Thanks for the quick reaction! I did the changes on Luci. I had guessed that more info were needed but I don’t know which one to send.
By the way, I see only the “normal” network and the button to enable the guest wifi in the page you show in ReForis. I don’t see the third and forth wifi networks there.
I’m sorry but there must be a misunderstanding, I don’t want to enable the guest network on the 5GHz wifi. I just wanted to say that without 5GHz guest network, the “normal” 5GHz is not active (I mean that clients don’t see the wifi network).
I think that the issue is more general. I disabled one of the wifi network in LuCi. In the following screenshot you can see that the network Doma.g is disabled but the diagram shows that there are still some clients connected to it.
