My Omnia is running with latest 3.11.7. But I had this at least with 3.11.6 as well.
My 5GHz WLAN is usually running on channel 64. This works for some time, but then suddenly the interface changes back to channel 36.
# iw dev wlan0 info
Interface wlan0
ifindex 21
wdev 0x7
addr ...
ssid ....
type AP
wiphy 0
channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
while
config wifi-device 'radio0'
option type 'mac80211'
option hwmode '11a'
option path 'soc/soc:pcie-controller/pci0000:00/0000:00:02.0/0000:02:00.0'
option country 'AT'
option htmode 'VHT80'
option txpower '20'
option channel '64'
luci displays the difference as well (36 active, 64 configured). Disabling and enabling the interface “fixes” it.
This time it happend while I was streaming a Video. It suddenly stopped and I can’t reconnect for some time (DFS delay?).
There is no output in dmesg or messages from the kernel. Only hostap reauthenticates all devices after some time.
