Updater issue - unreachable /tmp/crl.pem
haven’t looked into Omnia for quite a while and now found the following message:
update: running updater.sh works - output:
root@Router:~# updater.sh
100 1080 100 1080 0 0 5885 0 --:–:-- --:–:-- --:–:-- 7248
INFO:Queue install of libcurl/turris/7.53.1-1
INFO:Queue install of curl/turris/7.53.1-1
INFO:Queue install of psmisc/turris/22.16-2
INFO:Queue install of vixie-cron/turris/7-2
INFO:Queue install of kernel/turris/4.4.59-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nls-base/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-scsi-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-storage/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-llc/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-stp/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of ntpdate/turris/4.2.8p10-1
INFO:Queue install of kmod-libphy/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-swconfig/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-bridge/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-ipt/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ipt-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ebtables/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of turris-diagnostics/turris/4
INFO:Queue install of kmod-ledtrig-oneshot/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-cfg80211/turris/4.4.59+2016-10-08-9-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-mac80211/turris/4.4.59+2016-10-08-9-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ath/turris/4.4.59+2016-10-08-9-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ath10k/turris/4.4.59+2016-10-08-9-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nfnetlink/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-tun/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ledtrig-netfilter/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-conntrack/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ipt-conntrack/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-conntrack-netlink/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-nat/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ipt-nat/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-lib-crc-ccitt/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ledtrig-usbdev/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-nathelper/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-slhc/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ppp/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-pppox/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-pppoe/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-wdt-orion/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-switch-mvsw61xx/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ledtrig-heartbeat/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-i2c-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-i2c-mv64xxx/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of dhparam/turris/2.1
INFO:Queue install of kmod-ledtrig-gpio/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-mmc/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-mvsdio/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb3/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-hwmon-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-thermal/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-conntrack6/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-ipt6/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ip6tables/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ath9k-common/turris/4.4.59+2016-10-08-9-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ath9k/turris/4.4.59+2016-10-08-9-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ledtrig-timer/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of logrotate/turris/3.8.1-9
INFO:Queue install of kmod-thermal-armada/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of knot-libdnssec/turris/2.4.2-1
INFO:Queue install of kmod-ledtrig-transient/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of knot-libzscanner/turris/2.4.2-1
INFO:Queue install of knot-libknot/turris/2.4.2-1
INFO:Queue install of knot-resolver/turris/1.2.5-2
INFO:Queue install of kmod-ledtrig-default-on/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of turris-version/turris/3.6.5
INFO:Queue install of kmod-ledtrig-morse/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ledtrig-netdev/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-serial/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-serial-wwan/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-serial-qualcomm/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-iptunnel6/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ip6-tunnel/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-lib-textsearch/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-nf-nathelper-extra/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-mii/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-net/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-net-cdc-ether/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-net-rndis/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-wdm/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-net-qmi-wwan/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-serial-option/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-usb-uhci/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of openvpn-openssl/turris/2.4.2-1
INFO:Queue install of kmod-atm/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-pppoa/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-pcompress/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-hash/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-null/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-aead/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-manager/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-ecb/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-crypto-sha1/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-mppe/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-iptunnel/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-gre/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-iptunnel4/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-sit/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-input-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-sound-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of luci-app-statistics/turris/git-17.009.29435-7d19852-2
INFO:Queue install of kmod-ipt-conntrack-extra/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ipt-ipopt/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-ifb/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-sched-core/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of kmod-sched/turris/4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
INFO:Queue install of luci-i18n-statistics-cs/turris/git-17.009.29435-7d19852-2
INFO:Queue install of luci-i18n-statistics-en/turris/git-17.009.29435-7d19852-2
INFO:Executing preupdate hooks…
INFO:Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:
Snapshot number 24 created
INFO:End of subprogram output
Output from knot-resolver.postinst:
  • [ -z ]
  • /etc/init.d/dnsmasq restart
    udhcpc: started, v1.25.1
    udhcpc: sending discover
    udhcpc: no lease, failing
  • sleep 2
  • /etc/kresd/kresd.postinst.sh
  • uci -q get resolver.kresd.static_domains
  • stat_dom=
  • [ ! -z ]
  • /etc/init.d/resolver restart
  • rm /etc/kresd/kresd.postinst.sh
    INFO:Executing postupdate hooks…
    cat: can’t open ‘/tmp/user_notify/1496262064-21917/message_de’: No such file or directory
    cat: can’t open ‘/tmp/user_notify/1496262077-27110/message_de’: No such file or directory
Afterwards there are no other messages available. Does anyone know what the problem might have been?
Hello Ssdnvv,
restart router and re-run updater all should be ok.
ok, worked. Thanks :slight_smile:
