often, the router seems to detect only one of the two present wireless adapters:
root@turris:~# dmesg | grep wlan
[ 24.981820] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.982786] device wlan0 entered promiscuous mode
[ 25.047853] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 25.047913] br-lan: port 3(wlan0) entered forwarding state
[ 25.047932] br-lan: port 3(wlan0) entered forwarding state
[ 27.040710] br-lan: port 3(wlan0) entered forwarding state
The output when both cards are detected is:
[ 26.651556] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 27.956724] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 27.956908] device wlan1 entered promiscuous mode
[ 27.961319] device wlan0 entered promiscuous mode
[ 28.024521] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 28.024579] br-lan: port 3(wlan1) entered forwarding state
[ 28.024598] br-lan: port 3(wlan1) entered forwarding state
[ 30.020733] br-lan: port 3(wlan1) entered forwarding state
[ 37.772865] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 37.772930] br-lan: port 4(wlan0) entered forwarding state
[ 37.772962] br-lan: port 4(wlan0) entered forwarding state
[ 39.770727] br-lan: port 4(wlan0) entered forwarding state
Only the WLE200N2 adapter is detected. So far, I haven’t investigated how to install lspci on the system.
I was also hit by https://discourse.labs.nic.cz/t/wi-fi-antenna-screwed/884 ; when connecting the antennas, I managed to disconnected one of the cables; but I connected it again before turning the router on. Also, my key size 8 seems to be too big (and size 7 too small).
I had a look at https://discourse.labs.nic.cz/t/second-wlan-adapter-not-detected/978 , but in my case, I Have problems with the other adapter, and sometimes, the adapter is detected and works correctly.
What can be wrong?
