Dekuji za pomoc, konfigurace zde:
[details=uci show resolver]uci show resolver
resolver.common=resolver
resolver.common.port=‘53’
resolver.common.keyfile=’/etc/root.keys’
resolver.common.net_ipv6='1’
resolver.common.net_ipv4='1’
resolver.common.prefered_resolver='unbound’
resolver.common.interface=‘0.0.0.0’ '::0’
resolver.common.verbose='1’
resolver.common.msg_buffer_size='8192’
resolver.common.msg_cache_size=‘100k’
resolver.common.auto_trust_anchor_file=’/etc/root.keys’
resolver.common.ignore_root_key='1’
resolver.common.forward_upstream='0’
resolver.common.dynamic_domains=‘1’
resolver.kresd=resolver
resolver.kresd.rundir=’/tmp/kresd’
resolver.kresd.log_stderr='0’
resolver.kresd.log_stdout='0’
resolver.kresd.forks='1’
resolver.unbound=resolver
resolver.unbound.outgoing_range='60’
resolver.unbound.outgoing_num_tcp='1’
resolver.unbound.incoming_num_tcp='1’
resolver.unbound.msg_cache_slabs='1’
resolver.unbound.num_queries_per_thread='30’
resolver.unbound.rrset_cache_size='100K’
resolver.unbound.rrset_cache_slabs='1’
resolver.unbound.infra_cache_slabs=‘1’
resolver.unbound.infra_cache_numhosts=‘200’
resolver.unbound.pidfile=’/var/run/unbound.pid’
resolver.unbound.root_hints=’/etc/unbound/named.cache’
resolver.unbound.target_fetch_policy='2 1 0 0 0’
resolver.unbound.harden_short_bufsize='yes’
resolver.unbound.harden_large_queries='yes’
resolver.unbound.key_cache_size='100k’
resolver.unbound.key_cache_slabs='1’
resolver.unbound.neg_cache_size='10k’
resolver.unbound.prefetch='yes’
resolver.unbound.prefetch_key='yes’
resolver.unbound.access_control=‘0.0.0.0/0 allow’ '::0/0 allow’
resolver.unbound_python=resolver
resolver.unbound_remote_control=resolver
resolver.unbound_remote_control.control_interface='127.0.0.1’
resolver.unbound_remote_control.control_enable='yes’
resolver.unbound_remote_control.control_use_cert=‘no’[/details]
[details=uci show dhcp]dhcp.@dnsmasq[0]=dnsmasq
dhcp.@dnsmasq[0].domainneeded='1’
dhcp.@dnsmasq[0].localise_queries='1’
dhcp.@dnsmasq[0].rebind_protection='1’
dhcp.@dnsmasq[0].rebind_localhost='1’
dhcp.@dnsmasq[0].expandhosts='1’
dhcp.@dnsmasq[0].authoritative='1’
dhcp.@dnsmasq[0].readethers=‘1’
dhcp.@dnsmasq[0].leasefile=’/tmp/dhcp.leases’
dhcp.@dnsmasq[0].localservice='0’
dhcp.@dnsmasq[0].nonwildcard=‘0’
dhcp.@dnsmasq[0].domain=‘lan’
dhcp.@dnsmasq[0].dhcpscript=’/etc/resolver/dhcp_host_domain_ng.py’
dhcp.@dnsmasq[0].local=’/lan/‘
dhcp.@dnsmasq[0].resolvfile=’/tmp/resolv.conf.auto’
dhcp.@dnsmasq[0].port='0’
dhcp.lan=dhcp
dhcp.lan.interface='lan’
dhcp.lan.start='100’
dhcp.lan.limit='150’
dhcp.lan.leasetime='12h’
dhcp.lan.force='1’
dhcp.lan.dhcp_option='6,192.168.100.1’
dhcp.lan.ra='server’
dhcp.wan=dhcp
dhcp.wan.interface='wan’
dhcp.wan.ignore='1’
dhcp.wan.dhcp_option='6,178.xxx.xxx.xxx’
dhcp.wan6=dhcp
dhcp.wan6.master='1’
dhcp.wan6.start='100’
dhcp.wan6.limit='150’
dhcp.wan6.leasetime='12h’
dhcp.wan6.interface=‘wan6’
dhcp.odhcpd=odhcpd
dhcp.odhcpd.maindhcp=‘0’
dhcp.odhcpd.leasefile=’/tmp/hosts/odhcpd’
dhcp.odhcpd.leasetrigger=’/usr/sbin/odhcpd-update’
dhcp.@host[0]=host
dhcp.@host[0].name='desktop’
dhcp.@host[0].mac='fc:aa:xxxxxx’
dhcp.@host[0].ip='192.168.100.221’
dhcp.@domain[0]=domain
dhcp.@domain[0].name='turris’
dhcp.@domain[0].ip='192.168.100.1’
dhcp.@host[1]=host
[/details]
Nejsem si vedom, ze bych rucne neco menil v configu, vse jsem nastavoval jen pres luci.
E: obnovil jsem vychozi nastaveni resolveru a zda se, ze uz funguje
[details=uci show resolver]resolver.common=resolver
resolver.common.verbose='0’
resolver.common.msg_buffer_size='4096’
resolver.common.msg_cache_size='20M’
resolver.common.forward_upstream='1’
resolver.common.ignore_root_key='0’
resolver.common.static_domains='1’
resolver.common.dynamic_domains='0’
resolver.common.prefered_resolver=‘kresd’
resolver.unbound.infra_cache_slabs='1’
resolver.unbound.access_control=‘0.0.0.0/0 allow’ ‘::0/0 allow’
resolver.unbound.qname_minimisation='yes’
resolver.unbound.harden_below_nxdomain='yes’
resolver.unbound_remote_control.control_use_cert='no’
resolver.unbound_remote_control.control_interface=‘127.0.0.1’[/details]
