Docs 5G kit - Turris Documentation say 5G kit isn’t officially supported on Omnia Wifi 6. Is the only reason the need to drill in the case, or are there some other incompatibilities?
I’ll answer myself. It works without issues if you find a place for the extra antenna(s). Not sure about interference, though.
