I’m using the Mini PCI-E to SATA 3 Expansion Card for Hard Drive - Green to connect to SATA drives to the Omnia.
Will hd-idle
work with RAID HDDs attached via PCI or just external USB drives?
Will hd-idle
It will work with both USB and SATA drives…
root@turris:~# cat /etc/config/hd-idle
config hd-idle 'disky’
option idle_time_unit 'minutes’
option idle_time_interval '10’
option enabled ‘1’
root@turris:~#
It doesn’t appear that hd-idle
is working with both HDDs (sda
and sdb
# ps | grep hd-idle
547 root 708 S /usr/bin/hd-idle -a sda -i 600
633 root 1092 R grep hd-idle
The configuration file (which I edited manually to add the second disk):
config hd-idle
option idle_time_unit 'minutes'
option idle_time_interval '10'
option enabled '1'
option disk 'sda'
config hd-idle
option enabled '1'
option disk 'sdb'
I restarted the service, but that didn’t make a difference.
Is there something else that I need to do?
That’s right:
config hd-idle
option enabled '1'
What’s the best way to determine if the disks are spinning or not?
** edit **
# smartctl --nocheck standby -i /dev/sdb
smartctl 6.5 2016-05-07 r4318 [armv7l-linux-4.4.59-627f0117679bc72ef5e58881035f567a-4] (localbuild)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda LP
Device Model: ST32000542AS
Serial Number: XXXXXXXXXXX
LU WWN Device Id: YYYYYYYYYY
Firmware Version: CC34
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5900 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Mon Jun 26 06:55:31 2017 CDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213915en
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Power mode is: ACTIVE or IDLE
Same for /dev/sda
** /edit **
Also, should this affect the fan? Will it always spin?
Is there a way to disable lines in this type of file? It seems like the #
(pound, hash, hashtag) doesn’t always work.
