First you need to find out why the WAN interface does not have an IP address. Should it get one from the DHCP server on the other router, or is it possible that you need to configure it manually?
Hi Thanks for reply. The solution was to check “Use default gateway” then I get my WAN to work.
Don’t know why but now I have connection from LAN to WAN
