Which card to use
Which wifi card should I use for the best 2.4ghz signal?
I opened up the turris and see a small wifi card with only two antennas attached to it. Then I see the second which is about twice as large which all three antennas attached hooked up to it. Would the larger card yield more and wider signal?
Wondering how to better increase the signal horizontally and which card to activate / deactivate . Tnx!
You should use the small one as by default the big one is targeted for 5GHz use and thus antenas are connected in a way, that directs 2.4GHz signal to the small one and 5GHz to the big one.
gotcha. thank you for the reply! :slight_smile:
