Wifi 6 upgrade problem
So, I’m late to the party but finally upgraded my Omnia with the wifi-6 kit. Just a heads up that running on Turris 7.1.3, the upgrade triggered a bug in the OS where the firewall would not setup correctly and block connections. I had to
connect to the serial console, disable the firewall manually, reset the wifi configuration and then it worked okay.
I’m still under the impression that there’s something wrong with my turris as it seems I sometimes have problem with the LAN0 port on the bridge. Is there a diagnostic tool to check for problems?
And what Uncle Google ??
et cetera
