No, the code block I posted shows the difference between my broken config (-
), and the new, working config (+
Iām fairly certain that the include_shell
line(s) are what breaks the config.
Same problem here. No error message when running /etc/init.d/lighttpd start but the daemon does not start. Nothing in /var/log/messages/
What worked for me was to edit
/etc/lighttpd/lighttpd.conf to replace the last two lines:
include_shell "cat /etc/lighttpd/modules.d/*.load"
include_shell "cat /etc/lighttpd/conf.d/*.conf"
by:
include "/etc/lighttpd/modules.d/*.load"
include "/etc/lighttpd/conf.d/*.conf"
Pity that it was not done automatically (and pity that lighthttp breaks the compatibiity).
Of course the replacement of include_shell
by include
works. But not for me. I used to not load SSL configuration from default but to use my one with my certificate.
Somethign must changed in upgraded lighttpd so now the config which was perfectly fine is no longer working.
In fact I played a bit and it seems not to be only issues of include_shell
itself but also the content of the files in conf.d
. Once I removed luci.conf
and foris-ws.conf
it works again. At least the conifguration is startable and not complaining of syntax.
And pity it was not caught during regression testing of the update. Actually I canāt understand how is it possible that regular updates break even mostly āuntouchedā systems like mineā¦ As far as I remember, it was not for the first time.
If the quality product releases Iām involved in were like this, MS Windows would be a super-seamless, super-safe, super-stable system compared to your cars! (OK, almostā¦)
When opting for the TO I didnāt think I should leave my current job, study hard to become a Linux guru and baby-sit my router on a daily basis to keep my basic infrastructure runningā¦
Well, I just updated and restarted my Turris 1.1 and all works. No need to manually change lighttpd config.
Well, I just updated and restarted my Turris 1.0 and my Omnia too and all works. No need to manually change lighttpd config.
I hit an unusual issue where in 3.10.6 the storage plugin was no longer configured, and writes to /srv were hitting the internal flash. My external storage (connected to USB) was no longer detected by the storage plugin as storage it could use.
I removed the external storage, reformatted it and plugged in back into the Turris. At that point it was detected by the router and I was able to configure the storage plugin to use the external storage again.
Has anyone else seen this? It may be worth checking if you make heavy use of the storage plugin (eg for lxc)
must agree with you. Been waiting for vanilla OpenWRT support for quite some time as well.
The updates might bring something nice for most users but if you want something solid,
without much plugins and āForisesā, OpenWRT is the way to go.
after upgrade (Turris 1.0) no more usb devices:
lsusb
dmesg | grep usb
[ 2.735277] usbcore: registered new interface driver usbfs
[ 2.740817] usbcore: registered new interface driver hub
[ 2.746190] usbcore: registered new device driver usb
[ 2.837036] usbcore: registered new interface driver usb-storage
[ 2.843845] usbcore: registered new interface driver uas
[ 18.898750] usbcore: registered new interface driver cdc_wdm
[ 18.998716] usbcore: registered new interface driver ums-alauda
[ 19.006228] usbcore: registered new interface driver ums-cypress
[ 19.013922] usbcore: registered new interface driver ums-datafab
[ 19.021438] usbcore: registered new interface driver ums-freecom
[ 19.029025] usbcore: registered new interface driver ums-isd200
[ 19.036709] usbcore: registered new interface driver ums-jumpshot
[ 19.044316] usbcore: registered new interface driver ums-karma
[ 19.052334] usbcore: registered new interface driver ums-sddr09
[ 19.059870] usbcore: registered new interface driver ums-sddr55
[ 19.067685] usbcore: registered new interface driver ums-usbat
[ 19.075432] usbcore: registered new interface driver usblp
[ 19.091563] usbcore: registered new interface driver usbserial
[ 19.097468] usbcore: registered new interface driver usbserial_generic
[ 19.104053] usbserial: USB Serial support registered for generic
[ 19.131945] usbcore: registered new interface driver cdc_ether
[ 19.139999] usbcore: registered new interface driver ftdi_sio
[ 19.145824] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 19.169749] usbcore: registered new interface driver qmi_wwan
[ 19.177360] usbcore: registered new interface driver rndis_host
[ 19.330915] usbcore: registered new interface driver option
[ 19.336587] usbserial: USB Serial support registered for GSM modem (1-port)
lsmod | grep usb
mii 3736 1 usbnet
ums_usbat 7408 0
usb_common 2381 1 usbcore
usb_storage 43570 11 ums_usbat
usb_wwan 5896 1 option
usbcore 144292 29 option
usblp 9072 0
usbnet 19267 3 rndis_host
usbserial 19951 3 option
why?
Hello guys.
Iād like to speak about the configuration file of lighttpd, because somebody here complains that it that it wasnāt caught before releasing Turris OS 3.10.6 for everybody and thatās why weād like to release Turris OS 3.10.7 soon, which will include at least 4 things:
- a new version of wireguard and kernel,
- fix for ath10k-ct,
- and what is the most interesting thing for you is the automatic change in lighttpd.conf to replace two lines with another.
