root@turris5:~# switch-branch hbl
Branch hbl isn't a supported branch!
Looks like something goes wrong with the branch check routine https://gitlab.labs.nic.cz/turris/turris-os-packages/-/blob/master/updater/switch-branch/files/switch-branch#L133
potential workaround in the interim, edit in /etc/config/updater -> option branch
Last update:
INFO:Running postinst of resolver-conf
nothing done
Called /etc/init.d/kresd stop
remove dhcp script
job 2 at Fri May 15 17:24:00 2020
Called /etc/init.d/kresd start
remove dhcp script
uci: Entry not found
Updater tab still not working.
Last update:
INFO:Running postinst of umdns
Command failed: Request timed out
I’m wondering if you don’t want to check reForis Updater tab, which was not working in Turris OS 5.1 for a few days, but it is working now! It is there 2 days and nobody checked it, yet. What’s new there?
And… Foris Updater tab should work too, but there are no Package list anymore in it and won’t be there.
I tested Foris and reForis after I found related commits in git, but with not success. Maybe too quickly. Now it’s working.
