Transmission-daemon has been updated to version 4.0.3 in rc, but it is not working properly. Can’t connect anywhere.
There is a fix comming for that:
Earlier today I got a notification in my email that a bunch of kernel modules were upgraded. And that reboot is needed. So I hit reboot earlier than the normal schedule in the middle of the night. This resulted in a boot loop. I’m able to connect via SSH for a few seconds in between reboots and there’s some kernel stack trace in logs. I’ll try to post details later. FYI.
UPD: so this ping stats demonstrate how much turris reboots vs. short few-second periods it’s available (SSH only becomes reachable after 7-8 successful pings and then, I maybe have like 10 seconds or less).
$ ping 192.168.1.1
^C
--- 192.168.1.1 ping statistics ---
12156 packets transmitted, 3173 received, +453 errors, 73.8977% packet loss, time 12315776ms
rtt min/avg/max/mdev = 0.251/37.689/2541.717/215.869 ms, pipe 4
The first idea I got was to feed the ssh client the log output command right away and get everything (most?) written there up until the connection loss:
➜ ssh root@192.168.1.1 -- 'logread; logread -f'
Mar 11 21:48:00 omnia syslog-ng[8184]: syslog-ng starting up; version='4.6.0'
Mar 11 21:48:00 omnia kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Mar 11 21:48:00 omnia kernel: [ 0.000000] Linux version 5.15.151 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 11.2.0 r20298+121-4895ab23a7) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 SMP Mon Mar 11 15:04:40 2024
Mar 11 21:48:00 omnia kernel: [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Mar 11 21:48:00 omnia kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Mar 11 21:48:00 omnia kernel: [ 0.000000] OF: fdt: Machine model: Turris Omnia
Mar 11 21:48:00 omnia kernel: [ 0.000000] Memory policy: Data cache writealloc
Mar 11 21:48:00 omnia kernel: [ 0.000000] Zone ranges:
Mar 11 21:48:00 omnia kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
Mar 11 21:48:00 omnia kernel: [ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
Mar 11 21:48:00 omnia kernel: [ 0.000000] Movable zone start for each node
Mar 11 21:48:00 omnia kernel: [ 0.000000] Early memory node ranges
Mar 11 21:48:00 omnia kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
Mar 11 21:48:00 omnia kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
Mar 11 21:48:00 omnia kernel: [ 0.000000] percpu: Embedded 12 pages/cpu s18060 r8192 d22900 u49152
Mar 11 21:48:00 omnia kernel: [ 0.000000] pcpu-alloc: s18060 r8192 d22900 u49152 alloc=12*4096
Mar 11 21:48:00 omnia kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Mar 11 21:48:00 omnia kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
Mar 11 21:48:00 omnia kernel: [ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
Mar 11 21:48:00 omnia kernel: [ 0.000000] Bootloader command line not present
Mar 11 21:48:00 omnia kernel: [ 0.000000] Unknown kernel command line parameters "earlyprintk mangled_fs=btrfs", will be passed to user space.
Mar 11 21:48:00 omnia kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Mar 11 21:48:00 omnia kernel: [ 0.000000] Memory: 2062456K/2097152K available (10240K kernel code, 672K rwdata, 2192K rodata, 1024K init, 258K bss, 34696K reserved, 0K cma-reserved, 1310720K highmem)
Mar 11 21:48:00 omnia kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Mar 11 21:48:00 omnia kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Mar 11 21:48:00 omnia kernel: [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Mar 11 21:48:00 omnia kernel: [ 0.000000] Tracing variant of Tasks RCU enabled.
Mar 11 21:48:00 omnia kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Mar 11 21:48:00 omnia kernel: [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Mar 11 21:48:00 omnia kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Mar 11 21:48:00 omnia kernel: [ 0.000000] Registering MPIC SoC Error Interrupt Controller
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
Mar 11 21:48:00 omnia kernel: [ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
Mar 11 21:48:00 omnia kernel: [ 0.000001] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
Mar 11 21:48:00 omnia kernel: [ 0.000018] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
Mar 11 21:48:00 omnia kernel: [ 0.000035] Switching to timer-based delay loop, resolution 1ns
Mar 11 21:48:00 omnia kernel: [ 0.000175] Ignoring duplicate/late registration of read_current_timer delay
Mar 11 21:48:00 omnia kernel: [ 0.000181] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Mar 11 21:48:00 omnia kernel: [ 0.000367] Console: colour dummy device 80x30
Mar 11 21:48:00 omnia kernel: [ 0.000395] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
Mar 11 21:48:00 omnia kernel: [ 0.000404] CPU: Testing write buffer coherency: ok
Mar 11 21:48:00 omnia kernel: [ 0.000423] CPU0: Spectre v2: using BPIALL workaround
Mar 11 21:48:00 omnia kernel: [ 0.000428] pid_max: default: 32768 minimum: 301
Mar 11 21:48:00 omnia kernel: [ 0.000514] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.000523] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.000997] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Mar 11 21:48:00 omnia kernel: [ 0.001302] Setting up static identity map for 0x100000 - 0x100060
Mar 11 21:48:00 omnia kernel: [ 0.001385] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
Mar 11 21:48:00 omnia kernel: [ 0.001471] mvebu-pmsu: Initializing Power Management Service Unit
Mar 11 21:48:00 omnia kernel: [ 0.001532] rcu: Hierarchical SRCU implementation.
Mar 11 21:48:00 omnia kernel: [ 0.001609] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
Mar 11 21:48:00 omnia kernel: [ 0.001672] smp: Bringing up secondary CPUs ...
Mar 11 21:48:00 omnia kernel: [ 0.001840] Booting CPU 1
Mar 11 21:48:00 omnia kernel: [ 0.001975] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Mar 11 21:48:00 omnia kernel: [ 0.001982] CPU1: Spectre v2: using BPIALL workaround
Mar 11 21:48:00 omnia kernel: [ 0.002039] smp: Brought up 1 node, 2 CPUs
Mar 11 21:48:00 omnia kernel: [ 0.002046] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
Mar 11 21:48:00 omnia kernel: [ 0.002052] CPU: All CPU(s) started in SVC mode.
Mar 11 21:48:00 omnia kernel: [ 0.002402] devtmpfs: initialized
Mar 11 21:48:00 omnia kernel: [ 0.004318] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Mar 11 21:48:00 omnia kernel: [ 0.004375] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 11 21:48:00 omnia kernel: [ 0.004387] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.004464] pinctrl core: initialized pinctrl subsystem
Mar 11 21:48:00 omnia kernel: [ 0.005004] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Mar 11 21:48:00 omnia kernel: [ 0.005546] DMA: preallocated 256 KiB pool for atomic coherent allocations
Mar 11 21:48:00 omnia kernel: [ 0.006011] thermal_sys: Registered thermal governor 'step_wise'
Mar 11 21:48:00 omnia kernel: [ 0.006150] cpuidle: using governor ladder
Mar 11 21:48:00 omnia kernel: [ 0.006240] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
Mar 11 21:48:00 omnia kernel: [ 0.006248] hw-breakpoint: maximum watchpoint size is 4 bytes.
Mar 11 21:48:00 omnia kernel: [ 0.006371] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
Mar 11 21:48:00 omnia kernel: [ 0.006378] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
Mar 11 21:48:00 omnia kernel: [ 0.014883] cryptd: max_cpu_qlen set to 1000
Mar 11 21:48:00 omnia kernel: [ 0.015714] raid6: skip pq benchmark and using algorithm neonx8
Mar 11 21:48:00 omnia kernel: [ 0.015724] raid6: using neon recovery algorithm
Mar 11 21:48:00 omnia kernel: [ 0.015989] SCSI subsystem initialized
Mar 11 21:48:00 omnia kernel: [ 0.016071] libata version 3.00 loaded.
Mar 11 21:48:00 omnia kernel: [ 0.016160] usbcore: registered new interface driver usbfs
Mar 11 21:48:00 omnia kernel: [ 0.016182] usbcore: registered new interface driver hub
Mar 11 21:48:00 omnia kernel: [ 0.016199] usbcore: registered new device driver usb
Mar 11 21:48:00 omnia kernel: [ 0.016822] clocksource: Switched to clocksource arm_global_timer
Mar 11 21:48:00 omnia kernel: [ 0.019079] NET: Registered PF_INET protocol family
Mar 11 21:48:00 omnia kernel: [ 0.019192] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.019690] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.019707] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.019716] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.019754] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.019816] TCP: Hash tables configured (established 8192 bind 8192)
Mar 11 21:48:00 omnia kernel: [ 0.019866] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.019897] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Mar 11 21:48:00 omnia kernel: [ 0.020003] NET: Registered PF_UNIX/PF_LOCAL protocol family
Mar 11 21:48:00 omnia kernel: [ 0.020022] PCI: CLS 0 bytes, default 64
Mar 11 21:48:00 omnia kernel: [ 0.020530] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Mar 11 21:48:00 omnia kernel: [ 0.022475] workingset: timestamp_bits=14 max_order=19 bucket_order=5
Mar 11 21:48:00 omnia kernel: [ 0.024438] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mar 11 21:48:00 omnia kernel: [ 0.024446] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Mar 11 21:48:00 omnia kernel: [ 0.024885] xor: measuring software checksum speed
Mar 11 21:48:00 omnia kernel: [ 0.028720] arm4regs : 2598 MB/sec
Mar 11 21:48:00 omnia kernel: [ 0.033848] 8regs : 1920 MB/sec
Mar 11 21:48:00 omnia kernel: [ 0.038986] 32regs : 1916 MB/sec
Mar 11 21:48:00 omnia kernel: [ 0.044012] neon : 1957 MB/sec
Mar 11 21:48:00 omnia kernel: [ 0.044016] xor: using function: arm4regs (2598 MB/sec)
Mar 11 21:48:00 omnia kernel: [ 0.044058] bounce: pool size: 64 pages
Mar 11 21:48:00 omnia kernel: [ 0.044087] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Mar 11 21:48:00 omnia kernel: [ 0.045185] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
Mar 11 21:48:00 omnia kernel: [ 0.045718] debugfs: Directory 'f1018100.gpio' with parent 'regmap' already present!
Mar 11 21:48:00 omnia kernel: [ 0.046016] debugfs: Directory 'f1018140.gpio' with parent 'regmap' already present!
