https://easylist-downloads.adblockplus.org/rolist+easylist.txt'
option adb_src_rset 'BEGIN{FS=\"[|^]\"}/^\|\|([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+\^("\\\$third-party")? $/{print tolower(\$3)}'
option adb_src_desc 'focus on romanian ads plus generic easylist additions, weekly updates, approx. 9.400 entries'
option enabled '0'
config source 'reg_ru'
option adb_src 'https://easylist-downloads.adblockplus.org/ruadlist+easylist.txt'
option adb_src_desc 'focus on russian ads plus generic easylist additions, weekly updates, approx. 14.500 entries'
option enabled '0'
config source 'shalla'
option adb_src 'http://www.shallalist.de/Downloads/shallalist.tar.gz'
option adb_src_rset '/^([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[:space:]]|$)/{print tolower(\$1)}'
option adb_src_desc 'broad blocklist subdivided in different categories, daily updates, approx. 31.700 entries'
list adb_src_cat 'adv'
list adb_src_cat 'costtraps'
list adb_src_cat 'spyware'
list adb_src_cat 'tracker'
list adb_src_cat 'warez'
option enabled '0'
config source 'spam404'
option adb_src 'https://raw.githubusercontent.com/Dawsey21/Lists/master/main-blacklist.txt'
option adb_src_rset '/^([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[:space:]]|$)+/{print tolower(\$1)}'
option adb_src_desc 'generic blocklist, infrequent updates, approx. 6.000 entries'
option enabled '0'
config source 'sysctl'
option adb_src 'http://sysctl.org/cameleon/hosts'
option adb_src_rset '/^127\.0\.0\.1[[:space:]]+([^([:space:]|#|\*|\/).]+\.)+[[:alpha:]]+([[:space:]]|$)/ {print tolower(\$2)}'
option adb_src_desc 'broad blocklist, weekly updates, approx. 16.500 entries'
option enabled '0'
config source 'whocares'
option adb_src 'http://someonewhocares.org/hosts/hosts'
option adb_src_desc 'broad blocklist, weekly updates, approx. 10.000 entries'
option enabled '0'
config source 'winspy'
option adb_src 'https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/win10/spy. txt'
option adb_src_desc 'focus on windows spy & telemetry domains, infrequent updates, approx. 300 entries'
option enabled '0'
config source 'winhelp'
option adb_src 'http://winhelp2002.mvps.org/hosts.txt'
option adb_src_desc 'broad blocklist, infrequent updates, approx. 13.000 entries'
option enabled '0'
config source 'yoyo'
option adb_src 'https://pgl.yoyo.org/adservers/serverlist.php? hostformat=nohtml&showintro=0&mimetype=plaintext'
option adb_src_desc 'focus on ad related domains, weekly updates, approx. 2.400 entries'
option enabled '1'
config source 'zeus'
option adb_src 'https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist'
option adb_src_desc 'focus on zeus botnet, daily updates, approx. 400 entries'
option enabled '0'
config source 'stevenblack'
option enabled '1'
option adb_src 'https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts'
option adb_src_rset '\$0~/^0\.0\.0\.0[[:space:]]+([[:alnum:]_-]+\.){1,}[[:alpha:]]+([[:space:]]|$)/{print tolower(\$2)}'
option adb_src_desc 'unified blocklist, daily updates, approx. 32.000 entries'
