pgotze
October 18, 2019, 8:40am
1
have updated one of my Turris to TurrisOS 4.0.1, only problem i have now is OPENVPN.
Configured by default from FORIS menu. I can connect to VPN, anyway i cannot ping any local IP.
I checked with second Turris, still on 3.8*, looks same.
Is OPENVPN working on Turris 4.0.1?
Thanks.
ekim
October 20, 2019, 1:16pm
2
Since 3.11 i havent got openvpn running. I migrated to 4.01 today and I saw something strange.
In the openvpn config file my IP was not filled in it said something like “serveraddress”. (even though autodetect is on)
Openvpn on 4.01 works better for me, as i got an ip from my openvpn network, but i cant do anything secure while away
Anyway, hope this can help you. I think I give up with openvpn.
ricmik
October 23, 2019, 4:25am
3
Did you try rebooting your Turris after enabling OpenVPN?
I had the same issue on TurrisOS 3.x, and the problem was that the routing table lacked the routing information to the VPN. This was solved by a reboot.
@ekim and @ricmik I had reported this issue here
Software
SW bugs discussion
in my openvpn configuration in foris, I have for “Router address” the “Use autodetection” option set. Sometime in the last couple of point releases (TurrisOS 3.11.6 or 3.11.7) this no longer works, and the OpenVPN client files now have the line ...
Reading time: 1 mins 🕑
Likes: 1 ❤
Easy to fix, in the client config file where it has
remote <server_adddress> 1194
just replace <server_adddress> with your WAN IP address.
The bug is fixed in the yet to be released TurrisOS 4.0.2 and 3.11.9 versions.