Mar 11 21:48:00 omnia kernel: [ 0.046340] mvebu-pcie soc:pcie: host bridge /soc/pcie ranges:
Mar 11 21:48:00 omnia kernel: [ 0.046369] mvebu-pcie soc:pcie: MEM 0x00f1080000..0x00f1081fff -> 0x0000080000
Mar 11 21:48:00 omnia kernel: [ 0.046385] mvebu-pcie soc:pcie: MEM 0x00f1040000..0x00f1041fff -> 0x0000040000
Mar 11 21:48:00 omnia kernel: [ 0.046398] mvebu-pcie soc:pcie: MEM 0x00f1044000..0x00f1045fff -> 0x0000044000
Mar 11 21:48:00 omnia kernel: [ 0.046410] mvebu-pcie soc:pcie: MEM 0x00f1048000..0x00f1049fff -> 0x0000048000
Mar 11 21:48:00 omnia kernel: [ 0.046421] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
Mar 11 21:48:00 omnia kernel: [ 0.046433] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
Mar 11 21:48:00 omnia kernel: [ 0.046444] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
Mar 11 21:48:00 omnia kernel: [ 0.046456] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
Mar 11 21:48:00 omnia kernel: [ 0.046467] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
Mar 11 21:48:00 omnia kernel: [ 0.046478] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
Mar 11 21:48:00 omnia kernel: [ 0.046490] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
Mar 11 21:48:00 omnia kernel: [ 0.046498] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
Mar 11 21:48:00 omnia kernel: [ 0.046599] mvebu-pcie soc:pcie: pcie0.0: Slot power limit 10.0W
Mar 11 21:48:00 omnia kernel: [ 0.046656] mvebu-pcie soc:pcie: pcie1.0: Slot power limit 10.0W
Mar 11 21:48:00 omnia kernel: [ 0.046703] mvebu-pcie soc:pcie: pcie2.0: Slot power limit 10.0W
Mar 11 21:48:00 omnia kernel: [ 0.047522] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
Mar 11 21:48:00 omnia kernel: [ 0.047535] pci_bus 0000:00: root bus resource [bus 00-ff]
Mar 11 21:48:00 omnia kernel: [ 0.047545] pci_bus 0000:00: root bus resource [mem 0xf1080000-0xf1081fff] (bus address [0x00080000-0x00081fff])
Mar 11 21:48:00 omnia kernel: [ 0.047553] pci_bus 0000:00: root bus resource [mem 0xf1040000-0xf1041fff] (bus address [0x00040000-0x00041fff])
Mar 11 21:48:00 omnia kernel: [ 0.047560] pci_bus 0000:00: root bus resource [mem 0xf1044000-0xf1045fff] (bus address [0x00044000-0x00045fff])
Mar 11 21:48:00 omnia kernel: [ 0.047567] pci_bus 0000:00: root bus resource [mem 0xf1048000-0xf1049fff] (bus address [0x00048000-0x00049fff])
Mar 11 21:48:00 omnia kernel: [ 0.047573] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
Mar 11 21:48:00 omnia kernel: [ 0.047579] pci_bus 0000:00: root bus resource [io 0x1000-0xeffff]
Mar 11 21:48:00 omnia kernel: [ 0.047645] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
Mar 11 21:48:00 omnia kernel: [ 0.047809] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
Mar 11 21:48:00 omnia kernel: [ 0.047953] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
Mar 11 21:48:00 omnia kernel: [ 0.048781] PCI: bus0: Fast back to back transfers disabled
Mar 11 21:48:00 omnia kernel: [ 0.048788] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Mar 11 21:48:00 omnia kernel: [ 0.048799] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Mar 11 21:48:00 omnia kernel: [ 0.048808] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Mar 11 21:48:00 omnia kernel: [ 0.048882] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
Mar 11 21:48:00 omnia kernel: [ 0.048905] pci 0000:01:00.0: reg 0x10: [mem 0xe8000000-0xe800ffff 64bit]
Mar 11 21:48:00 omnia kernel: [ 0.049004] pci 0000:01:00.0: supports D1
Mar 11 21:48:00 omnia kernel: [ 0.049010] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
Mar 11 21:48:00 omnia kernel: [ 0.049891] PCI: bus1: Fast back to back transfers disabled
Mar 11 21:48:00 omnia kernel: [ 0.049899] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Mar 11 21:48:00 omnia kernel: [ 0.049973] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
Mar 11 21:48:00 omnia kernel: [ 0.049995] pci 0000:02:00.0: reg 0x10: [mem 0xea000000-0xea1fffff 64bit]
Mar 11 21:48:00 omnia kernel: [ 0.050027] pci 0000:02:00.0: reg 0x30: [mem 0xea200000-0xea20ffff pref]
Mar 11 21:48:00 omnia kernel: [ 0.050096] pci 0000:02:00.0: supports D1 D2
Mar 11 21:48:00 omnia kernel: [ 0.050971] PCI: bus2: Fast back to back transfers disabled
Mar 11 21:48:00 omnia kernel: [ 0.050978] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
Mar 11 21:48:00 omnia kernel: [ 0.051808] PCI: bus3: Fast back to back transfers enabled
Mar 11 21:48:00 omnia kernel: [ 0.051814] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Mar 11 21:48:00 omnia kernel: [ 0.051838] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe03fffff]
Mar 11 21:48:00 omnia kernel: [ 0.051847] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0400000-0xe07fffff]
Mar 11 21:48:00 omnia kernel: [ 0.051854] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0800000-0xe0bfffff]
Mar 11 21:48:00 omnia kernel: [ 0.051861] pci 0000:00:01.0: BAR 7: assigned [io 0x10000-0x10fff]
Mar 11 21:48:00 omnia kernel: [ 0.051867] pci 0000:00:02.0: BAR 7: assigned [io 0x20000-0x20fff]
Mar 11 21:48:00 omnia kernel: [ 0.051874] pci 0000:00:03.0: BAR 7: assigned [io 0x30000-0x30fff]
Mar 11 21:48:00 omnia kernel: [ 0.051882] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
Mar 11 21:48:00 omnia kernel: [ 0.051894] pci 0000:00:01.0: PCI bridge to [bus 01]
Mar 11 21:48:00 omnia kernel: [ 0.051900] pci 0000:00:01.0: bridge window [io 0x10000-0x10fff]
Mar 11 21:48:00 omnia kernel: [ 0.051911] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe03fffff]
Mar 11 21:48:00 omnia kernel: [ 0.051923] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0400000-0xe05fffff 64bit]
Mar 11 21:48:00 omnia kernel: [ 0.051935] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0600000-0xe060ffff pref]
Mar 11 21:48:00 omnia kernel: [ 0.051942] pci 0000:00:02.0: PCI bridge to [bus 02]
Mar 11 21:48:00 omnia kernel: [ 0.051947] pci 0000:00:02.0: bridge window [io 0x20000-0x20fff]
Mar 11 21:48:00 omnia kernel: [ 0.051955] pci 0000:00:02.0: bridge window [mem 0xe0400000-0xe07fffff]
Mar 11 21:48:00 omnia kernel: [ 0.051966] pci 0000:00:03.0: PCI bridge to [bus 03]
Mar 11 21:48:00 omnia kernel: [ 0.051971] pci 0000:00:03.0: bridge window [io 0x30000-0x30fff]
Mar 11 21:48:00 omnia kernel: [ 0.051979] pci 0000:00:03.0: bridge window [mem 0xe0800000-0xe0bfffff]
Mar 11 21:48:00 omnia kernel: [ 0.052044] pcieport 0000:00:01.0: enabling device (0140 -> 0143)
Mar 11 21:48:00 omnia kernel: [ 0.052105] pcieport 0000:00:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 11 21:48:00 omnia kernel: [ 0.052399] pcieport 0000:00:02.0: enabling device (0140 -> 0143)
Mar 11 21:48:00 omnia kernel: [ 0.052455] pcieport 0000:00:02.0: pciehp: Slot #2 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 11 21:48:00 omnia kernel: [ 0.052839] pcieport 0000:00:03.0: enabling device (0140 -> 0143)
Mar 11 21:48:00 omnia kernel: [ 0.052897] pcieport 0000:00:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
Mar 11 21:48:00 omnia kernel: [ 0.053232] pcieport 0000:00:03.0: pciehp: Slot(3): Card present
Mar 11 21:48:00 omnia kernel: [ 0.053480] mv_xor f1060800.xor: Marvell shared XOR driver
Mar 11 21:48:00 omnia kernel: [ 0.066821] mvebu-pcie soc:pcie: pcie1.0: link up
Mar 11 21:48:00 omnia kernel: [ 0.066843] mvebu-pcie soc:pcie: pcie0.0: link up
Mar 11 21:48:00 omnia kernel: [ 0.107231] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Mar 11 21:48:00 omnia kernel: [ 0.107375] mv_xor f1060900.xor: Marvell shared XOR driver
Mar 11 21:48:00 omnia kernel: [ 0.167203] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Mar 11 21:48:00 omnia kernel: [ 0.167490] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Mar 11 21:48:00 omnia kernel: [ 0.168970] printk: console [ttyS0] disabled
Mar 11 21:48:00 omnia kernel: [ 0.189067] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 30, base_baud = 15625000) is a 16550A
Mar 11 21:48:00 omnia kernel: [ 1.439990] printk: console [ttyS0] enabled
Mar 11 21:48:00 omnia kernel: [ 1.464657] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 31, base_baud = 15625000) is a 16550A
Mar 11 21:48:00 omnia kernel: [ 1.476119] loop: module loaded
Mar 11 21:48:00 omnia kernel: [ 1.479304] Loading iSCSI transport class v2.0-870.
Mar 11 21:48:00 omnia kernel: [ 1.485335] ahci-mvebu f10a8000.sata: supply ahci not found, using dummy regulator
Mar 11 21:48:00 omnia kernel: [ 1.493013] ahci-mvebu f10a8000.sata: supply phy not found, using dummy regulator
Mar 11 21:48:00 omnia kernel: [ 1.500543] ahci-mvebu f10a8000.sata: supply target not found, using dummy regulator
Mar 11 21:48:00 omnia kernel: [ 1.508382] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
Mar 11 21:48:00 omnia kernel: [ 1.517462] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
Mar 11 21:48:00 omnia kernel: [ 1.526767] scsi host0: ahci-mvebu
Mar 11 21:48:00 omnia kernel: [ 1.530500] scsi host1: ahci-mvebu
Mar 11 21:48:00 omnia kernel: [ 1.533996] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 53
Mar 11 21:48:00 omnia kernel: [ 1.541964] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 53
Mar 11 21:48:00 omnia kernel: [ 1.550903] spi-nor spi0.0: s25fl164k (8192 Kbytes)
Mar 11 21:48:00 omnia kernel: [ 1.555917] 2 fixed-partitions partitions found on MTD device spi0.0
Mar 11 21:48:00 omnia kernel: [ 1.562305] Creating 2 MTD partitions on "spi0.0":
Mar 11 21:48:00 omnia kernel: [ 1.567150] 0x000000000000-0x000000100000 : "U-Boot"
Mar 11 21:48:00 omnia kernel: [ 1.572418] 0x000000100000-0x000000800000 : "Rescue system"
Mar 11 21:48:00 omnia kernel: [ 1.580815] hwmon hwmon0: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 1.587985] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Mar 11 21:48:00 omnia kernel: [ 1.612864] hwmon hwmon1: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 1.631994] hwmon hwmon2: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 1.651058] hwmon hwmon3: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 1.673844] hwmon hwmon4: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 1.692906] hwmon hwmon5: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 1.829463] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
Mar 11 21:48:00 omnia kernel: [ 1.838492] mvneta f1070000.ethernet eth0: Using device tree mac address d8:censored:2a
Mar 11 21:48:00 omnia kernel: [ 1.848063] mvneta f1030000.ethernet eth1: Using hardware mac address d8:censored:29
Mar 11 21:48:00 omnia kernel: [ 1.857352] mvneta f1034000.ethernet eth2: Using hardware mac address d8:censored:2a
Mar 11 21:48:00 omnia kernel: [ 1.865514] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mar 11 21:48:00 omnia kernel: [ 1.872070] ehci-pci: EHCI PCI platform driver
Mar 11 21:48:00 omnia kernel: [ 1.876556] ehci-platform: EHCI generic platform driver
Mar 11 21:48:00 omnia kernel: [ 1.881881] ehci-orion: EHCI orion driver
Mar 11 21:48:00 omnia kernel: [ 1.883175] ata1: SATA link down (SStatus 0 SControl 300)
Mar 11 21:48:00 omnia kernel: [ 1.885989] orion-ehci f1058000.usb: EHCI Host Controller
Mar 11 21:48:00 omnia kernel: [ 1.891356] ata2: SATA link down (SStatus 0 SControl 300)
Mar 11 21:48:00 omnia kernel: [ 1.896738] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
Mar 11 21:48:00 omnia kernel: [ 1.909779] orion-ehci f1058000.usb: irq 49, io mem 0xf1058000
Mar 11 21:48:00 omnia kernel: [ 1.936825] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
Mar 11 21:48:00 omnia kernel: [ 1.943068] hub 1-0:1.0: USB hub found
Mar 11 21:48:00 omnia kernel: [ 1.946883] hub 1-0:1.0: 1 port detected
Mar 11 21:48:00 omnia kernel: [ 1.951255] xhci-hcd f10f0000.usb3: xHCI Host Controller
Mar 11 21:48:00 omnia kernel: [ 1.956592] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
Mar 11 21:48:00 omnia kernel: [ 1.964161] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Mar 11 21:48:00 omnia kernel: [ 1.973435] xhci-hcd f10f0000.usb3: irq 55, io mem 0xf10f0000
Mar 11 21:48:00 omnia kernel: [ 1.979277] xhci-hcd f10f0000.usb3: xHCI Host Controller
Mar 11 21:48:00 omnia kernel: [ 1.984606] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
Mar 11 21:48:00 omnia kernel: [ 1.992146] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
Mar 11 21:48:00 omnia kernel: [ 1.998780] hub 2-0:1.0: USB hub found
Mar 11 21:48:00 omnia kernel: [ 2.002555] hub 2-0:1.0: 1 port detected
Mar 11 21:48:00 omnia kernel: [ 2.006627] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
Mar 11 21:48:00 omnia kernel: [ 2.014956] hub 3-0:1.0: USB hub found
Mar 11 21:48:00 omnia kernel: [ 2.018739] hub 3-0:1.0: 1 port detected
Mar 11 21:48:00 omnia kernel: [ 2.022853] xhci-hcd f10f8000.usb3: xHCI Host Controller
Mar 11 21:48:00 omnia kernel: [ 2.028197] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
Mar 11 21:48:00 omnia kernel: [ 2.035764] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Mar 11 21:48:00 omnia kernel: [ 2.045039] xhci-hcd f10f8000.usb3: irq 56, io mem 0xf10f8000
Mar 11 21:48:00 omnia kernel: [ 2.050874] xhci-hcd f10f8000.usb3: xHCI Host Controller
Mar 11 21:48:00 omnia kernel: [ 2.056202] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
Mar 11 21:48:00 omnia kernel: [ 2.063729] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
Mar 11 21:48:00 omnia kernel: [ 2.070333] hub 4-0:1.0: USB hub found
Mar 11 21:48:00 omnia kernel: [ 2.074105] hub 4-0:1.0: 1 port detected
Mar 11 21:48:00 omnia kernel: [ 2.078177] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
Mar 11 21:48:00 omnia kernel: [ 2.086485] hub 5-0:1.0: USB hub found
Mar 11 21:48:00 omnia kernel: [ 2.090282] hub 5-0:1.0: 1 port detected
Mar 11 21:48:00 omnia kernel: [ 2.094425] usbcore: registered new interface driver usb-storage
Mar 11 21:48:00 omnia kernel: [ 2.100955] armada38x-rtc f10a3800.rtc: registered as rtc0
Mar 11 21:48:00 omnia kernel: [ 2.106526] armada38x-rtc f10a3800.rtc: setting system clock to 2024-03-11T20:47:24 UTC (1710190044)
Mar 11 21:48:00 omnia kernel: [ 2.115854] i2c_dev: i2c /dev entries driver
Mar 11 21:48:00 omnia kernel: [ 2.122378] orion_wdt: Initial timeout 171 sec
Mar 11 21:48:00 omnia kernel: [ 2.127101] sdhci: Secure Digital Host Controller Interface driver
Mar 11 21:48:00 omnia kernel: [ 2.133298] sdhci: Copyright(c) Pierre Ossman
Mar 11 21:48:00 omnia kernel: [ 2.137779] sdhci-pltfm: SDHCI platform and OF driver helper
Mar 11 21:48:00 omnia kernel: [ 2.144422] marvell-cesa f1090000.crypto: CESA device successfully registered
Mar 11 21:48:00 omnia kernel: [ 2.152081] NET: Registered PF_INET6 protocol family
Mar 11 21:48:00 omnia kernel: [ 2.157741] Segment Routing with IPv6
Mar 11 21:48:00 omnia kernel: [ 2.161435] In-situ OAM (IOAM) with IPv6
Mar 11 21:48:00 omnia kernel: [ 2.165404] NET: Registered PF_PACKET protocol family
Mar 11 21:48:00 omnia kernel: [ 2.169736] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
Mar 11 21:48:00 omnia kernel: [ 2.170513] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mar 11 21:48:00 omnia kernel: [ 2.191052] 8021q: 802.1Q VLAN Support v1.8
Mar 11 21:48:00 omnia kernel: [ 2.195339] Registering SWP/SWPB emulation handler
Mar 11 21:48:00 omnia kernel: [ 2.202435] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
Mar 11 21:48:00 omnia kernel: [ 2.210393] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Mar 11 21:48:00 omnia kernel: [ 2.235315] hwmon hwmon2: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 2.252195] hwmon hwmon3: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 2.268185] hwmon hwmon4: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 2.285011] hwmon hwmon5: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 2.301858] hwmon hwmon6: temp1_input not attached to any thermal zone
Mar 11 21:48:00 omnia kernel: [ 2.310894] mmc0: new high speed MMC card at address 0001
Mar 11 21:48:00 omnia kernel: [ 2.316648] mmcblk0: mmc0:0001 008G30 7.28 GiB
Mar 11 21:48:00 omnia kernel: [ 2.322543] mmcblk0: p1
Mar 11 21:48:00 omnia kernel: [ 2.325373] mmcblk0boot0: mmc0:0001 008G30 4.00 MiB
Mar 11 21:48:00 omnia kernel: [ 2.330726] mmcblk0boot1: mmc0:0001 008G30 4.00 MiB
Mar 11 21:48:00 omnia kernel: [ 2.335935] mmcblk0rpmb: mmc0:0001 008G30 4.00 MiB, chardev (247:0)
Mar 11 21:48:00 omnia kernel: [ 3.196948] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
Mar 11 21:48:00 omnia kernel: [ 3.206845] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
Mar 11 21:48:00 omnia kernel: [ 3.216242] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
Mar 11 21:48:00 omnia kernel: [ 3.230441] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
Mar 11 21:48:00 omnia kernel: [ 3.286823] pcieport 0000:00:03.0: pciehp: Slot(3): No link
Mar 11 21:48:00 omnia kernel: [ 3.330454] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540] (irq=79)
Mar 11 21:48:00 omnia kernel: [ 3.449117] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540] (irq=80)
Mar 11 21:48:00 omnia kernel: [ 3.563577] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540] (irq=81)
Mar 11 21:48:00 omnia kernel: [ 3.683576] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540] (irq=82)
Mar 11 21:48:00 omnia kernel: [ 3.799102] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540] (irq=83)
Mar 11 21:48:00 omnia kernel: [ 3.815060] DSA: tree 0 setup
Mar 11 21:48:00 omnia kernel: [ 3.818702] Waiting 2 sec before mounting root device...
