Hello, I operate multiple Turris Omnia routers and noticed that some devices’ boots up are significantly longer than others. There are probably negligible differences in their configurations like different hostnames or wifi configurations.
I noticed that the ones which boot longer have significantly more schnapps snapshots like 110:30.
I tried to delete the most of snapshots from slow devices and now I noticed that the boot-up speed seems to be comparable with other devices.
Is it known that a type or number of snapshots affects boot-up speed? Are there some more dependencies that affect boot speed and the user should be aware of that?
I have no record of the previous disk usage level. But there is space for normal usage without any notices of overfull. After cleanup, the / usage level is at 10%.
