Yamon 4.0.7 on turris 5.2.3
Did somebody installed yamon 4.0.7 on turris 5.2.3 successfully?
I did everything as installation instruction prosed, also I fixed link as mentioned
But when I go http://192.168.10.1/yamon I got “404 Not Found” (my turris ip is 192.168.10.1 and e.g. http://192.168.10.1/reforis is working)
As there are data in /opt/YAMon4/data/2021/07 I expect there is problem with web interface…
seems like lighttpd problem:
mkdir /www/test
echo "<P>It works!</P>" > /www/test/index.html
/etc/init.d/lighttpd restart
and http://192.168.10.1/test/ produced “404 Not Found”…
Did you find a solution to this issue? I have again the same problem!
Thanks
Astrakan
I tried some things too, but gave up with Yamon 4 a while back since I couldn’t get it to work properly.
It was taking more management than the benefit I was seeing. I haven’t bothered with going back to Yamon 3 either.