Mar 11 21:48:00 omnia kernel: [ 5.848387] squashfs: Unknown parameter 'subvol'
Mar 11 21:48:00 omnia kernel: [ 5.854065] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Mar 11 21:48:00 omnia kernel: [ 5.861322] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
Mar 11 21:48:00 omnia kernel: [ 5.869997] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Mar 11 21:48:00 omnia kernel: [ 5.877245] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
Mar 11 21:48:00 omnia kernel: [ 5.885921] BTRFS: device fsid f564ec89-5151-4fa4-ba31-178e0e78bb30 devid 1 transid 207468 /dev/root scanned by swapper/0 (1)
Mar 11 21:48:00 omnia kernel: [ 5.898619] BTRFS info (device mmcblk0p1): using crc32c (crc32c-generic) checksum algorithm
Mar 11 21:48:00 omnia kernel: [ 5.907042] BTRFS info (device mmcblk0p1): disk space caching is enabled
Mar 11 21:48:00 omnia kernel: [ 5.913760] BTRFS info (device mmcblk0p1): has skinny extents
Mar 11 21:48:00 omnia kernel: [ 5.930427] BTRFS info (device mmcblk0p1): enabling ssd optimizations
Mar 11 21:48:00 omnia kernel: [ 5.970855] VFS: Mounted root (btrfs filesystem) on device 0:14.
Mar 11 21:48:00 omnia kernel: [ 5.978067] devtmpfs: mounted
Mar 11 21:48:00 omnia kernel: [ 5.981619] Freeing unused kernel image (initmem) memory: 1024K
Mar 11 21:48:00 omnia kernel: [ 6.016986] Run /sbin/init as init process
Mar 11 21:48:00 omnia kernel: [ 6.021093] with arguments:
Mar 11 21:48:00 omnia kernel: [ 6.021095] /sbin/init
Mar 11 21:48:00 omnia kernel: [ 6.021097] earlyprintk
Mar 11 21:48:00 omnia kernel: [ 6.021099] with environment:
Mar 11 21:48:00 omnia kernel: [ 6.021102] HOME=/
Mar 11 21:48:00 omnia kernel: [ 6.021104] TERM=linux
Mar 11 21:48:00 omnia kernel: [ 6.021106] mangled_fs=btrfs
Mar 11 21:48:00 omnia kernel: 6.064186] init: Console is alive
Mar 11 21:48:00 omnia kernel: 6.067735] init: - watchdog -
Mar 11 21:48:00 omnia kernel: 6.485915] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Mar 11 21:48:00 omnia kernel: [ 6.501121] Key type encrypted registered
Mar 11 21:48:00 omnia kernel: [ 6.508627] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
Mar 11 21:48:00 omnia kernel: [ 6.531287] SGI XFS with ACLs, security attributes, no debug enabled
Mar 11 21:48:00 omnia kernel: [ 6.539148] fsl-ehci: Freescale EHCI Host controller driver
Mar 11 21:48:00 omnia kernel: [ 6.548392] usbcore: registered new interface driver uas
Mar 11 21:48:00 omnia kernel: 6.553855] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Mar 11 21:48:00 omnia kernel: 6.571309] init: - preinit -
Mar 11 21:48:00 omnia kernel: 8.695490] Starting lvm2 during preinit
Mar 11 21:48:00 omnia kernel: [ 8.807406] random: lvm: uninitialized urandom read (4 bytes read)
Mar 11 21:48:00 omnia kernel: [ 8.935770] random: lvm: uninitialized urandom read (4 bytes read)
Mar 11 21:48:00 omnia kernel: 9.046972] mount_root: mounting /dev/root
Mar 11 21:48:00 omnia kernel: 9.053572] mount_root: loading kmods from internal overlay
Mar 11 21:48:00 omnia kernel: 9.075841] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Mar 11 21:48:00 omnia kernel: 9.084426] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Mar 11 21:48:00 omnia kernel: 9.576393] block: attempting to load /etc/config/fstab
Mar 11 21:48:00 omnia kernel: 9.583555] block: extroot: not configured
Mar 11 21:48:00 omnia kernel: [ 9.604414] random: procd: uninitialized urandom read (4 bytes read)
Mar 11 21:48:00 omnia kernel: [ 9.674858] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by mount (726)
Mar 11 21:48:00 omnia kernel: 9.699896] urandom-seed: Seeding with /etc/urandom.seed
Mar 11 21:48:00 omnia kernel: 10.089858] procd: - early -
Mar 11 21:48:00 omnia kernel: 10.092802] procd: - watchdog -
Mar 11 21:48:00 omnia kernel: [ 10.228636] random: jshn: uninitialized urandom read (4 bytes read)
Mar 11 21:48:00 omnia kernel: [ 10.313196] random: jshn: uninitialized urandom read (4 bytes read)
Mar 11 21:48:00 omnia kernel: [ 10.383126] random: jshn: uninitialized urandom read (4 bytes read)
Mar 11 21:48:00 omnia kernel: 10.649598] procd: - watchdog -
Mar 11 21:48:00 omnia kernel: 10.652928] procd: - ubus -
Mar 11 21:48:00 omnia kernel: 10.707508] procd: - init -
Mar 11 21:48:00 omnia kernel: 11.231654] kmodloader: loading kernel modules from /etc/modules.d/*
Mar 11 21:48:00 omnia kernel: [ 11.358145] NET: Registered PF_ALG protocol family
Mar 11 21:48:00 omnia kernel: [ 11.388555] async_tx: api initialized (async)
Mar 11 21:48:00 omnia kernel: [ 11.403667] Key type dns_resolver registered
Mar 11 21:48:00 omnia kernel: [ 11.442722] Key type cifs.idmap registered
Mar 11 21:48:00 omnia kernel: [ 11.480754] RPC: Registered named UNIX socket transport module.
Mar 11 21:48:00 omnia kernel: [ 11.486700] RPC: Registered udp transport module.
Mar 11 21:48:00 omnia kernel: [ 11.491438] RPC: Registered tcp transport module.
Mar 11 21:48:00 omnia kernel: [ 11.493581] random: crng init done
Mar 11 21:48:00 omnia kernel: [ 11.496159] RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 11 21:48:00 omnia kernel: [ 11.499591] random: 31 urandom warning(s) missed due to ratelimiting
Mar 11 21:48:00 omnia kernel: [ 11.513901] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Mar 11 21:48:00 omnia kernel: [ 11.521450] tun: Universal TUN/TAP device driver, 1.6
Mar 11 21:48:00 omnia kernel: [ 11.541444] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Mar 11 21:48:00 omnia kernel: [ 11.550935] gre: GRE over IPv4 demultiplexor driver
Mar 11 21:48:00 omnia kernel: [ 11.556627] ip_gre: GRE over IPv4 tunneling driver
Mar 11 21:48:00 omnia kernel: [ 11.579409] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Mar 11 21:48:00 omnia kernel: [ 11.590345] NFS: Registering the id_resolver key type
Mar 11 21:48:00 omnia kernel: [ 11.595438] Key type id_resolver registered
Mar 11 21:48:00 omnia kernel: [ 11.599694] Key type id_legacy registered
Mar 11 21:48:00 omnia kernel: [ 11.631367] cryptodev: driver 1.12 loaded.
