I just updated an Omnia from 5.4.3 to 6.1.0. No issues before the upgrade. After the reboot I was unable to login to reForis via Wifi. If I enter the correct password it stays at https://192.168.1.1/login?/reforis/
Going via a port forward on ssh lets me into reForis. Before the upgrade I could login via Wifi. Would like to be able to again. Thanks
Hello @101,
If you are saying that it is not possible to login to reForis over Wi-Fi. Did you try to use a wired connection? Did you use a different browser or incognito mode to see if it is not browser related? Btw, which browser are you using?
Josef,
Thanks for suggesting another browser. The problem occurs with Firefox, but I was able to log in with Chrome. To be clear I was able to login over Wi-Fi with Firefox if I did an ssh port forward and used the url localhost:8443. All on macOS 12.6.1. No time until the new year to research this more.
