Updated RC contains latest knot resolver, fixed localrepo from updater and few minor updates.
update from 3.11.1 stable went without a hitch and thus far nothing in the logs, except the earlier reported btrfs output, indicating any issue with the setup/conf this end.
I find the release notes way to scarce. E.g. those package updates discovered earlier I found now others in addition such as tor.
IMHO TO owes its user base a better transparency of which packages are being updated, perhaps also a version history of TOS, and not just those cryptic snippets.
The TurrisOS 3.11.2 RC3 was downloaded and installed on my router without any problems.
Everything works fine.
Yesterday’s update did not start syslog-ng after stopping it to update (however, no router reboot was requested).
2019-01-11 17:44:04 info updater[20979]: transaction.lua:141 (fun): Checking for file collisions between packages
2019-01-11 17:44:05 info updater[20979]: transaction.lua:159 (fun): Running pre-install scripts and merging packages to root file system
2019-01-11 17:44:06 warning updater[20979]: backend.lua:861 (pkg_merge_files): Config file /etc/syslog-ng.conf modified by the user. Backing up the new one into /etc/syslog-ng.conf-opkg
2019-01-11 17:44:08 warning updater[20979]: backend.lua:861 (pkg_merge_files): Config file /etc/tor/torrc modified by the user. Backing up the new one into /etc/tor/torrc-opkg
2019-01-11 17:44:11 info updater[20979]: transaction.lua:205 (fun): Running post-install and post-rm scripts
2019-01-11 17:44:11 notice syslog-ng[5567]: syslog-ng shutting down; version='3.10.1'
# manual start
2019-01-12 02:23:30 notice syslog-ng[26320]: syslog-ng starting up; version='3.19.1'
there are now these entries in the kernel log appearing which were never seen prior
ieee80211 phy0: failed to reallocate TX buffer
ieee80211 phy1: failed to reallocate TX buffer
Updated yutube-dl and little bit of polishing for syslog-ng.
The final version is out!