Mar 11 21:48:00 omnia kernel: [ 11.640066] turris-omnia-mcu 1-002a: MCU type STM32
Mar 11 21:48:00 omnia kernel: [ 11.647203] turris-omnia-mcu 1-002a: MCU bootloader firmware version hash: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
Mar 11 21:48:00 omnia kernel: [ 11.661464] turris-omnia-mcu 1-002a: MCU application firmware version hash: 67eddc9540526d0a9d9660f7a7867af9a28a68d6
Mar 11 21:48:00 omnia kernel: [ 11.675574] turris-omnia-mcu 1-002a: registered as rtc1
Mar 11 21:48:00 omnia kernel: [ 11.709633] i2c i2c-0: Added multiplexed i2c bus 1
Mar 11 21:48:00 omnia kernel: [ 11.716988] i2c i2c-0: Added multiplexed i2c bus 2
Mar 11 21:48:00 omnia kernel: [ 11.722235] i2c i2c-0: Added multiplexed i2c bus 3
Mar 11 21:48:00 omnia kernel: [ 11.727388] i2c i2c-0: Added multiplexed i2c bus 4
Mar 11 21:48:00 omnia kernel: [ 11.732500] i2c i2c-0: Added multiplexed i2c bus 5
Mar 11 21:48:00 omnia kernel: [ 11.737493] i2c i2c-0: Added multiplexed i2c bus 6
Mar 11 21:48:00 omnia kernel: [ 11.742567] i2c i2c-0: Added multiplexed i2c bus 7
Mar 11 21:48:00 omnia kernel: [ 11.747839] pca953x 8-0071: supply vcc not found, using dummy regulator
Mar 11 21:48:00 omnia kernel: [ 11.754591] pca953x 8-0071: using no AI
Mar 11 21:48:00 omnia kernel: [ 11.761424] i2c i2c-0: Added multiplexed i2c bus 8
Mar 11 21:48:00 omnia kernel: [ 11.766251] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
Mar 11 21:48:00 omnia kernel: [ 11.779085] GACT probability on
Mar 11 21:48:00 omnia kernel: [ 11.782928] Mirror/redirect action on
Mar 11 21:48:00 omnia kernel: [ 11.790107] u32 classifier
Mar 11 21:48:00 omnia kernel: [ 11.792827] input device check on
Mar 11 21:48:00 omnia kernel: [ 11.796499] Actions configured
Mar 11 21:48:00 omnia kernel: [ 11.805479] fuse: init (API version 7.34)
Mar 11 21:48:00 omnia kernel: [ 11.819583] at24 1-0054: supply vcc not found, using dummy regulator
Mar 11 21:48:00 omnia kernel: [ 11.826961] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
Mar 11 21:48:00 omnia kernel: [ 11.834668] Bridge firewalling registered
Mar 11 21:48:00 omnia kernel: [ 11.840258] usbcore: registered new interface driver cdc_wdm
Mar 11 21:48:00 omnia kernel: [ 11.852496] Loading modules backported from Linux version v5.15.148-0-g6139f2a02fe0
Mar 11 21:48:00 omnia kernel: [ 11.860214] Backport generated by backports.git v5.15.148-1-0-gc9ba2fbc
Mar 11 21:48:00 omnia kernel: [ 11.885453] usbcore: registered new interface driver ums-alauda
Mar 11 21:48:00 omnia kernel: [ 11.891917] usbcore: registered new interface driver ums-cypress
Mar 11 21:48:00 omnia kernel: [ 11.898581] usbcore: registered new interface driver ums-datafab
Mar 11 21:48:00 omnia kernel: [ 11.905178] usbcore: registered new interface driver ums-freecom
Mar 11 21:48:00 omnia kernel: [ 11.912048] usbcore: registered new interface driver ums-isd200
Mar 11 21:48:00 omnia kernel: [ 11.922653] usbcore: registered new interface driver ums-jumpshot
Mar 11 21:48:00 omnia kernel: [ 11.929355] usbcore: registered new interface driver ums-karma
Mar 11 21:48:00 omnia kernel: [ 11.935837] usbcore: registered new interface driver ums-sddr09
Mar 11 21:48:00 omnia kernel: [ 11.942314] usbcore: registered new interface driver ums-sddr55
Mar 11 21:48:00 omnia kernel: [ 11.948895] usbcore: registered new interface driver ums-usbat
Mar 11 21:48:00 omnia kernel: [ 11.958211] usbcore: registered new interface driver usbserial_generic
Mar 11 21:48:00 omnia kernel: [ 11.964813] usbserial: USB Serial support registered for generic
Mar 11 21:48:00 omnia kernel: [ 11.981391] xt_time: kernel timezone is -0000
Mar 11 21:48:00 omnia kernel: [ 12.038997] PPP generic driver version 2.4.2
Mar 11 21:48:00 omnia kernel: [ 12.044041] PPP MPPE Compression module registered
Mar 11 21:48:00 omnia kernel: [ 12.049512] NET: Registered PF_PPPOX protocol family
Mar 11 21:48:00 omnia kernel: [ 12.055377] usbcore: registered new interface driver qmi_wwan
Mar 11 21:48:00 omnia kernel: [ 12.063802] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Mar 11 21:48:00 omnia kernel: [ 12.071695] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Mar 11 21:48:00 omnia kernel: [ 12.100281] ath10k 5.15 driver, optimized for CT firmware, probing pci device: 0x3c.
Mar 11 21:48:00 omnia kernel: [ 12.112465] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Mar 11 21:48:00 omnia kernel: [ 25.942117] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Mar 11 21:48:00 omnia kernel: [ 25.951411] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Mar 11 21:48:00 omnia kernel: [ 25.960782] ath10k_pci 0000:02:00.0: firmware ver 10.1-ct-8x-__fH-022-ecad3248 api 2 features wmi-10.x,mfp,txstatus-noack,wmi-10.x-CT,ratemask-CT,txrate-CT,get-temp-CT,tx-rc-CT,cust-stats-CT,retry-gt2-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT crc32 1b2a161c
Mar 11 21:48:00 omnia kernel: [ 26.008673] ath10k_pci 0000:02:00.0: Loading BDF type 0
Mar 11 21:48:00 omnia kernel: [ 26.028768] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Mar 11 21:48:00 omnia kernel: [ 26.886017] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Mar 11 21:48:00 omnia kernel: [ 26.902983] ath10k_pci 0000:02:00.0: wmi print 'P 128 V 8 T 410'
Mar 11 21:48:00 omnia kernel: [ 26.909095] ath10k_pci 0000:02:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0 ct-sta: 0'
Mar 11 21:48:00 omnia kernel: [ 26.917128] ath10k_pci 0000:02:00.0: wmi print 'alloc rem: 25000 iram: 38944'
Mar 11 21:48:00 omnia kernel: [ 26.983039] ath10k_pci 0000:02:00.0: htt-ver 2.2 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Mar 11 21:48:00 omnia kernel: [ 26.992710] ath10k_pci 0000:02:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
Mar 11 21:48:00 omnia kernel: [ 27.108236] ath: EEPROM regdomain: 0x0
Mar 11 21:48:00 omnia kernel: [ 27.108243] ath: EEPROM indicates default country code should be used
Mar 11 21:48:00 omnia kernel: [ 27.108246] ath: doing EEPROM country->regdmn map search
Mar 11 21:48:00 omnia kernel: [ 27.108250] ath: country maps to regdmn code: 0x3a
Mar 11 21:48:00 omnia kernel: [ 27.108253] ath: Country alpha2 being used: US
Mar 11 21:48:00 omnia kernel: [ 27.108256] ath: Regpair used: 0x3a
Mar 11 21:48:00 omnia kernel: [ 27.121062] usbcore: registered new interface driver qcserial
Mar 11 21:48:00 omnia kernel: [ 27.126919] usbserial: USB Serial support registered for Qualcomm USB modem
Mar 11 21:48:00 omnia kernel: [ 27.225609] ath: EEPROM regdomain: 0x0
Mar 11 21:48:00 omnia kernel: [ 27.225621] ath: EEPROM indicates default country code should be used
Mar 11 21:48:00 omnia kernel: [ 27.225624] ath: doing EEPROM country->regdmn map search
Mar 11 21:48:00 omnia kernel: [ 27.225628] ath: country maps to regdmn code: 0x3a
Mar 11 21:48:00 omnia kernel: [ 27.225631] ath: Country alpha2 being used: US
Mar 11 21:48:00 omnia kernel: [ 27.225634] ath: Regpair used: 0x3a
Mar 11 21:48:00 omnia kernel: [ 27.237349] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Mar 11 21:48:00 omnia kernel: [ 27.242073] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xd0482589, irq=100
Mar 11 21:48:00 omnia kernel: 27.249231] kmodloader: done loading kernel modules from /etc/modules.d/*
Mar 11 21:48:00 omnia kernel: [ 31.636529] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
Mar 11 21:48:00 omnia kernel: [ 31.637280] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Mar 11 21:48:00 omnia kernel: [ 31.637310] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Mar 11 21:48:00 omnia kernel: [ 31.641041] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
Mar 11 21:48:00 omnia kernel: [ 31.645568] br-lan: port 1(lan0) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 31.645581] br-lan: port 1(lan0) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 31.714798] device lan0 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 31.714812] device eth1 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 31.902180] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
Mar 11 21:48:00 omnia kernel: [ 31.951580] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
Mar 11 21:48:00 omnia kernel: [ 32.010764] br-lan: port 2(lan1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.010780] br-lan: port 2(lan1) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 32.011954] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 100Mbps/Full - flow control off
Mar 11 21:48:00 omnia kernel: [ 32.059643] device lan1 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 32.077335] br-lan: port 1(lan0) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.077349] br-lan: port 1(lan0) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 32.077561] br-lan: port 2(lan1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.077568] br-lan: port 2(lan1) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 32.077757] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mar 11 21:48:00 omnia kernel: [ 32.089978] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
Mar 11 21:48:00 omnia kernel: [ 32.148335] br-lan: port 3(lan2) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.148351] br-lan: port 3(lan2) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 32.218023] device lan2 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 32.238357] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
Mar 11 21:48:00 omnia kernel: [ 32.300773] br-lan: port 4(lan3) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.300787] br-lan: port 4(lan3) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 32.349695] device lan3 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 32.371948] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
Mar 11 21:48:00 omnia kernel: [ 32.376522] br-lan: port 5(lan4) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.376541] br-lan: port 5(lan4) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 32.465638] device lan4 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 32.528108] mv88e6085 f1072004.mdio-mii:10 lan4: Link is Up - 1Gbps/Full - flow control rx/tx
Mar 11 21:48:00 omnia kernel: [ 32.588032] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510] (irq=POLL)
Mar 11 21:48:00 omnia kernel: [ 32.588256] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
Mar 11 21:48:00 omnia kernel: [ 32.590884] br-lan: port 5(lan4) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 32.590900] br-lan: port 5(lan4) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 32.996486] ath: EEPROM regdomain: 0x80cb
Mar 11 21:48:00 omnia kernel: [ 32.996501] ath: EEPROM indicates we should expect a country code
Mar 11 21:48:00 omnia kernel: [ 32.996504] ath: doing EEPROM country->regdmn map search
Mar 11 21:48:00 omnia kernel: [ 32.996506] ath: country maps to regdmn code: 0x37
Mar 11 21:48:00 omnia kernel: [ 32.996510] ath: Country alpha2 being used: CZ
Mar 11 21:48:00 omnia kernel: [ 32.996512] ath: Regpair used: 0x37
Mar 11 21:48:00 omnia kernel: [ 32.996515] ath: regdomain 0x80cb dynamically updated by user
Mar 11 21:48:00 omnia kernel: [ 32.996575] ath: EEPROM regdomain: 0x80cb
Mar 11 21:48:00 omnia kernel: [ 32.996578] ath: EEPROM indicates we should expect a country code
Mar 11 21:48:00 omnia kernel: [ 32.996581] ath: doing EEPROM country->regdmn map search
Mar 11 21:48:00 omnia kernel: [ 32.996583] ath: country maps to regdmn code: 0x37
Mar 11 21:48:00 omnia kernel: [ 32.996586] ath: Country alpha2 being used: CZ
Mar 11 21:48:00 omnia kernel: [ 32.996588] ath: Regpair used: 0x37
Mar 11 21:48:00 omnia kernel: [ 32.996591] ath: regdomain 0x80cb dynamically updated by user
Mar 11 21:48:00 omnia kernel: [ 34.443082] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Mar 11 21:48:00 omnia kernel: [ 34.452415] ath10k_pci 0000:02:00.0: wmi print 'P 128 V 8 T 410'