I understand that it is quite annoying, but who didnāt touch lighttpd.conf then there shouldnāt be any issue caused by this release.
If you edit lighttpd.conf somehow that Iām so sorry for any inconvenience caused by this, but we canāt fix things, which we are not aware of. Somebody from our team is using a nightly branch on regular basis at home.
At work, weāre testing the release, if it is prepared to release it to RC. Once we released RC, weāre happy to hear any opinion about it.
When we released Turris OS 3.10.6 into RC and then also for everyone, I have been looking all the time to our support system to catch any email regarding the release, but none of them showed.
If you want, you can look into the thread about releasing 3.10.6 into RC. Itās unfortunate that nobody didnāt mention this issue. Even you have the opinion to improve future release(s) when you decide to opt-in for RC.
If Iām not mistaken OpenWRT would replace the file with a new one without doing a backup of the file, which it replaced and it will do without any permission.
For example, I have as somebody of you know Turris 1.1 at home and I didnāt need to do any change and everything went smooth. Even I have two routers at work for testing and playing with them and still, I didnāt come to lighttpd issue, which was reported to us on Friday.
Hello @fojtp,
This issue might not be related to this release as this cannot be solved on our forum. Would you please reach us at tech.support@turris.cz?
Also, please include diagnostics, which you can generate in the administration interface Foris.
Looking forward to hearing from you,
Pepe
Hi @jiberjaber,
regarding WiFi tab in Foris:
Would you please tell me, if you have swapped WiFi cards?
You might have in /etc/config/wireless one network or radio, which you donāt use and it shouldnāt be there. Once youād remove it, then the tab will work for you. Iām ready to help you if you reach me on tech.support@turris.cz
Can I know if the Data collection and the Cloud Backups works for you after restarting your router?
Hey @Twinkie,
The notification for you should appear to you once you reboot your router. There are many cases, when you donāt want to run LXC containers on the storage from which are you booting as it means to unscrew the top case, unplug RAM and remove microSD card and insert it the new microSD card, plug the RAM back and screw the top case. Sometimes it could be very difficult to unplug the router.
I hope you can understand, why the notification is there, and we can understand that you donāt like it, while youāre booting from microSD card. Weāll try to improve it in future releases.
Hi @rguerra,
This is odd. Would you please run in the terminal following commands and send us the compressed file, so we can take a look closer on it?
pkgupdate -e TRACE 2>&1 | tee updater.log
gzip updater.log
Just getting back into this topic. A tornado destroyed the main electrical substation for the city and I was out of power for 3 days.
Anyway, my lighthttd.conf issue was:
root@turris:/etc/lighttpd# /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf Duplicate config variable in conditional 0 global: rrdtool.binary 2018-09-24 09:47:37: (configfile.c.1289) source: /etc/lighttpd/conf.d/local.conf line: 3 pos: 1 parser failed somehow near here: (EOL)
(my conf file was already using include
and not include_shell
local.conf
's content was simply setting rrdtool.binary
so on a whim I did
mv /etc/lighttpd/conf.d/local.conf /etc/lighttpd/conf.d/local.conf_old
and I was able to restart lighttpd after a reboot.
Is local.conf
still in use? Am I shooting myself in the foot in the near future?
OK - yes as part as my internal flash dieing I installed a SSD and moved one of the radio cards. Upon inspection of the wireless config there was indeed a Radio2 entry sharing the same path details. Upon removing that the wifi config page now works
I think the wiki page needs some more info on other things to watch out for when adding an internal SSD. Ensuring the wifi config paths match the new location of the radio card and that no new entries have been added probably need highlighting.
Any idea on a fix for the data collection page?
The lighttpd config issue is specific to people who have changed the config file, and would not show up in any standard configuration systems (as your test subjects most likely where in this case).
Not when the file in question has been marked as a config file (which /etc/lighttpd/lighttpd.conf
is), and that config file has been changed (checksum no longer matching).
This is working like intended, as you, as a package manager, donāt want to destroy user configs.
# opkg info lighttpd
Package: lighttpd
Version: 1.4.50-2
Depends: libc, libopenssl, libpcre, libpthread
Status: install user installed
Architecture: mvebu
Conffiles:
/etc/lighttpd/lighttpd.conf 73511417d45a9fd89ae3ab9125e841467e14c66e0db004e37a7252196085edda
Installed-Time: 1537452822
Iāll get the update log to you ASAP. Let me know best email address to send to youā¦
There is a bug in a just released 3.10.6 minidlna. If you add a new media file, minidlna got a sigsev. Itās 100% repeatable.
[2018/09/25 19:45:20] minissdp.c:309: maxdebug: Sending ssdp:alive [9]
[2018/09/25 19:45:24] monitor.c:709: debug: The file /mnt/voo_black/test.mp4 was changed.
[2018/09/25 19:45:24] monitor.c:396: debug: Adding: /mnt/voo_black/test.mp4
Segmentation fault
root@turris:~#
Please send it to tech.support@turris.cz, and weāll look at it.
