Hi, I recently purchased a Turris Omnia 2019 edition. I configured the WAN port on SFP and the connection to the ISP via PPPoE. What I want to do is activate the LED under the globe design, which I suppose refers to the connection and data transferred to and from the WAN. In LuCI do I have to activate netdev on PPPoE or on the network eth1.xxx which I use to pass data?
It should work either way. For the purpose of LED blinking it does not matter whether the data are encapsulated in PPPoE frames or not.
Thank you for your attention and response. In fact I set it to eth and it works perfectly