Mar 11 21:48:00 omnia kernel: [ 34.452468] ath10k_pci 0000:02:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0 ct-sta: 0'
Mar 11 21:48:00 omnia kernel: [ 34.453030] ath10k_pci 0000:02:00.0: wmi print 'alloc rem: 25000 iram: 38944'
Mar 11 21:48:00 omnia kernel: [ 34.512091] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
Mar 11 21:48:00 omnia kernel: [ 34.519533] ath10k_pci 0000:02:00.0: rts threshold -1
Mar 11 21:48:00 omnia kernel: [ 34.539896] br-lan: port 6(wlan0) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 34.539915] br-lan: port 6(wlan0) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 34.540073] device wlan0 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 35.258817] br-lan: port 7(wlan1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 35.258832] br-lan: port 7(wlan1) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 35.258988] device wlan1 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 35.259076] br-lan: port 7(wlan1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 35.259086] br-lan: port 7(wlan1) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 35.424285] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Mar 11 21:48:00 omnia kernel: [ 35.638904] br-lan: port 8(wlan1-1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 35.638920] br-lan: port 8(wlan1-1) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 35.639039] device wlan1-1 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 35.639293] br-lan: port 8(wlan1-1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 35.639302] br-lan: port 8(wlan1-1) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 35.661738] br-lan: port 8(wlan1-1) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 35.694783] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1-1: link becomes ready
Mar 11 21:48:00 omnia kernel: [ 35.694890] br-lan: port 8(wlan1-1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 35.694903] br-lan: port 8(wlan1-1) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 36.727511] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Mar 11 21:48:00 omnia kernel: [ 38.374436] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mar 11 21:48:00 omnia kernel: [ 38.374577] br-lan: port 6(wlan0) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 38.374594] br-lan: port 6(wlan0) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 38.418751] br-lan: port 9(wlan0-1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 38.418764] br-lan: port 9(wlan0-1) entered disabled state
Mar 11 21:48:00 omnia kernel: [ 38.418926] device wlan0-1 entered promiscuous mode
Mar 11 21:48:00 omnia kernel: [ 38.419481] ath10k_pci 0000:02:00.0: rts threshold -1
Mar 11 21:48:00 omnia kernel: [ 38.419965] br-lan: port 9(wlan0-1) entered blocking state
Mar 11 21:48:00 omnia kernel: [ 38.419980] br-lan: port 9(wlan0-1) entered forwarding state
Mar 11 21:48:00 omnia kernel: [ 38.502437] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0-1: link becomes ready
Mar 11 20:48:00 omnia netifd: Network device 'wlan0-1' link is up
Mar 11 20:48:00 omnia hostapd: wlan0: interface state HT_SCAN->ENABLED
Mar 11 20:48:00 omnia hostapd: wlan0: AP-ENABLED
Mar 11 20:48:01 omnia ModemManager[8145]: hotplug: event reported: action=add, name=SQM_IFB_05a7a, subsystem=net
Mar 11 20:48:01 omnia ModemManager[8145]: hotplug: parent device sysfspath not found
Mar 11 20:48:01 omnia ModemManager[8576]: hotplug: event reported: action=remove, name=SQM_IFB_05a7a, subsystem=net
Mar 11 20:48:01 omnia sshd[8487]: Accepted publickey for root from 192.168.1.censored port 45648 ssh2: RSA SHA256:YicTuWQvERnuU6COFiTNS7DUi/LD+j/uhiuiZ0DzsCQ
Mar 11 21:47:51 omnia dnsmasq[4999]: started, version 2.86 cachesize 150
Mar 11 21:48:01 omnia dnsmasq[4999]: overflow: 30 log entries lost
Mar 11 21:48:01 omnia dnsmasq[8735]: started, version 2.86 cachesize 150
Mar 11 21:48:01 omnia dnsmasq[8735]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Mar 11 21:48:01 omnia dnsmasq[8735]: UBus support enabled: connected to system bus
Mar 11 21:48:01 omnia dnsmasq[8735]: DNSSEC validation enabled
Mar 11 21:48:01 omnia dnsmasq[8735]: DNSSEC signature timestamps not checked until receipt of SIGINT
Mar 11 21:48:01 omnia dnsmasq[8735]: configured with trust anchor for <root> keytag 20326
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 2d
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: DHCP, sockets bound exclusively to interface br-lan
Mar 11 21:48:01 omnia dnsmasq[8735]: using only locally-known addresses for test
Mar 11 21:48:01 omnia dnsmasq[8735]: using only locally-known addresses for onion
Mar 11 21:48:01 omnia dnsmasq[8735]: using only locally-known addresses for localhost
Mar 11 21:48:01 omnia dnsmasq[8735]: using only locally-known addresses for invalid
Mar 11 21:48:01 omnia dnsmasq[8735]: using only locally-known addresses for bind
Mar 11 21:48:01 omnia dnsmasq[8735]: using only locally-known addresses for home.censored.lan.censored.com
Mar 11 21:48:01 omnia dnsmasq[8735]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mar 11 21:48:01 omnia dnsmasq[8735]: using nameserver 1.1.1.1#53
Mar 11 21:48:01 omnia dnsmasq[8735]: using nameserver 8.8.8.8#53
Mar 11 21:48:01 omnia dnsmasq[8735]: using nameserver 1.0.0.1#53
Mar 11 21:48:01 omnia dnsmasq[8735]: using nameserver 8.8.4.4#53
Mar 11 21:48:01 omnia dnsmasq[8735]: read /etc/hosts - 4 addresses
Mar 11 21:48:01 omnia dnsmasq[8735]: read /tmp/hosts/dhcp.cfg01411c - 64 addresses
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: read /etc/ethers - 0 addresses
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 available DHCP range: 192.168.1.100 -- 192.168.1.249
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 client provides name: W550-480978
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 DHCPDISCOVER(br-lan) 36:39:53:48:09:78
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 tags: lan, known, br-lan
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 DHCPOFFER(br-lan) 192.168.1.censored 36:censored:78
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 requested options: 1:netmask, 3:router, 6:dns-server, 15:domain-name,
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 requested options: 58:T1, 59:T2
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 next server: 192.168.1.1
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 broadcast response
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 1 option: 53 message-type 2
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 54 server-identifier 192.168.1.1
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 51 lease-time 2d
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 58 T1 1d
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 59 T2 1d18h
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 1 netmask 255.255.255.0
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 28 broadcast 192.168.1.255
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 3 router 192.168.1.1
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 29 option: 15 domain-name home.censored.lan.censored.com
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 4 option: 6 dns-server 192.168.1.1
Mar 11 20:48:01 omnia ModemManager[8590]: hotplug: event reported: action=add, name=SQM_IFB_fb83c, subsystem=net
Mar 11 20:48:01 omnia ModemManager[8590]: hotplug: parent device sysfspath not found
Mar 11 20:48:01 omnia ModemManager[8899]: hotplug: event reported: action=remove, name=SQM_IFB_fb83c, subsystem=net
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 DHCPREQUEST(br-lan) 192.168.1.censored 36:censored:78
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: Ignoring domain garage.ground-floor for DHCP host name Solax-inverter-fotovoltaika-W550-480978
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 DHCPACK(br-lan) 192.168.1.censored 36:censored:78 Solax-inverter-fotovoltaika-W550-480978
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 requested options: 58:T1, 59:T2, 31:router-discovery, 33:static-route
Mar 11 21:48:01 omnia dnsmasq-dhcp[8735]: 305419896 sent size: 1 option: 53 message-type 5
Mar 11 20:48:02 omnia procd: /etc/rc.d/S60resolver: job 2 at Mon Mar 11 21:50:00 2024
Mar 11 20:48:02 omnia procd: /etc/rc.d/S60resolver: Called /etc/init.d/kresd start
Mar 11 20:48:02 omnia procd: /etc/rc.d/S60resolver: set dhcp script
Mar 11 20:48:02 omnia dhcp_host_domain_ng.py: DHCP add new hostname [Solax-inverter-fotovoltaika-W550-480978,192.168.1.censored]
Mar 11 20:48:03 omnia ModemManager[8921]: hotplug: event reported: action=add, name=wlan0, subsystem=net
Mar 11 20:48:03 omnia ModemManager[9233]: hotplug: event reported: action=add, name=wlan1, subsystem=net
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: Traceback (most recent call last):
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: File "/etc/resolver/dhcp_host_domain_ng.py", line 391, in <module>
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: dd.refresh_resolver()
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: File "/etc/resolver/dhcp_host_domain_ng.py", line 317, in refresh_resolver
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: tmp_res = Kresd(dhcp_static_leases=static_leases)
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: File "/etc/resolver/dhcp_host_domain_ng.py", line 122, in __init__
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: self.__socket_path = self._get_socket_path()
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: File "/etc/resolver/dhcp_host_domain_ng.py", line 126, in _get_socket_path
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: files_control = [f for f in listdir(path_control)]
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: FileNotFoundError: [Errno 2] No such file or directory: '/tmp/kresd/control'
Mar 11 20:48:03 omnia procd: /etc/rc.d/S60resolver: Called /etc/resolver/dhcp_host_domain_ng.py
Mar 11 20:48:04 omnia ModemManager[9439]: hotplug: event reported: action=add, name=wlan1-1, subsystem=net
Mar 11 20:48:04 omnia ModemManager[9652]: hotplug: event reported: action=add, name=SQM_IFB_08543, subsystem=net
Mar 11 20:48:04 omnia ModemManager[9652]: hotplug: parent device sysfspath not found
Mar 11 20:48:04 omnia ModemManager[9859]: hotplug: event reported: action=remove, name=SQM_IFB_08543, subsystem=net
Mar 11 21:48:04 omnia dnsmasq-dhcp[8735]: 3470319548 available DHCP range: 192.168.1.100 -- 192.168.1.249
Mar 11 21:48:04 omnia dnsmasq-dhcp[8735]: 3470319548 vendor class: android-dhcp-13
Mar 11 21:48:04 omnia dnsmasq-dhcp[8735]: 3470319548 client provides name: OnePlus-9R
Mar 11 20:48:04 omnia ModemManager[9870]: hotplug: event reported: action=add, name=SQM_IFB_21eb9, subsystem=net
Mar 11 20:48:04 omnia ModemManager[9870]: hotplug: parent device sysfspath not found
Mar 11 20:48:05 omnia procd: /etc/rc.d/S65fosquitto: Generating fosquitto config file in /var/etc/fosquitto.generated.conf
Mar 11 20:48:05 omnia ModemManager[10093]: hotplug: event reported: action=remove, name=SQM_IFB_21eb9, subsystem=net
Mar 11 20:48:05 omnia mosquitto[10136]: 1710190085: The 'port' option is now deprecated and will be removed in a future version. Please use 'listener' instead.
Mar 11 20:48:05 omnia mosquitto[10136]: 1710190085: The 'bind_address' option is now deprecated and will be removed in a future version. The behaviour will default to true.
Mar 11 20:48:05 omnia mosquitto[10136]: 1710190085: Warning: File /etc/fosquitto/credentials.hashed group is not mosquitto. Future versions will refuse to load this file.
Mar 11 20:48:05 omnia firewall: Reloading firewall due to ifup of lan (br-lan)
Mar 11 21:48:05 omnia kernel: [ 43.445430] ------------[ cut here ]------------
