3.7.1 is in RC with OpenVPN 2.4.3 and fixes!
Dear Turristers,
3.7.1 is now in RC, you’re welcome to test it and share your experience here.
Changes are:
• kernel: security update to the newer version
• opnvpn: security update to the newer version (fixing CVE-2017-7521)
• knot: security update to the newer version
• luci-ssl: fix dependencies
• foris: fix data collecting
• printing: cups removed from userlist for old turris routers
EDIT:
:eyes: We have found a bug (caused by a kernel update) that could turn off the 5GHz network on Omnia in some specific conditions.
Results:
  1. RC has been reverted on Omnia, is up and running on Turris 1.x
  2. Bug fixed, transmission-web package added.
  3. We are building the release.
  4. RC will be released for both models tomorrow.
EDIT 2:
RC2 had been released including 5GHz fix and transmission-web package.
Happy testing, deploy should be tomorrow!
I want to warn about forris error - home automation installing via forris does nothing.
only luci opkg works.
Yep. There was just plain -- TODO fill in O:-). But nobody noticed since Omnia came out. Thank you for reporting it. It will be fixed in one of the following fixup releases.
Czech: Dnes ráno (cca v 9:00) byly vydány další RC verze pro Turris i Omnii (link do repa)
The same in English: The other version of RC was released this morning for both (Turris and Omnia) routers.
Tady vás někdo ukouše, píšete jim do angl. fóra česky… :grinning:
3.7.1 has been released for all, enjoy the fixes!
https://forum.test.turris.cz/t/turris-os-3-7-1-out-with-fixes/4466?u=vaclav
