we just released Turris OS 3.8.5. It contains various security fixes but apart from them, we finally pinned down the bug in update approvals. If you have enabled manual approvals of updates, next release will be installed only after you confirm it (this release just installs this fix).
Full release notes are as follows:
updater: fix update approvals
resolver: various fixes mainly regarding local domain names
Update approval seems indeed to be working. I first got an email about updater-ng and libcurl being updated and now I got a notification about all the other packages waiting for my approval. Thank you
Release appears to be working fine. Did this update to Kresd fix the compression problem that was preventing some devices getting usable DNS responses ( see the Yamaha receiver thread for example? ).
Thnings are allright. But DNS local devices are no longer working.
I cannot have e.g. router.lan dns.lan or notebook.lan.
It used to work but no longer is.
I just want to say thank you for the continuous updates.
Update approval worked for me. There was an update to updater that it installed without approval, but I bet this fixed the approvals
I am gaining trust in Omnia Turris software and so I did two things now:
I enabled data collection. I will monitor it in the first weeks, but I am pretty confident already that it doesn´t do anything nasty.
I switched to kresd for resolving. I had the issue that on deinstalling dnsmasq-full somehow the dnsmasq service was disabled completely. I enabled it again in LuCi web gui and now it works nicely. I just need to be patient enough to start up.
Aside from that I made Turris OS a bit more comfortable for me, by installing procps versions of ps, free and top as well as Z-Shell. And vim-runtime for syntax highlighting. All with a configuration that matches my Debian configuration as far as I want it to.
I know I gave quite harsh feedback initially, partly even unjustified, yet… as I see that you take user feedback seriously and for example installed update approvals, it becomes easier for me to trust.