Mar 11 21:48:05 omnia kernel: [ 43.445430] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.445443] WARNING: CPU: 1 PID: 10267 at net/core/dst.c:169 dst_release+0xb4/0xb8
Mar 11 21:48:05 omnia kernel: [ 43.445459] dst_release underflow
Mar 11 21:48:05 omnia kernel: [ 43.445461] Modules linked in: ath9k ath9k_common xt_connlimit qcserial pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT wireguard usb_wwan qmi_wwan pppox ppp_mppe ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 libchacha20poly1305 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute curve25519_neon cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_NFQUEUE xt_NFLOG xt_LOG xt_HL xt_DSCP xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake poly1305_arm nfnetlink_queue nfnetlink_log nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 libcurve25519_generic
Mar 11 21:48:05 omnia kernel: [ 43.445637] iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt compat chacha_neon cdc_wdm br_netfilter at24 fuse sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs i2c_mux_pca954x i2c_mux ledtrig_oneshot ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 nfsv4 nfsd nfs msdos bonding ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel rpcsec_gss_krb5 auth_rpcgss veth
Mar 11 21:48:05 omnia kernel: [ 43.445803] tun ntfs lockd sunrpc grace hfsplus hfs cdrom cifs cifs_md4 cifs_arc4 autofs4 dns_resolver multipath raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp1251 nls_cp1250
Mar 11 21:48:05 omnia kernel: [ 43.445879] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.445885] xts crypto_user algif_skcipher algif_rng algif_hash algif_aead af_alg sha512_generic seqiv jitterentropy_rng drbg pcbc md5 md4 kpp hmac ghash_arm_ce ecb cts cmac arc4 vfat fat nls_iso8859_1 nls_cp437 uas leds_turris_omnia turris_omnia_mcu ledtrig_transient ahci fsl_mph_dr_of ehci_fsl xfs exfat dm_mirror dm_region_hash dm_log dm_crypt dm_mod dax mii encrypted_keys trusted tpm oid_registry asn1_encoder asn1_decoder
Mar 11 21:48:05 omnia kernel: [ 43.445978] CPU: 1 PID: 10267 Comm: foris-ws Not tainted 5.15.151 #0
Mar 11 21:48:05 omnia kernel: [ 43.445985] Hardware name: Marvell Armada 380/385 (Device Tree)
Mar 11 21:48:05 omnia kernel: [ 43.445992] [<c010e9b0>] (unwind_backtrace) from [<c010a69c>] (show_stack+0x10/0x14)
Mar 11 21:48:05 omnia kernel: [ 43.446006] [<c010a69c>] (show_stack) from [<c05f4bbc>] (dump_stack_lvl+0x40/0x4c)
Mar 11 21:48:05 omnia kernel: [ 43.446016] [<c05f4bbc>] (dump_stack_lvl) from [<c012d56c>] (__warn+0x9c/0xf8)
Mar 11 21:48:05 omnia kernel: [ 43.446029] [<c012d56c>] (__warn) from [<c012d640>] (warn_slowpath_fmt+0x78/0xa8)
Mar 11 21:48:05 omnia kernel: [ 43.446039] [<c012d640>] (warn_slowpath_fmt) from [<c086baec>] (dst_release+0xb4/0xb8)
Mar 11 21:48:05 omnia kernel: [ 43.446049] [<c086baec>] (dst_release) from [<c086384c>] (__dev_queue_xmit+0x56c/0xc38)
Mar 11 21:48:05 omnia kernel: [ 43.446063] [<c086384c>] (__dev_queue_xmit) from [<c08fb12c>] (ip_finish_output2+0x3ac/0x5e0)
Mar 11 21:48:05 omnia kernel: [ 43.446073] [<c08fb12c>] (ip_finish_output2) from [<c0867188>] (__netif_receive_skb_one_core+0x58/0x80)
Mar 11 21:48:05 omnia kernel: [ 43.446082] [<c0867188>] (__netif_receive_skb_one_core) from [<c0867280>] (netif_receive_skb+0x64/0x118)
Mar 11 21:48:05 omnia kernel: [ 43.446091] [<c0867280>] (netif_receive_skb) from [<c09f0cec>] (br_handle_frame_finish+0x1a4/0x4ec)
Mar 11 21:48:05 omnia kernel: [ 43.446102] [<c09f0cec>] (br_handle_frame_finish) from [<c09f1484>] (br_handle_frame+0x450/0x4c4)
Mar 11 21:48:05 omnia kernel: [ 43.446109] [<c09f1484>] (br_handle_frame) from [<c086482c>] (__netif_receive_skb_core.constprop.0+0x274/0xe58)
Mar 11 21:48:05 omnia kernel: [ 43.446118] [<c086482c>] (__netif_receive_skb_core.constprop.0) from [<c08654f8>] (__netif_receive_skb_list_core+0xe8/0x1f0)
Mar 11 21:48:05 omnia kernel: [ 43.446127] [<c08654f8>] (__netif_receive_skb_list_core) from [<c08657d0>] (netif_receive_skb_list_internal+0x1d0/0x2dc)
Mar 11 21:48:05 omnia kernel: [ 43.446137] [<c08657d0>] (netif_receive_skb_list_internal) from [<c08664bc>] (napi_complete_done+0x130/0x1c8)
Mar 11 21:48:05 omnia kernel: [ 43.446146] [<c08664bc>] (napi_complete_done) from [<c08b3aa8>] (gro_cell_poll+0x74/0x84)
Mar 11 21:48:05 omnia kernel: [ 43.446158] [<c08b3aa8>] (gro_cell_poll) from [<c086657c>] (__napi_poll+0x28/0x170)
Mar 11 21:48:05 omnia kernel: [ 43.446166] [<c086657c>] (__napi_poll) from [<c0866b2c>] (net_rx_action+0x2c4/0x318)
Mar 11 21:48:05 omnia kernel: [ 43.446175] [<c0866b2c>] (net_rx_action) from [<c0101544>] (__do_softirq+0x104/0x28c)
Mar 11 21:48:05 omnia kernel: [ 43.446185] [<c0101544>] (__do_softirq) from [<c0133138>] (irq_exit+0x74/0x9c)
Mar 11 21:48:05 omnia kernel: [ 43.446195] [<c0133138>] (irq_exit) from [<c017e884>] (handle_domain_irq+0x60/0x78)
Mar 11 21:48:05 omnia kernel: [ 43.446207] [<c017e884>] (handle_domain_irq) from [<c01012e4>] (gic_handle_irq+0x7c/0x90)
Mar 11 21:48:05 omnia kernel: [ 43.446216] [<c01012e4>] (gic_handle_irq) from [<c0100eb0>] (__irq_usr+0x50/0x80)
Mar 11 21:48:05 omnia kernel: [ 43.446224] Exception stack(0xc41fbfb0 to 0xc41fbff8)
Mar 11 21:48:05 omnia kernel: [ 43.446230] bfa0: b69aa780 b6f9018c b6ee2980 00000006
Mar 11 21:48:05 omnia kernel: [ 43.446236] bfc0: b69aa780 b6f9018c b69acd10 00000200 b6ddf44c b69aa728 b6f9017c b6c4be80
Mar 11 21:48:05 omnia kernel: [ 43.446241] bfe0: b693af24 bea8f4b0 b6ddf45c b6ddf02c a0000010 ffffffff
Mar 11 21:48:05 omnia kernel: [ 43.446244] ---[ end trace 334443c4c52c9e59 ]---
Mar 11 21:48:05 omnia kernel: [ 43.446248] dst_release: dst:e467fa86 refcnt:-988812287
Mar 11 21:48:05 omnia kernel: [ 43.446308] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.446350] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.446462] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.446510] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.446546] dst_release: dst:e467fa86 refcnt:-988812288
Mar 11 21:48:05 omnia kernel: [ 43.468588] dst_release: dst:5923c5c2 refcnt:-1
Mar 11 21:48:05 omnia kernel: [ 43.468610] ------------[ cut here ]------------
Mar 11 21:48:05 omnia kernel: [ 43.468613] WARNING: CPU: 0 PID: 10454 at include/net/dst.h:230 __copy_skb_header+0x1d0/0x1e4
Mar 11 21:48:05 omnia kernel: [ 43.468629] Modules linked in: ath9k ath9k_common xt_connlimit qcserial pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT wireguard usb_wwan qmi_wwan pppox ppp_mppe ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 libchacha20poly1305 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute curve25519_neon cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_NFQUEUE xt_NFLOG xt_LOG xt_HL xt_DSCP xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake poly1305_arm nfnetlink_queue nfnetlink_log nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 libcurve25519_generic
Mar 11 21:48:05 omnia kernel: [ 43.468810] iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt compat chacha_neon cdc_wdm br_netfilter at24 fuse sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs i2c_mux_pca954x i2c_mux ledtrig_oneshot ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 nfsv4 nfsd nfs msdos bonding ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel rpcsec_gss_krb5 auth_rpcgss veth
Mar 11 21:48:05 omnia kernel: [ 43.468977] tun ntfs lockd sunrpc grace hfsplus hfs cdrom cifs cifs_md4 cifs_arc4 autofs4 dns_resolver multipath raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp1251 nls_cp1250 xts crypto_user algif_skcipher algif_rng algif_hash algif_aead af_alg sha512_generic seqiv jitterentropy_rng drbg pcbc md5 md4 kpp hmac ghash_arm_ce ecb cts cmac arc4 vfat fat nls_iso8859_1 nls_cp437 uas leds_turris_omnia turris_omnia_mcu ledtrig_transient ahci fsl_mph_dr_of ehci_fsl xfs exfat dm_mirror dm_region_hash dm_log dm_crypt dm_mod dax mii encrypted_keys trusted tpm oid_registry asn1_encoder asn1_decoder
Mar 11 21:48:05 omnia kernel: [ 43.469147] CPU: 0 PID: 10454 Comm: S70modemmanager Tainted: G W 5.15.151 #0
Mar 11 21:48:05 omnia kernel: [ 43.469155] Hardware name: Marvell Armada 380/385 (Device Tree)
Mar 11 21:48:05 omnia kernel: [ 43.469162] [<c010e9b0>] (unwind_backtrace) from [<c010a69c>] (show_stack+0x10/0x14)
Mar 11 21:48:05 omnia kernel: [ 43.469176] [<c010a69c>] (show_stack) from [<c05f4bbc>] (dump_stack_lvl+0x40/0x4c)
Mar 11 21:48:05 omnia kernel: [ 43.469185] [<c05f4bbc>] (dump_stack_lvl) from [<c012d56c>] (__warn+0x9c/0xf8)
Mar 11 21:48:05 omnia kernel: [ 43.469199] [<c012d56c>] (__warn) from [<c012d640>] (warn_slowpath_fmt+0x78/0xa8)
Mar 11 21:48:05 omnia kernel: [ 43.469208] [<c012d640>] (warn_slowpath_fmt) from [<c0846488>] (__copy_skb_header+0x1d0/0x1e4)
Mar 11 21:48:05 omnia kernel: [ 43.469218] [<c0846488>] (__copy_skb_header) from [<c0848a64>] (skb_clone+0x7c/0x1d0)
Mar 11 21:48:05 omnia kernel: [ 43.469225] [<c0848a64>] (skb_clone) from [<c085c82c>] (dev_queue_xmit_nit+0x158/0x2bc)
Mar 11 21:48:05 omnia kernel: [ 43.469238] [<c085c82c>] (dev_queue_xmit_nit) from [<c0863150>] (dev_hard_start_xmit+0x70/0x134)
Mar 11 21:48:05 omnia kernel: [ 43.469249] [<c0863150>] (dev_hard_start_xmit) from [<c0863acc>] (__dev_queue_xmit+0x7ec/0xc38)
Mar 11 21:48:05 omnia kernel: [ 43.469258] [<c0863acc>] (__dev_queue_xmit) from [<c08fb12c>] (ip_finish_output2+0x3ac/0x5e0)
Mar 11 21:48:05 omnia kernel: [ 43.469268] [<c08fb12c>] (ip_finish_output2) from [<c0867188>] (__netif_receive_skb_one_core+0x58/0x80)
Mar 11 21:48:05 omnia kernel: [ 43.469277] [<c0867188>] (__netif_receive_skb_one_core) from [<c0867414>] (process_backlog+0xe0/0x1b0)
Mar 11 21:48:05 omnia kernel: [ 43.469286] [<c0867414>] (process_backlog) from [<c086657c>] (__napi_poll+0x28/0x170)
Mar 11 21:48:05 omnia kernel: [ 43.469296] [<c086657c>] (__napi_poll) from [<c0866b2c>] (net_rx_action+0x2c4/0x318)
Mar 11 21:48:05 omnia kernel: [ 43.469304] [<c0866b2c>] (net_rx_action) from [<c0101544>] (__do_softirq+0x104/0x28c)
Mar 11 21:48:05 omnia kernel: [ 43.469315] [<c0101544>] (__do_softirq) from [<c0133138>] (irq_exit+0x74/0x9c)
Mar 11 21:48:05 omnia kernel: [ 43.469326] [<c0133138>] (irq_exit) from [<c017e884>] (handle_domain_irq+0x60/0x78)
Mar 11 21:48:05 omnia kernel: [ 43.469337] [<c017e884>] (handle_domain_irq) from [<c01012e4>] (gic_handle_irq+0x7c/0x90)
Mar 11 21:48:05 omnia kernel: [ 43.469345] [<c01012e4>] (gic_handle_irq) from
Mar 11 21:48:05 omnia kernel: [ 43.469352] Exception stack(0xc536ffb0 to 0xc536fff8)
Mar 11 21:48:05 omnia kernel: [ 43.469357] ffa0: 00000000 00000000 0056fac0 f13f87e0
Mar 11 21:48:05 omnia kernel: [ 43.469363] ffc0: 0000006e befd01f4 00000000 00570704 00000001 b6f34c0f befd0314 befd023c
Mar 11 21:48:05 omnia kernel: [ 43.469368] ffe0: befd01f8 befd00c8 0050fc94 0050f0a0 60000010 ffffffff
Mar 11 21:48:05 omnia kernel: [ 43.469371] ---[ end trace 334443c4c52c9e5a ]---
Mar 11 21:48:05 omnia kernel: [ 43.469379] dst_release: dst:5923c5c2 refcnt:-1
Mar 11 20:48:06 omnia [10590]: <info> ModemManager (version 1.18.6) starting in system bus...
Mar 11 20:48:06 omnia ModemManager[10118]: hotplug: event reported: action=add, name=ifb4eth2, subsystem=net
^C
I also tried unloading some modules (rmmod ath9k; rmmod ath9k_common; rmmod ath9k_hw; rmmod ath10k_pci; rmmod ath10k_core; rmmod ath
), having seen the kernel trace, but that didn’t help.
$ ssh root@192.168.1.1 -- 'set -x; cat /etc/rc.local | tee /etc/rc.local.bak; echo "exit 0" > /etc/rc.local; cat /etc/rc.local; cat /etc/rc.local.bak; ls -alh /etc/uci-defaults; cat /etc/uci-defaults/50-libatsha204; df -h; mount; free -m; ps auxxx'
+ tee /etc/rc.local.bak
+ cat /etc/rc.local
exit 0
+ echo 'exit 0'
+ cat /etc/rc.local
exit 0
+ cat /etc/rc.local.bak
exit 0
+ ls -alh /etc/uci-defaults
drwxr-xr-x 1 root root 28 Mar 11 17:37 .
drwxr-xr-x 1 root root 2.8K Mar 12 01:49 ..
