Hallo Turris,
is there some 2 WAN model planned (backup connection)?
Or is it possible to use 2 WAN ports with actual components?
Thx
Definitely yes. You can set any LAN port to work as WAN. It is just the configuration.
Thank you, but one more question: Are there some settings related to 2 WAN ports i.e. traffic balance, priority, routing and fail connection behaviour?
Try using mwan3 package to manage multiple WANs.
