ekim
January 24, 2018, 6:15am
1
Since some time the wireless speed on the 5ghz band is really slow. The speed I get is 20 Mbps. When I use another wireless access point I get 200 Mbps.
Are there more people who are having this problem?
If you need more info, please let iT know below.
fickk
January 24, 2018, 8:21am
2
You can try last four lines from my /etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option hwmode '11a'
option path 'platform/soc/soc:pcie-controller/pci0000:00/0000:00:01.0/0000:01:00.0'
option htmode 'VHT80'
option channel '36'
option txpower '23'
option distance '10'
option country '00'
option bursting '1'
option ff '1'
option compression '1'
option noscan '1'
ekim
January 24, 2018, 7:19pm
3
Hi thnx for your reply.
Can you tell me what those options do please?
fickk
January 24, 2018, 9:50pm
4
Unfortunatelly I have done only short tests with copying big files. Throughput was better, but I am unsure about cause.
https://wiki.openwrt.org/doc/uci/wireless
ekim
January 26, 2018, 8:13am
5
To eliminate the possibility that my omnia is the problem, I have installer my old router for now.
I have been werking with a cabke and the problem still persists. So this might not even be a wireless problem.
I work from home so a good connection is really important.
I Am sad to say this, But in the case that there is somerhing wrong with my omnia I have No choice to refrein from using iT.
ekim
January 27, 2018, 7:30pm
6
Update:
Rolled my turris omnia back to factory settings (3.2.1 iirc).
Problem seems to be solved. However, when I turn WIFI on, the problem occurs again.