-rwxr-xr-x 1 root root 1.1K Feb 18 01:06 50-libatsha204
+ cat /etc/uci-defaults/50-libatsha204
#!/bin/sh
set -e
CONF=/etc/atsha.sw
if [ -f "$CONF" ]; then
if head -n1 "$CONF" | grep -q '00 00 00 00' ; then
# Delete version 1 config, it is no longer supported, and generate new one.
rm /etc/atsha.sw
elif head -n18 "$CONF" | tail -n1 | grep -q 'FF FF FF FF' ; then
# As well for the version 3 config
rm /etc/atsha.sw
else
# Alredy generated
exit
fi
fi
#FIXME: Omnia currently doesn't have a mac address at this time
#MAC=$(ifconfig | head -n1 | sed -e 's/.* HWaddr //;s/^..:..//')
MAC=$(dd if=/dev/urandom bs=1 count=4 | hexdump -C | sed -e 's/^[^ ]*//;s/|.*//;s/ //g' | tr '\n' ' ' | tr '[a-z]' '[A-Z]' | sed -e 's/ //g')
touch /tmp/atsha.sw
chmod 0600 /tmp/atsha.sw
for i in `seq 1 16` ; do
KEY=$(dd if=/dev/urandom bs=1 count=32 | hexdump -C | sed -e 's/^[^ ]*//;s/|.*//;s/ //g' | tr '\n' ' ' | tr '[a-z]' '[A-Z]' | sed -e 's/ //g')
echo "$KEY" >>/tmp/atsha.sw
done
echo 00 00 00 0A >>/tmp/atsha.sw
echo "$MAC" >>/tmp/atsha.sw
echo 00 00 00 00 >>/tmp/atsha.sw
for i in `seq 1 13` ; do
echo FF FF FF FF >>/tmp/atsha.sw
done
echo "00 00 00 $MAC" >>/tmp/atsha.sw
chmod 0400 /tmp/atsha.sw
mv /tmp/atsha.sw "$CONF"
+ df -h
Filesystem Size Used Available Use% Mounted on
/dev/mmcblk0p1 7.3G 4.0G 3.3G 55% /
devtmpfs 512.0K 0 512.0K 0% /dev
tmpfs 1007.6M 22.2M 985.3M 2% /tmp
+ mount
/dev/mmcblk0p1 on / type btrfs (rw,noatime,ssd,space_cache,commit=5,subvolid=509,subvol=/@)
devtmpfs on /dev type devtmpfs (rw,relatime,size=1031228k,nr_inodes=187934,mode=755)
proc on /proc type proc (rw,nosuid,nodev,noexec,noatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,noatime)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,nosuid,noexec,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,noatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
bpffs on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,noatime,mode=700)
+ free -m
total used free shared buff/cache available
Mem: 2063480 100716 1864724 22720 98040 1828528
Swap: 0 0 0
+ ps auxxx
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 5.1 0.0 1528 984 ? Ss 01:49 0:02 /sbin/procd
root 2 0.0 0.0 0 0 ? S 01:49 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? I< 01:49 0:00 [rcu_gp]
root 4 0.0 0.0 0 0 ? I< 01:49 0:00 [rcu_par_gp]
root 5 0.0 0.0 0 0 ? I< 01:49 0:00 [slub_flushwq]
root 6 0.0 0.0 0 0 ? I< 01:49 0:00 [netns]
root 7 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:0-events_long]
root 8 0.0 0.0 0 0 ? I< 01:49 0:00 [kworker/0:0H-events_highpri]
root 9 0.1 0.0 0 0 ? I 01:49 0:00 [kworker/u4:0-events_unbound]
root 10 0.0 0.0 0 0 ? I< 01:49 0:00 [mm_percpu_wq]
root 11 0.0 0.0 0 0 ? S 01:49 0:00 [rcu_tasks_trace]
root 12 0.1 0.0 0 0 ? S 01:49 0:00 [ksoftirqd/0]
root 13 0.1 0.0 0 0 ? I 01:49 0:00 [rcu_sched]
root 14 0.0 0.0 0 0 ? S 01:49 0:00 [migration/0]
root 15 0.0 0.0 0 0 ? S 01:49 0:00 [cpuhp/0]
root 16 0.0 0.0 0 0 ? S 01:49 0:00 [cpuhp/1]
root 17 0.0 0.0 0 0 ? S 01:49 0:00 [migration/1]
root 18 0.0 0.0 0 0 ? S 01:49 0:00 [ksoftirqd/1]
root 19 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/1:0-events_long]
root 20 0.0 0.0 0 0 ? I< 01:49 0:00 [kworker/1:0H-kblockd]
root 21 0.0 0.0 0 0 ? S 01:49 0:00 [kdevtmpfs]
root 22 0.0 0.0 0 0 ? I< 01:49 0:00 [inet_frag_wq]
root 23 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:1-events_long]
root 24 0.0 0.0 0 0 ? S 01:49 0:00 [oom_reaper]
root 25 0.0 0.0 0 0 ? I< 01:49 0:00 [writeback]
root 26 0.0 0.0 0 0 ? S 01:49 0:00 [kcompactd0]
root 38 0.0 0.0 0 0 ? I< 01:49 0:00 [pencrypt_serial]
root 39 0.0 0.0 0 0 ? I< 01:49 0:00 [pdecrypt_serial]
root 40 0.0 0.0 0 0 ? I< 01:49 0:00 [cryptd]
root 57 0.0 0.0 0 0 ? I< 01:49 0:00 [kblockd]
root 58 0.0 0.0 0 0 ? I< 01:49 0:00 [blkcg_punt_bio]
root 59 0.0 0.0 0 0 ? I< 01:49 0:00 [ata_sff]
root 60 0.0 0.0 0 0 ? S 01:49 0:00 [watchdogd]
root 61 1.7 0.0 0 0 ? I 01:49 0:00 [kworker/u4:1-btrfs-endio]
root 62 0.1 0.0 0 0 ? I< 01:49 0:00 [kworker/0:1H-mmc_complete]
root 66 2.9 0.0 0 0 ? I 01:49 0:01 [kworker/u4:2-events_unbound]
root 88 0.0 0.0 0 0 ? S 01:49 0:00 [kswapd0]
root 91 0.0 0.0 0 0 ? I< 01:49 0:00 [kthrotld]
root 120 0.1 0.0 0 0 ? I 01:49 0:00 [kworker/1:1-events_long]
root 132 0.0 0.0 0 0 ? S 01:49 0:00 [irq/64-pciehp]
root 138 0.0 0.0 0 0 ? S 01:49 0:00 [irq/65-pciehp]
root 144 0.0 0.0 0 0 ? S 01:49 0:00 [irq/66-pciehp]
root 182 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:2-events_long]
root 210 0.0 0.0 0 0 ? I< 01:49 0:00 [iscsi_eh]
root 216 0.0 0.0 0 0 ? I< 01:49 0:00 [iscsi_conn_clea]
root 220 0.0 0.0 0 0 ? I< 01:49 0:00 [nvme-wq]
root 222 0.0 0.0 0 0 ? I< 01:49 0:00 [nvme-reset-wq]
root 224 0.0 0.0 0 0 ? I< 01:49 0:00 [nvme-delete-wq]
root 238 0.0 0.0 0 0 ? S 01:49 0:00 [scsi_eh_0]
root 239 0.0 0.0 0 0 ? I< 01:49 0:00 [scsi_tmf_0]
root 243 0.0 0.0 0 0 ? S 01:49 0:00 [scsi_eh_1]
root 244 0.0 0.0 0 0 ? I< 01:49 0:00 [scsi_tmf_1]
root 248 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/u4:3-events_unbound]
root 256 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/u4:4-events_unbound]
root 259 0.3 0.0 0 0 ? S 01:49 0:00 [spi0]
root 424 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:3-events_power_efficient]
root 425 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:4-events]
root 426 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:5-ipv6_addrconf]
root 427 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/0:6]
root 493 0.0 0.0 0 0 ? I< 01:49 0:00 [kworker/u5:0]
root 494 0.0 0.0 0 0 ? I< 01:49 0:00 [sdhci]
root 495 0.0 0.0 0 0 ? S 01:49 0:00 [irq/54-mmc0]
root 502 0.0 0.0 0 0 ? S 01:49 0:00 [irq/50-f1090000]
root 503 0.0 0.0 0 0 ? S 01:49 0:00 [irq/51-f1090000]
root 520 0.0 0.0 0 0 ? I< 01:49 0:00 [mld]
root 521 0.0 0.0 0 0 ? I< 01:49 0:00 [ipv6_addrconf]
root 524 0.0 0.0 0 0 ? I 01:49 0:00 [kworker/1:2-rcu_gp]
root 525 0.0 0.0 0 0 ? I< 01:49 0:00 [dsa_ordered]
root 526 0.1 0.0 0 0 ? I 01:49 0:00 [kworker/1:3-events_power_efficient]
root 541 0.0 0.0 0 0 ? S 01:49 0:00 [irq/69-mv88e6xx]
root 542 0.0 0.0 0 0 ? S 01:49 0:00 [irq/77-mv88e6xx]
root 543 0.0 0.0 0 0 ? S 01:49 0:00 [irq/94-mv88e6xx]
root 544 0.0 0.0 0 0 ? S 01:49 0:00 [irq/73-mv88e6xx]
root 545 0.0 0.0 0 0 ? S 01:49 0:00 [irq/75-mv88e6xx]
root 568 0.0 0.0 0 0 ? I< 01:49 0:00 [mmc_complete]
root 584 0.0 0.0 0 0 ? S 01:50 0:00 [irq/79-mv88e6xx]
root 588 0.0 0.0 0 0 ? S 01:50 0:00 [irq/80-mv88e6xx]
root 592 0.0 0.0 0 0 ? S 01:50 0:00 [irq/81-mv88e6xx]
root 596 0.0 0.0 0 0 ? S 01:50 0:00 [irq/82-mv88e6xx]
root 600 0.0 0.0 0 0 ? S 01:50 0:00 [irq/83-mv88e6xx]
root 610 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-worker]
root 611 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-worker-hi]
root 612 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-delalloc]
root 613 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-flush_del]
root 614 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-cache]
root 615 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-fixup]
root 616 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-endio]
root 617 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-endio-met]
root 618 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-endio-met]
root 619 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-endio-rai]
root 620 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-rmw]
root 621 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-endio-wri]
root 622 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-freespace]
root 623 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-delayed-m]
root 624 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-readahead]
root 625 0.0 0.0 0 0 ? I< 01:50 0:00 [btrfs-qgroup-re]
root 626 0.0 0.0 0 0 ? S 01:50 0:00 [btrfs-cleaner]
root 627 0.4 0.0 0 0 ? S 01:50 0:00 [btrfs-transacti]
root 629 0.0 0.0 0 0 ? I< 01:50 0:00 [kworker/1:1H-kblockd]
root 635 0.0 0.0 0 0 ? I< 01:50 0:00 [tpm_dev_wq]
root 649 0.0 0.0 0 0 ? I< 01:50 0:00 [xfsalloc]
root 650 0.0 0.0 0 0 ? I< 01:50 0:00 [xfs_mru_cache]
root 663 0.0 0.0 0 0 ? I< 01:50 0:00 [uas]
ubus 1049 0.1 0.0 1128 764 ? S 01:50 0:00 /sbin/ubusd
root 1066 0.0 0.0 780 524 ttyS0 Ss+ 01:50 0:00 /sbin/askfirst /bin/ash --login
root 1197 1.1 0.0 1684 1300 ? S 01:50 0:00 /usr/sbin/haveged -F -w 1024 -d 32 -i 32 -v 1
root 1358 0.0 0.0 0 0 ? I< 01:50 0:00 [md]
root 1370 0.0 0.0 0 0 ? I< 01:50 0:00 [raid5wq]
root 1379 0.0 0.0 0 0 ? I< 01:50 0:00 [cifsiod]
root 1380 0.0 0.0 0 0 ? I< 01:50 0:00 [smb3decryptd]
root 1381 0.0 0.0 0 0 ? I< 01:50 0:00 [cifsfileinfoput]
root 1382 0.0 0.0 0 0 ? I< 01:50 0:00 [cifsoplockd]
root 1383 0.0 0.0 0 0 ? I< 01:50 0:00 [deferredclose]
root 1390 0.0 0.0 0 0 ? I< 01:50 0:00 [rpciod]
root 1391 0.0 0.0 0 0 ? I< 01:50 0:00 [xprtiod]
root 1441 0.0 0.0 0 0 ? I< 01:50 0:00 [nfsiod]
root 1484 0.0 0.0 0 0 ? I< 01:50 0:00 [cryptodev_queue]
root 1511 0.0 0.0 0 0 ? S 01:50 0:00 [irq/95-turris-o]
root 1517 0.0 0.0 0 0 ? I 01:50 0:00 [kworker/1:4-events]
root 1586 0.0 0.0 0 0 ? S 01:50 0:00 [irq/97-8-0071]
root 1601 0.0 0.0 0 0 ? I 01:50 0:00 [kworker/1:5-events]
root 1761 0.0 0.0 0 0 ? I< 01:50 0:00 [cfg80211]
root 1832 0.0 0.0 0 0 ? I< 01:50 0:00 [ath10k_wq]
root 1833 0.0 0.0 0 0 ? I< 01:50 0:00 [ath10k_aux_wq]
root 1834 0.0 0.0 0 0 ? I< 01:50 0:00 [ath10k_tx_compl]
root 4532 0.0 0.0 1284 36 ? Ss 01:50 0:00 watchdog -T 30 -t 5 /dev/watchdog
root 4562 0.1 0.1 5988 2068 ? S 01:50 0:00 /sbin/rpcd -s /var/run/ubus/ubus.sock -t 30
root 4598 0.0 0.0 0 0 ? I< 01:50 0:00 [kworker/0:2H]
root 5182 6.8 0.1 5724 2952 ? S 01:50 0:00 /usr/sbin/hostapd -s -g /var/run/hostapd/global
root 5183 0.0 0.0 5524 1756 ? S 01:50 0:00 /usr/sbin/wpa_supplicant -n -s -g /var/run/wpa_supplicant/global
root 5245 0.9 0.0 1700 1096 ? S 01:50 0:00 /sbin/netifd
root 5349 6.4 0.7 20204 14960 ? Sl 01:50 0:00 python3 /usr/bin/sentinel-dynfw-client --ipset turris-sn-dynfw-block_v4 --cert /etc/sentinel_dynfw_server.pub --renew
root 5466 1.3 0.0 1788 1464 ? S 01:50 0:00 /bin/sh /usr/bin/adblock.sh
root 5607 0.0 0.0 1376 880 ? S 01:50 0:00 /usr/sbin/odhcpd
root 5680 0.0 0.0 0 0 ? I< 01:50 0:00 [kworker/1:2H]
root 5688 0.0 0.0 1368 1100 ? S 01:50 0:00 /bin/sh /sbin/hotplug-call iface
nobody 6327 0.0 0.0 868 612 ? S 01:50 0:00 /usr/sbin/atd -f
root 7191 0.3 0.2 5908 4484 ? S 01:50 0:00 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
root 7612 0.0 0.0 1788 1356 ? S 01:50 0:00 /bin/sh /usr/bin/adblock.sh
root 7728 24.8 0.0 1532 1136 ? R 01:50 0:01 /usr/bin/awk BEGIN{FS="[/|^|.] "}/^\|\|([[:alnum:]_-]{1,63}\.)+[[:alpha:]]+[\/\^.]+$ /{print tolower($3)} /tmp/tmp.Olgmim/tmp.efKmGD.adguard.load
root 7729 15.4 0.0 1376 996 ? S 01:50 0:00 sed s/\r//g
root 7730 10.8 0.0 1376 932 ? S 01:50 0:00 grep -Evf /tmp/tmp.Olgmim/tmp.rem.whitelist
root 7731 19.6 0.0 1444 628 ? R 01:50 0:00 /usr/bin/awk BEGIN{FS=". }{for(f=NF;f>1;f--)printf "%s. ,$f;print $1}
root 7987 0.5 0.1 3984 3360 ? S 01:50 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root 8051 6.3 0.3 12724 8028 ? Sl 01:50 0:00 /usr/sbin/syslog-ng --foreground
root 8153 0.3 0.0 1512 1148 ? S 01:50 0:00 /usr/bin/dbus-daemon --system --nofork
root 8327 1.0 0.0 2820 1560 ? S 01:50 0:00 /usr/sbin/uhttpd -f -c /dev/null -l / -L /usr/bin/prometheus-node-exporter-lua -k 70 -p 127.0.0.1:9100
root 8329 0.5 0.0 1400 1128 ? S 01:50 0:00 /bin/sh /etc/rc.common /etc/rc.d/S60resolver boot
root 8382 6.0 0.0 1592 1352 ? S 01:50 0:00 /bin/sh /etc/rc.common /etc/init.d/kresd start
root 8400 0.0 0.0 1284 584 ? S 01:50 0:00 /bin/sh /etc/hotplug.d/iface/99-foris-controller
root 8403 23.5 0.5 14724 10676 ? D 01:50 0:00 /usr/bin/python3 /usr/bin/foris-notify -n -m networks -a network_change mqtt --host localhost --port 11883 --passwd-file /etc/fosquitto/credentials.plain --controller-id 0000000C00007C2A {"network":"guest_turris","device":"br-guest_turris","action":"ifup"}
root 8533 0.0 0.0 1368 1028 ? S 01:50 0:00 /bin/sh /sbin/hotplug-call net
root 8581 0.0 0.0 1592 1176 ? S 01:50 0:00 /bin/sh /etc/rc.common /etc/init.d/kresd start
root 8584 0.0 0.0 1592 1176 ? S 01:50 0:00 /bin/sh /etc/rc.common /etc/init.d/kresd start
root 8585 3.0 0.0 1376 1036 ? S 01:50 0:00 /bin/sh /sbin/hotplug-call net
root 8617 33.0 0.3 30900 6264 ? S< 01:50 0:00 /usr/sbin/kresd --noninteractive -c /tmp/kresd.config /tmp/kresd
root 8644 3.0 0.1 4292 3808 ? Ss 01:50 0:00 sshd: root@notty
root 8720 0.0 0.0 1596 780 ? Rs 01:50 0:00 ps auxxx
root 8727 0.0 0.2 4992 4368 ? R 01:50 0:00 python3 /usr/bin/ipcheck.py -4 -c 1.0.0.1
What’s that /etc/uci-defaults/50-libatsha204
thing? Since it doesn’t disappear across reboots, I assume it exits with an error? Also, the contents of /etc/rc.local
comes back post reboot too. /tmp/atsha.sw
it produces does not exist on disk and /etc/atsha.sw
exists but is empty sometimes.
