Snažím se z konfigurovat VLAN a moc mi to nejde. Tak jsem zacal podle navodu na VLAN Turris 1.0 ale kdyz zmemin my sitovou konfiguraci tak “bricknu” Turise, proste nereaguje na ping ani na jednom LAN portu. Nevim co delam spatne:
Original konfugurace je: ta funguje bez problemu:
config interface 'lan'
option ifname 'eth0 eth1'
option type 'bridge'
option proto 'static'
option ip6assign '60'
option ipaddr '192.168.15.1'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 1 2 3 4 '
config switch_vlan
option vlan '2'
option ports '5 6'
Nova konfigurace s VLAN 4: u teto nejede ping ani na jednom portu, proste Turris nereaguje
option ifname 'eth0 eth1.1'
config interface 'lan-2'
option ifname 'eth1.4'
option ipaddr '172.16.15.1'
config switch
option reset '1'
config switch_vlan
option vlan '1'
option ports '0t 1 2 3'
config switch_vlan
option vlan '2'
option ports '5 6'
config switch_vlan
option vlan '4'
option ports '0t 4'
