Updater.sh WARN:Morpher is obsoleted!
Since the 3.8 update i get this message from updater.sh.
WARN:Morpher is obsoleted! You have used morpher syntax with function: Install
Morpher is syntax without brackets and commas used in updater’s configuration. Please review what you have in /etc/updater/user.lua and change syntax to not use morpher any more (it should be just plain lua). So for example
Install "pkga" "pkgb" { repository = {"turris"} }
Should become
Install("pkga", "pkgb", { repository = {"turris"} })
so how to fix this
WARN:Morpher is obsoleted! You have used morpher syntax with function: Uninstall
As I wrote. Go to /etc/updater/user.lua and update syntax.
That worked. Thank you.
There are two more warnings.
Don’t care about those. They will be removed in next major release and are harmless.
So, is this correct?
Package "mysql-server" { content = "file:///root/upravy/packages/mysql-server_5.1.73-2_mvebu.ipk" }
Install "mysql-server"
Package "vncrepeater" { content = "file:///root/upravy/packages/vncrepeater_0.17-4_mvebu.ipk" }
Install "vncrepeater"
Install "mc"
Install "lighttpd-mod-redirect"
Install "collectd-mod-thermal"
Install "collectd-mod-memory"
Install "collectd-mod-wireless"
Install "collectd-mod-cpu"
Install "collectd-mod-openvpn"
Package "collectd-mod-cpufreq" { content = "file:///root/upravy/packages/collectd-mod-cpufreq_4.10.8-3_mvebu.ipk" }
Install "collectd-mod-cpufreq"
became
Package("mysql-server", { content = "file:///root/upravy/packages/mysql-server_5.1.73-2_mvebu.ipk" })
Install("mysql-server")
Package("vncrepeater", { content = "file:///root/upravy/packages/vncrepeater_0.17-4_mvebu.ipk" })
Install("vncrepeater")
Install("mc")
Install("lighttpd-mod-redirect")
Install("collectd-mod-thermal")
Install("collectd-mod-memory")
Install("collectd-mod-wireless")
Install("collectd-mod-cpu")
Install("collectd-mod-openvpn")
Package("collectd-mod-cpufreq", { content = "file:///root/upravy/packages/collectd-mod-cpufreq_4.10.8-3_mvebu.ipk" })
Install("collectd-mod-cpufreq")
Maybe dumb question, but if this will not be correct in next updater’s run, it would break a lot of things :frowning:
I converted my configuration successfully, but is this priority stuff aka
Uninstall("transmission-daemon-openssl", "luci-i18n-transmission-en", "luci-app-transmission", {priority=60})
Uninstall("fswebcam", {priority=60})
Uninstall("luci-app-mjpg-streamer", "mjpg-streamer", {priority=60})
still needed?
I am asking cause the dnsmasq-full instead of Knot example I got from a forum post by a Omnia Turris team member her, is just:
Install("dnsmasq-full")
Uninstall("knot-resolver")