More details about TurrisOS+kernel:
$ cat /etc/os-release
NAME="TurrisOS"
VERSION="7.0.0"
ID="turrisos"
ID_LIKE="lede openwrt"
PRETTY_NAME="TurrisOS 7.0.0"
VERSION_ID="7.0.0"
HOME_URL="https://www.turris.cz/"
BUG_URL="https://gitlab.nic.cz/groups/turris/-/issues/"
SUPPORT_URL="https://www.turris.cz/support/"
BUILD_ID="r20298+121-4895ab23a7"
OPENWRT_BOARD="mvebu/cortexa9"
OPENWRT_ARCH="arm_cortex-a9_vfpv3-d16"
OPENWRT_TAINTS="busybox"
OPENWRT_DEVICE_MANUFACTURER="CZ.NIC"
OPENWRT_DEVICE_MANUFACTURER_URL="https://www.turris.cz/"
OPENWRT_DEVICE_PRODUCT="Turris Omnia"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="TurrisOS 7.0.0 4895ab23a75cafc6c984f2f931c9e209838d8d3f"
$ uname -a
Linux omnia 5.15.151 #0 SMP Mon Mar 11 15:04:40 2024 armv7l GNU/Linux
UPD: Using Rollback to latest snapshot
fixes it for me but only if applied twice (latest minus one?)
Updating the packages and rebooting via reForis re-breaks it, after which a double rollback resurrects it. I disabled the automatic updates for now. Rebooting without applying updates keeps the system functional and there’s no boot loop.
UPD 2: I forgot to post the email notification with the list of package updates that seem to cause the breakage.
Update notifications
Changes performed by updater at 2024-03-11T16:36:56+00:00
• Reinstalled package kernel from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ledtrig-gpio from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-base from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-scsi-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-storage from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-storage-extras from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-storage-uas from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ikconfig from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-i2c-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-regmap-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-regmap-i2c from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-gpio-pca953x from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-serial from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-serial-wwan from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-serial-qualcomm from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-i2c-mux from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-i2c-mux-pca954x from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-log from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-ipt from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-reject from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-br-netfilter from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-hwmon-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-thermal from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-hash from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-null from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-gf128 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-ghash from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-sha256 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-aead from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-manager from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-hmac from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-rng from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-seqiv from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-ctr from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-gcm from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-ccm from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-cmac from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-cfg80211 from version 5.15.148+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-mac80211 from version 5.15.148+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-mt76-core from version 5.15.148+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-mt76-connac from version 5.15.148+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-mt7615-common from version 5.15.148+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-mt7915e from version 5.15.148+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+2023-09-11-bdf8ea71-5-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-ehci from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb2 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-conntrack from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-flow from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-offload from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-nat from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-nathelper from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-ath from version 5.15.148+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-ath10k-ct from version 5.15.148+2022-05-13-f808496f-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+2022-05-13-f808496f-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-eeprom-at24 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ledtrig-oneshot from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-log6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-ipt6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-reject6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ip6tables from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-nat from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-conntrack6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-conntrack from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package knot-resolver from version 5.7.1-9 to version 5.7.1-10
• Reinstalled package kmod-turris-omnia-mcu from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-leds-turris-omnia from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ledtrig-transient from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package omnia-generic-support from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package updater-supervisor from version 1.5.6-3.10-2 to version 1.5.6-3.10-3
• Reinstalled package base-files from version 1515-7.0.0-r20298+120-4895ab23a7 to version 1515-7.0.0-r20298+121-4895ab23a7
• Reinstalled package kmod-crypto-acompress from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-zstd from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-xor from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-raid6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-zlib-deflate from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-zlib-inflate from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-lzo from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-crc32c from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-crc32c from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-btrfs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-ath9k-common from version 5.15.148+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-ath9k from version 5.15.148+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151+5.15.148-1-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-bonding from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-udptunnel6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-udptunnel4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-kpp from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-lib-curve25519 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-lib-poly1305 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-lib-chacha20 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-lib-chacha20poly1305 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-wireguard from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-ipopt from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ifb from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-sched-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-sched-cake from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-utf8 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ata-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ata-ahci from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nfnetlink from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nf-conntrack-netlink from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-md5 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-netlink-diag from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-ipset from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ebtables from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-iptunnel4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-iptunnel from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-sit from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-iptunnel6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ip6-tunnel from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-crc-ccitt from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-slhc from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ppp from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-pppox from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-pppoe from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-iso8859-2 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-iso8859-15 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-iso8859-13 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-iso8859-6 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-koi8r from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-iso8859-8 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-iso8859-1 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fuse from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-dnsresolver from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-oid-registry from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-asn1-decoder from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-des from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-ecb from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-sha512 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-cifs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-autofs4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-asn1-encoder from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-random-core from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-tpm from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-sha1 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-keys-trusted from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-cbc from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-keys-encrypted from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-dax from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-dm from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp932 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp864 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-raw from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-conntrack-extra from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nfnetlink-log from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nfnetlink-queue from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-nfqueue from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp866 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-exfat from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp437 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp1251 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp1250 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-exportfs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-xfs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp775 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp852 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp862 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-vfat from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-arc4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-cts from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-nfs-common from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-nfs-common-rpcsec from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-nfsd from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-lib-crc16 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-ext4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-ntfs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-cdrom from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-hfs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-msdos from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-hfsplus from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-nfs from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-fs-nfs-v4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-nls-cp850 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-ipt-nflog from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-tun from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-mppe from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-gre from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-wdm from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-mii from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-net from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-usb-net-qmi-wwan from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-deflate from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-veth from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-md-mod from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-md-linear from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-md-raid0 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-md-raid10 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-user from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-md-raid1 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-authenc from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Updated package kmod-cryptodev from version 5.15.148+1.12-mvebu-1 to version 5.15.151+1.12-mvebu-1
• Reinstalled package kmod-md-raid456 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-md-multipath from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-pcbc from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-xts from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
• Reinstalled package kmod-crypto-md4 from version 5.15.148-1-cfaf0eaef6d040cba91b2530b83dd2ac to version 5.15.151-1-cfaf0eaef6d040cba91b2530b83dd2ac
We tried to reproduce but without success. Do you have an old device and updated U-Boot? Does it still persist in 5.15.152?
We just released a new rc. Main changes are new kernel, fixed knot-resolver lua modules and fixed version parsing in updater-supervisor. Hope this will address most of the issues mentioned here.
MOX classic, HBK branch, .5 GB, 2x WiFi, simple config. All seems OK.
Good evening everyone,
That last update is a failure on my side (Turris omnia).
It’s ending up into boot loop.
Had to rollback before update (tried the update multiple times)
Here is the logs from dmesg command I’m getting just before the boot loop :
I now found my Omnia with a totally full RAM and tmpfs for /tmp, mostly because of a 350 MB log of suricata. I don’t know what was logged because I’ve deleted the file to free up memory. This definitely needs some upper limit…
Hi, do you have some special setup? Do you use nftables? Have you configured something special somewhere? To debug it, the best way would be if we could reproduce it
Would you be willing to share your rootfs? Change passwords, exporting it via http://turris.local/snapshots and send it through our support or via PM?
7.0.0 RC2 → 7.0.0 RC3 update okay. No noticeable cable/wifi/internet interruption. Restart was needed.
Transmission is still hogging the CPU.
Turris Omnia 2017, 1 GB RAM, dead eMMC, system running from mSATA SSD, original wifi cards, UBoot 2022.10. Storage plugin enabled, LXC containers, tor relay, USB HDD shared over samba4 and minidlna, Syncthing, SQM, Hardwario gateway + MQTT IoT bridge, OpenVPN, PPtP VPN, Strongswan IKEv2 VPN, morce.
Okay, so the log has reached 7 MB in 10 hours. It is full of these messages (once every second):
[ERRCODE: SC_ERR_AFP_CREATE(190)] - Couldn’t set fanout mode, error Invalid argument
And sometimes also (once in about 30 secs)
[ERRCODE: SC_ERR_AFP_CREATE(190)] - Can not open iface ‘tun_turris’
I have had behavior similar to yours with the last RC.
In my case the update went well, I did the reboot … but after this → the connection began to cut off both via Ethernet and WiFi.
Type errors in Re foris page like:
TypeError: t.map is not a function
TypeError: NetworkError when attempting to fetch resource.
Or internal server error.
The connection came and went and I was barely able to make a rollback from Reforis.
With the previous RC version (Kernel 5.15.148 on HBT) everything working fine right now.
I have no special configurations in my Turris Omnia 2020 except installed packages like Adblock, Dynamic Firewall, New Devices Detection and the latest MCU Firmware.
Greetings.
I did update yesterday and it seems that it works fine on my Mox.
Hi @d0s1s and @julien113,
just question what u-boot version do you have?
Via serial cable you can see it directly at the first line or from system via ssh through this command:
strings /dev/mtd0 | grep "U-Boot"
Thanks,
Tom
TurrisOS 7.0.0, Turris Omnia
root@TO:~# strings /dev/mtd0 | grep "U-Boot"
U-Boot SPL 2015.10-rc2 (Oct 06 2020 - 03:14:44)
U-Boot
U-Boot 2019.07 for turris_omnia
** Invalid partition type "%.32s" (expect "U-Boot")
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
U-Boot.armv7
No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb>
U-Boot
U-Boot 2019.07 (Oct 05 2020 - 23:50:39 +0000)
U-Boot
Do you recommend that I upgrade it through the Reforis U-Boot package with the latest RC release?
Thanks
Would be better to upgrade U-Boot and MCU firmware, but before you start, do you have Omnia from Indiegogo campain?
No, I bought my Turris Omnia 2020 directly from Amazon.
So should I update only the U-Boot and MCU before putting the latest RC?
What commands should I put via SSH to do that?
I ask because if I try to do it with Reforis it will install/update everything together.
Maybe the problem with this latest RC is that i had an updated MCU firm but an old U-Boot, I don’t know… I await instructions.
Thank you!
root@turris:~# strings /dev/mtd0 | grep "U-Boot"
U-Boot SPL 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
U-Boot
U-Boot.armv7
U-Boot
U-Boot 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
:U-Boot
About the special setup, I’m using vlan and batman mesh which is out of the turris/foris scope, but they haven’t been showing any side effect until that RC.
I’m not using nftables but still with the old firewall pkg.
To export the configuration it might take little bit more time as there are quite a lot of credential here and there in the rootfs
