@stangri vpn-policy-routing 0.0.7-15 seems to have introduced a bug of sorts
Whilst the other report seems to be on a OpenVPN node my node with WG is exhibiting the same issue
/etc/init.d/vpn-policy-routing restart
vpn-policy-routing 0.0.7-15 stopped [✓]
Creating table ‘wan/xxx.233.237.160 peer xxx.46.104.107’ [✗]
Creating table ‘wg0/192.168.45.2’ [✓]
Routing ‘oc-ssh’ via wan [✓]
Routing ‘oc-vps-cp’ via wan [✓]
Routing ‘oc-vnc’ via wan [✓]
Routing ‘stv’ via wan [✓]
Routing ‘1750e’ via wan [✓]
Routing ‘dvb-c’ via wan [✓]
Routing ‘to.lan’ via wg0 [✓]
vpn-policy-routing 0.0.7-15 started on wg0/192.168.45.2 with errors [✗]
ERROR: Failed to set up ‘wan/xxx.233.237.160 peer xxx.46.104.107’
vpn-policy-routing 0.0.7-15 monitoring interfaces: wan wg0 [✓]
If so, is there any remaining reason why the repo is not added to the list of repo’s queried by Turris OS luci ?
(Just trying to understand if it’s a good idea for me to do that manually on my system or if there are remaining things that need to be fixed to make it stable. I’d like to do IP source address based routing for my Android Set Top Box.)
When I try to update to the newest VPN PBR routing I get the following error. Does somebody else have the same issue?
Blockquote ## Error from 2019/11/15 13:37:clock430:
Updater failed:
inconsistent: Package luci-app-vpn-policy-routing requires package luci-compat that is not available.
I can confirm this currently being exhibited on a TOS4.x node. For some reason the package luci-compat would seem to be absent at the upstream [1] repo and thus not being available throuhg the TOS repo either.
Probably best to lodge a package request with upstream development.
I have the same problem. Assuming that this will be fixed in a future release, is there a way to work around this?
I keep getting several emails per day notifying me that “luci-compat” is not available.
As I understood it, luci-compat has been added in a recent openwrt upgrade?
I tried to manually upgrade luci-app-vpn-policy routing with opkg --nodeps install luci-app-vpn-policy-routing
but that didn’t help.
As @anon50890781 advised you might want to use HBT branch (RC) by using switch-branch hbt or you may try HBK. Why this happened, you can take a look here:
