it seems the turris omnia hardware doesn’t like my ups and that causes a bunch of usb timeouts which cause all usb devices not to work
while a fix would be nice my main problem is that it causes the usb storage to fail at the wrong time so it fails to mount as the disk path vanishes which fails to mount and you get “none” mounted at /srv which causes lots of silent failures for software which uses /srv
maybe an extra test to prevent none from mounting could be created to reduce the headache it causes as it fails in random ways but the router mostly works
my latest wierd bug was ipv4 dhcp stopped working while everything else seemed to work fine and there are no hints in the logs of anything about dhcp
my ups uses an internal cypress serial to usb which might be the reason for usb problems
